[postgis-users] Re : IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Vince Lotito vince at vvl.com
Sun Jan 15 12:02:51 PST 2012
Chris,
Sorry, I didn't realize PostGIS-users list, I follow the devel as well.  My bad.
Vince
Sent from my iPad
On Jan 15, 2012, at 12:19 PM, "Chris English" <sglish at hotmail.com<mailto:sglish at hotmail.com>> wrote:
Vince,
As I said below, I just happen to have VS Express 2010 on my box.  It doesn't offer JIT debugging
and this distinguishes it from the paid for developer platforms otherwise offered by MS.  I have it and mingw32
as from time to time I need to build something, but wouldn't consider myself a developer otherwise.
My Framework 4.0 is up to date.
This being said, I wasn't trying to run ifc2pg.exe under Express debugger, just nonchalantly
double clicking to run for the first time to follow along the tutorial, get an overview of Jerome's work,
and met with resistance.
That would make me a lowly tester that possesses a smattering of tools.
I intuit that removing the check environment for JIT debugger or providing
a case for situations like mine will allow non-developers to play along and explore the value
of IFC.  We won't be able to contribute much to debugging should other problems present
themselves, but at least we'll get in the door.  And three weeks or so is a short time to wait.
Thanks for your input.
Chris
To: postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>
Date: Sat, 14 Jan 2012 13:01:22 -0600
Subject: Re: [postgis-users] Re : IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Just-In-Time debugging launches Visual Studio automatically when an exception or crash occurs in an application running outside Visual Studio. This enables you to test your application when Visual Studio is not running and begin debugging with Visual Studio when a problem occurs.  This does not apply to the Express edition of Visual Studio.  Are you running ifc2pg.exe under  the Visual Studio Express debugger? If so, then you should be able to debug the exception.
V
From: postgis-users-bounces at postgis.refractions.net<mailto:postgis-users-bounces at postgis.refractions.net> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of jrmrolland at aol.com<mailto:jrmrolland at aol.com>
Sent: Saturday, January 14, 2012 1:14 PM
Subject: [postgis-users] Re : IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Chris,
I am busy for the next three week, you need Framework 4.0 for ifc2pg.
I am looking for this problem as soon as possible.
best regards,
Jerome
-----E-mail d'origine-----
De : Chris English <sglish at hotmail.com<mailto:sglish at hotmail.com>>
A: postgis_users <postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net>>
Envoyé le : Samedi, 14 Janvier 2012 18:26
Sujet : Re: [postgis-users] IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
Jerome,
Under Visual Studios Express 2010 - An unhandled win32 exception occured in ifc2pg.exe[3560].
Just-In_Time debugging this exception failed: No installed debugger has Just-In-Time debugging enabled.
VS Express doesn't (seem to) have JIT debugging capability.  Does ifc2pg require VS Pro or is there
some work around for Express?
Thanks,
Chris
> Date: Thu, 12 Jan 2012 07:27:54 -0800
> From: jrmrolland at aol.com<mailto:jrmrolland at aol.com>
> Subject: [postgis-users] IFC2PG 3D : Industry Foundation Classes to PostGIS 3rd Part
> Hello,
> I have just set up on my blog at the following address
> http://ageoguy.blogspot.com/2012/01/ifc2pg-3d-industry-foundation-classes.html
> A GeoSpatial World
> the third part of a tutorial which presents IFC2PG a tool under development
> which makes it possible to export the objects of a file IFC towards PostGIS.
> http://postgis.17.n6.nabble.com/file/n3665545/ifc2pg_splashscreen3.gif
> This 3rd part inserts to us in the world of the third dimension under
> PostGIS 2.0,
> the objects imported in the database will be it in 3D.
> Regards,
> Jérôme
> View this message in context: http://postgis.17.n6.nabble.com/IFC2PG-3D-Industry-Foundation-Classes-to-PostGIS-3rd-Part-tp3665545p3665545.html
> Sent from the PostGIS - User mailing list archive at Nabble.com<http://Nabble.com>.
> postgis-users mailing list
_______________________________________________ postgis-users mailing list postgis-users at postgis.refractions.net<mailto:postgis-users at postgis.refractions.net> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120115/3209c324/attachment.html>
