[postgis-users] DXF to Postgis using ogr
Bob Pawley rjpawley at shaw.ca
Mon Jan 16 10:27:14 PST 2012
Hi Guglielmo
I found the QGIS dxf2shp plugin works with Dassault's DraftSight version of
dxf.
One needs to run an unexploded version of dxf - once for polyline and again
for polygon.
For text and accompanying points an exploded version of the dxf file needs
to be selected.
I then use FWTools to import the shapefiles into Postgis.
QGIS is written in VC++ of which I am not acquainted.  Perhaps this will
help you.
It would be of help to have a standalone version that imports all of the dxf
information directly into Postgis with one click.
Bob
-----Original Message-----
Sent: Monday, December 19, 2011 11:48 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] DXF to Postgis using ogr
Hi Bob,
sorry for delay in answering.
Yes, Dxf2PostGis manage blocks like points and I don't plan (for the
moment) to develop extra code to do it in different way.
I'm not expert user of Org2org (I remember also a different name
"ogr2ogr") and I can't help you, sorry.
I can suggest you to explode blocks before use Dxf2PostGIS, if this is
compatible with your requirements.
In any case, good luck!
Please, tell me if you find a workaround to the trouble.
Guglielmo
2011/12/17 Bob Pawley <rjpawley at shaw.ca>:
> Hi Guglielmo
> I tried it a couple of weeks ago but it didn't import the block geometries
> nor the block text. It worked well with the non-block text and geometries.
> I've managed to, with Org2org, import the whole DXF file but for some
> reason
> it appears to turn the block text into linestrings.
> Bob
> -----Original Message----- From: Guglielmo Raimondi
> Sent: Saturday, December 17, 2011 1:26 AM
> Have you try to use "dxf2postgis"?
> It's a tool for Windows environment that convert DXF files (R11 and
> R12 version) in SQL scripts for PostgreSQL+PostGIS.
> In detail, text are converted in points with special attibutes (text,
> size, rotation, font, etc.) that you can use to replay the AutoCad
> graphic aspect in a desktop GIS like QGis.
> This is a link:
> http://www.glasic.it/dxf2postgis.html
> Regards,
> Guglielmo Raimondi
> 2011/12/16 Bob Pawley <rjpawley at shaw.ca>:
>> I have imported a dxf file into Postgis using the following command
>> line -
>> set DXF_INLINE_BLOCKS=FALSE&set DXF_MERGE_BLOCK_GEOMETRIES=FALSE&set
>> PGCLIENTENCODING=LATIN1&&ogr2ogr -f "PostgreSQL" PG:"host=localhost
>> user=postgres dbname=dbname password=pass"  W_Works.dxf -nln Import_PID
>> -overwrite –skipfailures
>> All geometries are intact.
>> However, the text is part of the Linestring layer and not in the text
>> column
>> of the Postgresql table.
>> Is this to be expected?
>> Is there some way of screening out the text as text and point geometry?
>> Bob
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Ing. Guglielmo R. Raimondi
> guglielmo.raimondi at gmail.com
> c/o MiPAAF - Ministero delle Politiche Agricole, Alimentari e Forestali
> Gestione Commissariale ex Agensud
> Via Venti Settembre 98/G
> 00187 Roma
> www.agensud.it
> tel.: (+39) 06 488887 55
00187 Roma
www.agensud.it
