[postgis-users] QGIS Plugin PostGIS Manager
Giuseppe Sucameli brush.tyler at gmail.com
Fri Jan 20 11:18:43 PST 2012
Hi Florian,
On Fri, Jan 20, 2012 at 7:54 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Jan 20, 2012 at 07:14:07PM +0100, Florian Beyerbach wrote:
>> it is the first time i use this community support. if i make any mistake i´m sorry.
I think this message should be sent to the qgis-user mailing list
as the plugin is a QGis plugin.
>> i try to use the PostGIS Manager Plugin 0.5.15 for QGIS 1.7.3 with the postgresql 9.1 and postgis 1.5.3 database on my MacBookPro with Mac OSX Lion 10.7.2.
>> know i want to "Load Data from Shapefile", i chose the shape file in the dialog and after i click the load button
>> i get the error message: "Message: Filename: None".
PostGis Manager assumes that shp2pgsql executable is in PATH
environment variable. It's unable to find it, so it throws an OSError
exception.
I'm sure that after adding shp2pgsql to the PATH env var it should
work fine, but I've no Mac so I cannot say how to do this...
I hope this helps.
Regards.
>> I have no idea what the problem is, can anybody help me?
> I think the db_manager plugin superceeds the PostGIS Manager one.
> Giuseppe (in Cc) is the author of db_manager, but can probably also
> help with the PostGIS Manager plugin.
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
Giuseppe Sucameli
