[postgis-users] QGIS Plugin PostGIS Manager
Giuseppe Sucameli brush.tyler at gmail.com
Sat Jan 21 15:03:00 PST 2012
On Fri, Jan 20, 2012 at 9:51 PM, Florian Beyerbach
<Florian.Beyerbach at gmx.de> wrote:
> i use the tool terminal and the path environment variables are:
> mbp-wlan:~ fbeyerbach$ echo $PATH
> /sw/bin:/sw/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin:/usr/X11R6/bin:/usr/local/pgsql/share/contrib/postgis-1.5/:/usr/local/pgsql-9.1/bin:/usr/local/pgsql-9.1/bin
I've no MacOS, but few months ago I understood how it works.
Each application defines what environment variables it needs, but
the user can change them editing ~/.MacOSX/environment.plist
What you wrote is the value of PATH defined for terminal,
not the one for all the applications you run.
A way to have the same terminal's environment in an application
is to run the application from terminal.
Could you try again running Qgis from terminal?
Another solution could be to add environment variables before
PostGis Manager launches shp2pgsql, just setting PATH using
the QGis Python Console (menu Plugins):
import os
path = os.getenv("PATH")
pgpath = "/usr/local/pgsql/share/contrib/postgis-1.5/:/usr/local/pgsql-9.1/bin:/usr/local/pgsql-9.1/bin"
path = pgpath if path == None or path == "" else path + os.pathsep + pgpath
os.putenv("PATH", path)
In addition, there's a opened ticket [1] to add a panel to set/override
environment variables withing QGis to help OSX users.
I hope this helps.
[1] http://hub.qgis.org/issues/3097
> i think this should work. any idea?
> Am 20.01.2012 um 20:18 schrieb Giuseppe Sucameli:
>> Hi Florian,
>> On Fri, Jan 20, 2012 at 7:54 PM, Sandro Santilli <strk at keybit.net> wrote:
>>> On Fri, Jan 20, 2012 at 07:14:07PM +0100, Florian Beyerbach wrote:
>>>> it is the first time i use this community support. if i make any mistake i´m sorry.
>> I think this message should be sent to the qgis-user mailing list
>> as the plugin is a QGis plugin.
>>>> i try to use the PostGIS Manager Plugin 0.5.15 for QGIS 1.7.3 with the postgresql 9.1 and postgis 1.5.3 database on my MacBookPro with Mac OSX Lion 10.7.2.
>>>> know i want to "Load Data from Shapefile", i chose the shape file in the dialog and after i click the load button
>>>> i get the error message: "Message: Filename: None".
>> PostGis Manager assumes that shp2pgsql executable is in PATH
>> environment variable. It's unable to find it, so it throws an OSError
>> exception.
>> I'm sure that after adding shp2pgsql to the PATH env var it should
>> work fine, but I've no Mac so I cannot say how to do this...
>> I hope this helps.
>> Regards.
>>>> I have no idea what the problem is, can anybody help me?
>>> I think the db_manager plugin superceeds the PostGIS Manager one.
>>> Giuseppe (in Cc) is the author of db_manager, but can probably also
>>> help with the PostGIS Manager plugin.
>>> --strk;
>>>  ()   Free GIS & Flash consultant/developer
>>>  /\   http://strk.keybit.net/services.html
>> Giuseppe Sucameli
Giuseppe Sucameli
