[postgis-users] ST_MapAlgebraExpr() Function
Deepak R aj Awasthi deepakrajawasthi at yahoo.com
Mon Jan 23 00:29:18 PST 2012
It means the POSTGIS I installed is the older one and it does not support this function. Can I upgrade it having no problem with the present data. If yes where can I get this version, I have searched the latest one but unable to get it.
Thanks
Regards
Deepak
 From: Deepak R aj Awasthi <deepakrajawasthi at yahoo.com>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Monday, 23 January 2012, 9:24
Subject: Re: [postgis-users] ST_MapAlgebraExpr() Function
Thanks for suggestion, I have checked the date and it is "2011-10-06 08:02:01".  What could be other problem can you please..
To: 'PostGIS Users Discussion' <postgis-users at postgis.refractions.net>
Sent: Monday, 23 January 2012, 4:57
Hmm I meant 2012-01-01
> From: postgis-users-bounces at postgis.refractions.net  [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon Corporation
>Sent: Sunday, January 22, 2012 10:48  PM
>Just tried it on my latest build which is about a  week old (a little newer than the windows build currently on site but much  older than when this doc section was written).  Works fine for  me.
>Which version of PostGIS are you  using?
>Run this command:
> select postgis_scripts_build_date(),  postgis_raster_lib_build_date();
>Make sure both return a value later than  2011-01-01
>Hope that helps,
>Regina
>> From: postgis-users-bounces at postgis.refractions.net  [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Deepak R aj Awasthi
>>Sent: Sunday, January 22, 2012 12:13  PM
>>To: postgis-users at postgis.refractions.net
>>Subject: [postgis-users] ST_MapAlgebraExpr() Function
>>Hello,
>>I am a
    M.Sc. student and currently working with postgreSQL/PostGIS to
    handle  raster.  I have installed PostgreSQl  9.0 and
    PostGIS 2.0 in  windows 7  home premium OS. I had no
    problem on handling raster so far but now I got problem while accessing
    ST_MapAlgebraExpr () function  which takes two rasters as function
    arguments. I have followed the example provided in the link below as
    follows.
>>First, I  create the table as given,
>>CREATE TABLE fun_shapes(rid serial PRIMARY KEY, fun_name text, rast raster);Then,  the second syntax to insert raster and finally the use of the function  ST_MapAlgebraExpr()  as.
>>SELECT  ST_MapAlgebraExpr( area.rast, bub.rast, 'rast2', '8BUI', 'INTERSECTION', 'rast2', 'rast1') As interrast, ST_MapAlgebraExpr( area.rast, bub.rast, 'rast2', '8BUI', 'UNION', 'rast2', 'rast1') As unionrast
FROM  (SELECT rast FROM fun_shapes WHERE fun_name = 'area') As area
CROSS JOIN  (SELECT rast
FROM fun_shapes WHERE fun_name = 'rand bubbles') As bub
>> http://postgis.refractions.net/documentation/manual-svn/RT_ST_MapAlgebraExpr2.html
>>But I got  error on using this syntax as:
>>ERROR:  function
    st_mapalgebraexpr(raster, raster, unknown, unknown,  unknown,
    unknown, unknown) does not exist
>> LINE 58: SELECT
     ST_MapAlgebraExpr()
>>  HINT:  No function matches the
    given name and argument types. You might need to add explicit type
    casts.
>> Although I am new to this database, I think  that there is problem with  PostGIS 2.0 to support the function. If this  the case which version I have  to install to use this function. Can anyone  provide me solution for it.
>> Thanks
>> With Best
    Regards,
>> Deepak
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120123/6bbaf5c6/attachment.html>
