[postgis-users] Running PostGIS 2.0 on 64 bit machine
Bborie Park bkpark at ucdavis.edu
Tue Jan 24 06:47:31 PST 2012
Hey Joan,
You must be using an older build of PostGIS 2.0 as raster2pgsql.py is
no longer supported.  You will want to download and use the latest
Windows Experimental builds.
http://postgis.refractions.net/download/windows/experimental.php
Look for the links under the text...
"These are 32-bit binaries so will not work on 64-bit PostgreSQL. We
are working on getting 64-bit binaries out as well, but are running
into some stumbling blocks. For the time being -- if you are on
Windows 64-bit, you must install the 32-bit PostgreSQL to use these."
Also, there are no 64-bit builds of PostGIS available yet due to
compilation issues.
Hopefully that gets you back on track.
-bborie
On Tue, Jan 24, 2012 at 5:19 AM, Joan <wamaithajoan at gmail.com> wrote:
> Hi,
> I have been trying to set up PostGIS on a 64 bit machine running windows 7.
> The installation was successful but when I run the raster2pgsql script I get
> the following error.
> Traceback (most recent call last):
>   File "C:\Postgresql\bin\raster2pgsql.py", line 34, in <module>
>     from osgeo import gdal
>   File "C:\Python27\lib\site-packages\osgeo\__init__.py", line 21, in
> <module>
>     _gdal = swig_import_helper()
>   File "C:\Python27\lib\site-packages\osgeo\__init__.py", line 17, in
> swig_import_helper
>     _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: DLL load failed: The operating system cannot run %1.
> I have gdal in C:\Program Files (x86)\GDAL and C:\Program Files
> (x86)\GDAL\gdal-data in the environmental variables
> Any ideas??
> Joan
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
