[postgis-users] How to match lines between two similar graphs?
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jan 25 19:42:59 PST 2012
Hi All,
I have an interesting problem I am trying to solve and would love some
feedback on how to best go about it.
I have road data from two different vendor data sets. But this could
also be one road network and a GPS track, so I think this is a pretty
common use case.
Assumptions:
o the networks are similar, ie: they have similar roadway coverage
o the two sets might be slightly misaligned, ie: shifted by some amount
o the segments in the two data sets do not have to be broken into
equivalent segments, ie: one segment in A might be represented my
multiple segments in B
o segments are not aligned end point wise, ie: a segment in A might go
from mid-point one segment in B to the midpoint of a connected segment in B
o in many cases I will be working with a set of lines in one set that I
need to match to the other to select a matching set of lines.
So strategies for matching these:
1. take a segment from A and buffer it, then intersect the data in B and
select the longest intersected object. I can probably throw out any
pieces smaller than the buffer distance.
2. Do the same but buffer and union the set of lines into a single
multipolygon, and intersect that with the other set.
3. ??? Other ideas?
Thoughts on performance?
Typically I will have a small set (1-20) of segments to compare against
a larger (100K-2M) set. Obvious a spatial index will will be used. But
I'm wondering what is the fast way to do this matching computationally.
I think I will want to be able to compare 1-200 sets like this every 5
mins as data comes in from a feed, while supporting other queries.
Thoughts would be appreciated.
-Steve
