[postgis-users] shp2pgsql segment fault (trunk -r 8924 ) without .shp file
Paul Ramsey pramsey at opengeo.org
Thu Jan 26 12:53:05 PST 2012
svn update, problem should be fixed now
P.
On Thu, Jan 26, 2012 at 12:52 PM, Min Wang <ser.basis at gmail.com> wrote:
> HI
>   I  built the trunk version 8924  on 64 bit machine.
>   The shp2pgsql seems gave me segment fault when there is no .shp file. but
> if pass -n, then it is ok.
>   Here is what I did:
>  gdb shp2pgsql
>  (gdb) set args s 4269 -g the_geom -W latin1 ./tl_2010_11001_featnames.dbf
> (gdb) run
>  Starting program: /usr/bin/shp2pgsql s 4269 -g the_geom -W latin1
> Unable to open s.shp or s.SHP.
> Unable to open s.shx or s.SHX.
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff7867974 in fclose () from /lib/libc.so.6
> (gdb) bt
> #0  0x00007ffff7867974 in fclose () from /lib/libc.so.6
> #1  0x0000000000405998 in ?? ()
> #2  0x0000000000405ecf in ?? ()
> #3  0x000000000040bde1 in ?? ()
> #4  0x000000000040c906 in ?? ()
> #5  0x00007ffff781ec4d in __libc_start_main () from /lib/libc.so.6
> #6  0x0000000000402199 in ?? ()
> #7  0x00007fffffffe698 in ?? ()
> #8  0x000000000000001c in ?? ()
> #9  0x0000000000000008 in ?? ()
> #10 0x00007fffffffe8f2 in ?? ()
> #11 0x00007fffffffe905 in ?? ()
> #12 0x00007fffffffe907 in ?? ()
> #13 0x00007fffffffe90c in ?? ()
> #14 0x00007fffffffe90f in ?? ()
> #15 0x00007fffffffe918 in ?? ()
> #16 0x00007fffffffe91b in ?? ()
> #17 0x00007fffffffe922 in ?? ()
> #18 0x0000000000000000 in ?? ()
> (gdb)
>   any clue?
> thanks.
> Min Wang
> postgis-users mailing list
