[postgis-users] ST_Quantile
Bborie Park bkpark at ucdavis.edu
Fri Jan 27 10:14:09 PST 2012
Hey Joan,
Assuming your whole coverage is in a table, you should use the
table/column version of ST_Quantile (which by the looks of it is
undocumented for some reason).
The function definition of ST_Quantile(rastertable, rastercolumn) is...
st_quantile(rastertable text, rastercolumn text, nband int DEFAULT 1,
exclude_nodata_value boolean DEFAULT TRUE, quantiles double precision[]
DEFAULT NULL)
At the moment an aggregate version of ST_Quantile (and the other basic
stats functions) does not exist.  It is expected that one will be
written for PostGIS 2.1 assuming dev-time is available.
-bborie
On 01/27/2012 09:06 AM, Joan wrote:
> Hi,
> I would like to find the quantile values of a whole raster coverage, but
> ST_Quantile returns quantile values of each tile. Which would be the best
> method to approximate the quantile value of the whole coverage?
> Regards,
> Joan
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
