[postgis-users] ST_Quantile
Joan wamaithajoan at gmail.com
Fri Jan 27 11:19:51 PST 2012
Hi Steve,
I have gotten the same problem (db server stopped running).
Joan
On 27 January 2012 20:05, Stephen Woodbridge <woodbri at swoodbridge.com>wrote:
> Joan,
> I've never used these function, but try doing:
> select st_quantile('kbd_ext', 'rast', 0.75);
> Since you probably do not want this called once for every row in the table.
> -Steve
> On 1/27/2012 2:03 PM, Joan wrote:
>> Hi Bborie,
>> This is my query and it crashes the db server.
>> select st_quantile('kbd_ext', 'rast', 0.75) from kbd_ext limit 10;
>> Joan
>> On 27 January 2012 19:14, Bborie Park <bkpark at ucdavis.edu
>> <mailto:bkpark at ucdavis.edu>> wrote:
>>    Hey Joan,
>>    Assuming your whole coverage is in a table, you should use the
>>    table/column version of ST_Quantile (which by the looks of it is
>>    undocumented for some reason).
>>    The function definition of ST_Quantile(rastertable, rastercolumn) is...
>>    st_quantile(rastertable text, rastercolumn text, nband int DEFAULT
>>    1, exclude_nodata_value boolean DEFAULT TRUE, quantiles double
>>    precision[] DEFAULT NULL)
>>    At the moment an aggregate version of ST_Quantile (and the other
>>    basic stats functions) does not exist.  It is expected that one will
>>    be written for PostGIS 2.1 assuming dev-time is available.
>>    -bborie
>>    On 01/27/2012 09:06 AM, Joan wrote:
>>        Hi,
>>        I would like to find the quantile values of a whole raster
>>        coverage, but
>>        ST_Quantile returns quantile values of each tile. Which would be
>>        the best
>>        method to approximate the quantile value of the whole coverage?
>>        Regards,
>>        Joan
>>        ______________________________ _________________
>>        postgis-users mailing list
>>        postgis-users at postgis. refractions.net
>>        <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>        http://postgis.refractions. net/mailman/listinfo/postgis- users
>>        <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>    Bborie Park
>>    Programmer
>>    Center for Vectorborne Diseases
>>    UC Davis
>>    530-752-8380
>>    bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>
>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120127/b938a9fc/attachment.html>
