[postgis-users] Make Check fails
Andreas Forø Tollefsen andreasft at gmail.com
Tue Jan 31 07:16:03 PST 2012
And the file exists:
andreas at andreas-priogrid:~/Downloads/postgis-2.0.0alpha3SVN$ locate
libgeos-3.4.0dev.so
/home/andreas/Downloads/geos-svn/src/.libs/libgeos-3.4.0dev.so
/usr/local/lib/libgeos-3.4.0dev.so
2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com>
> 2012/1/31 Mathieu Basille <basille at ase-research.org>
>> Le 31/01/2012 09:51, Andreas Forø Tollefsen a écrit :
>>> Hi Mathieu,
>>> Thanks. I was thinking the same. I downloaded the latest from trunk.
>>> ./autogen.sh
>>> ./configure --with-raster --with-gui
>>> Also tried --with-geosconfig and --with-gdalconfig manually with the same
>>> problem.
>>> Could it be worth a try to delete the postgis-2.0.so
>>> <http://postgis-2.0.so> file and reinstall postgis?
>> I don't think it is related to postgis-2.0.so, but really to the mess
>> with GEOS installs. Try to make sure that you're using the correct
>> geos-config. If you're using a Linux OS, you can try:
>> sudo updatedb
>> locate geos-config
>> See how many do you have. Mine (compiled by myself) is in
>> '/usr/local/bin/geos-config'. You can check if it is the correct one with,
>> e.g. less:
>> less /usr/local/bin/geos-config
>> It shows me somewhere that this is the 3.4.0dev version:
>>    --version)
>>    echo 3.4.0dev
>> Then I can use:
>> ./configure --with-raster --with-geosconfig=/usr/local/**bin/geos-config
>> Now you have to adjust it for your needs. How did you install GEOS 3.3.2?
>> Did you use a package manager, or compile it manually? Only this will tell
>> you which geos-config to use...
>> Mathieu.
>> Hi Mathieu,
> I have compiled my geos myself using ./autogen.sh, ./configure, make, make
> install.
> Then i set the path to the geos-config manually when configuring postgis:
> ./configure --with-geosconfig=/usr/local/bin/geos-config --with raster
> I also tried by reinstalling the latest geos3.4.dev from trunk.
> However. I get the same error:
> ---- Making check in liblwgeom
> make[1]: Entering directory
> `/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom'
> make -C cunit check
> make[2]: Entering directory
> `/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit'
> /bin/bash ../../libtool --mode=link gcc -g -O2  -Wall -Wmissing-prototypes
> -I/usr/local/include  -DPOSTGIS_GEOS_VERSION=34 -o cu_tester cu_algorithm.o
> cu_print.o cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_measures.o
> cu_node.o cu_libgeom.o cu_split.o cu_surface.o cu_homogenize.o cu_out_wkt.o
> cu_out_wkb.o cu_out_gml.o cu_out_kml.o cu_out_geojson.o cu_out_svg.o
> cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../liblwgeom.la -lcunit
> libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes -I/usr/local/include
> -DPOSTGIS_GEOS_VERSION=34 -o .libs/cu_tester cu_algorithm.o cu_print.o
> cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_measures.o cu_node.o
> cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../.libs/liblwgeom.so
> /usr/lib/libcunit.so
> #gcc -o cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
> cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
> cu_surface.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
> cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o
> cu_in_wkt.o cu_tester.o  ../.libs/liblwgeom.a -lm -lcunit -L/usr/local/lib
> -lgeos_c
> /home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit/.libs/lt-cu_tester:
> error while loading shared libraries: libgeos-3.4.0dev.so: cannot open
> shared object file: No such file or directory
> make[2]: *** [check] Error 127
> make[2]: Leaving directory
> make[1]: *** [check] Error 2
> make[1]: Leaving directory
> make: *** [check] Error 1
>>  Andreas
>>> <mailto:basille at ase-research.**org <basille at ase-research.org>>>
>>>    It seems indeed to be related to your previous GEOS install. What
>>>    command did you use to compile PostGIS? Is it possible that the path
>>> to
>>>    geos-config is still linking to the previous install? You can override
>>>    it by: '--with-geosconfig=/usr/bin/__**geos-config' (or the one
>>> related
>>>    to your current install of GEOS) in the ./configure.
>>>    Hope it helps. If not, please provide more details (OS, previous
>>>    commands, etc.).
>>>    Mathieu.
>>>    Le 31/01/2012 09:33, Andreas Forø Tollefsen a écrit :
>>>        Hi,
>>>        I have installed GEOS 3.3.2 and GDAL 1.9.
>>>        I previously had a GEOS SVN 3.4 installed, but no longer.
>>>        Still i get this error when running make check.
>>>        Any idea?
>>>        /home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**
>>> liblwgeom/cunit/.libs/lt-cu___**testr:
>>>        <http://libgeos-3.4.0dev.so>
>>>        <http://libgeos-3.4.0dev.so>: cannot open shared object file: No
>>>        such file
>>>        or directory
>>>        `/home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**
>>> liblwgeom/cunit'
>>> liblwgeom'
>>>        ______________________________**___________________
>>>        postgis-users mailing list
>>>        postgis-users at postgis.__refrac**tions.net<http://refractions.net>
>>>        <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>        http://postgis.refractions.__**net/mailman/listinfo/postgis-_**
>>> _users
>>>        <http://postgis.refractions.**net/mailman/listinfo/postgis-**
>>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>>
>>>    ~$ whoami
>>>    Mathieu Basille, Post-Doc
>>>    ~$ locate
>>>    Laboratoire d'Écologie Comportementale et de Conservation de la Faune
>>>    + Centre d'Étude de la Forêt
>>>    Département de Biologie
>>>    Université Laval, Québec
>>>    ~$ info
>>>    http://ase-research.org/__**basille<http://ase-research.org/__basille><
>>> http://ase-research.org/**basille <http://ase-research.org/basille>>
>>>    ~$ fortune
>>>    ``If you can't win by reason, go for volume.''
>>>    Calvin, by Bill Watterson.
>>>    postgis-users at postgis.__refrac**tions.net <http://refractions.net>
>>>    http://postgis.refractions.__**net/mailman/listinfo/postgis-_**_users
>>>    <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> ~$ whoami
>> ~$ locate
>> ~$ info
>> ~$ fortune
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/917a116f/attachment.html>
