[postgis-users] Make Check fails
Andreas Forø Tollefsen andreasft at gmail.com
Tue Jan 31 07:45:43 PST 2012
Thank you Mathieu!
That did it. Could you explain what the commands excactly do, so i know
next time?
Best,
Andreas
2012/1/31 Mathieu Basille <basille at ase-research.org>
> Arf, I was just too late :)
> I remember a similar problem with GDAL (also compiled manually), for which
> the lib .so could not be found. You can first check the paths:
> /sbin/ldconfig -p | grep geos
> I have something like that:
>        libgeos_c.so.1 (libc6) => /usr/local/lib/libgeos_c.so.1
>        libgeos_c.so (libc6) => /usr/local/lib/libgeos_c.so
>        libgeos-3.4.0dev.so (libc6) => /usr/local/lib/libgeos-3.4.**0dev.so<http://libgeos-3.4.0dev.so>
> If you don't have this, you can try (use sudo if needed):
> echo '/usr/local/lib' >> /etc/ld.so.conf
> ldconfig
> And check again. This should be enough for PostGIS to compile (at least it
> worked for me).
> Hope this helps,
> Mathieu.
> Le 31/01/2012 10:16, Andreas Forø Tollefsen a écrit :
>> And the file exists:
>> andreas at andreas-priogrid:~/**Downloads/postgis-2.0.**0alpha3SVN$ locate
>> libgeos-3.4.0dev.so <http://libgeos-3.4.0dev.so>
>> /home/andreas/Downloads/geos-**svn/src/.libs/libgeos-3.4.**0dev.so<http://libgeos-3.4.0dev.so>
>> /usr/local/lib/libgeos-3.4.**0dev.so <http://libgeos-3.4.0dev.so> <
>> 2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com
>> <mailto:andreasft at gmail.com>>
>>    <mailto:basille at ase-research.**org <basille at ase-research.org>>>
>>        Le 31/01/2012 09:51, Andreas Forø Tollefsen a écrit :
>>            Hi Mathieu,
>>            Thanks. I was thinking the same. I downloaded the latest from
>>            trunk.
>>            ./autogen.sh
>>            ./configure --with-raster --with-gui
>>            Also tried --with-geosconfig and --with-gdalconfig manually
>>            with the same
>>            problem.
>>            Could it be worth a try to delete the postgis-2.0.so
>>            <http://postgis-2.0.so>
>>            <http://postgis-2.0.so> file and reinstall postgis?
>>        I don't think it is related to postgis-2.0.so
>>        <http://postgis-2.0.so>, but really to the mess with GEOS
>> installs.
>>        Try to make sure that you're using the correct geos-config. If
>>        you're using a Linux OS, you can try:
>>        sudo updatedb
>>        locate geos-config
>>        See how many do you have. Mine (compiled by myself) is in
>>        '/usr/local/bin/geos-config'. You can check if it is the correct
>>        one with, e.g. less:
>>        less /usr/local/bin/geos-config
>>        It shows me somewhere that this is the 3.4.0dev version:
>>            --version)
>>            echo 3.4.0dev
>>        Then I can use:
>>        --with-geosconfig=/usr/local/_**_bin/geos-config
>>        Now you have to adjust it for your needs. How did you install GEOS
>>        3.3.2? Did you use a package manager, or compile it manually? Only
>>        this will tell you which geos-config to use...
>>        Mathieu.
>>    Hi Mathieu,
>>    I have compiled my geos myself using ./autogen.sh, ./configure, make,
>>    make install.
>>    Then i set the path to the geos-config manually when configuring
>> postgis:
>>    ./configure --with-geosconfig=/usr/local/**bin/geos-config --with
>> raster
>>    I also tried by reinstalling the latest geos3.4.dev from trunk.
>>    However. I get the same error:
>>    ---- Making check in liblwgeom
>>    make[1]: Entering directory
>>    `/home/andreas/Downloads/**postgis-2.0.0alpha3SVN/**liblwgeom'
>>    make -C cunit check
>>    make[2]: Entering directory
>>    `/home/andreas/Downloads/**postgis-2.0.0alpha3SVN/**liblwgeom/cunit'
>>    /bin/bash ../../libtool --mode=link gcc -g -O2  -Wall
>>    -Wmissing-prototypes -I/usr/local/include  -DPOSTGIS_GEOS_VERSION=34 -o
>>    cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
>>    cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
>>    cu_surface.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
>>    cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o
>>    cu_in_wkt.o cu_tester.o  ../liblwgeom.la <http://liblwgeom.la> -lcunit
>>    libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes
>>    -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -o .libs/cu_tester
>>    cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o cu_geodetic.o
>>    cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o cu_surface.o
>>    cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o cu_out_kml.o
>>    cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o
>>    cu_tester.o  ../.libs/liblwgeom.so /usr/lib/libcunit.so
>>    #gcc -o cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
>>    cu_in_wkt.o cu_tester.o  ../.libs/liblwgeom.a -lm -lcunit
>>    -L/usr/local/lib -lgeos_c
>> liblwgeom/cunit/.libs/lt-cu_**tester:
>>    error while loading shared libraries: libgeos-3.4.0dev.so
>>    <http://libgeos-3.4.0dev.so>: cannot open shared object file: No such
>>    file or directory
>>    make[2]: *** [check] Error 127
>>    make[2]: Leaving directory
>>    make[1]: *** [check] Error 2
>>    make[1]: Leaving directory
>>    make: *** [check] Error 1
>>            Andreas
>>            <mailto:basille at ase-research._**_org
>>                It seems indeed to be related to your previous GEOS
>>            install. What
>>                command did you use to compile PostGIS? Is it possible that
>>            the path to
>>                geos-config is still linking to the previous install? You
>>            can override
>>                it by: '--with-geosconfig=/usr/bin/__**__geos-config' (or
>> the
>>            one related
>>                to your current install of GEOS) in the ./configure.
>>                Hope it helps. If not, please provide more details (OS,
>>            previous
>>                commands, etc.).
>>                Mathieu.
>>                Le 31/01/2012 09:33, Andreas Forø Tollefsen a écrit :
>>                    Hi,
>>                    I have installed GEOS 3.3.2 and GDAL 1.9.
>>                    I previously had a GEOS SVN 3.4 installed, but no
>> longer.
>>                    Still i get this error when running make check.
>>                    Any idea?
>>              /home/andreas/Downloads/____**postgis-2.0.0alpha3SVN/____**
>> liblwgeom/cunit/.libs/lt-cu___**__testr:
>> No
>>                    such file
>>                    or directory
>>              `/home/andreas/Downloads/____**postgis-2.0.0alpha3SVN/____**
>> liblwgeom/cunit'
>> liblwgeom'
>>                    ______________________________**_____________________
>>                    postgis-users mailing list
>>                    postgis-users at postgis.__refrac**__tions.net<http://refrac__tions.net>
>>            <http://refractions.net>
>>            <mailto:postgis-users at postgis.**__refractions.net
>>            <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>            http://postgis.refractions.___**_net/mailman/listinfo/postgis-
>> **____users
>>            <http://postgis.refractions.__**net/mailman/listinfo/postgis-_
>> **_users
>>            <http://postgis.refractions.**net/mailman/listinfo/postgis-**
>> users <http://postgis.refractions.net/mailman/listinfo/postgis-users>>>
>>                ~$ whoami
>>                Mathieu Basille, Post-Doc
>>                ~$ locate
>>                Laboratoire d'Écologie Comportementale et de Conservation
>>            de la Faune
>>                + Centre d'Étude de la Forêt
>>                Département de Biologie
>>                Université Laval, Québec
>>                ~$ info
>>            http://ase-research.org/____**basille<http://ase-research.org/____basille>
>>            <http://ase-research.org/__**basille<http://ase-research.org/__basille>
>>            <http://ase-research.org/**basille<http://ase-research.org/basille>
>>                ~$ fortune
>>                ``If you can't win by reason, go for volume.''
>>                Calvin, by Bill Watterson.
>> **____users
>> **_users
>>            postgis-users at postgis.__refrac**tions.net<http://refractions.net>
>>            http://postgis.refractions.__**net/mailman/listinfo/postgis-_*
>> *_users
>>        ~$ whoami
>>        ~$ locate
>>        Laboratoire d'Écologie Comportementale et de Conservation de la
>> Faune
>>        ~$ info
>>        http://ase-research.org/__**basille<http://ase-research.org/__basille><
>> http://ase-research.org/**basille <http://ase-research.org/basille>>
>>        ~$ fortune
>>        postgis-users at postgis.__refrac**tions.net <http://refractions.net>
>>        http://postgis.refractions.__**net/mailman/listinfo/postgis-_**
>> _users
>>        <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
> ~$ whoami
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> ~$ info
> ~$ fortune
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/bd14a613/attachment.html>
