[postgis-users] Length of a line above polygon
Matej Mailing mailing at tam.si
Tue Jul 3 23:51:24 PDT 2012
I think I have just found it out. I just add ST_Intersection to have a
query like:
SELECT areas.id, SUM( ST_Length( ST_Intersection(lines.geometry,
areas.geometry) ) ) FROM lines,areas WHERE
ST_Intersects(lines.geometry,areas.geometry) GROUP BY areas.id ;
Now the numbers seem to be correct :-) Hopefully this could be of some
use to anyone else when having such a problem.
Thanks,
Matej
2012/7/4 Matej Mailing <mailing at tam.si>:
> Hi,
> Thank you for the answer. However, I don't get the right result. For
> example, when there is a line that is long 500 meters and it crosses 5
> polygons (on each of them maybe just a meter or few meters, except one
> where lies a majority of the line), I get the full length of the lines
> for corresponding polygons - i.e. as every polygon that is crossed is
> crossed by the total line length. What I want to get is the actual
> length of the part of the line that crosses every specific polygon.
> TIA,
> Matej
> 2012/7/3 Denis Rouzaud <denis.rouzaud at gmail.com>:
>> Hi,
>> You can use something like
>> SELECT areas.id, SUM( ST_Length( lines.geometry) ) FROM lines,areas WHERE
>> Greetings,
>> Denis
>> On 07/03/2012 01:36 PM, Matej Mailing wrote:
>>> Hi all,
>>> We have a layer that contains polygons and another that contains lines
>>> that lie on them. Parts of the lines are laying "inside" the polygons
>>> and I would like to get a sum of all the lengths of lines that lie on
>>> the polygons. What is the easiest way to achieve this?
>>> TIA,
>>> Matej
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
