[postgis-users] Coordinate transformation with customrecordsofspatial_sys_ref
Robert_Clift at doh.state.fl.us Robert_Clift at doh.state.fl.us
Tue Jul 17 05:49:21 PDT 2012
One easy way to generate the syntax required to add a custom projection is to select something similar at spatialreference.org and click "PostGIS spatial_ref_sys INSERT statement," then copy and paste into a text or query editor to revise. Blinding flash of the obvious, perhaps, but hope it's helpful to someone.
-Rob
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sandro Santilli
Sent: Tuesday, July 17, 2012 5:49 AM
To: DUPREZ Cédric
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] Coordinate transformation with customrecordsofspatial_sys_ref
On Tue, Jul 17, 2012 at 11:34:46AM +0200, DUPREZ Cédric wrote:
> SELECT AddGeometryColumn('public', 'pts', 'geom', 320002120, 'POINT',
> 2, false);
> This gives me the following error message: "ERROR: AddGeometryColumn()
> - SRID must be <= 998999
> How can I use the correct 320002120 SRID specified by French IGN?
Is 320002120 in your spatial_ref_sys already ?
You'll need to assign it a different SRID, the spatial_ref_sys has provision for "auth_srid" so you can put 320002120 in there and use something valid for PostGIS' "srid" field.
Unfortunately we never got around writing a page about SRID ranges in PostGIS manual (contributions welcome!) but the idea is that you put your "custom" entries somewhere from 910000 and below 999000.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.1
  |  / 2.1 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
