[postgis-users] spatialreference.org srid insert error
Stephen V. Mather svm at clevelandmetroparks.com
Tue Jul 17 12:35:58 PDT 2012
Since early on (perhaps always) the insert statements generated by spatialreference.org have appended ‘9’ to the SRID.  I’ve never understood why.  I think, however, that in earlier PostGIS instances, there was no enforcement of a maximum integer, so many would have never noticed.
BTW, with California State Plane you might think to see if there is an equivalent SRID in the official EPSGs, rather than the ESRI number for it (102243), but I don’t know your application here.  In Ohio, ESRI’s 102722 is about the same as EPSG 3734.
Best,
Steve
http://www.clemetparks.com/images/esig/cmp-ms-90x122.pngStephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
 <http://www.clemetparks.com/> clevelandmetroparks.com
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Peter Tittmann
Sent: Tuesday, July 17, 2012 3:20 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] spatialreference.org srid insert error
Thanks Astrid!
Seems a little strange that spatialreference.org would produce an invalid insert statement. Regardless, thanks for the pointer.
Peter
Peter Tittmann
On Tuesday, July 17, 2012 at 1:09 PM, Astrid Emde wrote:
Hello Peter,
there is a constraint that checks that srid is < 998999
ALTER TABLE spatial_ref_sys
ADD CONSTRAINT spatial_ref_sys_srid_check CHECK (srid > 0 AND srid <=
998999);
You should set sird in the insert to 102243 instead of 9102243:
INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text,
srtext) values
( 102243, 'esri', 102243, '+proj=lcc +lat_1=37.06666666666667
+lat_2=38.43333333333333 +lat_0=36.5 +lon_0=-120.5 +x_0=2000000
+y_0=500000 +ellps=GRS80 +units=m +no_defs ',
'PROJCS["NAD_1983_HARN_StatePlane_California_III_FIPS_0403",GEOGCS["GCS_North_American_1983_HARN",DATUM["NAD83_High_Accuracy_Regional_Network",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["False_Easting",2000000],PARAMETER["False_Northing",500000],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",37.06666666666667],PARAMETER["Standard_Parallel_2",38.43333333333333],PARAMETER["Latitude_Of_Origin",36.5],UNIT["Meter",1],AUTHORITY["EPSG","102243"]]');
Astrid
On Tue, July 17, 2012 6:14 pm, Peter Tittmann wrote:
Im trying to add a srid from spatial reference.org
(http://spatialreference.org/ref/esri/102243/postgis/) but i'm getting a
error using the insert statement:
ERROR: new row for relation "spatial_ref_sys" violates check constraint
"spatial_ref_sys_srid_check"
I saw this ticket
(http://www.google.com/url?sa=t <http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDYQ> &rct=j&q=&esrc=s&source=web&cd=1&ved=0CDYQ
FjAA&url=http%3A%2F%2Ftrac.osgeo.org%2Fpostgis%2Fticket%2F1505&ei=f6gFUOy
kJcWl2AXz2eDKBQ&usg=AFQjCNH1dlCvTvWEYntRmqflCDtAOUT49g&sig2=tch67lIoPp2IO
RZaCyOpSw) and thread
(http://www.google.com/url?sa=t <http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDgQ> &rct=j&q=&esrc=s&source=web&cd=2&ved=0CDgQ
FjAB&url=http%3A%2F%2Fpostgis.refractions.net%2Fpipermail%2Fpostgis-devel
%2F2012-February%2F018485.html&ei=f6gFUOykJcWl2AXz2eDKBQ&usg=AFQjCNGxJREc
0HrXIbAFuKSfvjU0tbfg9A&sig2=0wH8-t8hCMiuIWKDL6AeFQ) but seems lie it
should be fixed.
Thanks in advance!
Peter
Peter Tittmann
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Mit freundlichen Grüßen
Astrid Emde
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
pgp-public key:
http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120717/1346b905/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120717/1346b905/attachment.png>
