[postgis-users] Loading a shapefile into a postgres database remotely
Charlie Sharpsteen charles.sharpsteen at gmail.com
Sun Jun 3 10:35:24 PDT 2012
On Sunday, June 3, 2012 10:22:03 AM UTC-7, David Quinn wrote:
> I have already edited the pg_hba.conf and postgresql.conf files and can
> connect remotely using pgadmin so I think that is not a problem.
> Charlie, should I include this code in the command that I described
> earlier, or is it something that I should run first?
It is something that you should run first, in a separate terminal. Note
that since you are using Windows you may not have an `ssh` command unless
you have installed a suite of UNIX tools such as MSYS. You may also be able
to set up a SSH tunnel using PuTTY.
-Charlie
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120603/f4774a47/attachment.html>
