[postgis-users] row-wise geometry intersecting
Brent Fraser bfraser at geoanalytic.com
Tue Jun 12 10:52:45 PDT 2012
Hi All,
I've got a table (a view actually) with two multipolygon geometry
columns: wkb_geom_extent and wkb_geom_digitized.
They contain polygons representing the footprint of images and the areas
digitized in the  images.
So the view looks like:
v_images
image_id:    wkb_geom_extent:    wkb_geom_digitized:
1                   xxxxx          xxxx
2                   xxxxx
3                   xxxxxx         xxxxx
I want to calculate the area digitized in each of the images and since
some of the polygons representing the area digitized could have be
sloppily defined to extend outside of the image footprint , I thought I
would intersect the two geometries:
SELECT image_id, ST_Intersection(wkb_geom_extent, wkb_geom_digitized) as
image_area FROM v _images
but I get an error:
NOTICE:  TopologyException: side location conflict at -17.2242 79.1865
ERROR:  GEOS Intersection() threw an error!
********** Error **********
SQL state: XX000
This may be due to some problems in my geometries, but I thought I would
check to see if my query was reasonable...
Thanks!
Best Regards,
Brent Fraser
