[postgis-users] raster retrieval
Yogesh Dahiya yogesh at vizexperts.com
Thu Jun 21 08:06:11 PDT 2012
I have  raster data into postgis server(I am able to see it in qgis).
When I retrieve it and form gtiff image out of it using gdal  , Image
generated is not proper (coloring problem).
I am able to retrieve metadata correctly
For raster I am doing  st_AsBinary(rast)
And then passing it to gdal rasterio buffer parameter
Attach file contain original and Downloaded image
43J is original
download_temp.tif is downloaded one.
Metadata is read first successfully
Image was stored as tiles
Code :
for(int row=0;row<99;row++){
            int xoff,yoff;
            yoff=row*metadata.tilesizeY ;
            for(int col=0;col<99;col++){
                  xoff=col*metadata.tilesizeX;
                  query<<"select st_asbinary(rast) from public.tkptest where
rid ="<<(row*99)+col+1;
                  retval = PQexec(options.connection,query.str().c_str());
                  res= PQresultStatus(retval);
                  if(res!=PGRES_TUPLES_OK){
                        std::cout<<"We did not get any data\n";
                        return res;
                  dstDS->RasterIO(GF_Write,xoff,yoff,metadata.tilesizeX
,metadata.tilesizeY ,PQgetvalue(retval,0,0),metadata.tilesizeX
*metadata.datasize,metadata.tilesizeY *metadata.datasize
,metadata.dtype,metadata.numBands,panBandMap,0,0,0);
                  PQclear(retval);
                  query.clear();
                  query.str("");
GDALClose(dstDS);
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120621/0069d68f/attachment.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120621/0069d68f/attachment.tif>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120621/0069d68f/attachment-0001.tif>
