[postgis-users] Error in geometry type
Birgit Laggner birgit.laggner at vti.bund.de
Mon Mar 5 02:54:58 PST 2012
Hi Yves,
did you test st_geometrytype(st_offsetcurve(way,-20))? Because, I could
imagine the MultiLineString results from the st_offsetcurve function.
Hope that helps,
Birgit.
Am 04.03.2012 09:07, schrieb yvecai:
> I have a strange error on ST_offsetcurve calls on geometries that are
> supposed to be LineStrings.
> Yves
>     gis=# update planet_osm_line set way=ST_OffsetCurve(way,-20) where
>     osm_id=-1461806;
>     ERREUR:  Geometry type (MultiLineString) does not match column
>     type (LineString)
>     gis=# select geometrytype(way) from planet_osm_line where osm_id =
>     -1461806;
>      geometrytype
>      LINESTRING
>     (1 ligne)
>     gis=# select st_geometrytype(way) from planet_osm_line where
>     osm_id = -1461806;
>      st_geometrytype
>      ST_LineString
>     (1 ligne)
>     gis=# select st_numgeometries(way) from planet_osm_line where
>     osm_id = -1461806;
>      st_numgeometries
>                     1
>     (1 ligne)
> See attached the result of:
> echo "select st_astext(way) from planet_osm_line where osm_id =
> -1461806;" | psql -d gis > out.wkt
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120305/5b2c1a0f/attachment.html>
