[postgis-users] about postgis gecode and fuzzy search
Min Wang ser.basis at gmail.com
Mon Mar 5 14:03:08 PST 2012
Hi Steve
     thanks a lot.
min
On 03/05/2012 04:42 PM, Stephen Woodbridge wrote:
> Hi Min,
> If you are doing a fuzzy search, then you request does not make sense.
> The whole purpose of a fuzzy search to to find some like what you are
> looking for. What you are asking for is different. You want and exact
> search with a fallback to to city centroid or zip centroid if the
> exact match fails.
> You could achieve this by filtering you query below like:
> select * from (
> SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat,
> (addy).address As stno, (addy).streetname As street,
> (addy).streettypeabbrev As styp, (addy).location As city,
> (addy).stateabbrev As st,(addy).zip
> FROM geocode('38 blair mill rod, glenside,pa') As g
> ) as h where h.city ilike "glenside";
> Then if this fails to return a result, you could lookup the city
> centroid for "glenside, pa" in another table you would need to load.
> -Steve
> On 3/5/2012 4:38 PM, Min Wang wrote:
>> HI
>> I am new to postgis geocoding.
>> I have installed postgis 2.0 with fuzzy search, and imported the tiger
>> data for usa.
>> Now for geocoding non-exist or some not accurate addresses
>> e.g: 38 blair mill rod, glenside, pa
>> its output:
>> FROM geocode('38 blair mill rod, glenside,pa') As g;
>> rating | lon | lat | stno | street | styp | city | st | zip
>> 20 | -80.1461480769354 | 39.8912098295989 | 38 | Blair | Ct | Waynesburg
>> | PA | 15370
>> 20 | -76.9528968230038 | 41.1701753366091 | 38 | Blair | Dr | Montgomery
>> | PA | 17752
>> 20 | -80.1461480769354 | 39.8912098295989 | 38 | Blair | Ct | West
>> Waynesburg | PA | 15370
>> Morrisville | PA | 15370
>> 20 | -77.2937928401596 | 40.2205725968637 | 38 | Blair | Ct | Plainfield
>> | PA | 17015
>> 21 | -78.7498163920357 | 40.467390956601 | 38 | Blair | Rd | Ebensburg |
>> PA | 15931
>> 22 | -80.0234909653877 | 41.4774803539524 | 38 | Blair | Ln | French
>> Creek | PA | 16311
>> 24 | -78.9484013917784 | 41.0336884088542 | | Blair | Dr | Reynoldsville
>> | PA | 15851
>> 25 | -80.236503518171 | 40.5702521235743 | 38 | Blair | Aly | South
>> Heights | PA | 15081
>> 27 | -75.1757087347985 | 41.0177238645261 | 38 | Blair | Ct | East
>> Stroudsburg | PA | 18301
>> none of them is in glenside, PA
>> what I would like the result is: return some addresses or center in
>> glenside, PA instead of other cities address?
>> Is it possible? Is there anyway to specify the weight of the search?
>> like city: glenside has some weight during the geocode search?
>> the state : PA has more weight?
>> thanks
>> min
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
