[postgis-users] Voronoi tessellation
Ben Madin lists at remoteinformation.com.au
Tue Mar 6 07:08:44 PST 2012
Hi Puneet,
Did it work when you removed the offending semicolon, as described in the syntax error message?
cheers
Ben
On 06/03/2012, at 11:52 AM, Puneet Kishor wrote:
> On Mar 5, 2012, at 9:44 PM, Derek Jones wrote:
>> Hi all,
>> I have used an R solution that works well with the plsql to do this. Found here:
>> http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgresql_plr_tut02
>> Needed some mods for my local solution, but helpful.
> Yes, I tried that, but as I noted in my earlier email, I got the following error
> ERROR:  R interpreter expression evaluation error
> DETAIL:  Error in pg.spi.exec(sprintf("select x(%2$s) as x, y(%2$s) as y from %1$s;",  :
> error in SQL statement : syntax error at or near ";"
> CONTEXT:  In R support function pg.spi.exec
> In PL/R function voronoi
> postgis-users mailing list
