[postgis-users] Using ST_intersection on Polygons returns multiple types
Paul Ramsey pramsey at opengeo.org
Wed Mar 7 10:08:31 PST 2012
ST_Intersection is perhaps a bit more complete than most users would
like. If two polygons share a boundary what is their intersection? Not
a polygon, but that linear, shared boundary: a line. Similar for
touching at a point.
Anyhow, probably a cleaner approach would be an extra optional
argument to ST_Intersection allowing users to specify the
dimensionally of the return, but in the meanwhile you can go to
ST_CollectionExtract and use that to pull out just the polygons.
P.
On Wed, Mar 7, 2012 at 9:58 AM, Rebecca Clarke <rebecca at clarke.net.nz> wrote:
> Hi there
> I have 2000 polygons in table A and I want to show only the polygons that
> intersect with the bounding box specified in table B  . So I do this:
>     SELECT the_geom
> FROM  A
> WHERE st_intersects(the_geom, (select the_geom from B))
> AND ST_GeometryType(the_geom) = 'ST_Polygon'
> This query returns all the intersecting polygons. When I run st_geometrytype
> they are all St_Polygon.
> Some of the polygons are large and exceed the boxes boundary so I use this
> query to trim them:
>     SELECT st_intersection(the_geom, (select the_geom from B)) as the_geom
> FROM  A
> The problem I'm having is that when I use the st_intersection, instead of
> returning just St_Polygon's, it's returning other types as well:
> ST_LineString
> ST_MultiLineString
> ST_MultiPolygon
> ST_Polygon
> I need to output the results to a SHP file and this is preventing me from
> doing so seeing there is more than one Geom Type.
> Any ideas how I can keep the results of the st_intersection as just
> St_Polygons? Am I doing something wrong?
> Regards
> Rebecca
> postgis-users mailing list
