[postgis-users] PostGIS 2.0.0beta3
Sandro Santilli strk at keybit.net
Wed Mar 14 13:46:08 PDT 2012
On Wed, Mar 14, 2012 at 03:41:52PM -0500, Andy Colson wrote:
> I followed the pg_upgrade instructions.
> 1) run pg91/bin/inidb
> 2) install extensions (in this case postgis 2.0)
> 3) stop all versions of pg
> 4) run: pg91/bin/pg_upgrade (with paths to old and new)
Uhm, I guess by "extensions" they mean _real_ extensions,
and assuming the dump would only contain _real_ extensions.
PostGIS 1.5 wasn't an extension so won't work.
> It complained it could not load postgis-1.5 in the newdb, which is
> correct, because I installed postgis-2.0.
That would not necessarely be a problem.
The problem will be restoring old pl/pgsql functions, which doesn't
even give you an error message I guess.
> I'm now attempting backup pg 9.0 postgis 1.5, and restore it to my
> new pg 9.1 postgis 2.0.
Make sure you follow the "Hard upgrade" procedure described
on the PostGIS manual.
Should happily bring you from 9.0/1.5 to 9.1/2.0.
And we're all very interested in any problem with that.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
