[postgis-users] change of polygon area due to st_transform
Birgit Laggner birgit.laggner at vti.bund.de
Thu Mar 15 04:41:39 PDT 2012
Dear list,
using the function st_transform() in order to transform polygon
geometries from srid 31468 to 31467, the polygon area of the transformed
geometry is changed compared to the original polygon area . The
percentual change is around 0.1% but with big geometries, it results in
changes of several hectares, which surprises and concerns me a little bit.
Can anybody tell me if this is expected behaviour?
I attach an geometry example at the end of the e-mail.
Thanks and regards,
Birgit.
select st_area(st_geomfromtext('POLYGON((4562878 5410125.5,4562864.5
5410124,4562855 5410115,4562852.5 5410115,4562813 5410144,4562768.5
5410147,4562728 5410147,4562718 5410157,4562688 5410157,4562678
5410167,4562638 5410167,4562628 5410177,4562608 5410177,4562598
5410187,4562579 5410187,4562569.5 5410192,4562539.5 5410192,4562529.5
5410202,4562499.5 5410202,4562479.5 5410182,4562449.5 5410182,4562429.5
5410202,4562409.5 5410202,4562399.5 5410212,4562369.5 5410212,4562349.5
5410232,4562339.5 5410232,4562329.5 5410242,4562319.5 5410242,4562299.5
5410262,4562289.5 5410252,4562289.5 5410242,4562279.5 5410242,4562269.5
5410232,4562259.5 5410242,4562259.5 5410252,4562249.5 5410262,4562229.5
5410262,4562219.5 5410272,4562219.5 5410292,4562209.5 5410302,4562199.5
5410302,4562199.5 5410312,4562189.5 5410322,4562179.5 5410322,4562169.5
5410332,4562169.5 5410342,4562129.5 5410382,4562109.5 5410382,4562099.5
5410392,4562109.5 5410402,4562099.5 5410412,4562079.5 5410412,4562069.5
5410402,4562059.5 5410402,4562049.5 5410412,4562049.5 5410432,4562039.5
5410442,4562029.5 5410442,4562019.5 5410452,4561939.5 5410452,4561929.5
5410462,4561909.5 5410462,4561899.5 5410472,4561829.5 5410472,4561819.5
5410462,4561809.5 5410462,4561799.5 5410472,4561779.5 5410472,4561739.5
5410432,4561739.5 5410422,4561729.5 5410412,4561729.5 5410372,4561719.5
5410361,4561719.5 5410351,4561709.5 5410341,4561709.5 5410331,4561699.5
5410321,4561699.5 5410311,4561679.5 5410291,4561659.5 5410291,4561639.5
5410271,4561639.5 5410261,4561579.5 5410201,4561569.5 5410201,4561589.5
5410221,4561569.5 5410241,4561619.5 5410291,4561619.5 5410311,4561639.5
5410331,4561639.5 5410361,4561649.5 5410371,4561649.5 5410381,4561629.5
5410401,4561619.5 5410391,4561629.5 5410381,4561609.5 5410381,4561609.5
5410401,4561599.5 5410411,4561589.5 5410411,4561579.5 5410401,4561559.5
5410401,4561549.5 5410411,4561529.5 5410411,4561479.5 5410361,4561479.5
5410351,4561419.5 5410291,4561419.5 5410281,4561409.5 5410281,4561379.5
5410251,4561320.5 5410201,4561378.5 5410101.5,4561378.5
5410088,4561365.5 5410074.5,4561191 5409940.5,4561176.5 5409934,4561101
5409881,4561060.5 5409858,4560971.5 5409821.5,4560965.5
5409812.5,4560965 5409802.5,4560969.5 5409787,4560974 5409774.5,4560988
5409746,4560999 5409715,4561008 5409698.5,4561012.5 5409685.5,4561012
5409679.5,4561007.5 5409671.5,4560999 5409662.5,4560956.5
5409647,4560939 5409643.5,4560929 5409645,4560918 5409650,4560876
5409692,4560886 5409668,4560890.5 5409648,4560888 5409637,4560885.5
5409632.5,4560870.5 5409630,4560854.5 5409624,4560809
5409611.5,4560772.5 5409597,4560760 5409598.5,4560756
5409600.5,4560711.5 5409663,4560734.5 5409603.5,4560738 5409597,4560741
5409578,4560740.5 5409569.5,4560738 5409563.5,4560732.5
5409556.5,4560715.5 5409541,4560709.5 5409537.5,4560710
5409531.5,4560703 5409518,4560698.5 5409504.5,4560702 5409495,4560708
5409489.5,4560717 5409487.5,4560724 5409493.5,4560735.5
5409482.5,4560734 5409473.5,4560725 5409472,4560722 5409469,4560725.5
5409464.5,4560728 5409456.5,4560739.5 5409456,4560740.5
5409443,4560731.5 5409435.5,4560738 5409415,4560746 5409415,4560751.5
5409411,4560742 5409370.5,4560741 5409361.5,4560742 5409343.5,4560740
5409335,4560731.5 5409329,4560713 5409320.5,4560680 5409309.5,4560659.5
5409301,4560646 5409296.5,4560628 5409298,4560614.5 5409305,4560576
5409305.5,4560565 5409302.5,4560534 5409284,4560504 5409276.5,4560469
5409273.5,4560420 5409272,4560397 5409276,4560378.5 5409277,4560361.5
5409275,4560351.5 5409271.5,4560327 5409258.5,4560317 5409254.5,4560302
5409251,4560209.5 5409246.5,4560186 5409243,4560154.5 5409232.5,4560136
5409224.5,4560117.5 5409220,4560100.5 5409224,4560092.5 5409233,4560094
5409239,4560102.5 5409245,4560161 5409268,4560176 5409270.5,4560188
5409270.5,4560200 5409276,4560211 5409275,4560219 5409282.5,4560251
5409290.5,4560336.5 5409301,4560340.5 5409299,4560362.5
5409304,4560371.5 5409304.5,4560388 5409310.5,4560404.5
5409311.5,4560435 5409318,4560470.5 5409323.5,4560478.5 5409317,4560486
5409314.5,4560500.5 5409315,4560508 5409319.5,4560511
5409325.5,4560520.5 5409330,4560532 5409327,4560545.5
5409325.5,4560553.5 5409329,4560553.5 5409334.5,4560570
5409349.5,4560577.5 5409353.5,4560611.5 5409364.5,4560618
5409370,4560618.5 5409376,4560615.5 5409382.5,4560609
5409386.5,4560600.5 5409389,4560593.5 5409394,4560586 5409402.5,4560576
5409408.5,4560570.5 5409415,4560561.5 5409418.5,4560549
5409413.5,4560546.5 5409414.5,4560524 5409405,4560513.5
5409412.5,4560494 5409419.5,4560470 5409434,4560462 5409435,4560448
5409429,4560447 5409425,4560445.5 5409424,4560441.5 5409431.5,4560438.5
5409431,4560420 5409461.5,4560413 5409459.5,4560409 5409450,4560390
5409455.5,4560373.5 5409450,4560368 5409449.5,4560362.5
5409451.5,4560357 5409457,4560336.5 5409493.5,4560314.5 5409540,4560309
5409546.5,4560303.5 5409548.5,4560295.5 5409549,4560290.5
5409548,4560288 5409549.5,4560289 5409564.5,4560282 5409577,4560283
5409581.5,4560249.5 5409553.5,4560195.5 5409517.5,4560189
5409518.5,4560177.5 5409510.5,4560119.5 5409483.5,4560089.5
5409472,4560071.5 5409461.5,4560028.5 5409439.5,4560016.5
5409425.5,4560006 5409415.5,4559990 5409410,4559984.5 5409412,4559981.5
5409415.5,4559974 5409412,4559966 5409415.5,4559961 5409415.5,4559940
5409405.5,4559934.5 5409401,4559924 5409402,4559913 5409399,4559878
5409375.5,4559859.5 5409369.5,4559846 5409368,4559826 5409362.5,4559823
5409355.5,4559747 5409341,4559709 5409330,4559708 5409326,4559705
5409322.5,4559664 5409317.5,4559614.5 5409316,4559594 5409318,4559560
5409314,4559546.5 5409315,4559527 5409313.5,4559495 5409309.5,4559465
5409310.5,4559451 5409312.5,4559440.5 5409300,4559432 5409301.5,4559424
5409310,4559386 5409315,4559358.5 5409314.5,4559354 5409311.5,4559327.5
5409313.5,4559325.5 5409316.5,4559243.5 5409323,4559227.5
5409322.5,4559203.5 5409330.5,4559195.5 5409328,4559188.5
5409331,4559177 5409331.5,4559155.5 5409327,4559133.5
5409333.5,4559114.5 5409348.5,4559092 5409354.5,4559069.5
5409358,4559045 5409356,4558966 5409374.5,4558944 5409378.5,4558917.5
5409381,4558909.5 5409386.5,4558905 5409383,4558904.5 5409384.5,4558909
5409390,4558866 5409414,4558856.5 5409413,4558851 5409416.5,4558846
5409414.5,4558829.5 5409418,4558809.5 5409415.5,4558790.5
5409429,4558781.5 5409433,4558778.5 5409431,4558776.5
5409427.5,4558757.5 5409432.5,4558758 5409442,4558755.5
5409443,4558745.5 5409442,4558731 5409446,4558721.5 5409444,4558694
5409452.5,4558687.5 5409460.5,4558673 5409460.5,4558666
5409455.5,4558640.5 5409442,4558622.5 5409427.5,4558586.5
5409392,4558569.5 5409387,4558563 5409383,4558559 5409387,4558552.5
5409387.5,4558541 5409394,4558543 5409398.5,4558552.5
5409402.5,4558546.5 5409407,4558532 5409403.5,4558528 5409407,4558535
5409429,4558547.5 5409441,4558554 5409458.5,4558560.5 5409495,4558559.5
5409522,4558516 5409540.5,4558496 5409558,4558490.5 5409558.5,4558416
5409606,4558348.5 5409645.5,4558316 5409675.5,4558284.5
5409695.5,4558258.5 5409702.5,4558246.5 5409715,4558226.5
5409739.5,4558188 5409776.5,4558130.5 5409821,4558105.5
5409836,4558086.5 5409831.5,4558074.5 5409835.5,4558061 5409850,4558057
5409874.5,4558046 5409884.5,4558042 5409893.5,4557990 5409938,4557968
5409949.5,4558025 5409896,4558029 5409875.5,4558008 5409858,4558004
5409858.5,4557973.5 5409819.5,4557969.5 5409807.5,4557956.5
5409786.5,4557941.5 5409791.5,4557930.5 5409809,4557889.5
5409865,4557843.5 5409924.5,4557774.5 5409988,4557771 5409994,4557782
5410056.5,4557793.5 5410082.5,4557808 5410085,4557812.5
5410090,4557809.5 5410098.5,4557786.5 5410111.5,4557772
5410077.5,4557759.5 5410075.5,4557746 5410078.5,4557733 5410085,4557735
5410094.5,4557749 5410114,4557758.5 5410122,4557770 5410115,4557775.5
5410122,4557781 5410125,4557778.5 5410129,4557765.5 5410135,4557761
5410130.5,4557733.5 5410146.5,4557728.5 5410152.5,4557737.5
5410176,4557736 5410184,4557708.5 5410216.5,4557710.5
5410222.5,4557704.5 5410230,4557699 5410235,4557682.5 5410237,4557677
5410235,4557651.5 5410218.5,4557634.5 5410222.5,4557618 5410219,4557607
5410211.5,4557595 5410211,4557598.5 5410214,4557598.5 5410225,4557605.5
5410226.5,4557631 5410253.5,4557652.5 5410267.5,4557661.5
5410285,4557657.5 5410310,4557651 5410320.5,4557639.5 5410329.5,4557585
5410395,4557555.5 5410426.5,4557527.5 5410453,4557508.5
5410463,4557476.5 5410487.5,4557446 5410506.5,4557425.5 5410521,4557405
5410532.5,4557370 5410560,4557365 5410558.5,4557343 5410541.5,4557359
5410559.5,4557358.5 5410568,4557350 5410579,4557305.5 5410615,4557285.5
5410634,4557264 5410649,4557230.5 5410667.5,4557218 5410667.5,4557210
5410670.5,4557196.5 5410669,4557187.5 5410661.5,4557171.5
5410644.5,4557149 5410637.5,4557130.5 5410628.5,4557119.5
5410606.5,4557114.5 5410593,4557117 5410561,4557114 5410524,4557107.5
5410500.5,4557099 5410499,4557096.5 5410475,4557098 5410461,4557104.5
5410432.5,4557117 5410420.5,4557120.5 5410410.5,4557010
5410491,4557015.5 5410511.5,4557016 5410529,4557004 5410546.5,4556998.5
5410559,4556995 5410573,4556997 5410591,4557005.5 5410608,4557008.5
5410624.5,4557008.5 5410652,4557004 5410709.5,4556998
5410723.5,4557000.5 5410762,4556995 5410786.5,4556998 5410809,4556995
5410821.5,4556956.5 5410867,4556940.5 5410893,4556875 5410953,4556767.5
5411072,4556784.725 5411085.737,4556774.564 5411092.394,4556703.412
5411170.442,4556683.282 5411189.629,4556665.423 5411208.811,4556605.314
5411288.567,4556599.959 5411294.057,4556647.842 5411359.72,4556995.974
5411003.444,4557197.748 5410801.332,4557392.967 5410603.397,4557541.06
5410501.049,4557764.003 5410347.387,4557947.478 5410250.481,4558154.397
5410140.961,4558220.546 5410106.646,4558376.668 5410037.51,4558680.651
5409903.06,4559121.415 5409819.081,4559165.688 5409816.129,4559373.626
5409802.159,4559621.729 5409784.98,4559630.705 5409786.091,4559978.004
5409829.769,4560200.677 5409855.981,4560227.326 5409864.282,4560391.847
5409915.533,4560587.746 5409975.333,4561020.622 5410199.564,4561387.331
5410407.445,4561403.673 5410420.025,4561683.803 5410635.716,4561755.313
5410760.667,4561874.666 5410974.179,4562013.359 5411265.561,4562217.2
5411541.675,4562414.933 5411709.379,4562221.271 5412402.845,4562223.323
5412402.94,4562331.501 5412408.029,4562494.84 5412415.824,4562444.198
5412636.97,4562260.207 5412859.642,4562229.446 5412873.408,4561964.907
5412988.885,4561974.557 5413037.134,4561975.186 5413039.816,4561977.772
5413053.209,4562012.086 5413230.933,4562039.061 5413363.264,4562377.269
5413606.804,4562053.618 5414016.114,4562052.294 5414017.794,4561918.281
5414049.585,4561789.923 5414080.142,4561711.737 5414352.528,4561706.707
5414370.507,4561701.923 5414385.701,4561649.506 5414562.886,4561629.344
5414631.607,4561611.337 5414691.908,4561585.573 5414778.189,4561616.264
5414821.65,4561624.794 5414833.706,4561632 5414826.5,4561652
5414826.5,4561662 5414816.5,4561672 5414826.5,4561682 5414826.5,4561692
5414816.5,4561702 5414826.5,4561702 5414866.5,4561722 5414886.5,4561722
5414906.5,4561779 5414962.5,4561830 5414895.5,4561847 5414863,4562027
5414683,4562027 5414673,4562087 5414613,4562097 5414613,4562237
5414473,4562247 5414473,4562307 5414413,4562317 5414413,4562367
5414363,4562377 5414363,4562417 5414323,4562427 5414323,4562467
5414283,4562477 5414283,4562507 5414253,4562517 5414253,4562547
5414223,4562557 5414223,4562587 5414193,4562597 5414193,4562627
5414163,4562637 5414163,4562657 5414143,4562667 5414143,4562677
5414133,4562687 5414133,4562697 5414123,4562707 5414123,4562717
5414113,4562727 5414113,4562737 5414123,4562677 5414183,4562667
5414183,4562637 5414213,4562627 5414213,4562597 5414243,4562587
5414243,4562557 5414273,4562547 5414273,4562507 5414313,4562497
5414313,4562447 5414363,4562437 5414363,4562377 5414423,4562367
5414423,4562257 5414533,4562247 5414533,4562047 5414733,4562047
5414743,4561947 5414843,4561947 5414863,4561957 5414863,4561967
5414873,4561957 5414883,4561916 5414884,4561913.5 5414897,4561897
5414913,4561871.5 5414944.5,4561867 5414953,4561860.5 5414956.5,4561857
5414963,4561838 5414983.5,4561827 5414993,4561817 5414993,4561817
5415013,4561827 5415023,4561827 5415089.134,4561837 5415093,4561837
5415003,4561848.5 5414992.5,4561847 5414983,4561883.5
5414946.5,4561889.5 5414942.5,4561899 5414927.5,4561915
5414909.5,4561917 5414903,4561927 5414893,4561937 5414903,4561937
5414923,4561927 5414933,4561937 5414943,4561947 5414943,4561967
5414963,4561977 5414953,4561997 5414973,4561997 5414983,4562027
5414983,4562047 5415003,4562037 5415013,4562047 5415023,4562077
5415023,4562077 5415003,4562087 5414993,4562077 5414983,4562097
5414963,4562107 5414973,4562107 5414903,4562097 5414893,4562097
5414873,4562087 5414863,4562087 5414853,4562077 5414853,4562067
5414843,4562077 5414833,4562087 5414833,4562097 5414823,4562107
5414833,4562107 5414863,4562117 5414873,4562117 5414883,4562127
5414893,4562127 5415013,4562147 5415013,4562157 5415023,4562167
5415023,4562187 5415043,4562187 5415053,4562197 5415063,4562257
5415063,4562267 5415053,4562277 5415053,4562297 5415033,4562327
5415033,4562337 5415023,4562367 5415023,4562377 5415013,4562387
5415023,4562407 5415023,4562417 5415013,4562427 5415013,4562427
5415003,4562447 5414983,4562447 5414973,4562457 5414963,4562477
5414963,4562487 5414953,4562557 5414953,4562567 5414963,4562597
5414963,4562607 5414973,4562617 5414973,4562637 5414993,4562637
5415003,4562657 5415023,4562657 5415043,4562667 5415053,4562667
5415063,4562677 5415073,4562677 5415083,4562687 5415093,4562697
5415093,4562707 5415103,4562717 5415103,4562727 5415113,4562737
5415113,4562757 5415133,4562767 5415123,4562807 5415123,4562817
5415133,4562837 5415113,4562857 5415113,4562867 5415103,4562877
5415103,4562897 5415083,4562907 5415083,4562917 5415073,4562927
5415073,4562977 5415023,4562977 5415013,4563037 5414953,4563037
5414933,4562997 5414893,4563007 5414883,4563047 5414923,4563047
5414913,4563057 5414903,4563087 5414873,4563097 5414873,4563117
5414853,4563117 5414843,4563137 5414823,4563137 5414813,4563157
5414793,4563157 5414783,4563177 5414763,4563177 5414743,4563197
5414723,4563207 5414723,4563207 5414713,4563217 5414703,4563217
5414693,4563237 5414673,4563237 5414663,4563257 5414643,4563257
5414623,4563267 5414613,4563267 5414593,4563257 5414583,4563257
5414553,4563267 5414543,4563267 5414523,4563277 5414513,4563277
5414473,4563257 5414473,4563247 5414483,4563237 5414483,4563227
5414473,4563217 5414473,4563207 5414463,4563197 5414463,4563157
5414423,4563157 5414413,4563147 5414403,4563147 5414383,4563157
5414373,4563157 5414343,4563167 5414333,4563167 5414323,4563177
5414313,4563187 5414313,4563197 5414303,4563217 5414303,4563227
5414293,4563257 5414293,4563267 5414283,4563267 5414263,4563277
5414253,4563297 5414253,4563297 5414243,4563307 5414233,4563317
5414233,4563327 5414223,4563337 5414233,4563347 5414223,4563357
5414223,4563367 5414213,4563407 5414213,4563417 5414203,4563447
5414203,4563457 5414193,4563467 5414203,4563527 5414203,4563537
5414213,4563577 5414213,4563597 5414193,4563677 5414193,4563697
5414213,4563717 5414193,4563837 5414193,4563867 5414223,4563867
5414233,4563857 5414243,4563857 5414273,4563867 5414263,4563887
5414283,4563887 5414293,4563917 5414323,4564007 5414323,4564017
5414333,4564077 5414333,4564087 5414323,4564127 5414323,4564137
5414333,4564147 5414333,4564157 5414323,4564167 5414323,4564177
5414313,4564207 5414313,4564217 5414303,4564237 5414303,4564247
5414313,4564247 5414353,4564257 5414353,4564267 5414363,4564307
5414363,4564317 5414373,4564347 5414373,4564357 5414383,4564387
5414383,4564397 5414393,4564407 5414393,4564417 5414383,4564467
5414383,4564477 5414393,4564497 5414393,4564507 5414403,4564527
5414403,4564537 5414413,4564587 5414413,4564597 5414423,4564607
5414413,4564617 5414423,4564707 5414423,4564717 5414433,4564817
5414433,4564837 5414453,4564837 5414463,4564847 5414453,4564857
5414453,4564867 5414443,4564877 5414443,4564887 5414433,4564907
5414433,4564917 5414423,4564947 5414423,4564957 5414413,4564967
5414413,4564987 5414393,4564997 5414393,4565007 5414383,4565017
5414383,4565027 5414373,4565027 5414333,4565037 5414323,4565037
5414293,4565047 5414283,4565057 5414293,4565057 5414333,4565067
5414343,4565077 5414343,4565087 5414333,4565087 5414323,4565097
5414313,4565097 5414263,4565107 5414253,4565107 5414233,4565117
5414223,4565117 5414213,4565137 5414193,4565197 5414193,4565207
5414198,4565287 5414198,4565297 5414188,4565317 5414208,4565327
5414198,4565337 5414198,4565347 5414188,4565377 5414188,4565407
5414158,4565417 5414158,4565427 5414148,4565437 5414148,4565447
5414138,4565467 5414138,4565477 5414128,4565487 5414128,4565497
5414118,4565507 5414118,4565517 5414108,4565527 5414108,4565537
5414098,4565577 5414098,4565587 5414088,4565607 5414088,4565617
5414078,4565627 5414078,4565637 5414068,4565647 5414068,4565647
5414048,4565657 5414038,4565677 5414038,4565697 5414018,4565717
5414018,4565737 5413998,4565757 5413998,4565767 5413988,4565787
5413988,4565797 5413978,4565807 5413978,4565827 5413958,4565837
5413958,4565837 5413948,4565847 5413938,4565857 5413938,4565857
5413918,4565847 5413928,4565837 5413928,4565827 5413918,4565837
5413908,4565847 5413908,4565857 5413918,4565857 5413908,4565867
5413898,4565857 5413888,4565867 5413878,4565867 5413868,4565877
5413858,4565867 5413848,4565867 5413838,4565857 5413828,4565857
5413618,4565827 5413588,4565827 5413578,4565817 5413568,4565817
5413428,4565827 5413418,4565837 5413418,4565867 5413388,4565877
5413388,4565887 5413378,4565917 5413378,4565927 5413388,4565957
5413388,4565967 5413398,4566017 5413398,4566037 5413378,4566067
5413378,4566077 5413388,4566087 5413388,4566097 5413398,4566167
5413398,4566187 5413418,4566367 5413418,4566387 5413438,4566597
5413438,4566617 5413418,4566677 5413418,4566687 5413408,4566697
5413408,4566707 5413398,4566737 5413398,4566757 5413378,4566767
5413378,4566777 5413368,4566797 5413368,4566807 5413358,4566867
5413358,4566877 5413348,4566887 5413348,4566897 5413338,4566917
5413338,4566927 5413328,4566947 5413328,4566957 5413318,4566977
5413318,4566997 5413298,4567027 5413298,4567047 5413278,4567087
5413278,4567107 5413298,4567107 5413308,4567117 5413318,4567117
5413328,4567127 5413338,4567127 5413358,4567137 5413368,4567147
5413368,4567187 5413408,4567197 5413408,4567217 5413428,4567237
5413428,4567257 5413448,4567257 5413458,4567267 5413468,4567397
5413468,4567407 5413458,4567427 5413458,4567437 5413448,4567447
5413448,4567457 5413438,4567487 5413438,4567507 5413458,4567507
5413468,4567517 5413478,4567517 5413498,4567527 5413508,4567527
5413528,4567517 5413538,4567517 5413548,4567567 5413548,4567577
5413558,4567577 5413568,4567587 5413578,4567587 5413588,4567597
5413578,4567607 5413578,4567617 5413568,4567627 5413578,4567627
5413588,4567637 5413588,4567647 5413598,4567657 5413588,4567657
5413558,4567665.243 5413533.64,4567646.634 5413523.581,4567629.031
5413510.504,4567616.347 5413486.285,4567610.424 5413460.792,4567610.167
5413440.706,4567585.446 5413380.965,4567577.352 5413347.584,4567563.914
5413333.141,4567546.364 5413319.339,4567520.952 5413307.638,4567521.226
5413312.848,4567511.536 5413311.568,4567493.162 5413311.934,4567475.886
5413317.145,4567465.374 5413316.962,4567437.037 5413325.737,4567417.383
5413336.615,4567362.171 5413353.343,4567348.277 5413359.285,4567326.064
5413357.914,4567314.272 5413353.252,4567297.91 5413337.712,4567258.329
5413291.093,4567208.785 5413210.56,4567166.918 5413136.792,4567173.774
5413130.393,4567154.395 5413098.49,4567141.506 5413071.799,4567137.484
5413058.087,4567135.29 5413038.342,4567135.199 5413014.393,4567145.345
5412965.031,4567177.522 5412836.234,4567186.95 5412787.946,4567180.233
5412787.133,4567193.282 5412731.034,4567216.318 5412641.73,4567222.629
5412606.703,4567252.689 5412603.49,4567251.689 5412596.493,4567252.053
5412560.597,4567263.866 5412545.512,4567264.048 5412538.242,4567274.135
5412517.614,4567287.312 5412504.8,4567294.764 5412492.987,4567283.496
5412477.356,4567302.034 5412450.094,4567306.032 5412433.646,4567323.935
5412426.103,4567343.564 5412414.289,4567374.461 5412401.749,4567425.714
5412350.495,4567429.258 5412343.68,4567453.249 5412325.868,4567475.332
5412298.697,4567480.603 5412279.704,4567494.506 5412261.166,4567508.137
5412249.897,4567525.767 5412222.271,4567589.197 5412139.03,4567625.82
5412098.318,4567667.44 5412063.786,4567689.432 5412048.337,4567729.144
5412025.346,4567869.273 5411951.556,4567881.814 5411958.008,4567909.894
5411946.103,4567918.163 5411945.921,4567922.798 5411947.103,4567919.89
5411942.014,4567915.891 5411929.655,4567965.873 5411876.312,4567986.956
5411851.412,4568014.893 5411809.125,4568048.485 5411767.046,4568076.193
5411745.226,4568061.335 5411712.827,4568190.541 5411630.705,4568354.239
5411521.755,4568557.082 5411415.817,4568614.568 5411392.822,4568747.607
5411342.454,4568906.104 5411286.337,4568920.338 5411259.51,4568994.249
5411224.471,4569126.466 5411149.739,4569170.265 5411126.745,4569288.796
5411067.89,4569495.197 5410978.103,4569450.304 5410864.773,4569482.331
5410827.818,4569484.167 5410831.215,4569485.664 5410828.327,4569523.5
5410904,4569590.418 5411025.454,4569612.085 5410933.483,4569647.672
5410857.93,4569733.175 5410784.301,4569742.563 5410774.371,4569749.319
5410770.537,4569782.627 5410742.137,4569813.253 5410734.248,4569822.5
5410729,4569773.628 5410638.736,4569808.558 5410621.11,4569843.219
5410686.432,4569861.397 5410725.73,4569878.29 5410722.235,4570196.251
5410558.456,4570356.391 5410473.87,4570635.941 5410322.337,4570606.837
5410267.575,4570630.508 5410258.537,4570655.5 5410309.5,4570784
5410236,4570775.5 5410216.5,4570779.5 5410204,4570768.658
5410177.979,4570874.375 5410084.249,4570957.523 5410003.378,4570992.832
5409964.652,4571060.035 5409883.782,4571094.205 5409859.862,4571063.452
5409903.145,4571019.03 5409958.957,4570984.859 5409997.683,4570941.577
5410042.105,4570776.419 5410190.177,4570793.504 5410215.235,4570802.617
5410211.818,4570819.702 5410201.567,4570842.482 5410181.065,4570837.926
5410174.231,4570855.012 5410158.284,4570864.123 5410160.563,4570883.487
5410171.953,4570932.464 5410142.338,4570951.267 5410147.76,4570956.132
5410145.083,4571131.529 5409917.548,4571148.327 5409884.502,4571175.154
5409814.972,4571184.69 5409848.585,4571683.5 5409201.5,4571802
5409078.5,4571841 5409022,4571875.5 5408901,4571904.5 5408835.5,4571951
5408756,4571971 5408692.5,4571995.5 5408405,4572004.5 5408250,4572011.5
5408176.5,4572045 5408090,4572107 5408022,4572247 5407949.5,4572326.5
5407923.5,4572436.5 5407865.5,4572529 5407792,4572706.5 5407665,4572870
5407588,4573030.5 5407478.5,4573128.5 5407364,4573208 5407292,4573212.5
5407241,4573274.5 5407200.5,4573352.5 5407180.5,4573436.5
5407118.5,4573582.5 5407039,4573871.5 5406920.5,4573962.5
5406904.5,4574082.5 5406907.5,4574253 5406942,4574347
5406920.5,4574475.5 5406861,4574547.5 5406820.5,4574602.5
5406777,4574743 5406628.5,4574805 5406582,4574894.5 5406527,4575182
5406420,4575241.5 5406385.5,4575335.5 5406297,4575510 5406121,4575579.5
5406025.5,4575623 5405970.5,4575735.5 5405853.5,4575790.5
5405810,4576007 5405779.5,4576019 5405738,4576102.5 5405700,4576175
5405723.5,4576212.5 5405717.5,4576326.5 5405674,4576524.5
5405631,4576627 5405568.5,4576744 5405487.5,4576854 5405428.5,4576933.5
5405409.5,4577111.5 5405385,4577271.5 5405378,4577316.5
5405392.5,4577370 5405405.5,4577411.624 5405410.703,4577424.176
5405412.272,4577438 5405414,4577487.859 5405414.719,4577503.352
5405414.943,4577521.471 5405415.204,4577523.839 5405415.238,4577524.287
5405415.245,4577542 5405415.5,4577557.5 5405412.5,4577557.122
5405408.312,4577555.702 5405392.567,4577551.5 5405346,4577531.545
5405302.961,4577524.293 5405287.319,4577517.407 5405272.468,4577510.274
5405257.084,4577505.36 5405246.486,4577382.5 5404981.5,4577356.5
5404852,4577347.5 5404718,4577414.5 5404594,4577477.5 5404548.5,4577467
5404518,4577488 5404459.5,4577538 5404409.5,4577538 5404399.5,4577558
5404379.5,4577558 5404369.5,4577568 5404359.5,4577568 5404349.5,4577678
5404239.5,4577708 5404239.5,4577718 5404229.5,4577728 5404229.5,4577748
5404249.5,4577758 5404249.5,4577768 5404259.5,4577778 5404259.5,4577788
5404269.5,4577808 5404269.5,4577818 5404279.5,4577818 5404289.5,4577828
5404299.5,4577838 5404299.5,4577848 5404309.5,4577878 5404309.5,4577888
5404319.5,4577898 5404319.5,4577908 5404309.5,4577938 5404309.5,4577988
5404259.5,4577988 5404249.5,4577998 5404239.5,4578008 5404239.5,4578018
5404229.5,4578038 5404229.5,4578048 5404219.5,4578078 5404219.5,4578078
5404209.5,4578108 5404179.5,4578118 5404179.5,4578128 5404169.5,4578208
5404169.5,4578248 5404129.5,4578248 5404119.5,4578258 5404109.5,4578258
5404079.5,4578288 5404049.5,4578298 5404049.5,4578328 5404019.5,4578348
5404019.5,4578358 5404009.5,4578368 5403999.5,4578368 5403989.5,4578378
5403979.5,4578378 5403959.5,4578398 5403939.5,4578408 5403939.5,4578448
5403899.5,4578468 5403899.5,4578558 5403809.5,4578568 5403809.5,4578618
5403759.5,4578618 5403749.5,4578628 5403739.5,4578638 5403739.5,4578678
5403699.5,4578688 5403699.5,4578698 5403689.5,4578708 5403689.5,4578718
5403679.5,4578738 5403679.5,4578758 5403659.5,4578758 5403649.5,4578768
5403639.5,4578768 5403609.5,4578778 5403599.5,4578778 5403589.5,4578788
5403579.5,4578788 5403569.5,4578798 5403559.5,4578808 5403559.5,4578828
5403539.5,4578838 5403539.5,4578868 5403509.5,4578878 5403509.5,4578878
5403489.5,4578868 5403479.5,4578868 5403459.5,4578848 5403459.5,4578838
5403449.5,4578818 5403449.5,4578808 5403439.5,4578788 5403439.5,4578778
5403429.5,4578728 5403429.5,4578718 5403439.5,4578708 5403439.5,4578698
5403449.5,4578648 5403449.5,4578638 5403439.5,4578608 5403439.5,4578578
5403409.5,4578578 5403399.5,4578608 5403369.5,4578638 5403369.5,4578648
5403359.5,4578658 5403359.5,4578658 5403279.5,4578648 5403289.5,4578618
5403289.5,4578608 5403299.5,4578598 5403289.5,4578588 5403289.5,4578568
5403269.5,4578568 5403239.5,4578578 5403229.5,4578578 5403219.5,4578618
5403179.5,4578618 5403169.5,4578628 5403159.5,4578628 5403119.5,4578678
5403069.5,4578678 5403059.5,4578688 5403049.5,4578708 5403049.5,4578708
5403039.5,4578718 5403029.5,4578738 5403029.5,4578738 5403019.5,4578758
5402999.5,4578758 5402989.5,4578738 5402969.5,4578738 5402959.5,4578728
5402949.5,4578738 5402939.5,4578738 5402929.5,4578778 5402889.5,4578778
5402879.5,4578798 5402859.5,4578798 5402849.5,4578808 5402839.5,4578808
5402829.5,4578818 5402819.5,4578818 5402789.5,4578828 5402779.5,4578828
5402769.5,4578838 5402759.5,4578838 5402749.5,4578848 5402739.5,4578848
5402729.5,4578858 5402719.5,4578858 5402699.5,4578868 5402689.5,4578868
5402649.5,4578878 5402639.5,4578878 5402629.5,4578898 5402609.5,4578898
5402599.5,4578918 5402579.5,4578918 5402569.5,4578928 5402559.5,4578928
5402539.5,4578908 5402519.5,4578908 5402509.5,4578888 5402489.5,4578888
5402479.5,4578858 5402449.5,4578858 5402419.5,4578848 5402409.5,4578848
5402389.5,4578838 5402379.5,4578838 5402369.5,4578798 5402329.5,4578798
5402309.5,4578778 5402289.5,4578778 5402279.5,4578768 5402269.5,4578768
5402259.5,4578758 5402249.5,4578758 5402239.5,4578768 5402229.5,4578768
5402159.5,4578818 5402109.5,4578818 5402059.5,4578808 5402049.5,4578808
5402039.5,4578798 5402029.5,4578798 5402019.5,4578788 5402009.5,4578788
5401999.5,4578748 5401959.5,4578748 5401909.5,4578768 5401889.5,4578768
5401869.5,4578778 5401859.5,4578778 5401829.5,4578788 5401819.5,4578788
5401809.5,4578778 5401799.5,4578778 5401789.5,4578768 5401779.5,4578778
5401769.5,4578778 5401759.5,4578768 5401749.5,4578778 5401739.5,4578798
5401739.5,4578798 5401729.5,4578808 5401719.5,4578818 5401719.5,4578828
5401709.5,4578838 5401709.5,4578848 5401699.5,4578858 5401699.5,4578878
5401679.5,4578888 5401679.5,4578918 5401649.5,4578928 5401649.5,4578928
5401639.5,4579008 5401559.5,4579008 5401539.5,4579018 5401529.5,4579018
5401489.5,4579008 5401479.5,4579028 5401459.5,4579028 5401449.5,4579038
5401439.5,4579038 5401409.5,4579048 5401399.5,4579048 5401379.5,4579058
5401369.5,4579058 5401349.5,4579068 5401339.5,4579068 5401269.5,4579058
5401259.5,4579058 5401229.5,4579068 5401219.5,4579058
5401209.5,4579053.5 5401198,4579053.5 5401178,4579073.5
5401158,4579073.5 5401138,4579103.5 5401108,4579093.5 5401098,4579093.5
5401088,4579103.5 5401078,4579093.5 5401068,4579093.5 5401058,4579073.5
5401038,4579083.5 5401028,4579083.5 5400998,4579093.5 5400988,4579093.5
5400978,4579093.5 5400928,4579083.5 5400918,4579083.5 5400908,4579073.5
5400898,4579073.5 5400838,4579083.5 5400828,4579083.5 5400788,4579093.5
5400778,4579093.5 5400768,4579103.5 5400758,4579103.5 5400748,4579093.5
5400738,4579093.5 5400728,4579083.5 5400718,4579083.5 5400688,4579073.5
5400678,4579073.5 5400608,4579083.5 5400598,4579083.5 5400508,4579073.5
5400498,4579073.5 5400428,4579083.5 5400418,4579083.5 5400398,4579093.5
5400388,4579093.5 5400368,4579103.5 5400358,4579103.5 5400348,4579113.5
5400338,4579113.5 5400308,4579133.5 5400288,4579133.5 5400278,4579153.5
5400258,4579153.5 5400228,4579163.5 5400218,4579163.5 5400198,4579183.5
5400178,4579183.5 5400168,4579193.5 5400158,4579193.5 5400118,4579203.5
5400108,4579203.5 5399978,4579183.5 5399958,4579183.5 5399948,4579193.5
5399938,4579173.5 5399938,4579163.5 5399928,4579163.5 5399918,4579153.5
5399908,4579153.5 5399838,4579163.5 5399828,4579163.5 5399818,4579103.5
5399758,4579103.5 5399748,4579073.5 5399718,4579073.5 5399708,4579063.5
5399698,4579053.5 5399698,4579013.5 5399658,4579013.5 5399628,4579003.5
5399618,4579003.5 5399598,4578983.5 5399578,4578973.5 5399578,4578963.5
5399568,4578903.5 5399568,4578893.5 5399558,4578863.5 5399558,4578853.5
5399568,4578843.5 5399568,4578803.5 5399608,4578793.5 5399608,4578783.5
5399598,4578793.5 5399588,4578793.5 5399578,4578783.5 5399578,4578753.5
5399608,4578733.5 5399608,4578723.5 5399618,4578693.5 5399618,4578683.5
5399608,4578673.5 5399608,4578653.5 5399588,4578643.5 5399588,4578633.5
5399578,4578633.5 5399568,4578623.5 5399558,4578623.5 5399548,4578603.5
5399528,4578603.5 5399498,4578593.5 5399498,4578573.5 5399478,4578573.5
5399438,4578583.5 5399428,4578583.5 5399398,4578593.5 5399388,4578593.5
5399368,4578613.5 5399348,4578613.5 5399338,4578633.5 5399318,4578643.5
5399328,4578653.5 5399328,4578663.5 5399338,4578683.5 5399338,4578703.5
5399318,4578733.5 5399318,4578743.5 5399308,4578753.5 5399308,4578763.5
5399298,4578773.5 5399298,4578773.5 5399288,4578793.5 5399268,4578803.5
5399268,4578823.5 5399248,4578833.5 5399248,4578863.5 5399218,4578883.5
5399218,4578893.5 5399208,4578923.5 5399208,4578953.5 5399178,4578953.5
5399168,4578943.5 5399158,4578943.5 5399148,4578933.5 5399138,4578937.5
5399126.5,4578947.5 5399126.5,4578957.5 5399116.5,4578967.5
5399116.5,4578977.5 5399106.5,4578987.5 5399106.5,4579007.5
5399086.5,4579017.5 5399086.5,4579037.5 5399066.5,4579047.5
5399066.5,4579057.5 5399056.5,4579067.5 5399056.5,4579087.5
5399036.5,4579097.5 5399036.5,4579117.5 5399016.5,4579127.5
5399016.5,4579167.5 5398976.5,4579157.5 5398966.5,4579167.5
5398956.5,4579177.5 5398966.5,4579167.5 5398976.5,4579177.5
5398976.5,4579197.5 5398956.5,4579207.5 5398956.5,4579237.5
5398926.5,4579237.5 5398916.5,4579247.5 5398906.5,4579227.5
5398886.5,4579227.5 5398876.5,4579237.5 5398866.5,4579247.5
5398876.5,4579267.5 5398876.5,4579277.5 5398886.5,4579297.5
5398866.5,4579297.5 5398856.5,4579347.5 5398806.5,4579347.5
5398796.5,4579377.5 5398766.5,4579387.5 5398766.5,4579407.5
5398746.5,4579417.5 5398746.5,4579457.5 5398706.5,4579457.5
5398696.5,4579487.5 5398666.5,4579517.5 5398666.5,4579537.5
5398646.5,4579547.5 5398646.5,4579587.5 5398606.5,4579597.5
5398606.5,4579607.5 5398596.5,4579617.5 5398596.5,4579617.5
5398586.5,4579627.5 5398576.5,4579627.5 5398566.5,4579637.5
5398556.5,4579647.5 5398556.5,4579657.5 5398546.5,4579667.5
5398546.5,4579677.5 5398536.5,4579687.5 5398536.5,4579697.5
5398526.5,4579707.5 5398526.5,4579717.5 5398516.5,4579727.5
5398516.5,4579737.5 5398506.5,4579737.5 5398496.5,4579757.5
5398476.5,4579767.5 5398486.5,4579777.5 5398486.5,4579787.5
5398476.5,4579807.5 5398476.5,4579817.5 5398466.5,4579827.5
5398466.5,4579892 5398402,4579995 5398344.5,4580019 5398356,4580023
5398363.5,4580025.5 5398360.5,4580016.5 5398338.5,4580059.5
5398297.5,4580100.5 5398270.5,4580142 5398250,4580170 5398231.5,4580234
5398202,4580237.5 5398208,4580229 5398217.5,4580265.5 5398229,4580290.5
5398208,4580328.5 5398160,4580347 5398133,4580345.5 5398118.5,4580331.5
5398108,4580309 5398107.5,4580283.5 5398120,4580244.5 5398142.5,4580233
5398147.5,4580209 5398123.5,4580209.5 5398116.5,4580249.5
5398061,4580277.5 5398033,4580296.5 5398023.5,4580310
5398027.5,4580318.5 5398039,4580313 5398053,4580313 5398063,4580325
5398074.5,4580343 5398079.5,4580356 5398073,4580367.5 5398060.5,4580370
5398043,4580380 5398032,4580403 5398027.5,4580417.5 5398019.5,4580424.5
5398007,4580426 5397994.5,4580432.5 5397993,4580446.5 5398026.5,4580461
5398041.5,4580506 5398058,4580518 5398052,4580534 5398048,4580580
5398030.5,4580589 5398029.5,4580601 5398035.5,4580605 5398046,4580612
5398056,4580619.5 5398060.5,4580635.5 5398051,4580642 5398014,4580653.5
5398009.5,4580661 5398011,4580674 5398010,4580695.5 5398002,4580734.5
5397980,4580756 5397974,4580797 5397967,4580827.5 5397921,4580842
5397915,4580862.5 5397918.5,4580892.5 5397933.5,4580914 5397941,4580943
5397945.5,4580982.5 5397945,4581012.5 5397927.5,4581048.5
5397900.5,4581074.5 5397892,4581093.5 5397892.5,4581106
5397884.5,4581113.5 5397826,4581109 5397813.5,4581088.5 5397808,4581078
5397801.5,4581076 5397789.5,4581089 5397772.5,4581115.5 5397753,4581127
5397741,4581124 5397712,4581143 5397716,4581163 5397713.5,4581172.5
5397698,4581162.5 5397617.5,4581152 5397561.5,4581143 5397539,4581172
5397561,4581217.5 5397577.5,4581291 5397565,4581319 5397547.5,4581342
5397558,4581358 5397561.5,4581472.5 5397480,4581517 5397360,4581567.5
5397247.5,4581577.5 5397237.5,4581597.5 5397237.5,4581607.5
5397227.5,4581607.5 5397187.5,4581617.5 5397177.5,4581607.5
5397167.5,4581607.5 5397147.5,4581617.5 5397137.5,4581617.5
5397107.5,4581627.5 5397097.5,4581637.5 5397107.5,4581647.5
5397107.5,4581667.5 5397087.5,4581667.5 5397077.5,4581677.5
5397067.5,4581667.5 5397067.5,4581657.5 5397057.5,4581667.5
5397047.5,4581657.5 5397037.5,4581667.5 5397027.5,4581677.5
5397027.5,4581687.5 5397037.5,4581707.5 5397017.5,4581707.5
5397007.5,4581727.5 5396987.5,4581727.5 5396977.5,4581737.5
5396967.5,4581737.5 5396957.5,4581747.5 5396947.5,4581747.5
5396937.5,4581767.5 5396917.5,4581777.5 5396927.5,4581777.5
5396947.5,4581767.5 5396957.5,4581767.5 5396967.5,4581797.5
5396937.5,4581797.5 5396927.5,4581807.5 5396917.5,4581807.5
5396907.5,4581837.5 5396877.5,4581837.5 5396857.5,4581857.5
5396837.5,4581857.5 5396817.5,4581867.5 5396807.5,4581857.5
5396807.5,4581847.5 5396817.5,4581837.5 5396807.5,4581867.5
5396777.5,4581867.5 5396767.5,4581887.5 5396747.5,4581897.5
5396757.5,4581887.5 5396767.5,4581887.5 5396787.5,4581897.5
5396777.5,4581897.5 5396767.5,4581907.5 5396757.5,4581907.5
5396747.5,4581917.5 5396737.5,4581917.5 5396727.5,4581927.5
5396717.5,4581927.5 5396707.5,4581937.5 5396697.5,4581937.5
5396687.5,4581947.5 5396677.5,4581947.5 5396667.5,4581957.5
5396657.5,4581957.5 5396617.5,4581977.5 5396597.5,4581977.5
5396577.5,4582007.5 5396547.5,4582007.5 5396527.5,4582017.5
5396517.5,4582017.5 5396497.5,4582027.5 5396487.5,4582027.5
5396477.5,4582037.5 5396467.5,4582037.5 5396457.5,4582057.5
5396437.5,4582057.5 5396427.5,4582067.5 5396417.5,4582057.5
5396417.5,4582047.5 5396407.5,4582057.5 5396397.5,4582057.5
5396377.5,4582047.5 5396367.5,4582047.5 5396327.5,4582057.5
5396317.5,4582077.5 5396317.5,4582087.5 5396307.5,4582097.5
5396307.5,4582097.5 5396257.5,4582077.5 5396237.5,4582077.5
5396217.5,4582087.5 5396207.5,4582087.5 5396187.5,4582117.5
5396157.5,4582117.5 5396147.5,4582127.5 5396137.5,4582107.5
5396117.5,4582107.5 5396077.5,4582117.5 5396067.5,4582127.5
5396067.5,4582127.5 5396047.5,4582137.5 5396037.5,4582137.5
5395977.5,4582127.5 5395967.5,4582127.5 5395957.5,4582117.5
5395947.5,4582117.5 5395927.5,4582127.5 5395917.5,4582137.5
5395917.5,4582137.5 5395907.5,4582147.5 5395897.5,4582147.5
5395887.5,4582137.5 5395877.5,4582137.5 5395867.5,4582127.5
5395857.5,4582137.5 5395847.5,4582137.5 5395817.5,4582147.5
5395807.5,4582147.5 5395797.5,4582157.5 5395787.5,4582177.5
5395787.5,4582184.5 5395792,4582197.5 5395807.5,4582224.5
5395833.5,4582227.5 5395827.5,4582227.5 5395817.5,4582207.5
5395797.5,4582197 5395789.5,4582183.5 5395781.5,4582177.5
5395767.5,4582157.5 5395747.5,4582157.5 5395737.5,4582137.5
5395737.5,4582127.5 5395727.5,4582137.5 5395717.5,4582178
5395717,4582146 5395459.5,4582135 5395397,4582129 5395345,4582126
5395225,4582098 5395226.5,4582100.5 5395209.5,4582129
5395206.5,4582128.5 5395131,4582132.5 5395028,4582201.5
5395035,4582205.5 5394881,4582343 5394635,4582341.5 5394529.5,4582380
5394409.5,4582465 5394398,4582559.5 5394354.5,4582646
5394328.5,4582663.5 5394312,4582666.5 5394293.5,4582670 5394292,4582685
5394304,4582699.5 5394295,4582706 5394281,4582713 5394276,4582720
5394274.5,4582731 5394276,4582735 5394274.5,4582742.5 5394264,4582752
5394256.5,4582753.5 5394248.5,4582752 5394246,4582738
5394241.5,4582736.5 5394238.5,4582738 5394234.5,4582744.5
5394229,4582754.5 5394239.5,4582762.5 5394232.5,4582764 5394224,4582754
5394209,4582751.5 5394195.5,4582754.5 5394189.5,4582781
5394187.5,4582787.5 5394181.5,4582796 5394167,4582798.5 5394156,4582811
5394132,4582807 5394109,4582802.5 5394103,4582794.5 5394101.5,4582793
5394100,4582794 5394090.5,4582791.5 5394085.5,4582785 5394079,4582778
5394083.5,4582756.5 5394092.5,4582751.5 5394097.5,4582730.5
5394069.5,4582737.5 5394061.5,4582801 5394048.5,4582807.5
5394044,4582812 5394037,4582815.5 5394025.5,4582818 5393999,4582817.5
5393975,4582804 5393932.5,4582800 5393915.5,4582799 5393885.5,4582786
5393878,4582785 5393874.5,4582791.5 5393860,4582794.5 5393857,4582807
5393855.5,4582810.5 5393854,4582811.5 5393850,4582810.5
5393843.5,4582807 5393835.5,4582808 5393829.5,4582812
5393824.5,4582819.5 5393810.5,4582829.5 5393797.5,4582836.5
5393782.5,4582838 5393773,4582827 5393748,4582828.5 5393742,4582838.5
5393730.5,4582826.5 5393726.5,4582825 5393722.5,4582832.5
5393702,4582838.5 5393693.5,4582860.5 5393653,4582878 5393601,4582882.5
5393596.5,4582883 5393587.5,4582889.5 5393569.5,4582897 5393563,4582898
5393557,4582913 5393537.5,4582913.5 5393532,4582933.5 5393480,4582947.5
5393453,4582959 5393441,4582973.5 5393438,4582972 5393434.5,4582958
5393428,4582964 5393400,4582966.5 5393372,4582976 5393344,4582976.5
5393333,4582982.5 5393326,4582988.5 5393321.5,4583022
5393242.5,4583026.5 5393238.5,4583047.5 5393207.5,4583067.5
5393156,4583106.5 5393212.5,4583113.5 5393237,4583129 5393249.5,4583134
5393257.5,4583138 5393268,4583172.5 5393286.5,4583179 5393297.5,4583180
5393312.5,4583177 5393319.5,4583198.5 5393332.5,4583259
5393290,4583241.5 5393269,4583248 5393262.5,4583287.5 5393253,4583329
5393213.5,4583329 5393183.5,4583319 5393173.5,4583319 5393163.5,4583309
5393153.5,4583299 5393153.5,4583289 5393143.5,4583289 5393073.5,4583259
5393043.5,4583259 5392983.5,4583269 5392973.5,4583269 5392953.5,4583279
5392943.5,4583279 5392933.5,4583289 5392923.5,4583289 5392913.5,4583269
5392893.5,4583279 5392883.5,4583299 5392903.5,4583309 5392903.5,4583299
5392893.5,4583329 5392863.5,4583339 5392863.5,4583379 5392823.5,4583379
5392813.5,4583389 5392803.5,4583409 5392803.5,4583419 5392813.5,4583439
5392793.5,4583479 5392793.5,4583489 5392783.5,4583519 5392783.5,4583539
5392763.5,4583539 5392743.5,4583559 5392723.5,4583609 5392723.5,4583609
5392713.5,4583649 5392673.5,4583649 5392663.5,4583659
5392653.5,4583674.5 5392546.5,4583650.5 5392536.5,4583597
5392532.5,4583589.5 5392525,4583617 5392521.5,4583626 5392513.5,4583710
5392515,4583740 5392485,4583764.5 5392485,4583779.5 5392459.5,4583800
5392457.5,4583833 5392444,4583846.5 5392431.5,4583888.5 5392422,4583952
5392417,4584010 5392421.5,4584069 5392412,4584112.5 5392411.5,4584131
5392417.5,4584159 5392435,4584179 5392441.5,4584247 5392416.5,4584274
5392413,4584340.5 5392359,4584350 5392361,4584357.5 5392338,4584384
5392324,4584423.5 5392322,4584495.5 5392310.5,4584512 5392294,4584532
5392294.5,4584547 5392283,4584561.5 5392279.5,4584573.5
5392268.5,4584594.5 5392260.5,4584667 5392215,4584706.5
5392204,4584732.5 5392203.5,4584755.5 5392166,4584849
5392096.5,4584905.5 5392060,4584943.5 5392020.5,4584943
5392000.5,4584972.5 5391963,4585036 5391956,4585048.5
5391953.5,4585169.5 5391835.5,4585194.5 5391805.5,4585245.5
5391756.5,4585313 5391702,4585341.5 5391681,4585387 5391651.5,4585391
5391647.5,4585391 5391642,4585403 5391634,4585404.5 5391619.5,4585413.5
5391605.5,4585427.5 5391593.5,4585442 5391593.5,4585456.5
5391588.5,4585482.5 5391560,4585485 5391550,4585491.5 5391545,4585508.5
5391524.5,4585520 5391514,4585528 5391511,4585564.5 5391479,4585631.5
5391427,4585633 5391422.5,4585666 5391398.5,4585673 5391390.5,4585771.5
5391299.5,4585775.5 5391299,4585787.5 5391276.5,4585835.5
5391230.5,4585849.5 5391230,4585923.5 5391154,4585940.5
5391138,4585955.5 5391120.5,4585953 5391119,4585943 5391122,4585943.5
5391118,4585946.5 5391112.5,4585959 5391109.5,4585968 5391104.5,4586002
5391072.5,4586019.5 5391053.5,4586043.5 5391034,4586062
5391021.5,4586096 5391002,4586115.5 5390997.5,4586128 5390989.5,4586228
5390904,4586257 5390877,4586275 5390859,4586385 5390718.5,4586408
5390691,4586431.5 5390666.5,4586447.5 5390652.5,4586457.5
5390647,4586460 5390643.5,4586452 5390637,4586451 5390634.5,4586467
5390614,4586477 5390606,4586518 5390591.5,4586530 5390579,4586560
5390554,4586586 5390529.5,4586655 5390447.5,4586669.5 5390434,4586674
5390420.5,4586705 5390390.5,4586713.5 5390395.5,4586709
5390387.5,4586716 5390364,4586718 5390345.5,4586736.5 5390330.5,4586749
5390327.5,4586764 5390327.5,4586801.5 5390312.5,4586821
5390280.5,4586850.5 5390256,4586908 5390239,4586930 5390239,4586992
5390204,4587000 5390189.5,4587032 5390177,4587116.5 5390118,4587135.5
5390077,4587153.5 5390053.5,4587090.5 5389990.5,4587089.163
5389989.633,4586393.799 5390252.837,4586274 5390369.5,4586201.5
5390431,4586115.5 5390491,4585950.5 5390583.5,4585880 5390631,4585758
5390722.5,4585592 5390866,4585409.5 5391021.5,4585402 5391044,4585386.5
5391045,4585314 5391099,4585326.5 5391117,4585313.5 5391132,4585303.5
5391135,4585300 5391146,4585274.5 5391135,4585215.5 5391178,4585133
5391261,4585064.5 5391342,4584995.5 5391410,4584896.5 5391496,4584805.5
5391564,4584726 5391614,4584661.5 5391647.5,4584559.5 5391687.5,4584441
5391720,4584323.5 5391731,4584031.5 5391722.5,4583946.5
5391724.5,4583838.5 5391739,4583682 5391790.5,4583583 5391835.5,4583530
5391864,4583533.016 5391863.339,4583490.575 5391889.606,4583444.425
5391914.124,4583323.282 5391974.695,4583256.942 5392002.097,4583215.119
5392022.287,4583160.316 5392045.362,4583099.744 5392068.437,4582987.254
5392098.723,4582912.26 5392108.818,4582850.247 5392114.587,4582770.927
5392116.029,4582719.5 5392112.266,4582719.5 5392085,4582709.5
5392075,4582699.5 5392075,4582679.5 5392055,4582679.5 5392045,4582639.5
5392045,4582629.5 5392035,4582579.5 5392035,4582559.5 5392055,4582539.5
5392055,4582529.5 5392045,4582529.5 5392035,4582509.5 5392035,4582499.5
5392045,4582479.5 5392045,4582469.5 5392035,4582459.5 5392035,4582449.5
5392025,4582419.5 5392025,4582409.5 5392015,4582359.5 5392015,4582349.5
5392005,4582339.5 5392015,4582319.5 5392015,4582309.5 5392025,4582299.5
5392015,4582299.5 5392005,4582279.5 5392005,4582269.5 5392015,4582239.5
5392015,4582229.5 5392005,4582219.5 5392015,4582209.5 5392015,4582209.5
5392025,4582199.5 5392035,4582189.5 5392035,4582189.5 5392045,4582169.5
5392065,4582159.5 5392065,4582149.5 5392055,4582139.5 5392055,4582109.5
5392085,4582099.5 5392085,4582089.5 5392095,4582079.5 5392095,4582059.5
5392115,4582049.5 5392105,4582069.5 5392085,4582079.5 5392075,4582089.5
5392075,4582119.5 5392045,4582129.5 5392045,4582149.5 5392025,4582139.5
5392015,4582139.5 5392005,4582109.5 5392005,4582099.5 5391995,4582089.5
5391995,4582079.5 5391985,4582059.5 5391985,4582039.5 5392005,4582029.5
5391995,4582029.5 5391985,4582009.5 5391985,4582009.5 5392025,4581999.5
5392035,4581989.5 5392025,4581979.5 5392025,4581959.5 5392045,4581949.5
5392035,4581949.5 5392025,4581919.5 5392025,4581919.5 5392045,4581929.5
5392035,4581939.5 5392035,4581949.5 5392045,4581949.5 5392055,4581939.5
5392065,4581929.5 5392065,4581919.5 5392075,4581889.5 5392075,4581879.5
5392065,4581879.5 5392035,4581869.5 5392035,4581859.5 5392025,4581869.5
5392015,4581879.5 5392015,4581869.5 5392005,4581889.5 5391985,4581889.5
5391975,4581899.5 5391965,4581889.5 5391955,4581879.5 5391955,4581869.5
5391965,4581829.5 5391965,4581819.5 5391955,4581799.5 5391955,4581779.5
5391935,4581769.5 5391935,4581759.5 5391925,4581749.5 5391925,4581739.5
5391915,4581729.5 5391915,4581719.5 5391905,4581699.5 5391905,4581689.5
5391895,4581679.5 5391895,4581669.5 5391885,4581649.5 5391885,4581639.5
5391875,4581619.5 5391875,4581609.5 5391885,4581599.5 5391885,4581589.5
5391895,4581569.5 5391895,4581569.5 5391905,4581559.5 5391915,4581569.5
5391925,4581559.5 5391935,4581549.5 5391935,4581539.5 5391925,4581509.5
5391955,4581499.5 5391955,4581469.5 5391985,4581439.5 5391985,4581429.5
5391995,4581419.5 5391995,4581409.5 5392005,4581379.5 5392005,4581369.5
5392015,4581349.5 5392015,4581329.5 5392035,4581319.5 5392035,4581299.5
5392055,4581289.5 5392055,4581279.5 5392065,4581269.5 5392065,4581259.5
5392075,4581249.5 5392075,4581239.5 5392085,4581219.5 5392085,4581209.5
5392095,4581179.5 5392095,4581169.5 5392105,4581129.5 5392105,4581119.5
5392115,4581089.5 5392115,4581079.5 5392105,4581039.5 5392105,4581029.5
5392095,4581029.5 5392085,4581019.5 5392075,4580979.5 5392075,4580969.5
5392065,4580949.5 5392065,4580899.5 5392015,4580899.5 5391955,4580889.5
5391965,4580879.5 5391955,4580879.5 5391945,4580819.5 5391945,4580809.5
5391955,4580749.5 5391955,4580739.5 5391965,4580679.5 5391965,4580679.5
5391975,4580669.5 5391985,4580669.5 5391995,4580679.5 5392005,4580689.5
5392005,4580699.5 5392015,4580689.5 5392025,4580669.5 5392025,4580669.5
5392035,4580699.5 5392035,4580709.5 5392045,4580709.5 5392055,4580719.5
5392055,4580729.5 5392065,4580739.5 5392065,4580749.5 5392075,4580769.5
5392075,4580779.5 5392085,4580799.5 5392085,4580809.5 5392095,4580819.5
5392095,4580829.5 5392105,4580859.5 5392105,4580869.5 5392115,4580879.5
5392115,4580889.5 5392125,4580909.5 5392125,4580919.5 5392135,4580919.5
5392175,4580939.5 5392195,4580939.5 5392205,4580929.5 5392215,4580929.5
5392225,4580889.5 5392265,4580879.5 5392265,4580869.5 5392275,4580859.5
5392275,4580849.5 5392285,4580839.5 5392285,4580829.5 5392295,4580819.5
5392295,4580779.5 5392335,4580759.5 5392335,4580719.5 5392375,4580699.5
5392375,4580689.5 5392385,4580619.5 5392385,4580609.5 5392375,4580569.5
5392375,4580559.5 5392385,4580539.5 5392365,4580529.5 5392365,4580519.5
5392355,4580479.5 5392355,4580469.5 5392345,4580449.5 5392345,4580439.5
5392335,4580229.5 5392335,4580209.5 5392355,4580199.5 5392355,4580179.5
5392375,4580159.5 5392375,4580149.5 5392385,4580129.5 5392385,4580119.5
5392395,4580089.5 5392395,4580079.5 5392385,4580059.5 5392385,4580049.5
5392395,4580039.5 5392395,4580009.5 5392425,4579999.5 5392415,4579969.5
5392415,4579959.5 5392425,4579919.5 5392425,4579909.5 5392415,4579889.5
5392415,4579879.5 5392405,4579859.5 5392405,4579849.5 5392395,4579839.5
5392395,4579829.5 5392385,4579829.5 5392375,4579819.5 5392365,4579819.5
5392325,4579809.5 5392325,4579799.5 5392335,4579799.5 5392345,4579809.5
5392355,4579809.5 5392385,4579789.5 5392405,4579769.5 5392405,4579759.5
5392395,4579759.5 5392405,4579749.5 5392415,4579739.5 5392415,4579729.5
5392425,4579699.5 5392425,4579679.5 5392445,4579679.5 5392455,4579649.5
5392485,4579649.5 5392505,4579639.5 5392515,4579639.5 5392525,4579629.5
5392535,4579609.5 5392535,4579609.5 5392565,4579599.5 5392575,4579579.5
5392555,4579579.5 5392545,4579569.5 5392535,4579559.5 5392535,4579559.5
5392545,4579539.5 5392565,4579539.5 5392585,4579549.5 5392595,4579539.5
5392605,4579529.5 5392605,4579529.5 5392615,4579539.5 5392625,4579539.5
5392645,4579559.5 5392625,4579569.5 5392635,4579569.5 5392645,4579549.5
5392665,4579539.5 5392655,4579539.5 5392665,4579529.5 5392675,4579519.5
5392675,4579519.5 5392685,4579509.5 5392695,4579499.5 5392685,4579479.5
5392685,4579469.5 5392675,4579469.5 5392655,4579459.5 5392645,4579469.5
5392635,4579479.5 5392635,4579479.5 5392615,4579459.5 5392615,4579459.5
5392625,4579449.5 5392635,4579439.5 5392635,4579439.5 5392685,4579449.5
5392695,4579449.5 5392705,4579439.5 5392715,4579429.5 5392715,4579399.5
5392745,4579369.5 5392745,4579369.5 5392755,4579349.5 5392775,4579339.5
5392775,4579329.5 5392765,4579329.5 5392745,4579319.5 5392735,4579319.5
5392745,4579309.5 5392755,4579289.5 5392755,4579279.5 5392745,4579269.5
5392745,4579269.5 5392755,4579249.5 5392775,4579239.5 5392775,4579219.5
5392795,4579139.5 5392795,4579068 5392807,4579018 5392807,4579008
5392817,4578988 5392817,4578978 5392827,4578958 5392827,4578948
5392837,4578938 5392837,4578928 5392847,4578918 5392847,4578908
5392857,4578898 5392857,4578888 5392867,4578878 5392867,4578858
5392887,4578848 5392887,4578838 5392897,4578828 5392897,4578808
5392917,4578788 5392917,4578778 5392927,4578768 5392927,4578758
5392937,4578748 5392937,4578738 5392947,4578728 5392947,4578718
5392957,4578708 5392957,4578688 5392977,4578678 5392977,4578668
5392987,4578658 5392987,4578638 5393007,4578628 5393007,4578608
5393027,4578598 5393027,4578548 5393077,4578538 5393077,4578408
5393207,4578408 5393217,4578328 5393297,4578328 5393307,4578238
5393397,4578238 5393407,4578218 5393427,4578218 5393437,4578208
5393447,4578198 5393447,4578188 5393457,4578188 5393467,4578198
5393477,4578198 5393487,4578138 5393547,4578118 5393547,4578088
5393577,4578078 5393577,4578078 5393587,4578048 5393617,4578048
5393627,4578008 5393667,4578008 5393677,4577978 5393707,4577978
5393717,4577948 5393747,4577948 5393757,4577908 5393797,4577908
5393807,4577878 5393837,4577878 5393847,4577848 5393877,4577848
5393887,4577808 5393927,4577808 5393937,4577778 5393967,4577778
5393977,4577748 5394007,4577748 5394027,4577758 5394037,4577758
5394067,4577768 5394077,4577768 5394127,4577778 5394137,4577778
5394157,4577788 5394167,4577788 5394187,4577798 5394197,4577798
5394207,4577808 5394217,4577808 5394247,4577848 5394287,4577858
5394287,4577878 5394307,4577878 5394327,4577888 5394337,4577898
5394337,4577908 5394347,4577918 5394357,4577918 5394367,4577908
5394377,4577908 5394417,4577898 5394427,4577898 5394447,4577888
5394457,4577888 5394477,4577858 5394507,4577848 5394497,4577848
5394477,4577838 5394487,4577838 5394497,4577828 5394507,4577828
5394517,4577808 5394537,4577788 5394537,4577778 5394547,4577778
5394557,4577768 5394567,4577758 5394567,4577748 5394577,4577738
5394577,4577738 5394587,4577718 5394607,4577708 5394607,4577648
5394667,4577648 5394677,4577668 5394677,4577678 5394687,4577668
5394697,4577678 5394697,4577688 5394707,4577688 5394697,4577718
5394667,4577738 5394667,4577748 5394677,4577728 5394697,4577728
5394707,4577718 5394717,4577718 5394737,4577728 5394747,4577738
5394747,4577758 5394727,4577768 5394727,4577788 5394707,4577798
5394707,4577808 5394697,4577818 5394697,4577828 5394707,4577828
5394787,4577838 5394797,4577838 5394807,4577828 5394817,4577828
5394827,4577838 5394837,4577838 5394867,4577828 5394877,4577828
5394917,4577818 5394927,4577818 5394957,4577828 5394957,4577828
5394937,4577858 5394907,4577868 5394917,4577868 5394927,4577878
5394937,4577868 5394947,4577878 5394957,4577882.5 5394969,4577882.5
5395039,4577892.5 5395049,4577892.5 5395069,4577882.5 5395079,4577892.5
5395089,4577892.5 5395099,4577902.5 5395109,4577902.5 5395119,4577912.5
5395129,4577912.5 5395139,4577932.5 5395159,4577932.5 5395169,4577942.5
5395179,4577942.5 5395189,4577932.5 5395199,4577932.5 5395209,4577922.5
5395219,4577912.5 5395229,4577902.5 5395229,4577902.5 5395239,4577892.5
5395249,4577852.5 5395249,4577852.5 5395289,4577832.5 5395309,4577822.5
5395309,4577782.5 5395349,4577772.5 5395349,4577772.5 5395359,4577762.5
5395369,4577762.5 5395379,4577752.5 5395389,4577752.5 5395399,4577742.5
5395409,4577722.5 5395409,4577712.5 5395399,4577702.5 5395399,4577682.5
5395379,4577672.5 5395379,4577662.5 5395369,4577652.5 5395369,4577642.5
5395359,4577642.5 5395299,4577632.5 5395289,4577632.5 5395259,4577612.5
5395239,4577612.5 5395229,4577602.5 5395229,4577592.5 5395219,4577592.5
5395209,4577562.5 5395209,4577552.5 5395199,4577502.5 5395199,4577492.5
5395189,4577482.5 5395189,4577472.5 5395179,4577472.5 5395169,4577442.5
5395139,4577442.5 5395129,4577452.5 5395089,4577452.5 5395079,4577462.5
5395069,4577462.5 5395049,4577472.5 5395039,4577472.5 5395019,4577482.5
5395009,4577482.5 5394999,4577492.5 5394989,4577492.5 5394979,4577512.5
5394959,4577518 5394947,4577518 5394937,4577548 5394907,4577548
5394897,4577568 5394877,4577568 5394867,4577598 5394837,4577598
5394827,4577608 5394817,4577608 5394807,4577618 5394797,4577618
5394787,4577598 5394807,4577588 5394807,4577588 5394837,4577578
5394847,4577568 5394847,4577568 5394857,4577558 5394867,4577548
5394867,4577548 5394877,4577538 5394887,4577528 5394887,4577528
5394897,4577508 5394917,4577498 5394917,4577498 5394937,4577492.5
5394949,4577472.5 5394949,4577472.5 5394959,4577462.5 5394969,4577442.5
5394969,4577442.5 5394989,4577432.5 5394999,4577452.5 5395019,4577452.5
5395059,4577442.5 5395069,4577442.5 5395099,4577439.5
5395110.5,4577435.5 5395115,4577422.5 5395109,4577412.5
5395109,4577402.5 5395099,4577382.5 5395119,4577372.5 5395119,4577382.5
5395129,4577372.5 5395139,4577362.5 5395129,4577362.5 5395169,4577352.5
5395179,4577352.5 5395189,4577332.5 5395209,4577322.5 5395209,4577322.5
5395219,4577312.5 5395229,4577312.5 5395249,4577302.5 5395259,4577302.5
5395289,4577322.5 5395269,4577352.5 5395299,4577352.5 5395359,4577362.5
5395369,4577352.5 5395379,4577362.5 5395379,4577372.5 5395389,4577392.5
5395389,4577422.5 5395419,4577422.5 5395429,4577412.5 5395439,4577412.5
5395449,4577402.5 5395459,4577382.5 5395459,4577372.5 5395469,4577372.5
5395479,4577382.5 5395489,4577392.5 5395479,4577402.5 5395489,4577402.5
5395479,4577442.5 5395439,4577442.5 5395419,4577452.5 5395409,4577462.5
5395409,4577472.5 5395399,4577482.5 5395399,4577492.5 5395409,4577502.5
5395409,4577532.5 5395439,4577532.5 5395449,4577522.5 5395459,4577502.5
5395459,4577502.5 5395469,4577472.5 5395499,4577472.5 5395509,4577462.5
5395519,4577512.5 5395519,4577522.5 5395529,4577562.5 5395529,4577572.5
5395539,4577562.5 5395549,4577532.5 5395549,4577532.5 5395569,4577542.5
5395579,4577552.5 5395579,4577572.5 5395599,4577572.5 5395619,4577582.5
5395629,4577582.5 5395659,4577562.5 5395679,4577562.5 5395689,4577572.5
5395699,4577522.5 5395749,4577522.5 5395779,4577512.5 5395789,4577492.5
5395789,4577482.5 5395799,4577472.5 5395799,4577452.5 5395819,4577432.5
5395819,4577422.5 5395809,4577402.5 5395809,4577392.5 5395819,4577362.5
5395819,4577362.5 5395869,4577382.5 5395869,4577402.5 5395849,4577422.5
5395849,4577432.5 5395859,4577412.5 5395879,4577402.5 5395879,4577372.5
5395909,4577362.5 5395909,4577252.5 5396019,4577252.5 5396029,4577242.5
5396039,4577212.5 5396039,4577212.5 5396059,4577202.5 5396069,4577202.5
5396079,4577142 5396138.5,4577142 5396148.5,4577002 5396288.5,4577002
5396298.5,4576992 5396308.5,4576992 5396318.5,4576932 5396378.5,4576932
5396388.5,4576902 5396418.5,4576902 5396428.5,4576892 5396438.5,4576892
5396448.5,4576872 5396468.5,4576872 5396478.5,4576852 5396498.5,4576852
5396508.5,4576832 5396528.5,4576832 5396538.5,4576822 5396548.5,4576812
5396548.5,4576802 5396558.5,4576792 5396548.5,4576792 5396518.5,4576802
5396508.5,4576802 5396498.5,4576812 5396488.5,4576812 5396478.5,4576822
5396468.5,4576822 5396438.5,4576802 5396458.5,4576802 5396478.5,4576772
5396508.5,4576772 5396518.5,4576762 5396528.5,4576762 5396548.5,4576752
5396558.5,4576752 5396568.5,4576742 5396578.5,4576732 5396578.5,4576722
5396588.5,4576682 5396588.5,4576672 5396598.5,4576642 5396598.5,4576612
5396568.5,4576612 5396558.5,4576582 5396528.5,4576572 5396528.5,4576562
5396538.5,4576562 5396548.5,4576572 5396558.5,4576572 5396568.5,4576562
5396578.5,4576552 5396578.5,4576552 5396588.5,4576532 5396608.5,4576482
5396608.5,4576462 5396588.5,4576442 5396588.5,4576432 5396578.5,4576432
5396558.5,4576422 5396558.5,4576412 5396568.5,4576412 5396578.5,4576402
5396588.5,4576392 5396588.5,4576392 5396598.5,4576382 5396608.5,4576372
5396598.5,4576372 5396578.5,4576382 5396568.5,4576392 5396568.5,4576392
5396538.5,4576492 5396438.5,4576522 5396438.5,4576542 5396418.5,4576542
5396408.5,4576552 5396398.5,4576582 5396398.5,4576572 5396388.5,4576572
5396378.5,4576562 5396368.5,4576552 5396378.5,4576542 5396368.5,4576542
5396358.5,4576512 5396358.5,4576502 5396348.5,4576522 5396328.5,4576532
5396328.5,4576542 5396318.5,4576542 5396308.5,4576552 5396298.5,4576552
5396288.5,4576562 5396278.5,4576562 5396268.5,4576572 5396258.5,4576592
5396258.5,4576612 5396238.5,4576612 5396218.5,4576622 5396208.5,4576632
5396208.5,4576642 5396198.5,4576632 5396198.5,4576622 5396188.5,4576632
5396178.5,4576662 5396178.5,4576722 5396118.5,4576722 5396108.5,4576752
5396078.5,4576762 5396078.5,4576792 5396048.5,4576802 5396048.5,4576812
5396058.5,4576812 5396068.5,4576802 5396078.5,4576802 5396088.5,4576792
5396098.5,4576802 5396108.5,4576802 5396118.5,4576782 5396138.5,4576772
5396138.5,4576752 5396158.5,4576742 5396158.5,4576742 5396168.5,4576722
5396188.5,4576712 5396188.5,4576712 5396228.5,4576702 5396238.5,4576682
5396238.5,4576662 5396258.5,4576652 5396258.5,4576632 5396278.5,4576632
5396288.5,4576622 5396298.5,4576622 5396358.5,4576632 5396368.5,4576682
5396368.5,4576702 5396388.5,4576712 5396388.5,4576722 5396398.5,4576762
5396398.5,4576782 5396378.5,4576772 5396368.5,4576772 5396358.5,4576802
5396328.5,4576812 5396328.5,4576782 5396298.5,4576782 5396248.5,4576772
5396238.5,4576772 5396228.5,4576782 5396218.5,4576802 5396218.5,4576812
5396208.5,4576822 5396208.5,4576852 5396238.5,4576852 5396258.5,4576872
5396278.5,4576872 5396288.5,4576882 5396288.5,4576882 5396268.5,4576892
5396258.5,4576892 5396248.5,4576902 5396238.5,4576912 5396238.5,4576912
5396218.5,4576932 5396198.5,4576932 5396178.5,4576942 5396168.5,4576952
5396178.5,4576962 5396178.5,4576952 5396168.5,4576952 5396158.5,4576962
5396148.5,4576982 5396148.5,4577002 5396128.5,4577002 5396108.5,4576992
5396108.5,4576982 5396098.5,4576982 5396078.5,4576972 5396068.5,4576972
5396058.5,4576962 5396048.5,4576962 5396028.5,4576952 5396018.5,4576952
5395988.5,4576942 5395988.5,4576922 5395968.5,4576922 5395948.5,4576912
5395938.5,4576932 5395918.5,4576932 5395908.5,4576952 5395888.5,4576952
5395838.5,4576942 5395828.5,4576942 5395818.5,4576932 5395808.5,4576932
5395798.5,4576912 5395778.5,4576912 5395768.5,4576882 5395768.5,4576882
5395778.5,4576872 5395788.5,4576872 5395798.5,4576862 5395808.5,4576862
5395818.5,4576842 5395838.5,4576832 5395828.5,4576822 5395828.5,4576812
5395818.5,4576812 5395808.5,4576822 5395798.5,4576822 5395788.5,4576842
5395768.5,4576852 5395768.5,4576872 5395748.5,4576882 5395748.5,4576882
5395738.5,4576892 5395728.5,4576887 5395715.5,4576900.5
5395703.5,4576912.5 5395709,4576912.5 5395719,4576922.5
5395729,4576922.5 5395739,4576932.5 5395749,4576932.5 5395759,4576942.5
5395769,4576942.5 5395779,4576962.5 5395799,4576962.5 5395809,4576972.5
5395819,4576972.5 5395829,4576982.5 5395829,4576992.5 5395819,4576992.5
5395799,4577002.5 5395789,4576992.5 5395779,4577012.5 5395759,4577012.5
5395749,4577082.5 5395679,4577072.5 5395669,4577082.5 5395659,4577082.5
5395649,4577072.5 5395649,4577062.5 5395639,4577052.5 5395639,4577042.5
5395629,4577032.5 5395629,4577022.5 5395619,4577012.5 5395619,4577002.5
5395609,4576992.5 5395609,4576982.5 5395599,4576972.5 5395599,4576962.5
5395589,4576952.5 5395589,4576944 5395581,4576952.5 5395569,4576962.5
5395569,4576992.5 5395539,4577022.5 5395539,4577032.5 5395549,4577042.5
5395549,4577052.5 5395559,4577042.5 5395569,4577032.5 5395569,4577042.5
5395579,4577042.5 5395589,4577072.5 5395559,4577082.5 5395559,4577092.5
5395549,4577132.5 5395549,4577132.5 5395539,4577152.5 5395519,4577152.5
5395509,4577162.5 5395499,4577162.5 5395479,4577172.5 5395469,4577172.5
5395459,4577182.5 5395449,4577182.5 5395439,4577172.5 5395449,4577162.5
5395439,4577162.5 5395429,4577152.5 5395429,4577142.5 5395419,4577122.5
5395419,4577112.5 5395409,4577092.5 5395409,4577082.5 5395399,4577072.5
5395409,4577062.5 5395399,4577052.5 5395399,4577022.5 5395429,4577022.5
5395439,4577002.5 5395459,4577002.5 5395469,4576992.5 5395479,4576982.5
5395479,4576982.5 5395489,4576972.5 5395499,4576962.5 5395499,4576962.5
5395509,4576952.5 5395519,4576952.5 5395539,4576942.5 5395549,4576922.5
5395549,4576912.5 5395559,4576912.5 5395569,4576922.5 5395569,4576933
5395575.5,4576934 5395581.5,4576922.5 5395589,4576902.5
5395589,4576882.5 5395609,4576872.5 5395609,4576862.5 5395619,4576862.5
5395639,4576872.5 5395649,4576872.5 5395659,4576892.5 5395679,4576891
5395704.5,4576882.5 5395709,4576862.5 5395689,4576862.5
5395679,4576852.5 5395669,4576822 5395698.5,4576802 5395698.5,4576802
5395718.5,4576792 5395728.5,4576782 5395738.5,4576752 5395738.5,4576752
5395748.5,4576732 5395768.5,4576732 5395778.5,4576712 5395798.5,4576692
5395798.5,4576662 5395828.5,4576652 5395828.5,4576632 5395848.5,4576642
5395858.5,4576612 5395888.5,4576602 5395888.5,4576572 5395918.5,4576562
5395918.5,4576552 5395928.5,4576542 5395928.5,4576522 5395948.5,4576502
5395948.5,4576482 5395968.5,4576472 5395968.5,4576442 5395998.5,4576432
5395998.5,4576432 5396008.5,4576452 5396028.5,4576442 5396038.5,4576422
5396018.5,4576412 5396028.5,4576392 5396028.5,4576332 5396088.5,4576312
5396088.5,4576302 5396098.5,4576282 5396078.5,4576262 5396078.5,4576242
5396098.5,4576232 5396098.5,4576242 5396108.5,4576262 5396108.5,4576272
5396118.5,4576262 5396128.5,4576252 5396128.5,4576252 5396148.5,4576262
5396148.5,4576272 5396158.5,4576262 5396168.5,4576252 5396168.5,4576242
5396178.5,4576232 5396178.5,4576222 5396188.5,4576192 5396188.5,4576172
5396208.5,4576152 5396208.5,4576142 5396218.5,4576122 5396218.5,4576112
5396228.5,4576092 5396228.5,4576072 5396208.5,4576062 5396208.5,4576052
5396198.5,4576072 5396178.5,4576072 5396168.5,4576082 5396158.5,4576082
5396148.5,4576092 5396138.5,4576092 5396128.5,4576112 5396108.5,4576112
5396098.5,4576122 5396088.5,4576122 5396068.5,4576132 5396058.5,4576132
5396038.5,4576142 5396028.5,4576142 5395988.5,4576152 5395978.5,4576162
5395978.5,4576172 5395968.5,4576172 5395958.5,4576182 5395948.5,4576182
5395928.5,4576192 5395918.5,4576192 5395898.5,4576202 5395888.5,4576202
5395878.5,4576192 5395888.5,4576182 5395888.5,4576152 5395858.5,4576152
5395828.5,4576162 5395818.5,4576162 5395808.5,4576182 5395788.5,4576192
5395798.5,4576212 5395798.5,4576222 5395808.5,4576252 5395778.5,4576252
5395768.5,4576272 5395748.5,4576292 5395748.5,4576312 5395728.5,4576312
5395718.5,4576342 5395688.5,4576342 5395678.5,4576362 5395658.5,4576362
5395648.5,4576382 5395628.5,4576382 5395618.5,4576392 5395608.5,4576392
5395598.5,4576412 5395578.5,4576412 5395568.5,4576422 5395558.5,4576422
5395548.5,4576432 5395538.5,4576432 5395528.5,4576442 5395518.5,4576442
5395508.5,4576452 5395498.5,4576452 5395488.5,4576462 5395478.5,4576462
5395458.5,4576472 5395448.5,4576472 5395438.5,4576482 5395428.5,4576482
5395408.5,4576492 5395398.5,4576492 5395388.5,4576502 5395378.5,4576502
5395348.5,4576512 5395338.5,4576512 5395318.5,4576502 5395318.5,4576492
5395328.5,4576492 5395338.5,4576472 5395358.5,4576452 5395358.5,4576442
5395368.5,4576442 5395388.5,4576432 5395398.5,4576422 5395398.5,4576412
5395388.5,4576412 5395378.5,4576402 5395388.5,4576402 5395408.5,4576392
5395418.5,4576382 5395418.5,4576382 5395428.5,4576362 5395448.5,4576362
5395458.5,4576342 5395478.5,4576332 5395478.5,4576322 5395488.5,4576312
5395488.5,4576122 5395678.5,4576122 5395688.5,4576112 5395698.5,4576102
5395698.5,4576092 5395708.5,4576152 5395768.5,4576142 5395778.5,4576132
5395768.5,4576122 5395768.5,4576092 5395798.5,4576082 5395788.5,4576062
5395788.5,4576052 5395798.5,4576052 5395818.5,4576042 5395828.5,4576042
5395838.5,4576022 5395858.5,4576022 5395868.5,4576032 5395878.5,4576032
5395908.5,4576022 5395918.5,4576022 5395928.5,4576012 5395938.5,4576012
5395958.5,4576002 5395968.5,4576002 5395998.5,4575992 5396008.5,4575992
5396018.5,4575972 5396038.5,4575972 5396048.5,4575952 5396068.5,4575952
5396078.5,4575922 5396108.5,4575922 5396118.5,4575902 5396138.5,4575902
5396148.5,4575872 5396178.5,4575852 5396158.5,4575852 5396148.5,4575842
5396138.5,4575842 5396128.5,4575822 5396108.5,4575822 5396128.5,4575812
5396138.5,4575792 5396138.5,4575792 5396148.5,4575802 5396158.5,4575812
5396158.5,4575832 5396178.5,4575842 5396168.5,4575872 5396198.5,4575872
5396208.5,4575862 5396218.5,4575882 5396238.5,4575902 5396238.5,4575912
5396248.5,4575912 5396258.5,4575882 5396288.5,4575882 5396298.5,4575872
5396308.5,4575862 5396308.5,4575852 5396318.5,4575852 5396328.5,4575832
5396348.5,4575812 5396328.5,4575802 5396328.5,4575782 5396308.5,4575812
5396278.5,4575822 5396278.5,4575802 5396258.5,4575802 5396238.5,4575752
5396238.5,4575742 5396248.5,4575732 5396238.5,4575692 5396238.5,4575682
5396248.5,4575662 5396248.5,4575662 5396258.5,4575642 5396278.5,4575632
5396278.5,4575642 5396288.5,4575642 5396308.5,4575632 5396318.5,4575622
5396318.5,4575622 5396348.5,4575612 5396358.5,4575602 5396358.5,4575592
5396348.5,4575582 5396348.5,4575572 5396338.5,4575592 5396318.5,4575602
5396318.5,4575592 5396308.5,4575592 5396298.5,4575582 5396288.5,4575582
5396298.5,4575572 5396308.5,4575562 5396308.5,4575562 5396318.5,4575552
5396328.5,4575552 5396338.5,4575542 5396348.5,4575532 5396348.5,4575512
5396368.5,4575512 5396378.5,4575522 5396388.5,4575502 5396408.5,4575492
5396408.5,4575482 5396418.5,4575482 5396428.5,4575442 5396468.5,4575452
5396478.5,4575452 5396468.5,4575502 5396418.5,4575512 5396418.5,4575522
5396408.5,4575542 5396408.5,4575552 5396398.5,4575572 5396398.5,4575582
5396408.5,4575662 5396408.5,4575672 5396418.5,4575682 5396418.5,4575692
5396428.5,4575712 5396428.5,4575742 5396458.5,4575742 5396488.5,4575752
5396478.5,4575762 5396488.5,4575762 5396498.5,4575752 5396508.5,4575742
5396498.5,4575742 5396488.5,4575712 5396518.5,4575712 5396528.5,4575702
5396538.5,4575692 5396528.5,4575692 5396548.5,4575672 5396568.5,4575662
5396558.5,4575662 5396548.5,4575672 5396538.5,4575672 5396518.5,4575692
5396498.5,4575692 5396488.5,4575662 5396488.5,4575662 5396518.5,4575652
5396528.5,4575652 5396538.5,4575642 5396548.5,4575632 5396548.5,4575612
5396568.5,4575602 5396568.5,4575602 5396588.5,4575592 5396598.5,4575602
5396608.5,4575602 5396618.5,4575612 5396618.5,4575622 5396628.5,4575632
5396618.5,4575632 5396608.5,4575642 5396598.5,4575662 5396598.5,4575672
5396608.5,4575672 5396598.5,4575682 5396588.5,4575692 5396588.5,4575702
5396598.5,4575742 5396598.5,4575742 5396588.5,4575762 5396568.5,4575762
5396548.5,4575752 5396558.5,4575742 5396558.5,4575722 5396538.5,4575722
5396528.5,4575732 5396518.5,4575742 5396528.5,4575762 5396528.5,4575772
5396538.5,4575782 5396538.5,4575792 5396528.5,4575792 5396498.5,4575782
5396488.5,4575802 5396468.5,4575832 5396468.5,4575842 5396478.5,4575852
5396478.5,4575862 5396488.5,4575872 5396488.5,4575883 5396499,4575882
5396508.5,4575872 5396518.5,4575832 5396518.5,4575822 5396528.5,4575812
5396528.5,4575812 5396548.5,4575802 5396558.5,4575822 5396578.5,4575822
5396588.5,4575832 5396588.5,4575832 5396568.5,4575842 5396558.5,4575852
5396558.5,4575862 5396568.5,4575862 5396548.5,4575872 5396538.5,4575892
5396538.5,4575892 5396518.5,4575902 5396508.5,4575902 5396478.5,4575912
5396468.5,4575922 5396468.5,4575932 5396478.5,4575932 5396498.5,4575952
5396498.5,4575962 5396508.5,4575942 5396528.5,4575952 5396538.5,4575962
5396528.5,4575972 5396538.5,4575962 5396548.5,4575952 5396538.5,4575932
5396558.5,4575922 5396548.5,4575912 5396558.5,4575902 5396558.5,4575892
5396568.5,4575892 5396618.5,4575882 5396628.5,4575872 5396628.5,4575852
5396608.5,4575842 5396608.5,4575842 5396618.5,4575852 5396628.5,4575852
5396638.5,4575862 5396648.5,4575892 5396648.5,4575902 5396658.5,4575902
5396668.5,4575892 5396678.5,4575882 5396668.5,4575872 5396668.5,4575852
5396688.5,4575862 5396698.5,4575862 5396708.5,4575852 5396718.5,4575862
5396728.5,4575872 5396718.5,4575882 5396728.5,4575892 5396718.5,4575902
5396718.5,4575912 5396708.5,4575922 5396718.5,4575902 5396738.5,4575892
5396738.5,4575902 5396748.5,4575892 5396758.5,4575882 5396758.5,4575892
5396768.5,4575882 5396778.5,4575872 5396768.5,4575862 5396768.5,4575872
5396778.5,4575872 5396798.5,4575862 5396808.5,4575852 5396798.5,4575842
5396798.5,4575832 5396808.5,4575842 5396818.5,4575842 5396838.5,4575852
5396838.5,4575862 5396848.5,4575862 5396858.5,4575892 5396888.5,4575892
5396898.5,4575902 5396908.5,4575902 5396948.5,4575892 5396958.5,4575872
5396958.5,4575862 5396948.5,4575862 5396938.5,4575842 5396918.5,4575842
5396928.5,4575852 5396938.5,4575852 5396948.5,4575842 5396958.5,4575832
5396958.5,4575822 5396948.5,4575822 5396938.5,4575812 5396928.5,4575812
5396918.5,4575802 5396928.5,4575792 5396918.5,4575792 5396908.5,4575782
5396898.5,4575792 5396888.5,4575802 5396888.5,4575822 5396868.5,4575832
5396868.5,4575832 5396848.5,4575822 5396838.5,4575802 5396838.5,4575792
5396848.5,4575782 5396848.5,4575792 5396858.5,4575782 5396868.5,4575772
5396858.5,4575762 5396868.5,4575772 5396878.5,4575772 5396888.5,4575762
5396898.5,4575742 5396898.5,4575732 5396888.5,4575722 5396898.5,4575712
5396898.5,4575712 5396908.5,4575722 5396918.5,4575722 5396928.5,4575732
5396918.5,4575742 5396928.5,4575722 5396948.5,4575712 5396948.5,4575692
5396928.5,4575692 5396948.5,4575682 5396958.5,4575672 5396958.5,4575662
5396968.5,4575652 5396968.5,4575642 5396958.5,4575642 5396948.5,4575632
5396938.5,4575622 5396938.5,4575612 5396948.5,4575602 5396938.5,4575592
5396938.5,4575582 5396928.5,4575572 5396928.5,4575562 5396918.5,4575552
5396918.5,4575522 5396888.5,4575512 5396898.5,4575502 5396898.5,4575492
5396888.5,4575492 5396878.5,4575482 5396888.5,4575472 5396888.5,4575462
5396878.5,4575442 5396878.5,4575432 5396868.5,4575432 5396838.5,4575422
5396848.5,4575392 5396848.5,4575392 5396858.5,4575382 5396868.5,4575372
5396858.5,4575362 5396858.5,4575352 5396848.5,4575352 5396818.5,4575362
5396808.5,4575362 5396798.5,4575372 5396788.5,4575372 5396768.5,4575362
5396778.5,4575322 5396778.5,4575312 5396768.5,4575302 5396778.5,4575292
5396778.5,4575292 5396798.5,4575272 5396818.5,4575262 5396818.5,4575252
5396828.5,4575252 5396838.5,4575262 5396848.5,4575252 5396858.5,4575222
5396858.5,4575222 5396868.5,4575212 5396878.5,4575212 5396898.5,4575202
5396908.5,4575202 5396918.5,4575182 5396938.5,4575182 5396948.5,4575162
5396968.5,4575162 5396988.5,4575152 5396998.5,4575152 5397008.5,4575122
5397038.5,4575122 5397058.5,4575112 5397068.5,4575112 5397078.5,4575102
5397088.5,4575102 5397118.5,4575092 5397128.5,4575092 5397148.5,4575072
5397168.5,4575072 5397228.5,4575062 5397238.5,4575062 5397248.5,4575052
5397258.5,4575052 5397268.5,4575042 5397278.5,4575042 5397298.5,4575032
5397308.5,4575032 5397328.5,4575022 5397338.5,4575012 5397338.5,4575002
5397348.5,4575002 5397368.5,4575012 5397368.5,4575022 5397378.5,4575022
5397438.5,4575012 5397448.5,4575012 5397488.5,4575002 5397498.5,4575002
5397558.5,4574992 5397568.5,4574992 5397638.5,4574982 5397648.5,4574982
5397718.5,4574972 5397728.5,4574972 5397838.5,4574962 5397848.5,4574962
5397868.5,4574942 5397888.5,4574942 5397898.5,4574952 5397898.5,4574972
5397918.5,4574972 5397958.5,4574962 5397968.5,4574962 5398048.5,4574952
5398058.5,4574952 5398168.5,4574955.5 5398190.5,4574930.5
5398193,4574916 5398207.5,4574894 5398239,4574889.5 5398259.5,4574892
5398278.5,4574881.5 5398353.5,4574839 5398417.5,4574831
5398439,4574816.5 5398459.5,4574804 5398473,4574792.5 5398479,4574759
5398565.5,4574740 5398601.5,4574723 5398620,4574722 5398633,4574674
5398728,4574658.5 5398729.5,4574638 5398771,4574620.5 5398796,4574608
5398846,4574597.5 5398855,4574595.5 5398866.5,4574574.5
5398872.5,4574523 5398899,4574499.5 5398907.5,4574441
5398909.5,4574406.5 5398922.5,4574321 5398945.5,4574282
5398963.5,4574260 5398967,4574212 5398955,4574209.5 5398953,4574199.5
5398953,4574189.5 5398943,4574179.5 5398943,4574169.5 5398933,4574149.5
5398933,4574149.5 5398943,4574189.5 5398983,4574189.5 5398993,4574179.5
5399003,4574179.5 5399013,4574169.5 5399023,4574159.5 5399023,4574159.5
5399033,4574149.5 5399043,4574139.5 5399043,4574109.5 5399073,4574099.5
5399073,4574069.5 5399103,4574059.5 5399103,4574039.5 5399123,4574029.5
5399123,4573989.5 5399163,4573979.5 5399163,4573959.5 5399183,4573949.5
5399183,4573919.5 5399213,4573909.5 5399213,4573899.5 5399223,4573889.5
5399223,4573879.5 5399233,4573869.5 5399223,4573839.5 5399223,4573839.5
5399233,4573849.5 5399243,4573849.5 5399263,4573819.5 5399293,4573809.5
5399293,4573789.5 5399313,4573779.5 5399313,4573789.5 5399323,4573779.5
5399333,4573769.5 5399333,4573759.5 5399343,4573749.5 5399343,4573739.5
5399333,4573729.5 5399343,4573709.5 5399343,4573699.5 5399353,4573689.5
5399353,4573669.5 5399373,4573609.5 5399373,4573599.5 5399383,4573599.5
5399393,4573589.5 5399403,4573579.5 5399403,4573569.5 5399393,4573549.5
5399393,4573539.5 5399383,4573519.5 5399383,4573519.5 5399393,4573509.5
5399403,4573499.5 5399403,4573479.5 5399383,4573439.5 5399383,4573409.5
5399413,4573229.5 5399413,4573219.5 5399423,4573189.5 5399423,4573179.5
5399433,4573149.5 5399433,4573139.5 5399423,4573009.5 5399423,4572999.5
5399413,4572919.5 5399413,4572914 5399420,4572904 5399420,4572894
5399430,4572814 5399430,4572804 5399440,4572784 5399440,4572754
5399470,4572734 5399470,4572704 5399500,4572694 5399500,4572674
5399520,4572654 5399520,4572664 5399530,4572664 5399560,4572704
5399560,4572714 5399550,4572724 5399550,4572734 5399540,4572744
5399540,4572734 5399530,4572734 5399520,4572744 5399510,4572774
5399510,4572784 5399520,4572774 5399530,4572784 5399530,4572794
5399520,4572874 5399520,4572884 5399510,4572894 5399520,4572904
5399510,4572934 5399510,4572944 5399500,4572954 5399500,4572964
5399510,4572974 5399510,4572984 5399520,4572994 5399520,4572999.5
5399513,4573019.5 5399513,4573029.5 5399503,4573079.5 5399503,4573089.5
5399513,4573099.5 5399513,4573119.5 5399533,4573119.5 5399543,4573109.5
5399553,4573109.5 5399563,4573129.5 5399563,4573129.5 5399553,4573139.5
5399543,4573149.5 5399543,4573159.5 5399533,4573169.5 5399533,4573179.5
5399523,4573219.5 5399523,4573229.5 5399513,4573329.5 5399513,4573339.5
5399503,4573539.5 5399503,4573549.5 5399493,4573559.5 5399493,4573569.5
5399483,4573629.5 5399483,4573639.5 5399473,4573649.5 5399483,4573679.5
5399483,4573689.5 5399493,4573719.5 5399493,4573719.5 5399483,4573729.5
5399473,4573739.5 5399473,4573749.5 5399463,4573769.5 5399463,4573799.5
5399433,4573809.5 5399433,4573809.5 5399423,4573839.5 5399393,4573849.5
5399393,4573859.5 5399383,4573869.5 5399383,4573879.5 5399373,4573889.5
5399373,4573899.5 5399363,4573909.5 5399363,4573909.5 5399353,4573899.5
5399343,4573899.5 5399323,4573909.5 5399313,4573919.5 5399323,4573939.5
5399323,4573979.5 5399283,4573989.5 5399283,4573999.5 5399273,4574019.5
5399273,4574029.5 5399263,4574049.5 5399263,4574059.5 5399253,4574059.5
5399243,4574069.5 5399233,4574089.5 5399233,4574089.5 5399223,4574099.5
5399213,4574099.5 5399203,4574109.5 5399193,4574119.5 5399203,4574159.5
5399163,4574169.5 5399163,4574219.5 5399113,4574219.5 5399103,4574249.5
5399073,4574249.5 5399063,4574259.5 5399053,4574269.5 5399053,4574289.5
5399073,4574309.5 5399053,4574319.5 5399053,4574329.5 5399043,4574349.5
5399043,4574359.5 5399033,4574369.5 5399033,4574379.5 5399023,4574389.5
5399023,4574399.5 5399013,4574409.5 5399013,4574419.5 5399003,4574439.5
5399003,4574449.5 5398993,4574469.5 5398993,4574469.5 5398973,4574499.5
5398943,4574509.5 5398953,4574509.5 5398973,4574599.5 5398973,4574619.5
5398993,4574619.5 5399003,4574609.5 5399013,4574599.5 5399013,4574599.5
5399023,4574549.5 5399073,4574539.5 5399073,4574519.5 5399093,4574509.5
5399093,4574499.5 5399103,4574489.5 5399103,4574469.5 5399123,4574449.5
5399123,4574429.5 5399143,4574379.5 5399143,4574369.5 5399153,4574359.5
5399153,4574349.5 5399163,4574329.5 5399163,4574319.5 5399173,4574309.5
5399173,4574299.5 5399183,4574289.5 5399183,4574279.5 5399193,4574269.5
5399183,4574259.5 5399183,4574239.5 5399203,4574219.5 5399203,4574209.5
5399213,4574199.5 5399213,4574179.5 5399233,4574159.5 5399233,4574149.5
5399243,4574139.5 5399243,4574129.5 5399253,4574119.5 5399253,4574109.5
5399263,4574099.5 5399263,4574089.5 5399273,4574079.5 5399273,4574069.5
5399283,4574069.5 5399293,4574049.5 5399313,4574029.5 5399313,4574009.5
5399333,4573999.5 5399323,4573989.5 5399323,4573969.5 5399343,4573969.5
5399353,4573939.5 5399383,4573919.5 5399383,4573909.5 5399393,4573909.5
5399403,4573869.5 5399443,4573859.5 5399443,4573839.5 5399463,4573839.5
5399473,4573829.5 5399483,4573819.5 5399483,4573809.5 5399493,4573799.5
5399493,4573769.5 5399523,4573769.5 5399533,4573739.5 5399563,4573739.5
5399573,4573729.5 5399583,4573719.5 5399583,4573719.5 5399593,4573709.5
5399603,4573709.5 5399613,4573679.5 5399643,4573679.5 5399663,4573639.5
5399703,4573639.5 5399713,4573619.5 5399733,4573619.5 5399743,4573609.5
5399753,4573609.5 5399763,4573599.5 5399773,4573599.5 5399783,4573569.5
5399813,4573569.5 5399823,4573549.5 5399843,4573549.5 5399853,4573489.5
5399913,4573489.5 5399923,4573479.5 5399933,4573469.5 5399933,4573469.5
5399943,4573439.5 5399973,4573429.5 5399973,4573429.5 5399983,4573424
5399990,4573414 5399990,4573394 5400010,4573394 5400020,4573344
5400070,4573344 5400080,4573334 5400090,4573334 5400100,4573324
5400110,4573324 5400120,4573314 5400130,4573314 5400140,4573294
5400160,4573294 5400180,4573274 5400200,4573274 5400210,4573244
5400240,4573244 5400260,4573234 5400270,4573234 5400290,4573224
5400300,4573224 5400320,4573214 5400330,4573214 5400340,4573194
5400360,4573194 5400370,4573184 5400380,4573184 5400390,4573164
5400410,4573164 5400420,4573144 5400440,4573144 5400450,4573114
5400480,4573114 5400490,4573104 5400500,4573094 5400510,4573084
5400510,4573084 5400520,4573034 5400570,4573034 5400580,4572994
5400620,4572984 5400620,4572974 5400610,4572964 5400610,4572614
5402050,4572614 5402040,4572594 5402030,4572584 5402020,4572574
5402020,4572564 5402000,4572554 5402000,4572544 5401990,4572494
5401970,4572474 5401970,4572444 5401950,4572434 5401940,4572414
5401930,4572404 5401920,4572494 5402050,4572464 5402040,4572404
5402040,4572184 5402160,4572056.727 5402141.818,4572024 5402150,4572009
5402135,4571904 5402120,4571924 5402110,4571924 5402100,4572004
5402130,4572009 5402135,4572056.727 5402141.818,4572064 5402140,4572184
5402160,4571977.829 5401970.432,4571836.698 5401939.281,4571654.393
5401921.131,4571465.504 5401897.582,4571321.206 5401856.119,4571234.363
5401821.73,4571084.45 5401773.725,4571061.53 5401738.561,4571032.985
5401659.457,4571003.147 5401661.364,4570893.923 5401619.481,4570818.294
5401595.143,4570749.534 5401527.801,4570722.508 5401509.883,4570697.721
5401497.639,4570647.849 5401477.855,4570544.038 5401408.347,4570406.7
5401367.444,4570197.288 5401342.574,4570001.999 5401396.699,4569740.381
5401367.062,4569685.358 5401330.405,4569642.728 5401190.272,4569550.6
5401085.975,4569497.071 5401001.208,4569520.638 5400887.166,4569520.737
5400775.771,4569427.787 5400707.832,4569347.271 5400653.122,4569288.49
5400616.553,4569136.794 5400586.214,4568999.998 5400704.59,4568877.829
5400846.262,4568791.626 5400943.527,4568612.778 5401080.586,4568637.533
5401071.504,4568453.91 5401335.186,4568259.317 5401596.861,4567984.077
5401808.381,4567562.685 5402122.866,4567377.783 5402257.228,4566768.225
5402717.633,4566717.68 5402766.388,4566503.816 5402962.319,4566343.568
5403106.542,4566168.873 5403266.902,4566000.267 5403417.793,4565638.536
5403757.03,4565499.184 5403885.594,4565189.166 5404209.171,4565142.847
5404261.446,4565105.561 5404300.551,4564802.106 5404611.024,4564498.467
5404925.443,4564325.676 5405012.26,4564122.668 5405032.448,4563969.594
5405065.187,4563873.139 5405065.265,4563856.65 5405105.038,4563947.396
5405162.601,4564107.556 5405177.838,4564282.615 5405231.676,4564475.959
5405327.501,4564807.115 5405464.975,4565112.876 5405688.116,4565310.96
5405871.979,4565540.935 5406066.493,4565807.245 5406301.836,4565856.79
5406338.996,4565989.945 5406422.604,4566089.037 5406518.6,4566181.936
5406592.918,4566268.641 5406636.271,4566373.926 5406716.783,4566522.564
5406846.841,4566623.602 5406846.05,4566669.784 5406855.757,4566681.137
5406859.356,4566692.675 5406864.802,4566705.229 5406873.386,4566721.17
5406893.727,4566731.111 5406903.669,4566753.099 5406946.496,4566777.189
5407000.985,4566792.484 5407019.912,4566820.206 5407036.546,4566924.023
5407073.064,4566940.848 5407080.902,4566959.393 5407086.255,4566994.19
5407099.065,4567089.211 5407142.466,4567143.7 5407172.1,4567200.101
5407206.132,4567217.698 5407219.119,4567232.222 5407226.589,4567267.592
5407249.914,4567297.8 5407276.299,4567384.027 5407344.745,4567478.092
5407426.574,4567541.185 5407490.814,4567613.073 5407574.364,4567667.18
5407644.532,4567757.039 5407763.261,4567811.5 5407841,4567919
5407982.5,4567978 5407953.5,4568028.5 5407941.5,4568074
5407937,4568134.5 5407938,4568152 5407952,4568149 5407964.5,4568124.5
5407966.5,4568063 5407968.5,4568012.5 5407980,4567963 5408000,4567946
5408014,4568024.5 5408114.5,4568075.5 5408174,4568210.5
5408339.5,4568331 5408473.5,4568805 5408971.5,4568987.5
5409188.5,4569106 5409343.5,4569210 5409494,4569362 5409753,4569491.5
5409991,4569673.188 5410355.366,4569629.077 5410371.908,4569551.5
5410238,4569317 5409774,4569195 5409574,4568930 5409200.5,4568776.5
5409018.5,4568703 5408940,4568322 5408545.5,4568125 5408323,4568096
5408289,4568064.5 5408248.5,4568038 5408269.5,4568003
5408293.5,4567952.5 5408312,4567889.5 5408341,4567852.5
5408370.5,4567813.5 5408419,4567755.5 5408454,4567544.137
5408529.123,4567640.334 5408669.958,4568277 5409280.5,4568662
5409652,4568865.5 5409834.5,4568964.5 5409938.5,4569022 5409994,4569058
5410045,4569135 5410147.5,4569216 5410275.5,4569336.008
5410497.066,4569304.914 5410507.805,4569260.5 5410407,4569250.5
5410397,4569250.5 5410387,4569240.5 5410377,4569240.5 5410367,4569230.5
5410357,4569230.5 5410347,4569220.5 5410337,4569220.5 5410327,4569200.5
5410307,4569200.5 5410297,4569190.5 5410287,4569190.5 5410277,4569180.5
5410267,4569190.5 5410257,4569180.5 5410247,4569180.5 5410237,4569170.5
5410227,4569170.5 5410217,4569160.5 5410207,4569150.5 5410207,4569140.5
5410197,4569140.5 5410187,4569120.5 5410167,4569120.5 5410157,4569100.5
5410137,4569100.5 5410127,4569080.5 5410107,4569080.5 5410097,4569060.5
5410077,4569060.5 5410057,4569040.5 5410037,4569040.5 5410027,4569020.5
5410007,4569020.5 5409997,4569010.5 5410007,4568950.5 5409947,4568950.5
5409957,4568940.5 5409967,4568930.5 5409957,4568920.5 5409957,4568870.5
5409907,4568870.5 5409897,4568860.5 5409897,4568670.5 5409707,4568660.5
5409707,4568650.5 5409697,4568650.5 5409687,4568660.5 5409677,4568670.5
5409677,4568660.5 5409667,4568650.5 5409667,4568620.5 5409637,4568610.5
5409637,4568600.5 5409647,4568420.5 5409467,4568410.5 5409467,4568320.5
5409377,4568330.5 5409367,4568310.5 5409367,4567640.5 5408697,4567630.5
5408707,4567620.5 5408697,4567630.5 5408687,4567563.306
5408619.806,4567543.638 5408607,4567540.5 5408607,4567534.645
5408601.146,4567528.279 5408597,4567520.5 5408597,4567510.5
5408587,4567500.5 5408587,4567490 5408581.5,4567448.664
5408545.164,4567104.739 5408321.239,4567110.5 5408327,4567110.5
5408337,4567120.5 5408347,4567120.5 5408357,4567140.5 5408377,4567140.5
5408387,4567190.5 5408387,4567200.5 5408397,4567220.5 5408397,4567230.5
5408407,4567230.5 5408417,4567220.5 5408427,4567220.5 5408437,4567210.5
5408447,4567200.5 5408447,4567200.5 5408467,4567202 5408478,4567197
5408494,4567184 5408510,4567161 5408526.5,4567115.5 5408553,4567074.5
5408580,4567067 5408591,4567071 5408602.5,4567104.5 5408657,4567111
5408677.5,4567106.5 5408689,4567090.5 5408697,4567080.5
5408697,4567060.5 5408717,4567050.5 5408717,4567040.5 5408727,4567020.5
5408727,4567010.5 5408737,4567000.5 5408737,4566970.5 5408767,4566950.5
5408767,4566950.5 5408777,4566940.5 5408787,4566930.5 5408787,4566920.5
5408797,4566910.5 5408797,4566890.5 5408817,4566880.5 5408817,4566870.5
5408827,4566860.5 5408827,4566850.5 5408837,4566870.5 5408857,4566860.5
5408867,4566870.5 5408877,4566880.5 5408877,4566890.5 5408887,4566880.5
5408897,4566900.5 5408917,4566910.5 5408917,4566950.5 5408957,4566966.5
5408968.5,4566985.5 5408978.5,4566999.5 5408990.5,4567010.5
5409007,4567010.5 5409017,4567000.5 5409027,4566990.5 5409027,4566950.5
5408987,4566930.5 5409007,4566930.5 5409037,4566940.5 5409047,4566940.5
5409057,4566930.5 5409067,4566910.5 5409067,4566900.5 5409077,4566860.5
5409077,4566850.5 5409087,4566840.5 5409087,4566830.5 5409097,4566820.5
5409097,4566820.5 5409117,4566830.5 5409127,4566830.5 5409137,4566840.5
5409147,4566840.5 5409167,4566830.5 5409177,4566830.5 5409197,4566840.5
5409207,4566840.5 5409217,4566860.5 5409237,4566860.5 5409247,4566900.5
5409287,4566900.5 5409337,4566890.5 5409347,4566760.5 5409347,4566750.5
5409357,4566740.5 5409347,4566730.5 5409347,4566720.5 5409337,4566720.5
5409327,4566690.5 5409297,4566670.5 5409317,4566660.5 5409307,4566650.5
5409307,4566640.5 5409297,4566640.5 5409287,4566650.5 5409277,4566660.5
5409277,4566650.5 5409267,4566640.5 5409267,4566630.5 5409257,4566620.5
5409257,4566610.5 5409247,4566600.5 5409247,4566590.5 5409257,4566590.5
5409307,4566580.5 5409317,4566580.5 5409367,4566560.5 5409387,4566560.5
5409427,4566540.5 5409447,4566540.5 5409457,4566550.5 5409447,4566570.5
5409447,4566580.5 5409437,4566600.5 5409437,4566610.5 5409427,4566640.5
5409427,4566650.5 5409437,4566650.5 5409447,4566640.5 5409457,4566640.5
5409477,4566630.5 5409487,4566610.5 5409487,4566590.5 5409507,4566610.5
5409527,4566620.5 5409527,4566630.5 5409517,4566650.5 5409517,4566670.5
5409497,4566730.5 5409497,4566740.5 5409487,4566760.5 5409487,4566770.5
5409477,4566780.5 5409477,4566800.5 5409497,4566820.5 5409497,4566830.5
5409487,4566820.5 5409477,4566820.5 5409467,4566830.5 5409457,4566850.5
5409457,4566860.5 5409447,4566880.5 5409467,4566880.5 5409477,4566900.5
5409457,4566910.5 5409467,4566910.5 5409477,4566930.5 5409497,4566930.5
5409527,4566970.5 5409567,4566980.5 5409567,4566990.5 5409577,4566990.5
5409587,4566980.5 5409597,4566980.5 5409617,4566990.5 5409617,4567010.5
5409637,4567020.5 5409637,4567030.5 5409647,4567050.5 5409647,4567060.5
5409657,4567060.5 5409677,4567080.5 5409697,4567070.5 5409707,4567070.5
5409717,4567050.5 5409737,4567060.5 5409737,4567070.5 5409747,4567170.5
5409747,4567180.5 5409737,4567210.5 5409737,4567220.5 5409747,4567250.5
5409747,4567270.5 5409767,4567280.5 5409757,4567290.5 5409757,4567300.5
5409767,4567320.5 5409767,4567330.5 5409777,4567320.5 5409787,4567270.5
5409787,4567290.5 5409807,4567290.5 5409817,4567320.5 5409817,4567330.5
5409827,4567340.5 5409827,4567340.5 5409807,4567350.5 5409797,4567370.5
5409817,4567370.5 5409837,4567400.5 5409837,4567410.5 5409847,4567430.5
5409847,4567450.5 5409867,4567450.5 5409877,4567460.5 5409887,4567470.5
5409887,4567510.5 5409927,4567520.5 5409927,4567530.5 5409937,4567530.5
5409947,4567520.5 5409957,4567490.5 5409957,4567480.5 5409967,4567480.5
5410027,4567440.5 5410067,4567430.5 5410067,4567420.5 5410077,4567410.5
5410077,4567390.5 5410097,4567380.5 5410097,4567370.5 5410107,4567370.5
5410117,4567310.5 5410177,4567300.5 5410177,4567300.5 5410187,4567290.5
5410197,4567290.5 5410207,4567250.5 5410247,4567230.5 5410247,4567220.5
5410257,4567200.5 5410257,4567190.5 5410267,4567180.5 5410267,4567180.5
5410277,4567140.5 5410317,4567090.5 5410317,4567080.5 5410327,4567060.5
5410327,4567050.5 5410337,4567010.5 5410337,4567000.5 5410347,4566918
5410366,4566888 5410336,4566888 5410316,4566878 5410306,4566878
5410296,4566868 5410286,4566868 5410276,4566848 5410256,4566848
5410236,4566838 5410246,4566828 5410236,4566828 5410226,4566818
5410216,4566818 5410176,4566828 5410166,4566768 5410166,4566718
5410116,4566678 5410116,4566668 5410106,4566648 5410106,4566638
5410116,4566588 5410116,4566578 5410106,4566558 5410106,4566548
5410096,4566488 5410096,4566468 5410076,4566458 5410086,4566448
5410086,4566438 5410076,4566418 5410096,4566408 5410086,4566398
5410096,4566388 5410096,4566378 5410086,4566378 5410076,4566368
5410066,4566359.5 5410062,4566359.5 5410052,4566339.5 5410032,4566349.5
5410022,4566349.5 5410012,4566379.5 5409982,4566379.5 5409972,4566389.5
5409962,4566398 5409956,4566389.5 5409952,4566389.5 5409942,4566399.5
5409932,4566408 5409936,4566428 5409916,4566428 5409906,4566458
5409876,4566458 5409866,4566478 5409846,4566488 5409846,4566498
5409836,4566488 5409826,4566488 5409816,4566478 5409806,4566498
5409786,4566488 5409776,4566488 5409766,4566468 5409746,4566459.5
5409742,4566399.5 5409742,4566389.5 5409732,4566379.5 5409732,4566379.5
5409802,4566359.5 5409822,4566349.5 5409822,4566339.5 5409812,4566339.5
5409832,4566319.5 5409852,4566309.5 5409852,4566299.5 5409862,4566289.5
5409852,4566279.5 5409852,4566269.5 5409862,4566249.5 5409862,4566239.5
5409872,4566209.5 5409872,4566209.5 5409882,4566239.5 5409912,4566259.5
5409912,4566269.5 5409902,4566279.5 5409912,4566289.5 5409912,4566299.5
5409922,4566289.5 5409932,4566249.5 5409932,4566259.5 5409942,4566239.5
5409962,4566239.5 5409972,4566229.5 5409982,4566219.5 5409992,4566209.5
5409992,4566219.5 5410002,4566209.5 5410012,4566209.5 5410022,4566199.5
5410032,4566199.5 5410052,4566179.5 5410072,4566169.5 5410072,4566159.5
5410082,4566139.5 5410082,4566109.5 5410112,4566109.5 5410122,4566069.5
5410162,4566069.5 5410172,4566049.5 5410192,4566019.5 5410192,4566019.5
5410202,4565989.5 5410232,4565959.5 5410232,4565959.5 5410252,4565949.5
5410262,4565929.5 5410262,4565919.5 5410272,4565909.5 5410262,4565909.5
5410282,4565889.5 5410302,4565879.5 5410292,4565859.5 5410292,4565849.5
5410302,4565809.5 5410302,4565799.5 5410312,4565759.5 5410312,4565762.5
5410269.5,4565801 5410239,4565822 5410266.5,4565843 5410260,4565889
5410232,4565866 5410205.5,4565837.5 5410201.5,4565836.5
5410154,4565826.5 5410071,4565808.5 5410045.5,4565818.5
5410021.5,4565795.5 5409978.5,4565443.5 5409906.5,4565443.5
5409793,4565206.5 5409793,4565199 5409831.5,4565089.5 5409838.5,4565071
5410129.5,4565030 5410297.5,4564941.5 5410291.5,4564882.5
5410360.5,4564833.5 5410377,4564759.5 5410374.5,4564707
5410398.5,4564569.5 5410387,4564558 5410387,4564548 5410397,4564519.5
5410397,4564509.5 5410387,4564368 5410387,4564358 5410397,4564218
5410397,4564208 5410407,4564199.5 5410407,4564189.5 5410397,4564128
5410397,4564118 5410407,4564108 5410407,4564098 5410417,4564089.5
5410417,4564079.5 5410407,4564069.5 5410407,4564058.5 5410396.5,4564048
5410407,4564038 5410407,4564028 5410417,4563959.5 5410417,4563949.5
5410407,4563928 5410407,4563918.5 5410416.5,4563899.5 5410397,4563888
5410397,4563878 5410407,4563850.5 5410407,4563848.5 5410409.5,4563835.5
5410412,4563779.5 5410412,4563769.5 5410422,4563699.5 5410422,4563689.5
5410432,4563679.5 5410432,4563659.5 5410412,4563659.5 5410392,4563649.5
5410382,4563639.5 5410382,4563629.5 5410372,4563619.5 5410382,4563599.5
5410382,4563589.5 5410372,4563579.5 5410372,4563569.5 5410362,4563569.5
5410352,4563559.5 5410342,4563559.5 5410312,4563549.5 5410312,4563549.5
5410342,4563539.5 5410352,4563529.5 5410352,4563519.5 5410342,4563519.5
5410332,4563529.5 5410322,4563529.5 5410302,4563539.5 5410292,4563549.5
5410292,4563549.5 5410282,4563569.5 5410262,4563569.5 5410232,4563579.5
5410222,4563579.5 5410192,4563569.5 5410182,4563569.5 5410152,4563549.5
5410132,4563549.5 5410122,4563539.5 5410112,4563539.5 5410102,4563529.5
5410092,4563529.5 5410082,4563509.5 5410062.5,4563486
5410011.5,4563519.5 5409988,4563519 5409984.5,4563478.5 5409967,4563430
5409927.5,4563372.5 5409877.5,4563333 5409834,4563291 5409776,4563248
5409733.5,4563210.5 5409709.5,4563181 5409706.5,4563158.5
5409708.5,4563157 5409712,4563195 5409751.5,4563215.5 5409778.5,4563284
5409881.5,4563322 5409944.5,4563366.5 5410027,4563377 5410070,4563424.5
5410149,4563446.5 5410191,4563448 5410219,4563447 5410245.5,4563434
5410262.5,4563410.5 5410280,4563360 5410272,4563327 5410259,4563202.5
5410201,4563171 5410204,4563089 5410187,4563027.5 5409969.5,4563025.5
5409968,4562970.5 5409969,4562941 5409980,4562911 5410011,4562884.5
5410015,4562883 5410017,4562878 5410125.5,4562880.5 5410126,4562878
5410128,4562878 5410125.5),(4570774 5402849.033,4570777.479
5402838.261,4570805.095 5402752.738,4570806.924 5402747.077,4570806.006
5402749.953,4570805.095 5402752.738,4570781.954 5402824.689,4570777.479
5402838.261,4570776.876 5402840.324,4570774 5402849.033),(4571285.765
5408495.315,4571292 5408436.5,4571292.137 5408438.425,4571285.765
5408495.315),(4570816.582 5402729.434,4570821.176 5402715.648,4570864
5402570.325,4570864 5402570,4570864.155 5402569.845,4570871.334
5402546.928,4570898.253 5402464.253,4570894 5402460,4570895.668
5402459.731,4570898.253 5402464.253,4570864.155 5402569.845,4570864
5402570.325,4570861.871 5402580.726,4570821.176 5402715.648,4570814
5402740,4570816.582 5402729.434),(4566665 5406634,4566678.974
5406622.743,4566684.521 5406614.764,4566719 5406590.5,4566678.974
5406622.743,4566663.5 5406645,4566665 5406634),(4571095.5
5408567.5,4571102.5 5408555.5,4571131 5408546.5,4571095.5
5408567.5),(4569842 5404392.5,4569941 5404483.5,4569925 5404471,4569884
5404433.5,4569842 5404392.5),(4569910 5404512,4569920 5404502,4569950
5404512,4569910 5404512),(4572524 5402090,4572534 5402100,4572564
5402140,4572584 5402160,4572574 5402160,4572564 5402150,4572524
5402090),(4569356.586 5410606.657,4569377.067 5410593.656,4569392.926
5410630.33,4569374.473 5410639.45,4569356.586 5410606.657),(4582632
5392963.5,4582632.5 5392959,4582639 5392953,4582641.5 5392948,4582644.5
5392946,4582654 5392945.5,4582667 5392947.5,4582670 5392949.5,4582672.5
5392953.5,4582671 5392965,4582667.5 5392967.5,4582662.5 5392976,4582660
5392978,4582649 5392979.5,4582642.5 5392977,4582639.5 5392982.5,4582638
5392982.5,4582632 5392963.5),(4571245 5408407,4571291.5
5408377.5,4571313.5 5408358,4571302.079 5408397.124,4571277
5408404.5,4571265.899 5408412.321,4571245 5408407),(4565687.028
5412191.47,4565759.5 5412112,4565816.352 5412111.154,4565728.067
5412202.931,4565687.028 5412191.47),(4581424.5 5392523,4581428
5392520,4581429.5 5392515,4581437 5392512.5,4581440.5 5392507,4581449
5392504.5,4581456 5392494.5,4581466 5392491,4581469 5392483.5,4581480.5
5392481.5,4581487.5 5392486,4581497 5392495,4581500.5 5392502,4581512
5392504.5,4581512.5 5392505.5,4581509.5 5392508,4581505.5
5392508.5,4581505.5 5392511,4581518.5 5392529,4581526 5392533,4581528.5
5392533.5,4581530 5392532.5,4581531 5392535,4581521.5
5392542.5,4581499.5 5392553.5,4581495 5392560,4581488.5
5392563,4581484.5 5392567.5,4581476 5392571.5,4581471.5
5392576.5,4581464.5 5392580,4581460 5392585,4581449.5
5392587.5,4581445.5 5392590.5,4581440.5 5392597,4581427
5392602.5,4581422 5392606,4581412 5392606.5,4581409.5 5392608,4581406.5
5392613,4581406 5392621,4581402.5 5392625,4581391 5392627.5,4581381.5
5392625.5,4581369.5 5392626.5,4581369.5 5392623.5,4581376
5392624,4581377.5 5392621.5,4581373 5392612.5,4581370 5392595,4581366.5
5392584.5,4581370.5 5392575,4581375.5 5392571,4581379 5392563,4581384.5
5392559.5,4581390 5392552.5,4581392 5392546,4581397.5 5392542,4581400.5
5392535.5,4581408 5392534,4581416.5 5392525.5,4581424.5
5392523),(4577954.347 5399138.644,4577989.539 5399107.073,4578109
5399299,4578166.5 5399425.5,4578230.5 5399602.5,4578194
5399607,4578153.5 5399476.5,4578107.5 5399375,4578043.5
5399267,4577954.347 5399138.644),(4581659.5 5392384.5,4581669
5392382,4581674.5 5392377.5,4581679 5392370.5,4581682 5392370,4581691.5
5392372.5,4581714 5392369,4581719.5 5392363.5,4581728 5392347,4581730.5
5392345.5,4581739 5392356.5,4581748.5 5392362.5,4581759.5
5392364.5,4581770 5392364.5,4581771 5392365.5,4581771 5392375,4581777.5
5392385,4581774.5 5392389.5,4581770 5392391,4581757 5392399.5,4581749
5392410,4581747 5392414.5,4581749.5 5392425,4581759.5 5392427.5,4581764
5392434.5,4581764.5 5392446.5,4581760.5 5392480.5,4581741.5
5392496,4581729 5392504.5,4581719.5 5392509,4581702 5392510.5,4581687.5
5392503.5,4581679.5 5392503.5,4581678.5 5392506,4581679.5
5392535,4581671.5 5392557.5,4581670.5 5392566,4581664 5392577,4581654
5392586,4581644.5 5392589.5,4581640 5392588.5,4581637.5
5392586.5,4581634 5392575,4581614 5392549.5,4581610.5 5392542,4581603.5
5392532.5,4581601.5 5392524.5,4581587.5 5392512,4581574.5
5392505,4581574 5392496.5,4581571 5392490,4581569.5 5392489.5,4581566.5
5392495.5,4581566.5 5392504,4581565.5 5392506,4581558 5392511.5,4581557
5392517,4581551.5 5392522.5,4581547 5392521,4581541.5 5392516,4581539.5
5392512.5,4581528.5 5392506,4581519.5 5392497,4581518.5 5392491,4581520
5392477.5,4581530.5 5392464.5,4581536.5 5392462,4581542.5
5392463,4581551 5392468,4581557.5 5392469,4581562 5392471.5,4581566
5392475.5,4581568.5 5392481,4581572.5 5392483.5,4581576.5
5392482,4581578.5 5392474.5,4581578 5392464.5,4581581.5
5392455.5,4581586.5 5392449,4581592 5392436,4581599 5392431.5,4581608.5
5392430,4581616.5 5392424.5,4581623.5 5392416,4581633.5
5392396.5,4581640.5 5392393.5,4581647 5392392.5,4581659.5
5392384.5),(4567896.5 5409901,4567906 5409838,4568032 5409879,4568218
5409947,4568571 5410026.5,4568767 5410036.5,4568767 5410089.5,4568668
5410085,4568479.5 5410051,4568109.5 5409951.5,4567896.5
5409901),(4577187 5397993.5,4577215 5397971,4577270.5
5398072.5,4577369.5 5398223,4577736 5398743,4577892.64
5398981.951,4577868.141 5399001.486,4577685 5398739.5,4577291
5398170,4577239 5398089,4577187 5397993.5),(4582437.5 5392938,4582440.5
5392930.5,4582453.5 5392930,4582461 5392931.5,4582480.5
5392939.5,4582490 5392945.5,4582504.5 5392949,4582506 5392951,4582502
5392960,4582497.5 5392964,4582494 5392965.5,4582485.5
5392965.5,4582475.5 5392977,4582472.5 5392985,4582472.5
5392991,4582478.5 5393003.5,4582481.5 5393004.5,4582488
5393002,4582496.5 5392996.5,4582509.5 5392998,4582520.5
5392997.5,4582525 5392989.5,4582526 5392985,4582536.5 5392979,4582533.5
5392971.5,4582536.5 5392968,4582539 5392959,4582535.5 5392950,4582535
5392944.5,4582531 5392931.5,4582532 5392924.5,4582535 5392922,4582540.5
5392921.5,4582550.5 5392910,4582551.5 5392899,4582549 5392895,4582546.5
5392896,4582540 5392892,4582532.5 5392890,4582519.5 5392878,4582507
5392860,4582508 5392850.5,4582513 5392838,4582517 5392834.5,4582521
5392833,4582523 5392830.5,4582530 5392810.5,4582539 5392803.5,4582550.5
5392792,4582565.5 5392760,4582569 5392754.5,4582580 5392742.5,4582584.5
5392734,4582594 5392726.5,4582600.5 5392718,4582606 5392715.5,4582609.5
5392711,4582631.5 5392704.5,4582647 5392696.5,4582654.5
5392690.5,4582656 5392685.5,4582661 5392684,4582666.5 5392674,4582672.5
5392671.5,4582688.5 5392675,4582696.5 5392675.5,4582698
5392674.5,4582706.5 5392656.5,4582711.5 5392655,4582718.5
5392648,4582721.5 5392649,4582735.5 5392661.5,4582741 5392664,4582748.5
5392659.5,4582759.5 5392648.5,4582780.5 5392636.5,4582789
5392629.5,4582807.5 5392621,4582809 5392618,4582812 5392618,4582818.5
5392613,4582822 5392612,4582832.5 5392613.5,4582833.5 5392611,4582825.5
5392580.5,4582826 5392579,4582831.5 5392575.5,4582834.5
5392570,4582839.5 5392566.5,4582857 5392570,4582862.5 5392572.5,4582874
5392595.5,4582874.5 5392599.5,4582872.5 5392603.5,4582879
5392607.5,4582883 5392613.5,4582883 5392616,4582879.5 5392619,4582878
5392618,4582871 5392607.5,4582867.5 5392605.5,4582859 5392608,4582852.5
5392613,4582851.5 5392615,4582853.5 5392626.5,4582863.5
5392633.5,4582861.5 5392636.5,4582854.5 5392640,4582854
5392644,4582856.5 5392658.5,4582856 5392663.5,4582850.5
5392680,4582830.5 5392720,4582826 5392725.5,4582820.5 5392740.5,4582801
5392742,4582786.5 5392759,4582775 5392764.5,4582771.5 5392770.5,4582763
5392775.5,4582754 5392792,4582730 5392799.5,4582721 5392809,4582712.5
5392811.5,4582708.5 5392821.5,4582702 5392826.5,4582689
5392828.5,4582681 5392832.5,4582661.5 5392830,4582651 5392832.5,4582641
5392832.5,4582623.5 5392826.5,4582618.5 5392826.5,4582602
5392837,4582590 5392839.5,4582584 5392842.5,4582580 5392842,4582576.5
5392843.5,4582555 5392857.5,4582552.5 5392862,4582538.5 5392869,4582538
5392870.5,4582541 5392879,4582551.5 5392889.5,4582570 5392895.5,4582579
5392896,4582582.5 5392898.5,4582583.5 5392904.5,4582591 5392917,4582592
5392921.5,4582588 5392927.5,4582585 5392937,4582573.5
5392949.5,4582561.5 5392959.5,4582560.5 5392963.5,4582555
5392964.5,4582554.5 5392970.5,4582550 5392975.5,4582546 5392977,4582552
5392990,4582559 5393000,4582559.5 5393002.5,4582555.5 5393015,4582540.5
5393020,4582531.5 5393019.5,4582521.5 5393010.5,4582519
5393019.5,4582513.5 5393029.5,4582498 5393045.5,4582492.5
5393062.5,4582483.5 5393083,4582476 5393085.5,4582474.5
5393090.5,4582467 5393096.5,4582464 5393102,4582454.5 5393106,4582459
5393120.5,4582460 5393130.5,4582457.5 5393136.5,4582454
5393141,4582454.5 5393144.5,4582452.5 5393149.5,4582460.5
5393169.5,4582473.5 5393180,4582466.5 5393186.5,4582459
5393190,4582447.5 5393191,4582439.5 5393189,4582435.5 5393194.5,4582433
5393207.5,4582435 5393213,4582440.5 5393219.5,4582452
5393226.5,4582454.5 5393231,4582449.5 5393236.5,4582433.5
5393246,4582427.5 5393264,4582424 5393270,4582426 5393276.5,4582418.5
5393277.5,4582409.5 5393271,4582401 5393268.5,4582396 5393270,4582394.5
5393272,4582391.5 5393272,4582389 5393270.5,4582382.5 5393259.5,4582383
5393231.5,4582386 5393218,4582383 5393207.5,4582383 5393200.5,4582386
5393187,4582385 5393168,4582388.5 5393158.5,4582388.5 5393148.5,4582395
5393136.5,4582395.5 5393133.5,4582394 5393114,4582396.5
5393091.5,4582397 5393074,4582399.5 5393067.5,4582409.5
5393060.5,4582408.5 5393049,4582417.5 5393040,4582418.5
5393032.5,4582417 5393027.5,4582417 5393020.5,4582420.5
5393017.5,4582423.5 5393019,4582425.5 5393021.5,4582426.5
5393029.5,4582440 5393036,4582444.5 5393034,4582449.5
5393029.5,4582453.5 5393020.5,4582451.5 5393014.5,4582446.5
5393009.5,4582438.5 5393005.5,4582435 5393005,4582430.5
5393012.5,4582429 5393011,4582428.5 5393005.5,4582430 5392992,4582432
5392990,4582439 5392988.5,4582441 5392981.5,4582440.5 5392969,4582447.5
5392958.5,4582440 5392946,4582437.5 5392938),(4565277 5412453,4565277
5412463,4565287 5412473,4565287 5412483,4565297 5412493,4565327
5412493,4565367 5412453,4565377 5412453,4565548.764
5412282.188,4565553.756 5412282.188,4565627.247 5412309.567,4565630.05
5412312.721,4565577 5412353,4565577 5412363,4565537 5412403,4565527
5412403,4565457 5412473,4565447 5412473,4565447 5412483,4565437
5412493,4565427 5412493,4565367 5412553,4565367 5412593,4565407
5412633,4565417 5412633,4565447 5412663,4565437 5412673,4565427
5412673,4565417 5412663,4565407 5412663,4565387 5412643,4565377
5412643,4565367 5412633,4565357 5412633,4565347 5412623,4565337
5412623,4565327 5412613,4565287 5412613,4565257 5412643,4565247
5412643,4565217 5412673,4565207 5412673,4565167 5412713,4565157
5412713,4565127 5412743,4565117 5412743,4565097 5412763,4565087
5412763,4565057 5412793,4565047 5412793,4565017 5412823,4565007
5412823,4564977 5412853,4564967 5412853,4564937 5412883,4564927
5412883,4564907 5412903,4564897 5412903,4564867 5412933,4564857
5412933,4564847 5412943,4564827 5412943,4564817 5412953,4564807
5412943,4564877 5412873,4564887 5412873,4564917 5412843,4564927
5412843,4564967 5412803,4564977 5412803,4565017 5412763,4565027
5412763,4565087 5412703,4565097 5412703,4565157 5412643,4565167
5412643,4565237 5412573,4565237 5412553,4565247 5412543,4565247
5412503,4565237 5412493,4565237 5412463,4565247 5412453,4565247
5412433,4565287 5412393,4565297 5412393,4565307 5412383,4565327
5412383,4565337 5412373,4565347 5412373,4565357 5412383,4565337
5412403,4565327 5412403,4565317 5412413,4565307 5412413,4565287
5412433,4565287 5412443,4565277 5412453),(4565915.098
5412017.886,4565866.436 5412003.047,4565958 5411908,4565960.5
5411856.5,4566713.5 5411027,4566738 5411016,4566748 5411026,4566748
5411036,4566758 5411026,4566758 5410996,4566768 5410986,4566778
5410986,4566908 5410856,4566918 5410856,4566998 5410776,4567008
5410776,4567038 5410746,4567048 5410746,4567068 5410726,4567088
5410726,4567094.5 5410733,4566950.5 5410877,4566940.5 5410877,4566770.5
5411047,4566760.5 5411037,4566750.5 5411047,4566760.5 5411057,4566600.5
5411217,4566600.5 5411227,4566590.5 5411237,4566580.5 5411237,4566580.5
5411247,4566490.5 5411337,4566490.5 5411347,4566420.5 5411417,4566420.5
5411427,4566360.5 5411487,4566360.5 5411497,4566300.5 5411557,4566300.5
5411567,4566250.5 5411617,4566250.5 5411627,4566200.5 5411677,4566200.5
5411687,4566150.5 5411737,4566150.5 5411747,4566100.5 5411797,4566100.5
5411807,4566060.5 5411847,4566060.5 5411857,4566010.5
5411907,4565915.098 5412017.886),(4576754.5 5404012.5,4576776.5
5403986,4576829 5404012.5,4576867 5404015,4576922 5403997.5,4576982
5403960,4577216.5 5403802.5,4577247 5403857.5,4576867
5404105.5,4576821.5 5404139,4576797 5404174,4576797 5404231,4576769
5404251.5,4576756 5404223.5,4576719.5 5404206,4576682 5404223.5,4576217
5404541.5,4576102 5404634.5,4575858.5 5404836,4575672 5405012,4575631
5404971.5,4576036.5 5404614.5,4576501 5404269,4576735.5
5404121.5,4576769 5404083.5,4576773.5 5404047,4576754.5
5404012.5),(4582359.5 5393647.5,4582363 5393641.5,4582363
5393639.5,4582370.5 5393628.5,4582380 5393620,4582381.5
5393614.5,4582385 5393609,4582379.5 5393602,4582377.5 5393596.5,4582378
5393582,4582381 5393574.5,4582383 5393572.5,4582387 5393550,4582392.5
5393544,4582396 5393535.5,4582404 5393531.5,4582407.5
5393525.5,4582410.5 5393524.5,4582415.5 5393530,4582417
5393536.5,4582420 5393541,4582429.5 5393544,4582433.5 5393543,4582434
5393541,4582431 5393528,4582422 5393519,4582411.5 5393513.5,4582404
5393515,4582398 5393510,4582400 5393498.5,4582408 5393495.5,4582411.5
5393492.5,4582419 5393489,4582421.5 5393489.5,4582433 5393497.5,4582438
5393497.5,4582439 5393495.5,4582439 5393482.5,4582438 5393480,4582422
5393468,4582419.5 5393463.5,4582419 5393459.5,4582428.5
5393453.5,4582434 5393454.5,4582435 5393453.5,4582435.5
5393438.5,4582436.5 5393436,4582440 5393434,4582441 5393432,4582443
5393411.5,4582447.5 5393400,4582447 5393396,4582450.5
5393383.5,4582450.5 5393376.5,4582447.5 5393368,4582450
5393364.5,4582451 5393359,4582451.5 5393336.5,4582451 5393328.5,4582447
5393320,4582446.5 5393316,4582451 5393314.5,4582453.5
5393310.5,4582451.5 5393304.5,4582449.5 5393302.5,4582439
5393299.5,4582433 5393289.5,4582432.5 5393283,4582434.5
5393283,4582440.5 5393287,4582450 5393289.5,4582466.5 5393280,4582470.5
5393276.5,4582478 5393265,4582480.5 5393263.5,4582486 5393269.5,4582488
5393280,4582486.5 5393287,4582489 5393299,4582486 5393308.5,4582486
5393317,4582480 5393328,4582477.5 5393346.5,4582475 5393350,4582477.5
5393380,4582469.5 5393406.5,4582469.5 5393411.5,4582475.5
5393429.5,4582476.5 5393436,4582474.5 5393462.5,4582475
5393472.5,4582466.5 5393489,4582469.5 5393499,4582465.5
5393502,4582463.5 5393505.5,4582463.5 5393511,4582466.5
5393519.5,4582474.5 5393528,4582475.5 5393530.5,4582473.5
5393533,4582473.5 5393550.5,4582472 5393552.5,4582466 5393553,4582465
5393554.5,4582464.5 5393568,4582473 5393601.5,4582469.5 5393606,4582468
5393610.5,4582477 5393645,4582482 5393657,4582489 5393655.5,4582514.5
5393640.5,4582519 5393637,4582521.5 5393632.5,4582526 5393621.5,4582538
5393579,4582536.5 5393553,4582538 5393547.5,4582546.5 5393546,4582552
5393543,4582561.5 5393542,4582580 5393543.5,4582589 5393546,4582597
5393544,4582602 5393540.5,4582611 5393520.5,4582615 5393515,4582618.5
5393498,4582620.5 5393496.5,4582632 5393495,4582635 5393493,4582637.5
5393484.5,4582637 5393479.5,4582627.5 5393469,4582630 5393468,4582640
5393476.5,4582652.5 5393477,4582659 5393476,4582672 5393485.5,4582688.5
5393484,4582700 5393493.5,4582711.5 5393493.5,4582713.5
5393493,4582714.5 5393484,4582722.5 5393482,4582723 5393480.5,4582720.5
5393464,4582718.5 5393459,4582722.5 5393452,4582731 5393453.5,4582733.5
5393452,4582734.5 5393436,4582739.5 5393430.5,4582760.5
5393429,4582767.5 5393431,4582780.5 5393442.5,4582784 5393449,4582780.5
5393468.5,4582776 5393475,4582775 5393485,4582770 5393492.5,4582768
5393499,4582768 5393505,4582767 5393507,4582760.5 5393511,4582750
5393540.5,4582738.5 5393560,4582742.5 5393569.5,4582741.5
5393579,4582733 5393601.5,4582732 5393621,4582720.5 5393671,4582716
5393677,4582712.5 5393689,4582713.5 5393699.5,4582717.5 5393709,4582715
5393714.5,4582709.5 5393717,4582708 5393719,4582713 5393739.5,4582720.5
5393750,4582724 5393760.5,4582720 5393763.5,4582715 5393764.5,4582711.5
5393771,4582705.5 5393772.5,4582703 5393775,4582701 5393782,4582697.5
5393788,4582691 5393810,4582672.5 5393840.5,4582672 5393859,4582667.5
5393867,4582663 5393882.5,4582661 5393884.5,4582656 5393886,4582651
5393891.5,4582642 5393894,4582638.5 5393899,4582638.5 5393907,4582647.5
5393919.5,4582648 5393922,4582641.5 5393939,4582637 5393946.5,4582627.5
5393968.5,4582620 5393976.5,4582611.5 5393980,4582609.5
5393985,4582607.5 5393980,4582605.5 5393978.5,4582600.5
5393976.5,4582597 5393976.5,4582596 5393983.5,4582587.5
5393987,4582585.5 5393990,4582585 5393994.5,4582571.5
5393993.5,4582560.5 5393989,4582555 5393990,4582551 5393993.5,4582548
5394004.5,4582543.5 5394010.5,4582543 5394014.5,4582544.5
5394019,4582561 5394031.5,4582568.5 5394039.5,4582573
5394050.5,4582567.5 5394057,4582560 5394061.5,4582551.5
5394070.5,4582548 5394078.5,4582555.5 5394097.5,4582557.5
5394117,4582552.5 5394123,4582538.5 5394129.5,4582553.5
5394147.5,4582568.5 5394159.5,4582573.5 5394167.5,4582574
5394170,4582571 5394171,4582566.5 5394176,4582563 5394187.5,4582560.5
5394190.5,4582550 5394191,4582530.5 5394182.5,4582506
5394161.5,4582504.5 5394158,4582507 5394142,4582505 5394138,4582495.5
5394133.5,4582480 5394134,4582477 5394131.5,4582471 5394121,4582468.5
5394121.5,4582462.5 5394132,4582452.5 5394142,4582437
5394147.5,4582421.5 5394149.5,4582411.5 5394155.5,4582400
5394149.5,4582373 5394126,4582357 5394120,4582322.5 5394110,4582320
5394107.5,4582317 5394078.5,4582317.5 5394060.5,4582320
5394048.5,4582365 5394020.5,4582365.5 5394019,4582341 5393976.5,4582340
5393969.5,4582340.5 5393950,4582335 5393940,4582333.5 5393931,4582335
5393911.5,4582329.5 5393868,4582327.5 5393860,4582321.5
5393850.5,4582317 5393836.5,4582315.5 5393827,4582319 5393819.5,4582335
5393807.5,4582341 5393800,4582352 5393774.5,4582362 5393740,4582354.5
5393727,4582352.5 5393720.5,4582363 5393700.5,4582359.5
5393689.5,4582358.5 5393668.5,4582363.5 5393659.5,4582359.5
5393652,4582359.5 5393647.5),(4581936.596 5393037.937,4581932.025
5393065.361,4581928.5 5393072.5,4581839.5 5393408,4581819.5
5393415,4581809.5 5393415,4581799.5 5393425,4581789.5 5393425,4581779.5
5393435,4581759.5 5393435,4581749.5 5393445,4581699.5 5393445,4581689.5
5393435,4581669.5 5393435,4581649.5 5393415,4581639.5 5393415,4581629.5
5393405,4581619.5 5393405,4581599.5 5393385,4581589.5 5393385,4581579.5
5393375,4581569.5 5393375,4581559.5 5393365,4581549.5 5393365,4581529.5
5393345,4581519.5 5393345,4581509.5 5393335,4581499.5 5393335,4581489.5
5393325,4581479.5 5393325,4581469.5 5393335,4581459.5 5393335,4581439.5
5393355,4581429.5 5393355,4581399.5 5393385,4581349.5 5393385,4581289.5
5393325,4581289.5 5393315,4581239.5 5393265,4581239.5 5393255,4581209.5
5393225,4581209.5 5393215,4581199.5 5393205,4581199.5 5393195,4581189.5
5393185,4581189.5 5393135,4581179.5 5393125,4581179.5 5393085,4581169.5
5393075,4581179.5 5393065,4581189.5 5393065,4581199.5 5393055,4581219.5
5393055,4581229.5 5393045,4581249.5 5393045,4581259.5 5393035,4581269.5
5393035,4581279.5 5393025,4581289.5 5393025,4581299.5 5393015,4581309.5
5393015,4581319.5 5393005,4581329.5 5393005,4581349.5 5392985,4581359.5
5392985,4581389.5 5392955,4581399.5 5392955,4581419.5 5392935,4581429.5
5392935,4581459.5 5392905,4581469.5 5392905,4581499.5 5392875,4581509.5
5392875,4581529.5 5392855,4581539.5 5392855,4581569.5 5392825,4581579.5
5392825,4581609.5 5392795,4581619.5 5392795,4581639.5 5392775,4581649.5
5392775,4581679.5 5392745,4581689.5 5392745,4581719.5 5392715,4581729.5
5392715,4581759.5 5392685,4581769.5 5392685,4581789.5 5392665,4581799.5
5392665,4581829.5 5392635,4581839.5 5392635,4581869.5 5392605,4581879.5
5392605,4581909.5 5392575,4581919.5 5392575,4581949.5 5392545,4581959.5
5392545,4581979.5 5392525,4581989.5 5392525,4582009.5 5392505,4582019.5
5392505,4582004 5392622,4581994 5392717,4581955.5 5392963,4581936.596
5393037.937),(4582269.5 5392095,4582279.5 5392085,4582489.5
5392085,4582499.5 5392095,4582579.5 5392095,4582589.5 5392105,4582689.5
5392105,4582699.5 5392115,4582708.412 5392115,4582709.884
5392131.436,4582686.31 5392132.677,4582644.621 5392129.296,4582574.765
5392128.17,4582526.316 5392121.409,4582478.122 5392117.394,4582479.5
5392115,4582469.5 5392115,4582459.5 5392105,4582359.5 5392105,4582369.5
5392115,4582369.5 5392125,4582339.5 5392155,4582329.5 5392155,4582299.5
5392125,4582309.5 5392115,4582239.5 5392115,4582229.5 5392125,4582199.5
5392125,4582189.5 5392135,4582159.5 5392135,4582149.5 5392145,4582129.5
5392145,4582119.5 5392155,4582099.5 5392155,4582089.5 5392165,4582069.5
5392165,4582059.5 5392175,4582049.5 5392175,4582039.5 5392185,4582029.5
5392185,4581989.5 5392225,4581979.5 5392215,4581979.5 5392225,4581969.5
5392235,4581959.5 5392235,4581949.5 5392225,4581939.5 5392225,4581939.5
5392235,4581919.5 5392255,4581909.5 5392245,4581889.5 5392245,4581679
5392351.5,4581032 5392658.5,4580608 5392874,4580468.5 5392935,4580323.5
5392973,4580187.5 5392993.5,4580149 5392995.5,4580140
5392998.5,4580138.5 5393001.5,4580135.5 5393003.5,4580118
5393005,4580113.5 5393008.5,4580095 5393015,4580088 5393021.5,4580080
5393025,4580073.5 5393038.5,4580066 5393048.5,4580054 5393059,4580034
5393068.5,4580019.5 5393072.5,4579999.5 5393081.5,4579989
5393083.5,4579978.5 5393083.5,4579960 5393081,4579922.5
5393071.5,4579909.5 5393067,4579900 5393065.5,4579889
5393066.5,4579870.5 5393064.5,4579830 5393057.5,4579823.5
5393043,4579802 5393026.5,4579786.5 5393024,4579776.5 5393021,4579766.5
5393016,4579767 5393010,4579763 5392992.5,4579755 5392983.5,4579749.5
5392981.5,4579743 5392990,4579722 5392991.5,4579717 5392993.5,4579715
5392998.5,4579720 5393012.5,4579728 5393025,4579728 5393027.5,4579727
5393036.5,4579718.5 5393044,4579715 5393050,4579707.5 5393051,4579701.5
5393056,4579691.5 5393060,4579681.5 5393060.5,4579667.5
5393050.5,4579658.5 5393042,4579649.5 5393040.5,4579641.5
5393035.5,4579639.5 5393033,4579632.5 5393036,4579630 5393045,4579624.5
5393049.5,4579620.5 5393058.5,4579609.5 5393057,4579602.5
5393054.5,4579600 5393051,4579597 5393034,4579588 5393004,4579579.5
5392992.5,4579569 5392988.5,4579565 5392980,4579564.5
5392974.5,4579559.5 5392964.5,4579550.5 5392960,4579547.5
5392962.5,4579548.5 5392984.5,4579551 5392997,4579549.5
5392996.5,4579545 5393000,4579542 5393007.5,4579534.5
5393009.5,4579521.5 5393009,4579498 5393005.5,4579490 5393001,4579479.5
5392993,4579471.5 5392982.5,4579455.5 5392965.5,4579449.5
5392963.5,4579442 5392955,4579441 5392947,4579443.5 5392945.5,4579443.5
5392942,4579440 5392935,4579429.5 5392922.5,4579425 5392913.5,4579425.5
5392900.5,4579430.5 5392875.5,4579423.5 5392863.5,4579420
5392861,4579415.5 5392861,4579407 5392862.5,4579400 5392866,4579393
5392855.5,4579381.5 5392843,4579366 5392839.5,4579360
5392840.5,4579358.5 5392837,4579352.5 5392830,4579347 5392827,4579339.5
5392826.5,4579335.5 5392824.5,4579331.5 5392815.5,4579346.5
5392808.5,4579350 5392805,4579351 5392799.5,4579355.5
5392792.5,4579363.5 5392788.5,4579371.5 5392787.5,4579387.5
5392787.5,4579392.5 5392790,4579398 5392796.5,4579403.5 5392806,4579403
5392807.5,4579395.5 5392810.5,4579395 5392813.5,4579397
5392825.5,4579401.5 5392829.5,4579415.5 5392828,4579423.5
5392825.5,4579430.5 5392825.5,4579433 5392818.5,4579439 5392812,4579459
5392811.5,4579481.5 5392817,4579491 5392815,4579499 5392810,4579502.5
5392806,4579504.5 5392796.5,4579502 5392780,4579502.5 5392768,4579507.5
5392761,4579514 5392757.5,4579517 5392749.5,4579516 5392735.5,4579506
5392727.5,4579504 5392723,4579506 5392718,4579510.5 5392715.5,4579531
5392723,4579536.5 5392731.5,4579542 5392749,4579550 5392763,4579557
5392765.5,4579570 5392766,4579585 5392760,4579589 5392755.5,4579590
5392751.5,4579592.5 5392726,4579596 5392712.5,4579595
5392696.5,4579593.5 5392693,4579587.5 5392686,4579569.5
5392676.5,4579568 5392672.5,4579570 5392666.5,4579577 5392666,4579580
5392667,4579590.5 5392676.5,4579599.5 5392682.5,4579612.5
5392679.5,4579615 5392675,4579616.5 5392663,4579619.5 5392654,4579641
5392646.5,4579643.5 5392641,4579645.5 5392635,4579643.5
5392608.5,4579645 5392605,4579645 5392600.5,4579646.5 5392600,4579660
5392603,4579667 5392615.5,4579670 5392628,4579675 5392637,4579681
5392640,4579688 5392635.5,4579686.5 5392625.5,4579681
5392608.5,4579676.5 5392587.5,4579671 5392576.5,4579671
5392575,4579677.5 5392571.5,4579680.5 5392571.5,4579685.5
5392575.5,4579685 5392585.5,4579688 5392594.5,4579690 5392596,4579697
5392592.5,4579709.5 5392592.5,4579719.5 5392594,4579732
5392585.5,4579737 5392579.5,4579741 5392577,4579769 5392584,4579781.5
5392590.5,4579791 5392588,4579800 5392588,4579808.5 5392596,4579818.5
5392609,4579829.5 5392615.5,4579837.5 5392623,4579856 5392635,4579860.5
5392640,4579887 5392659,4579900 5392663,4579909.5 5392663,4579919
5392665,4579938 5392664,4579986 5392641.5,4580019 5392632.5,4580039
5392625.5,4580071.5 5392618,4580079.5 5392614.5,4580103
5392616,4580120.5 5392612.5,4580140 5392605.5,4580159 5392605.5,4580183
5392597.5,4580230.5 5392593,4580244.5 5392589.5,4580261.5
5392582.5,4580274 5392567.5,4580282.5 5392553,4580287 5392542,4580288
5392534.5,4580293 5392527,4580296 5392517,4580300 5392509.5,4580310.5
5392504,4580319 5392502,4580329.5 5392497,4580356.5 5392476,4580380
5392469,4580418.5 5392471.5,4580448.5 5392471,4580460 5392472,4580467
5392470,4580479 5392461.5,4580480.5 5392462,4580488.5
5392467.5,4580502.5 5392472,4580523.5 5392484,4580541
5392495.5,4580547.5 5392503,4580549 5392508,4580549 5392514.5,4580543.5
5392526,4580530.5 5392546,4580512 5392567,4580487 5392582.5,4580462
5392608.5,4580441 5392620,4580428.5 5392632,4580418.5
5392638.5,4580410.5 5392646.5,4580399.5 5392654,4580387.5
5392669.5,4580359 5392694.5,4580350 5392706.5,4580341
5392721.5,4580332.5 5392727.5,4580324.5 5392736,4580313 5392755,4580304
5392762,4580290 5392769.5,4580280.5 5392778,4580257 5392793.5,4580241.5
5392807.5,4580229.5 5392814.5,4580223.5 5392821.5,4580198.5
5392843.5,4580180.5 5392865.5,4580170 5392875.5,4580166
5392881.5,4580159.5 5392886.5,4580150 5392899,4580140
5392908.5,4580131.5 5392924.5,4580123.5 5392946.5,4580122.5
5392965,4580125 5392974.5,4580147 5392976,4580151.5 5392975.5,4580155
5392970.5,4580160 5392970.5,4580165.5 5392968.5,4580175
5392967.5,4580221.5 5392967.5,4580231 5392965.5,4580233.5
5392961.5,4580236.5 5392959.5,4580242 5392958.5,4580259.5
5392958,4580279 5392955.5,4580291.5 5392956.5,4580297.5
5392951.5,4580300 5392952,4580389.5 5392930.5,4580506.5 5392891,4580684
5392806.5,4581101 5392602,4581864.5 5392231.5,4581899.5
5392215,4581919.5 5392215,4581929.5 5392205,4581939.5 5392205,4581949.5
5392195,4581959.5 5392195,4581969.5 5392185,4581979.5 5392185,4581989.5
5392175,4581999.5 5392175,4581999.5 5392165,4582009.5 5392155,4582019.5
5392165,4582029.5 5392165,4582039.5 5392155,4582049.5 5392155,4582059.5
5392145,4582079.5 5392145,4582089.5 5392135,4582109.5 5392135,4582119.5
5392125,4582139.5 5392125,4582149.5 5392115,4582169.5 5392115,4582179.5
5392105,4582209.5 5392105,4582219.5 5392095,4582269.5
5392095))',31468)),
st_area(st_transform(st_geomfromtext('POLYGON((4562878
5410125.5,4562864.5 5410124,4562855 5410115,4562852.5 5410115,4562813
5410144,4562768.5 5410147,4562728 5410147,4562718 5410157,4562688
5410157,4562678 5410167,4562638 5410167,4562628 5410177,4562608
5410177,4562598 5410187,4562579 5410187,4562569.5 5410192,4562539.5
5410192,4562529.5 5410202,4562499.5 5410202,4562479.5 5410182,4562449.5
5410182,4562429.5 5410202,4562409.5 5410202,4562399.5 5410212,4562369.5
5410212,4562349.5 5410232,4562339.5 5410232,4562329.5 5410242,4562319.5
5410242,4562299.5 5410262,4562289.5 5410252,4562289.5 5410242,4562279.5
5410242,4562269.5 5410232,4562259.5 5410242,4562259.5 5410252,4562249.5
5410262,4562229.5 5410262,4562219.5 5410272,4562219.5 5410292,4562209.5
5410302,4562199.5 5410302,4562199.5 5410312,4562189.5 5410322,4562179.5
5410322,4562169.5 5410332,4562169.5 5410342,4562129.5 5410382,4562109.5
5410382,4562099.5 5410392,4562109.5 5410402,4562099.5 5410412,4562079.5
5410412,4562069.5 5410402,4562059.5 5410402,4562049.5 5410412,4562049.5
5410432,4562039.5 5410442,4562029.5 5410442,4562019.5 5410452,4561939.5
5410452,4561929.5 5410462,4561909.5 5410462,4561899.5 5410472,4561829.5
5410472,4561819.5 5410462,4561809.5 5410462,4561799.5 5410472,4561779.5
5410472,4561739.5 5410432,4561739.5 5410422,4561729.5 5410412,4561729.5
5410372,4561719.5 5410361,4561719.5 5410351,4561709.5 5410341,4561709.5
5410331,4561699.5 5410321,4561699.5 5410311,4561679.5 5410291,4561659.5
5410291,4561639.5 5410271,4561639.5 5410261,4561579.5 5410201,4561569.5
5410201,4561589.5 5410221,4561569.5 5410241,4561619.5 5410291,4561619.5
5410311,4561639.5 5410331,4561639.5 5410361,4561649.5 5410371,4561649.5
5410381,4561629.5 5410401,4561619.5 5410391,4561629.5 5410381,4561609.5
5410381,4561609.5 5410401,4561599.5 5410411,4561589.5 5410411,4561579.5
5410401,4561559.5 5410401,4561549.5 5410411,4561529.5 5410411,4561479.5
5410361,4561479.5 5410351,4561419.5 5410291,4561419.5 5410281,4561409.5
5410281,4561379.5 5410251,4561320.5 5410201,4561378.5
5410101.5,4561378.5 5410088,4561365.5 5410074.5,4561191
5409940.5,4561176.5 5409934,4561101 5409881,4561060.5 5409858,4560971.5
5409821.5,4560965.5 5409812.5,4560965 5409802.5,4560969.5
5409787,4560974 5409774.5,4560988 5409746,4560999 5409715,4561008
5409698.5,4561012.5 5409685.5,4561012 5409679.5,4561007.5
5409671.5,4560999 5409662.5,4560956.5 5409647,4560939 5409643.5,4560929
5409645,4560918 5409650,4560876 5409692,4560886 5409668,4560890.5
5409648,4560888 5409637,4560885.5 5409632.5,4560870.5 5409630,4560854.5
5409624,4560809 5409611.5,4560772.5 5409597,4560760 5409598.5,4560756
5409600.5,4560711.5 5409663,4560734.5 5409603.5,4560738 5409597,4560741
5409578,4560740.5 5409569.5,4560738 5409563.5,4560732.5
5409556.5,4560715.5 5409541,4560709.5 5409537.5,4560710
5409531.5,4560703 5409518,4560698.5 5409504.5,4560702 5409495,4560708
5409489.5,4560717 5409487.5,4560724 5409493.5,4560735.5
5409482.5,4560734 5409473.5,4560725 5409472,4560722 5409469,4560725.5
5409464.5,4560728 5409456.5,4560739.5 5409456,4560740.5
5409443,4560731.5 5409435.5,4560738 5409415,4560746 5409415,4560751.5
5409411,4560742 5409370.5,4560741 5409361.5,4560742 5409343.5,4560740
5409335,4560731.5 5409329,4560713 5409320.5,4560680 5409309.5,4560659.5
5409301,4560646 5409296.5,4560628 5409298,4560614.5 5409305,4560576
5409305.5,4560565 5409302.5,4560534 5409284,4560504 5409276.5,4560469
5409273.5,4560420 5409272,4560397 5409276,4560378.5 5409277,4560361.5
5409275,4560351.5 5409271.5,4560327 5409258.5,4560317 5409254.5,4560302
5409251,4560209.5 5409246.5,4560186 5409243,4560154.5 5409232.5,4560136
5409224.5,4560117.5 5409220,4560100.5 5409224,4560092.5 5409233,4560094
5409239,4560102.5 5409245,4560161 5409268,4560176 5409270.5,4560188
5409270.5,4560200 5409276,4560211 5409275,4560219 5409282.5,4560251
5409290.5,4560336.5 5409301,4560340.5 5409299,4560362.5
5409304,4560371.5 5409304.5,4560388 5409310.5,4560404.5
5409311.5,4560435 5409318,4560470.5 5409323.5,4560478.5 5409317,4560486
5409314.5,4560500.5 5409315,4560508 5409319.5,4560511
5409325.5,4560520.5 5409330,4560532 5409327,4560545.5
5409325.5,4560553.5 5409329,4560553.5 5409334.5,4560570
5409349.5,4560577.5 5409353.5,4560611.5 5409364.5,4560618
5409370,4560618.5 5409376,4560615.5 5409382.5,4560609
5409386.5,4560600.5 5409389,4560593.5 5409394,4560586 5409402.5,4560576
5409408.5,4560570.5 5409415,4560561.5 5409418.5,4560549
5409413.5,4560546.5 5409414.5,4560524 5409405,4560513.5
5409412.5,4560494 5409419.5,4560470 5409434,4560462 5409435,4560448
5409429,4560447 5409425,4560445.5 5409424,4560441.5 5409431.5,4560438.5
5409431,4560420 5409461.5,4560413 5409459.5,4560409 5409450,4560390
5409455.5,4560373.5 5409450,4560368 5409449.5,4560362.5
5409451.5,4560357 5409457,4560336.5 5409493.5,4560314.5 5409540,4560309
5409546.5,4560303.5 5409548.5,4560295.5 5409549,4560290.5
5409548,4560288 5409549.5,4560289 5409564.5,4560282 5409577,4560283
5409581.5,4560249.5 5409553.5,4560195.5 5409517.5,4560189
5409518.5,4560177.5 5409510.5,4560119.5 5409483.5,4560089.5
5409472,4560071.5 5409461.5,4560028.5 5409439.5,4560016.5
5409425.5,4560006 5409415.5,4559990 5409410,4559984.5 5409412,4559981.5
5409415.5,4559974 5409412,4559966 5409415.5,4559961 5409415.5,4559940
5409405.5,4559934.5 5409401,4559924 5409402,4559913 5409399,4559878
5409375.5,4559859.5 5409369.5,4559846 5409368,4559826 5409362.5,4559823
5409355.5,4559747 5409341,4559709 5409330,4559708 5409326,4559705
5409322.5,4559664 5409317.5,4559614.5 5409316,4559594 5409318,4559560
5409314,4559546.5 5409315,4559527 5409313.5,4559495 5409309.5,4559465
5409310.5,4559451 5409312.5,4559440.5 5409300,4559432 5409301.5,4559424
5409310,4559386 5409315,4559358.5 5409314.5,4559354 5409311.5,4559327.5
5409313.5,4559325.5 5409316.5,4559243.5 5409323,4559227.5
5409322.5,4559203.5 5409330.5,4559195.5 5409328,4559188.5
5409331,4559177 5409331.5,4559155.5 5409327,4559133.5
5409333.5,4559114.5 5409348.5,4559092 5409354.5,4559069.5
5409358,4559045 5409356,4558966 5409374.5,4558944 5409378.5,4558917.5
5409381,4558909.5 5409386.5,4558905 5409383,4558904.5 5409384.5,4558909
5409390,4558866 5409414,4558856.5 5409413,4558851 5409416.5,4558846
5409414.5,4558829.5 5409418,4558809.5 5409415.5,4558790.5
5409429,4558781.5 5409433,4558778.5 5409431,4558776.5
5409427.5,4558757.5 5409432.5,4558758 5409442,4558755.5
5409443,4558745.5 5409442,4558731 5409446,4558721.5 5409444,4558694
5409452.5,4558687.5 5409460.5,4558673 5409460.5,4558666
5409455.5,4558640.5 5409442,4558622.5 5409427.5,4558586.5
5409392,4558569.5 5409387,4558563 5409383,4558559 5409387,4558552.5
5409387.5,4558541 5409394,4558543 5409398.5,4558552.5
5409402.5,4558546.5 5409407,4558532 5409403.5,4558528 5409407,4558535
5409429,4558547.5 5409441,4558554 5409458.5,4558560.5 5409495,4558559.5
5409522,4558516 5409540.5,4558496 5409558,4558490.5 5409558.5,4558416
5409606,4558348.5 5409645.5,4558316 5409675.5,4558284.5
5409695.5,4558258.5 5409702.5,4558246.5 5409715,4558226.5
5409739.5,4558188 5409776.5,4558130.5 5409821,4558105.5
5409836,4558086.5 5409831.5,4558074.5 5409835.5,4558061 5409850,4558057
5409874.5,4558046 5409884.5,4558042 5409893.5,4557990 5409938,4557968
5409949.5,4558025 5409896,4558029 5409875.5,4558008 5409858,4558004
5409858.5,4557973.5 5409819.5,4557969.5 5409807.5,4557956.5
5409786.5,4557941.5 5409791.5,4557930.5 5409809,4557889.5
5409865,4557843.5 5409924.5,4557774.5 5409988,4557771 5409994,4557782
5410056.5,4557793.5 5410082.5,4557808 5410085,4557812.5
5410090,4557809.5 5410098.5,4557786.5 5410111.5,4557772
5410077.5,4557759.5 5410075.5,4557746 5410078.5,4557733 5410085,4557735
5410094.5,4557749 5410114,4557758.5 5410122,4557770 5410115,4557775.5
5410122,4557781 5410125,4557778.5 5410129,4557765.5 5410135,4557761
5410130.5,4557733.5 5410146.5,4557728.5 5410152.5,4557737.5
5410176,4557736 5410184,4557708.5 5410216.5,4557710.5
5410222.5,4557704.5 5410230,4557699 5410235,4557682.5 5410237,4557677
5410235,4557651.5 5410218.5,4557634.5 5410222.5,4557618 5410219,4557607
5410211.5,4557595 5410211,4557598.5 5410214,4557598.5 5410225,4557605.5
5410226.5,4557631 5410253.5,4557652.5 5410267.5,4557661.5
5410285,4557657.5 5410310,4557651 5410320.5,4557639.5 5410329.5,4557585
5410395,4557555.5 5410426.5,4557527.5 5410453,4557508.5
5410463,4557476.5 5410487.5,4557446 5410506.5,4557425.5 5410521,4557405
5410532.5,4557370 5410560,4557365 5410558.5,4557343 5410541.5,4557359
5410559.5,4557358.5 5410568,4557350 5410579,4557305.5 5410615,4557285.5
5410634,4557264 5410649,4557230.5 5410667.5,4557218 5410667.5,4557210
5410670.5,4557196.5 5410669,4557187.5 5410661.5,4557171.5
5410644.5,4557149 5410637.5,4557130.5 5410628.5,4557119.5
5410606.5,4557114.5 5410593,4557117 5410561,4557114 5410524,4557107.5
5410500.5,4557099 5410499,4557096.5 5410475,4557098 5410461,4557104.5
5410432.5,4557117 5410420.5,4557120.5 5410410.5,4557010
5410491,4557015.5 5410511.5,4557016 5410529,4557004 5410546.5,4556998.5
5410559,4556995 5410573,4556997 5410591,4557005.5 5410608,4557008.5
5410624.5,4557008.5 5410652,4557004 5410709.5,4556998
5410723.5,4557000.5 5410762,4556995 5410786.5,4556998 5410809,4556995
5410821.5,4556956.5 5410867,4556940.5 5410893,4556875 5410953,4556767.5
5411072,4556784.725 5411085.737,4556774.564 5411092.394,4556703.412
5411170.442,4556683.282 5411189.629,4556665.423 5411208.811,4556605.314
5411288.567,4556599.959 5411294.057,4556647.842 5411359.72,4556995.974
5411003.444,4557197.748 5410801.332,4557392.967 5410603.397,4557541.06
5410501.049,4557764.003 5410347.387,4557947.478 5410250.481,4558154.397
5410140.961,4558220.546 5410106.646,4558376.668 5410037.51,4558680.651
5409903.06,4559121.415 5409819.081,4559165.688 5409816.129,4559373.626
5409802.159,4559621.729 5409784.98,4559630.705 5409786.091,4559978.004
5409829.769,4560200.677 5409855.981,4560227.326 5409864.282,4560391.847
5409915.533,4560587.746 5409975.333,4561020.622 5410199.564,4561387.331
5410407.445,4561403.673 5410420.025,4561683.803 5410635.716,4561755.313
5410760.667,4561874.666 5410974.179,4562013.359 5411265.561,4562217.2
5411541.675,4562414.933 5411709.379,4562221.271 5412402.845,4562223.323
5412402.94,4562331.501 5412408.029,4562494.84 5412415.824,4562444.198
5412636.97,4562260.207 5412859.642,4562229.446 5412873.408,4561964.907
5412988.885,4561974.557 5413037.134,4561975.186 5413039.816,4561977.772
5413053.209,4562012.086 5413230.933,4562039.061 5413363.264,4562377.269
5413606.804,4562053.618 5414016.114,4562052.294 5414017.794,4561918.281
5414049.585,4561789.923 5414080.142,4561711.737 5414352.528,4561706.707
5414370.507,4561701.923 5414385.701,4561649.506 5414562.886,4561629.344
5414631.607,4561611.337 5414691.908,4561585.573 5414778.189,4561616.264
5414821.65,4561624.794 5414833.706,4561632 5414826.5,4561652
5414826.5,4561662 5414816.5,4561672 5414826.5,4561682 5414826.5,4561692
5414816.5,4561702 5414826.5,4561702 5414866.5,4561722 5414886.5,4561722
5414906.5,4561779 5414962.5,4561830 5414895.5,4561847 5414863,4562027
5414683,4562027 5414673,4562087 5414613,4562097 5414613,4562237
5414473,4562247 5414473,4562307 5414413,4562317 5414413,4562367
5414363,4562377 5414363,4562417 5414323,4562427 5414323,4562467
5414283,4562477 5414283,4562507 5414253,4562517 5414253,4562547
5414223,4562557 5414223,4562587 5414193,4562597 5414193,4562627
5414163,4562637 5414163,4562657 5414143,4562667 5414143,4562677
5414133,4562687 5414133,4562697 5414123,4562707 5414123,4562717
5414113,4562727 5414113,4562737 5414123,4562677 5414183,4562667
5414183,4562637 5414213,4562627 5414213,4562597 5414243,4562587
5414243,4562557 5414273,4562547 5414273,4562507 5414313,4562497
5414313,4562447 5414363,4562437 5414363,4562377 5414423,4562367
5414423,4562257 5414533,4562247 5414533,4562047 5414733,4562047
5414743,4561947 5414843,4561947 5414863,4561957 5414863,4561967
5414873,4561957 5414883,4561916 5414884,4561913.5 5414897,4561897
5414913,4561871.5 5414944.5,4561867 5414953,4561860.5 5414956.5,4561857
5414963,4561838 5414983.5,4561827 5414993,4561817 5414993,4561817
5415013,4561827 5415023,4561827 5415089.134,4561837 5415093,4561837
5415003,4561848.5 5414992.5,4561847 5414983,4561883.5
5414946.5,4561889.5 5414942.5,4561899 5414927.5,4561915
5414909.5,4561917 5414903,4561927 5414893,4561937 5414903,4561937
5414923,4561927 5414933,4561937 5414943,4561947 5414943,4561967
5414963,4561977 5414953,4561997 5414973,4561997 5414983,4562027
5414983,4562047 5415003,4562037 5415013,4562047 5415023,4562077
5415023,4562077 5415003,4562087 5414993,4562077 5414983,4562097
5414963,4562107 5414973,4562107 5414903,4562097 5414893,4562097
5414873,4562087 5414863,4562087 5414853,4562077 5414853,4562067
5414843,4562077 5414833,4562087 5414833,4562097 5414823,4562107
5414833,4562107 5414863,4562117 5414873,4562117 5414883,4562127
5414893,4562127 5415013,4562147 5415013,4562157 5415023,4562167
5415023,4562187 5415043,4562187 5415053,4562197 5415063,4562257
5415063,4562267 5415053,4562277 5415053,4562297 5415033,4562327
5415033,4562337 5415023,4562367 5415023,4562377 5415013,4562387
5415023,4562407 5415023,4562417 5415013,4562427 5415013,4562427
5415003,4562447 5414983,4562447 5414973,4562457 5414963,4562477
5414963,4562487 5414953,4562557 5414953,4562567 5414963,4562597
5414963,4562607 5414973,4562617 5414973,4562637 5414993,4562637
5415003,4562657 5415023,4562657 5415043,4562667 5415053,4562667
5415063,4562677 5415073,4562677 5415083,4562687 5415093,4562697
5415093,4562707 5415103,4562717 5415103,4562727 5415113,4562737
5415113,4562757 5415133,4562767 5415123,4562807 5415123,4562817
5415133,4562837 5415113,4562857 5415113,4562867 5415103,4562877
5415103,4562897 5415083,4562907 5415083,4562917 5415073,4562927
5415073,4562977 5415023,4562977 5415013,4563037 5414953,4563037
5414933,4562997 5414893,4563007 5414883,4563047 5414923,4563047
5414913,4563057 5414903,4563087 5414873,4563097 5414873,4563117
5414853,4563117 5414843,4563137 5414823,4563137 5414813,4563157
5414793,4563157 5414783,4563177 5414763,4563177 5414743,4563197
5414723,4563207 5414723,4563207 5414713,4563217 5414703,4563217
5414693,4563237 5414673,4563237 5414663,4563257 5414643,4563257
5414623,4563267 5414613,4563267 5414593,4563257 5414583,4563257
5414553,4563267 5414543,4563267 5414523,4563277 5414513,4563277
5414473,4563257 5414473,4563247 5414483,4563237 5414483,4563227
5414473,4563217 5414473,4563207 5414463,4563197 5414463,4563157
5414423,4563157 5414413,4563147 5414403,4563147 5414383,4563157
5414373,4563157 5414343,4563167 5414333,4563167 5414323,4563177
5414313,4563187 5414313,4563197 5414303,4563217 5414303,4563227
5414293,4563257 5414293,4563267 5414283,4563267 5414263,4563277
5414253,4563297 5414253,4563297 5414243,4563307 5414233,4563317
5414233,4563327 5414223,4563337 5414233,4563347 5414223,4563357
5414223,4563367 5414213,4563407 5414213,4563417 5414203,4563447
5414203,4563457 5414193,4563467 5414203,4563527 5414203,4563537
5414213,4563577 5414213,4563597 5414193,4563677 5414193,4563697
5414213,4563717 5414193,4563837 5414193,4563867 5414223,4563867
5414233,4563857 5414243,4563857 5414273,4563867 5414263,4563887
5414283,4563887 5414293,4563917 5414323,4564007 5414323,4564017
5414333,4564077 5414333,4564087 5414323,4564127 5414323,4564137
5414333,4564147 5414333,4564157 5414323,4564167 5414323,4564177
5414313,4564207 5414313,4564217 5414303,4564237 5414303,4564247
5414313,4564247 5414353,4564257 5414353,4564267 5414363,4564307
5414363,4564317 5414373,4564347 5414373,4564357 5414383,4564387
5414383,4564397 5414393,4564407 5414393,4564417 5414383,4564467
5414383,4564477 5414393,4564497 5414393,4564507 5414403,4564527
5414403,4564537 5414413,4564587 5414413,4564597 5414423,4564607
5414413,4564617 5414423,4564707 5414423,4564717 5414433,4564817
5414433,4564837 5414453,4564837 5414463,4564847 5414453,4564857
5414453,4564867 5414443,4564877 5414443,4564887 5414433,4564907
5414433,4564917 5414423,4564947 5414423,4564957 5414413,4564967
5414413,4564987 5414393,4564997 5414393,4565007 5414383,4565017
5414383,4565027 5414373,4565027 5414333,4565037 5414323,4565037
5414293,4565047 5414283,4565057 5414293,4565057 5414333,4565067
5414343,4565077 5414343,4565087 5414333,4565087 5414323,4565097
5414313,4565097 5414263,4565107 5414253,4565107 5414233,4565117
5414223,4565117 5414213,4565137 5414193,4565197 5414193,4565207
5414198,4565287 5414198,4565297 5414188,4565317 5414208,4565327
5414198,4565337 5414198,4565347 5414188,4565377 5414188,4565407
5414158,4565417 5414158,4565427 5414148,4565437 5414148,4565447
5414138,4565467 5414138,4565477 5414128,4565487 5414128,4565497
5414118,4565507 5414118,4565517 5414108,4565527 5414108,4565537
5414098,4565577 5414098,4565587 5414088,4565607 5414088,4565617
5414078,4565627 5414078,4565637 5414068,4565647 5414068,4565647
5414048,4565657 5414038,4565677 5414038,4565697 5414018,4565717
5414018,4565737 5413998,4565757 5413998,4565767 5413988,4565787
5413988,4565797 5413978,4565807 5413978,4565827 5413958,4565837
5413958,4565837 5413948,4565847 5413938,4565857 5413938,4565857
5413918,4565847 5413928,4565837 5413928,4565827 5413918,4565837
5413908,4565847 5413908,4565857 5413918,4565857 5413908,4565867
5413898,4565857 5413888,4565867 5413878,4565867 5413868,4565877
5413858,4565867 5413848,4565867 5413838,4565857 5413828,4565857
5413618,4565827 5413588,4565827 5413578,4565817 5413568,4565817
5413428,4565827 5413418,4565837 5413418,4565867 5413388,4565877
5413388,4565887 5413378,4565917 5413378,4565927 5413388,4565957
5413388,4565967 5413398,4566017 5413398,4566037 5413378,4566067
5413378,4566077 5413388,4566087 5413388,4566097 5413398,4566167
5413398,4566187 5413418,4566367 5413418,4566387 5413438,4566597
5413438,4566617 5413418,4566677 5413418,4566687 5413408,4566697
5413408,4566707 5413398,4566737 5413398,4566757 5413378,4566767
5413378,4566777 5413368,4566797 5413368,4566807 5413358,4566867
5413358,4566877 5413348,4566887 5413348,4566897 5413338,4566917
5413338,4566927 5413328,4566947 5413328,4566957 5413318,4566977
5413318,4566997 5413298,4567027 5413298,4567047 5413278,4567087
5413278,4567107 5413298,4567107 5413308,4567117 5413318,4567117
5413328,4567127 5413338,4567127 5413358,4567137 5413368,4567147
5413368,4567187 5413408,4567197 5413408,4567217 5413428,4567237
5413428,4567257 5413448,4567257 5413458,4567267 5413468,4567397
5413468,4567407 5413458,4567427 5413458,4567437 5413448,4567447
5413448,4567457 5413438,4567487 5413438,4567507 5413458,4567507
5413468,4567517 5413478,4567517 5413498,4567527 5413508,4567527
5413528,4567517 5413538,4567517 5413548,4567567 5413548,4567577
5413558,4567577 5413568,4567587 5413578,4567587 5413588,4567597
5413578,4567607 5413578,4567617 5413568,4567627 5413578,4567627
5413588,4567637 5413588,4567647 5413598,4567657 5413588,4567657
5413558,4567665.243 5413533.64,4567646.634 5413523.581,4567629.031
5413510.504,4567616.347 5413486.285,4567610.424 5413460.792,4567610.167
5413440.706,4567585.446 5413380.965,4567577.352 5413347.584,4567563.914
5413333.141,4567546.364 5413319.339,4567520.952 5413307.638,4567521.226
5413312.848,4567511.536 5413311.568,4567493.162 5413311.934,4567475.886
5413317.145,4567465.374 5413316.962,4567437.037 5413325.737,4567417.383
5413336.615,4567362.171 5413353.343,4567348.277 5413359.285,4567326.064
5413357.914,4567314.272 5413353.252,4567297.91 5413337.712,4567258.329
5413291.093,4567208.785 5413210.56,4567166.918 5413136.792,4567173.774
5413130.393,4567154.395 5413098.49,4567141.506 5413071.799,4567137.484
5413058.087,4567135.29 5413038.342,4567135.199 5413014.393,4567145.345
5412965.031,4567177.522 5412836.234,4567186.95 5412787.946,4567180.233
5412787.133,4567193.282 5412731.034,4567216.318 5412641.73,4567222.629
5412606.703,4567252.689 5412603.49,4567251.689 5412596.493,4567252.053
5412560.597,4567263.866 5412545.512,4567264.048 5412538.242,4567274.135
5412517.614,4567287.312 5412504.8,4567294.764 5412492.987,4567283.496
5412477.356,4567302.034 5412450.094,4567306.032 5412433.646,4567323.935
5412426.103,4567343.564 5412414.289,4567374.461 5412401.749,4567425.714
5412350.495,4567429.258 5412343.68,4567453.249 5412325.868,4567475.332
5412298.697,4567480.603 5412279.704,4567494.506 5412261.166,4567508.137
5412249.897,4567525.767 5412222.271,4567589.197 5412139.03,4567625.82
5412098.318,4567667.44 5412063.786,4567689.432 5412048.337,4567729.144
5412025.346,4567869.273 5411951.556,4567881.814 5411958.008,4567909.894
5411946.103,4567918.163 5411945.921,4567922.798 5411947.103,4567919.89
5411942.014,4567915.891 5411929.655,4567965.873 5411876.312,4567986.956
5411851.412,4568014.893 5411809.125,4568048.485 5411767.046,4568076.193
5411745.226,4568061.335 5411712.827,4568190.541 5411630.705,4568354.239
5411521.755,4568557.082 5411415.817,4568614.568 5411392.822,4568747.607
5411342.454,4568906.104 5411286.337,4568920.338 5411259.51,4568994.249
5411224.471,4569126.466 5411149.739,4569170.265 5411126.745,4569288.796
5411067.89,4569495.197 5410978.103,4569450.304 5410864.773,4569482.331
5410827.818,4569484.167 5410831.215,4569485.664 5410828.327,4569523.5
5410904,4569590.418 5411025.454,4569612.085 5410933.483,4569647.672
5410857.93,4569733.175 5410784.301,4569742.563 5410774.371,4569749.319
5410770.537,4569782.627 5410742.137,4569813.253 5410734.248,4569822.5
5410729,4569773.628 5410638.736,4569808.558 5410621.11,4569843.219
5410686.432,4569861.397 5410725.73,4569878.29 5410722.235,4570196.251
5410558.456,4570356.391 5410473.87,4570635.941 5410322.337,4570606.837
5410267.575,4570630.508 5410258.537,4570655.5 5410309.5,4570784
5410236,4570775.5 5410216.5,4570779.5 5410204,4570768.658
5410177.979,4570874.375 5410084.249,4570957.523 5410003.378,4570992.832
5409964.652,4571060.035 5409883.782,4571094.205 5409859.862,4571063.452
5409903.145,4571019.03 5409958.957,4570984.859 5409997.683,4570941.577
5410042.105,4570776.419 5410190.177,4570793.504 5410215.235,4570802.617
5410211.818,4570819.702 5410201.567,4570842.482 5410181.065,4570837.926
5410174.231,4570855.012 5410158.284,4570864.123 5410160.563,4570883.487
5410171.953,4570932.464 5410142.338,4570951.267 5410147.76,4570956.132
5410145.083,4571131.529 5409917.548,4571148.327 5409884.502,4571175.154
5409814.972,4571184.69 5409848.585,4571683.5 5409201.5,4571802
5409078.5,4571841 5409022,4571875.5 5408901,4571904.5 5408835.5,4571951
5408756,4571971 5408692.5,4571995.5 5408405,4572004.5 5408250,4572011.5
5408176.5,4572045 5408090,4572107 5408022,4572247 5407949.5,4572326.5
5407923.5,4572436.5 5407865.5,4572529 5407792,4572706.5 5407665,4572870
5407588,4573030.5 5407478.5,4573128.5 5407364,4573208 5407292,4573212.5
5407241,4573274.5 5407200.5,4573352.5 5407180.5,4573436.5
5407118.5,4573582.5 5407039,4573871.5 5406920.5,4573962.5
5406904.5,4574082.5 5406907.5,4574253 5406942,4574347
5406920.5,4574475.5 5406861,4574547.5 5406820.5,4574602.5
5406777,4574743 5406628.5,4574805 5406582,4574894.5 5406527,4575182
5406420,4575241.5 5406385.5,4575335.5 5406297,4575510 5406121,4575579.5
5406025.5,4575623 5405970.5,4575735.5 5405853.5,4575790.5
5405810,4576007 5405779.5,4576019 5405738,4576102.5 5405700,4576175
5405723.5,4576212.5 5405717.5,4576326.5 5405674,4576524.5
5405631,4576627 5405568.5,4576744 5405487.5,4576854 5405428.5,4576933.5
5405409.5,4577111.5 5405385,4577271.5 5405378,4577316.5
5405392.5,4577370 5405405.5,4577411.624 5405410.703,4577424.176
5405412.272,4577438 5405414,4577487.859 5405414.719,4577503.352
5405414.943,4577521.471 5405415.204,4577523.839 5405415.238,4577524.287
5405415.245,4577542 5405415.5,4577557.5 5405412.5,4577557.122
5405408.312,4577555.702 5405392.567,4577551.5 5405346,4577531.545
5405302.961,4577524.293 5405287.319,4577517.407 5405272.468,4577510.274
5405257.084,4577505.36 5405246.486,4577382.5 5404981.5,4577356.5
5404852,4577347.5 5404718,4577414.5 5404594,4577477.5 5404548.5,4577467
5404518,4577488 5404459.5,4577538 5404409.5,4577538 5404399.5,4577558
5404379.5,4577558 5404369.5,4577568 5404359.5,4577568 5404349.5,4577678
5404239.5,4577708 5404239.5,4577718 5404229.5,4577728 5404229.5,4577748
5404249.5,4577758 5404249.5,4577768 5404259.5,4577778 5404259.5,4577788
5404269.5,4577808 5404269.5,4577818 5404279.5,4577818 5404289.5,4577828
5404299.5,4577838 5404299.5,4577848 5404309.5,4577878 5404309.5,4577888
5404319.5,4577898 5404319.5,4577908 5404309.5,4577938 5404309.5,4577988
5404259.5,4577988 5404249.5,4577998 5404239.5,4578008 5404239.5,4578018
5404229.5,4578038 5404229.5,4578048 5404219.5,4578078 5404219.5,4578078
5404209.5,4578108 5404179.5,4578118 5404179.5,4578128 5404169.5,4578208
5404169.5,4578248 5404129.5,4578248 5404119.5,4578258 5404109.5,4578258
5404079.5,4578288 5404049.5,4578298 5404049.5,4578328 5404019.5,4578348
5404019.5,4578358 5404009.5,4578368 5403999.5,4578368 5403989.5,4578378
5403979.5,4578378 5403959.5,4578398 5403939.5,4578408 5403939.5,4578448
5403899.5,4578468 5403899.5,4578558 5403809.5,4578568 5403809.5,4578618
5403759.5,4578618 5403749.5,4578628 5403739.5,4578638 5403739.5,4578678
5403699.5,4578688 5403699.5,4578698 5403689.5,4578708 5403689.5,4578718
5403679.5,4578738 5403679.5,4578758 5403659.5,4578758 5403649.5,4578768
5403639.5,4578768 5403609.5,4578778 5403599.5,4578778 5403589.5,4578788
5403579.5,4578788 5403569.5,4578798 5403559.5,4578808 5403559.5,4578828
5403539.5,4578838 5403539.5,4578868 5403509.5,4578878 5403509.5,4578878
5403489.5,4578868 5403479.5,4578868 5403459.5,4578848 5403459.5,4578838
5403449.5,4578818 5403449.5,4578808 5403439.5,4578788 5403439.5,4578778
5403429.5,4578728 5403429.5,4578718 5403439.5,4578708 5403439.5,4578698
5403449.5,4578648 5403449.5,4578638 5403439.5,4578608 5403439.5,4578578
5403409.5,4578578 5403399.5,4578608 5403369.5,4578638 5403369.5,4578648
5403359.5,4578658 5403359.5,4578658 5403279.5,4578648 5403289.5,4578618
5403289.5,4578608 5403299.5,4578598 5403289.5,4578588 5403289.5,4578568
5403269.5,4578568 5403239.5,4578578 5403229.5,4578578 5403219.5,4578618
5403179.5,4578618 5403169.5,4578628 5403159.5,4578628 5403119.5,4578678
5403069.5,4578678 5403059.5,4578688 5403049.5,4578708 5403049.5,4578708
5403039.5,4578718 5403029.5,4578738 5403029.5,4578738 5403019.5,4578758
5402999.5,4578758 5402989.5,4578738 5402969.5,4578738 5402959.5,4578728
5402949.5,4578738 5402939.5,4578738 5402929.5,4578778 5402889.5,4578778
5402879.5,4578798 5402859.5,4578798 5402849.5,4578808 5402839.5,4578808
5402829.5,4578818 5402819.5,4578818 5402789.5,4578828 5402779.5,4578828
5402769.5,4578838 5402759.5,4578838 5402749.5,4578848 5402739.5,4578848
5402729.5,4578858 5402719.5,4578858 5402699.5,4578868 5402689.5,4578868
5402649.5,4578878 5402639.5,4578878 5402629.5,4578898 5402609.5,4578898
5402599.5,4578918 5402579.5,4578918 5402569.5,4578928 5402559.5,4578928
5402539.5,4578908 5402519.5,4578908 5402509.5,4578888 5402489.5,4578888
5402479.5,4578858 5402449.5,4578858 5402419.5,4578848 5402409.5,4578848
5402389.5,4578838 5402379.5,4578838 5402369.5,4578798 5402329.5,4578798
5402309.5,4578778 5402289.5,4578778 5402279.5,4578768 5402269.5,4578768
5402259.5,4578758 5402249.5,4578758 5402239.5,4578768 5402229.5,4578768
5402159.5,4578818 5402109.5,4578818 5402059.5,4578808 5402049.5,4578808
5402039.5,4578798 5402029.5,4578798 5402019.5,4578788 5402009.5,4578788
5401999.5,4578748 5401959.5,4578748 5401909.5,4578768 5401889.5,4578768
5401869.5,4578778 5401859.5,4578778 5401829.5,4578788 5401819.5,4578788
5401809.5,4578778 5401799.5,4578778 5401789.5,4578768 5401779.5,4578778
5401769.5,4578778 5401759.5,4578768 5401749.5,4578778 5401739.5,4578798
5401739.5,4578798 5401729.5,4578808 5401719.5,4578818 5401719.5,4578828
5401709.5,4578838 5401709.5,4578848 5401699.5,4578858 5401699.5,4578878
5401679.5,4578888 5401679.5,4578918 5401649.5,4578928 5401649.5,4578928
5401639.5,4579008 5401559.5,4579008 5401539.5,4579018 5401529.5,4579018
5401489.5,4579008 5401479.5,4579028 5401459.5,4579028 5401449.5,4579038
5401439.5,4579038 5401409.5,4579048 5401399.5,4579048 5401379.5,4579058
5401369.5,4579058 5401349.5,4579068 5401339.5,4579068 5401269.5,4579058
5401259.5,4579058 5401229.5,4579068 5401219.5,4579058
5401209.5,4579053.5 5401198,4579053.5 5401178,4579073.5
5401158,4579073.5 5401138,4579103.5 5401108,4579093.5 5401098,4579093.5
5401088,4579103.5 5401078,4579093.5 5401068,4579093.5 5401058,4579073.5
5401038,4579083.5 5401028,4579083.5 5400998,4579093.5 5400988,4579093.5
5400978,4579093.5 5400928,4579083.5 5400918,4579083.5 5400908,4579073.5
5400898,4579073.5 5400838,4579083.5 5400828,4579083.5 5400788,4579093.5
5400778,4579093.5 5400768,4579103.5 5400758,4579103.5 5400748,4579093.5
5400738,4579093.5 5400728,4579083.5 5400718,4579083.5 5400688,4579073.5
5400678,4579073.5 5400608,4579083.5 5400598,4579083.5 5400508,4579073.5
5400498,4579073.5 5400428,4579083.5 5400418,4579083.5 5400398,4579093.5
5400388,4579093.5 5400368,4579103.5 5400358,4579103.5 5400348,4579113.5
5400338,4579113.5 5400308,4579133.5 5400288,4579133.5 5400278,4579153.5
5400258,4579153.5 5400228,4579163.5 5400218,4579163.5 5400198,4579183.5
5400178,4579183.5 5400168,4579193.5 5400158,4579193.5 5400118,4579203.5
5400108,4579203.5 5399978,4579183.5 5399958,4579183.5 5399948,4579193.5
5399938,4579173.5 5399938,4579163.5 5399928,4579163.5 5399918,4579153.5
5399908,4579153.5 5399838,4579163.5 5399828,4579163.5 5399818,4579103.5
5399758,4579103.5 5399748,4579073.5 5399718,4579073.5 5399708,4579063.5
5399698,4579053.5 5399698,4579013.5 5399658,4579013.5 5399628,4579003.5
5399618,4579003.5 5399598,4578983.5 5399578,4578973.5 5399578,4578963.5
5399568,4578903.5 5399568,4578893.5 5399558,4578863.5 5399558,4578853.5
5399568,4578843.5 5399568,4578803.5 5399608,4578793.5 5399608,4578783.5
5399598,4578793.5 5399588,4578793.5 5399578,4578783.5 5399578,4578753.5
5399608,4578733.5 5399608,4578723.5 5399618,4578693.5 5399618,4578683.5
5399608,4578673.5 5399608,4578653.5 5399588,4578643.5 5399588,4578633.5
5399578,4578633.5 5399568,4578623.5 5399558,4578623.5 5399548,4578603.5
5399528,4578603.5 5399498,4578593.5 5399498,4578573.5 5399478,4578573.5
5399438,4578583.5 5399428,4578583.5 5399398,4578593.5 5399388,4578593.5
5399368,4578613.5 5399348,4578613.5 5399338,4578633.5 5399318,4578643.5
5399328,4578653.5 5399328,4578663.5 5399338,4578683.5 5399338,4578703.5
5399318,4578733.5 5399318,4578743.5 5399308,4578753.5 5399308,4578763.5
5399298,4578773.5 5399298,4578773.5 5399288,4578793.5 5399268,4578803.5
5399268,4578823.5 5399248,4578833.5 5399248,4578863.5 5399218,4578883.5
5399218,4578893.5 5399208,4578923.5 5399208,4578953.5 5399178,4578953.5
5399168,4578943.5 5399158,4578943.5 5399148,4578933.5 5399138,4578937.5
5399126.5,4578947.5 5399126.5,4578957.5 5399116.5,4578967.5
5399116.5,4578977.5 5399106.5,4578987.5 5399106.5,4579007.5
5399086.5,4579017.5 5399086.5,4579037.5 5399066.5,4579047.5
5399066.5,4579057.5 5399056.5,4579067.5 5399056.5,4579087.5
5399036.5,4579097.5 5399036.5,4579117.5 5399016.5,4579127.5
5399016.5,4579167.5 5398976.5,4579157.5 5398966.5,4579167.5
5398956.5,4579177.5 5398966.5,4579167.5 5398976.5,4579177.5
5398976.5,4579197.5 5398956.5,4579207.5 5398956.5,4579237.5
5398926.5,4579237.5 5398916.5,4579247.5 5398906.5,4579227.5
5398886.5,4579227.5 5398876.5,4579237.5 5398866.5,4579247.5
5398876.5,4579267.5 5398876.5,4579277.5 5398886.5,4579297.5
5398866.5,4579297.5 5398856.5,4579347.5 5398806.5,4579347.5
5398796.5,4579377.5 5398766.5,4579387.5 5398766.5,4579407.5
5398746.5,4579417.5 5398746.5,4579457.5 5398706.5,4579457.5
5398696.5,4579487.5 5398666.5,4579517.5 5398666.5,4579537.5
5398646.5,4579547.5 5398646.5,4579587.5 5398606.5,4579597.5
5398606.5,4579607.5 5398596.5,4579617.5 5398596.5,4579617.5
5398586.5,4579627.5 5398576.5,4579627.5 5398566.5,4579637.5
5398556.5,4579647.5 5398556.5,4579657.5 5398546.5,4579667.5
5398546.5,4579677.5 5398536.5,4579687.5 5398536.5,4579697.5
5398526.5,4579707.5 5398526.5,4579717.5 5398516.5,4579727.5
5398516.5,4579737.5 5398506.5,4579737.5 5398496.5,4579757.5
5398476.5,4579767.5 5398486.5,4579777.5 5398486.5,4579787.5
5398476.5,4579807.5 5398476.5,4579817.5 5398466.5,4579827.5
5398466.5,4579892 5398402,4579995 5398344.5,4580019 5398356,4580023
5398363.5,4580025.5 5398360.5,4580016.5 5398338.5,4580059.5
5398297.5,4580100.5 5398270.5,4580142 5398250,4580170 5398231.5,4580234
5398202,4580237.5 5398208,4580229 5398217.5,4580265.5 5398229,4580290.5
5398208,4580328.5 5398160,4580347 5398133,4580345.5 5398118.5,4580331.5
5398108,4580309 5398107.5,4580283.5 5398120,4580244.5 5398142.5,4580233
5398147.5,4580209 5398123.5,4580209.5 5398116.5,4580249.5
5398061,4580277.5 5398033,4580296.5 5398023.5,4580310
5398027.5,4580318.5 5398039,4580313 5398053,4580313 5398063,4580325
5398074.5,4580343 5398079.5,4580356 5398073,4580367.5 5398060.5,4580370
5398043,4580380 5398032,4580403 5398027.5,4580417.5 5398019.5,4580424.5
5398007,4580426 5397994.5,4580432.5 5397993,4580446.5 5398026.5,4580461
5398041.5,4580506 5398058,4580518 5398052,4580534 5398048,4580580
5398030.5,4580589 5398029.5,4580601 5398035.5,4580605 5398046,4580612
5398056,4580619.5 5398060.5,4580635.5 5398051,4580642 5398014,4580653.5
5398009.5,4580661 5398011,4580674 5398010,4580695.5 5398002,4580734.5
5397980,4580756 5397974,4580797 5397967,4580827.5 5397921,4580842
5397915,4580862.5 5397918.5,4580892.5 5397933.5,4580914 5397941,4580943
5397945.5,4580982.5 5397945,4581012.5 5397927.5,4581048.5
5397900.5,4581074.5 5397892,4581093.5 5397892.5,4581106
5397884.5,4581113.5 5397826,4581109 5397813.5,4581088.5 5397808,4581078
5397801.5,4581076 5397789.5,4581089 5397772.5,4581115.5 5397753,4581127
5397741,4581124 5397712,4581143 5397716,4581163 5397713.5,4581172.5
5397698,4581162.5 5397617.5,4581152 5397561.5,4581143 5397539,4581172
5397561,4581217.5 5397577.5,4581291 5397565,4581319 5397547.5,4581342
5397558,4581358 5397561.5,4581472.5 5397480,4581517 5397360,4581567.5
5397247.5,4581577.5 5397237.5,4581597.5 5397237.5,4581607.5
5397227.5,4581607.5 5397187.5,4581617.5 5397177.5,4581607.5
5397167.5,4581607.5 5397147.5,4581617.5 5397137.5,4581617.5
5397107.5,4581627.5 5397097.5,4581637.5 5397107.5,4581647.5
5397107.5,4581667.5 5397087.5,4581667.5 5397077.5,4581677.5
5397067.5,4581667.5 5397067.5,4581657.5 5397057.5,4581667.5
5397047.5,4581657.5 5397037.5,4581667.5 5397027.5,4581677.5
5397027.5,4581687.5 5397037.5,4581707.5 5397017.5,4581707.5
5397007.5,4581727.5 5396987.5,4581727.5 5396977.5,4581737.5
5396967.5,4581737.5 5396957.5,4581747.5 5396947.5,4581747.5
5396937.5,4581767.5 5396917.5,4581777.5 5396927.5,4581777.5
5396947.5,4581767.5 5396957.5,4581767.5 5396967.5,4581797.5
5396937.5,4581797.5 5396927.5,4581807.5 5396917.5,4581807.5
5396907.5,4581837.5 5396877.5,4581837.5 5396857.5,4581857.5
5396837.5,4581857.5 5396817.5,4581867.5 5396807.5,4581857.5
5396807.5,4581847.5 5396817.5,4581837.5 5396807.5,4581867.5
5396777.5,4581867.5 5396767.5,4581887.5 5396747.5,4581897.5
5396757.5,4581887.5 5396767.5,4581887.5 5396787.5,4581897.5
5396777.5,4581897.5 5396767.5,4581907.5 5396757.5,4581907.5
5396747.5,4581917.5 5396737.5,4581917.5 5396727.5,4581927.5
5396717.5,4581927.5 5396707.5,4581937.5 5396697.5,4581937.5
5396687.5,4581947.5 5396677.5,4581947.5 5396667.5,4581957.5
5396657.5,4581957.5 5396617.5,4581977.5 5396597.5,4581977.5
5396577.5,4582007.5 5396547.5,4582007.5 5396527.5,4582017.5
5396517.5,4582017.5 5396497.5,4582027.5 5396487.5,4582027.5
5396477.5,4582037.5 5396467.5,4582037.5 5396457.5,4582057.5
5396437.5,4582057.5 5396427.5,4582067.5 5396417.5,4582057.5
5396417.5,4582047.5 5396407.5,4582057.5 5396397.5,4582057.5
5396377.5,4582047.5 5396367.5,4582047.5 5396327.5,4582057.5
5396317.5,4582077.5 5396317.5,4582087.5 5396307.5,4582097.5
5396307.5,4582097.5 5396257.5,4582077.5 5396237.5,4582077.5
5396217.5,4582087.5 5396207.5,4582087.5 5396187.5,4582117.5
5396157.5,4582117.5 5396147.5,4582127.5 5396137.5,4582107.5
5396117.5,4582107.5 5396077.5,4582117.5 5396067.5,4582127.5
5396067.5,4582127.5 5396047.5,4582137.5 5396037.5,4582137.5
5395977.5,4582127.5 5395967.5,4582127.5 5395957.5,4582117.5
5395947.5,4582117.5 5395927.5,4582127.5 5395917.5,4582137.5
5395917.5,4582137.5 5395907.5,4582147.5 5395897.5,4582147.5
5395887.5,4582137.5 5395877.5,4582137.5 5395867.5,4582127.5
5395857.5,4582137.5 5395847.5,4582137.5 5395817.5,4582147.5
5395807.5,4582147.5 5395797.5,4582157.5 5395787.5,4582177.5
5395787.5,4582184.5 5395792,4582197.5 5395807.5,4582224.5
5395833.5,4582227.5 5395827.5,4582227.5 5395817.5,4582207.5
5395797.5,4582197 5395789.5,4582183.5 5395781.5,4582177.5
5395767.5,4582157.5 5395747.5,4582157.5 5395737.5,4582137.5
5395737.5,4582127.5 5395727.5,4582137.5 5395717.5,4582178
5395717,4582146 5395459.5,4582135 5395397,4582129 5395345,4582126
5395225,4582098 5395226.5,4582100.5 5395209.5,4582129
5395206.5,4582128.5 5395131,4582132.5 5395028,4582201.5
5395035,4582205.5 5394881,4582343 5394635,4582341.5 5394529.5,4582380
5394409.5,4582465 5394398,4582559.5 5394354.5,4582646
5394328.5,4582663.5 5394312,4582666.5 5394293.5,4582670 5394292,4582685
5394304,4582699.5 5394295,4582706 5394281,4582713 5394276,4582720
5394274.5,4582731 5394276,4582735 5394274.5,4582742.5 5394264,4582752
5394256.5,4582753.5 5394248.5,4582752 5394246,4582738
5394241.5,4582736.5 5394238.5,4582738 5394234.5,4582744.5
5394229,4582754.5 5394239.5,4582762.5 5394232.5,4582764 5394224,4582754
5394209,4582751.5 5394195.5,4582754.5 5394189.5,4582781
5394187.5,4582787.5 5394181.5,4582796 5394167,4582798.5 5394156,4582811
5394132,4582807 5394109,4582802.5 5394103,4582794.5 5394101.5,4582793
5394100,4582794 5394090.5,4582791.5 5394085.5,4582785 5394079,4582778
5394083.5,4582756.5 5394092.5,4582751.5 5394097.5,4582730.5
5394069.5,4582737.5 5394061.5,4582801 5394048.5,4582807.5
5394044,4582812 5394037,4582815.5 5394025.5,4582818 5393999,4582817.5
5393975,4582804 5393932.5,4582800 5393915.5,4582799 5393885.5,4582786
5393878,4582785 5393874.5,4582791.5 5393860,4582794.5 5393857,4582807
5393855.5,4582810.5 5393854,4582811.5 5393850,4582810.5
5393843.5,4582807 5393835.5,4582808 5393829.5,4582812
5393824.5,4582819.5 5393810.5,4582829.5 5393797.5,4582836.5
5393782.5,4582838 5393773,4582827 5393748,4582828.5 5393742,4582838.5
5393730.5,4582826.5 5393726.5,4582825 5393722.5,4582832.5
5393702,4582838.5 5393693.5,4582860.5 5393653,4582878 5393601,4582882.5
5393596.5,4582883 5393587.5,4582889.5 5393569.5,4582897 5393563,4582898
5393557,4582913 5393537.5,4582913.5 5393532,4582933.5 5393480,4582947.5
5393453,4582959 5393441,4582973.5 5393438,4582972 5393434.5,4582958
5393428,4582964 5393400,4582966.5 5393372,4582976 5393344,4582976.5
5393333,4582982.5 5393326,4582988.5 5393321.5,4583022
5393242.5,4583026.5 5393238.5,4583047.5 5393207.5,4583067.5
5393156,4583106.5 5393212.5,4583113.5 5393237,4583129 5393249.5,4583134
5393257.5,4583138 5393268,4583172.5 5393286.5,4583179 5393297.5,4583180
5393312.5,4583177 5393319.5,4583198.5 5393332.5,4583259
5393290,4583241.5 5393269,4583248 5393262.5,4583287.5 5393253,4583329
5393213.5,4583329 5393183.5,4583319 5393173.5,4583319 5393163.5,4583309
5393153.5,4583299 5393153.5,4583289 5393143.5,4583289 5393073.5,4583259
5393043.5,4583259 5392983.5,4583269 5392973.5,4583269 5392953.5,4583279
5392943.5,4583279 5392933.5,4583289 5392923.5,4583289 5392913.5,4583269
5392893.5,4583279 5392883.5,4583299 5392903.5,4583309 5392903.5,4583299
5392893.5,4583329 5392863.5,4583339 5392863.5,4583379 5392823.5,4583379
5392813.5,4583389 5392803.5,4583409 5392803.5,4583419 5392813.5,4583439
5392793.5,4583479 5392793.5,4583489 5392783.5,4583519 5392783.5,4583539
5392763.5,4583539 5392743.5,4583559 5392723.5,4583609 5392723.5,4583609
5392713.5,4583649 5392673.5,4583649 5392663.5,4583659
5392653.5,4583674.5 5392546.5,4583650.5 5392536.5,4583597
5392532.5,4583589.5 5392525,4583617 5392521.5,4583626 5392513.5,4583710
5392515,4583740 5392485,4583764.5 5392485,4583779.5 5392459.5,4583800
5392457.5,4583833 5392444,4583846.5 5392431.5,4583888.5 5392422,4583952
5392417,4584010 5392421.5,4584069 5392412,4584112.5 5392411.5,4584131
5392417.5,4584159 5392435,4584179 5392441.5,4584247 5392416.5,4584274
5392413,4584340.5 5392359,4584350 5392361,4584357.5 5392338,4584384
5392324,4584423.5 5392322,4584495.5 5392310.5,4584512 5392294,4584532
5392294.5,4584547 5392283,4584561.5 5392279.5,4584573.5
5392268.5,4584594.5 5392260.5,4584667 5392215,4584706.5
5392204,4584732.5 5392203.5,4584755.5 5392166,4584849
5392096.5,4584905.5 5392060,4584943.5 5392020.5,4584943
5392000.5,4584972.5 5391963,4585036 5391956,4585048.5
5391953.5,4585169.5 5391835.5,4585194.5 5391805.5,4585245.5
5391756.5,4585313 5391702,4585341.5 5391681,4585387 5391651.5,4585391
5391647.5,4585391 5391642,4585403 5391634,4585404.5 5391619.5,4585413.5
5391605.5,4585427.5 5391593.5,4585442 5391593.5,4585456.5
5391588.5,4585482.5 5391560,4585485 5391550,4585491.5 5391545,4585508.5
5391524.5,4585520 5391514,4585528 5391511,4585564.5 5391479,4585631.5
5391427,4585633 5391422.5,4585666 5391398.5,4585673 5391390.5,4585771.5
5391299.5,4585775.5 5391299,4585787.5 5391276.5,4585835.5
5391230.5,4585849.5 5391230,4585923.5 5391154,4585940.5
5391138,4585955.5 5391120.5,4585953 5391119,4585943 5391122,4585943.5
5391118,4585946.5 5391112.5,4585959 5391109.5,4585968 5391104.5,4586002
5391072.5,4586019.5 5391053.5,4586043.5 5391034,4586062
5391021.5,4586096 5391002,4586115.5 5390997.5,4586128 5390989.5,4586228
5390904,4586257 5390877,4586275 5390859,4586385 5390718.5,4586408
5390691,4586431.5 5390666.5,4586447.5 5390652.5,4586457.5
5390647,4586460 5390643.5,4586452 5390637,4586451 5390634.5,4586467
5390614,4586477 5390606,4586518 5390591.5,4586530 5390579,4586560
5390554,4586586 5390529.5,4586655 5390447.5,4586669.5 5390434,4586674
5390420.5,4586705 5390390.5,4586713.5 5390395.5,4586709
5390387.5,4586716 5390364,4586718 5390345.5,4586736.5 5390330.5,4586749
5390327.5,4586764 5390327.5,4586801.5 5390312.5,4586821
5390280.5,4586850.5 5390256,4586908 5390239,4586930 5390239,4586992
5390204,4587000 5390189.5,4587032 5390177,4587116.5 5390118,4587135.5
5390077,4587153.5 5390053.5,4587090.5 5389990.5,4587089.163
5389989.633,4586393.799 5390252.837,4586274 5390369.5,4586201.5
5390431,4586115.5 5390491,4585950.5 5390583.5,4585880 5390631,4585758
5390722.5,4585592 5390866,4585409.5 5391021.5,4585402 5391044,4585386.5
5391045,4585314 5391099,4585326.5 5391117,4585313.5 5391132,4585303.5
5391135,4585300 5391146,4585274.5 5391135,4585215.5 5391178,4585133
5391261,4585064.5 5391342,4584995.5 5391410,4584896.5 5391496,4584805.5
5391564,4584726 5391614,4584661.5 5391647.5,4584559.5 5391687.5,4584441
5391720,4584323.5 5391731,4584031.5 5391722.5,4583946.5
5391724.5,4583838.5 5391739,4583682 5391790.5,4583583 5391835.5,4583530
5391864,4583533.016 5391863.339,4583490.575 5391889.606,4583444.425
5391914.124,4583323.282 5391974.695,4583256.942 5392002.097,4583215.119
5392022.287,4583160.316 5392045.362,4583099.744 5392068.437,4582987.254
5392098.723,4582912.26 5392108.818,4582850.247 5392114.587,4582770.927
5392116.029,4582719.5 5392112.266,4582719.5 5392085,4582709.5
5392075,4582699.5 5392075,4582679.5 5392055,4582679.5 5392045,4582639.5
5392045,4582629.5 5392035,4582579.5 5392035,4582559.5 5392055,4582539.5
5392055,4582529.5 5392045,4582529.5 5392035,4582509.5 5392035,4582499.5
5392045,4582479.5 5392045,4582469.5 5392035,4582459.5 5392035,4582449.5
5392025,4582419.5 5392025,4582409.5 5392015,4582359.5 5392015,4582349.5
5392005,4582339.5 5392015,4582319.5 5392015,4582309.5 5392025,4582299.5
5392015,4582299.5 5392005,4582279.5 5392005,4582269.5 5392015,4582239.5
5392015,4582229.5 5392005,4582219.5 5392015,4582209.5 5392015,4582209.5
5392025,4582199.5 5392035,4582189.5 5392035,4582189.5 5392045,4582169.5
5392065,4582159.5 5392065,4582149.5 5392055,4582139.5 5392055,4582109.5
5392085,4582099.5 5392085,4582089.5 5392095,4582079.5 5392095,4582059.5
5392115,4582049.5 5392105,4582069.5 5392085,4582079.5 5392075,4582089.5
5392075,4582119.5 5392045,4582129.5 5392045,4582149.5 5392025,4582139.5
5392015,4582139.5 5392005,4582109.5 5392005,4582099.5 5391995,4582089.5
5391995,4582079.5 5391985,4582059.5 5391985,4582039.5 5392005,4582029.5
5391995,4582029.5 5391985,4582009.5 5391985,4582009.5 5392025,4581999.5
5392035,4581989.5 5392025,4581979.5 5392025,4581959.5 5392045,4581949.5
5392035,4581949.5 5392025,4581919.5 5392025,4581919.5 5392045,4581929.5
5392035,4581939.5 5392035,4581949.5 5392045,4581949.5 5392055,4581939.5
5392065,4581929.5 5392065,4581919.5 5392075,4581889.5 5392075,4581879.5
5392065,4581879.5 5392035,4581869.5 5392035,4581859.5 5392025,4581869.5
5392015,4581879.5 5392015,4581869.5 5392005,4581889.5 5391985,4581889.5
5391975,4581899.5 5391965,4581889.5 5391955,4581879.5 5391955,4581869.5
5391965,4581829.5 5391965,4581819.5 5391955,4581799.5 5391955,4581779.5
5391935,4581769.5 5391935,4581759.5 5391925,4581749.5 5391925,4581739.5
5391915,4581729.5 5391915,4581719.5 5391905,4581699.5 5391905,4581689.5
5391895,4581679.5 5391895,4581669.5 5391885,4581649.5 5391885,4581639.5
5391875,4581619.5 5391875,4581609.5 5391885,4581599.5 5391885,4581589.5
5391895,4581569.5 5391895,4581569.5 5391905,4581559.5 5391915,4581569.5
5391925,4581559.5 5391935,4581549.5 5391935,4581539.5 5391925,4581509.5
5391955,4581499.5 5391955,4581469.5 5391985,4581439.5 5391985,4581429.5
5391995,4581419.5 5391995,4581409.5 5392005,4581379.5 5392005,4581369.5
5392015,4581349.5 5392015,4581329.5 5392035,4581319.5 5392035,4581299.5
5392055,4581289.5 5392055,4581279.5 5392065,4581269.5 5392065,4581259.5
5392075,4581249.5 5392075,4581239.5 5392085,4581219.5 5392085,4581209.5
5392095,4581179.5 5392095,4581169.5 5392105,4581129.5 5392105,4581119.5
5392115,4581089.5 5392115,4581079.5 5392105,4581039.5 5392105,4581029.5
5392095,4581029.5 5392085,4581019.5 5392075,4580979.5 5392075,4580969.5
5392065,4580949.5 5392065,4580899.5 5392015,4580899.5 5391955,4580889.5
5391965,4580879.5 5391955,4580879.5 5391945,4580819.5 5391945,4580809.5
5391955,4580749.5 5391955,4580739.5 5391965,4580679.5 5391965,4580679.5
5391975,4580669.5 5391985,4580669.5 5391995,4580679.5 5392005,4580689.5
5392005,4580699.5 5392015,4580689.5 5392025,4580669.5 5392025,4580669.5
5392035,4580699.5 5392035,4580709.5 5392045,4580709.5 5392055,4580719.5
5392055,4580729.5 5392065,4580739.5 5392065,4580749.5 5392075,4580769.5
5392075,4580779.5 5392085,4580799.5 5392085,4580809.5 5392095,4580819.5
5392095,4580829.5 5392105,4580859.5 5392105,4580869.5 5392115,4580879.5
5392115,4580889.5 5392125,4580909.5 5392125,4580919.5 5392135,4580919.5
5392175,4580939.5 5392195,4580939.5 5392205,4580929.5 5392215,4580929.5
5392225,4580889.5 5392265,4580879.5 5392265,4580869.5 5392275,4580859.5
5392275,4580849.5 5392285,4580839.5 5392285,4580829.5 5392295,4580819.5
5392295,4580779.5 5392335,4580759.5 5392335,4580719.5 5392375,4580699.5
5392375,4580689.5 5392385,4580619.5 5392385,4580609.5 5392375,4580569.5
5392375,4580559.5 5392385,4580539.5 5392365,4580529.5 5392365,4580519.5
5392355,4580479.5 5392355,4580469.5 5392345,4580449.5 5392345,4580439.5
5392335,4580229.5 5392335,4580209.5 5392355,4580199.5 5392355,4580179.5
5392375,4580159.5 5392375,4580149.5 5392385,4580129.5 5392385,4580119.5
5392395,4580089.5 5392395,4580079.5 5392385,4580059.5 5392385,4580049.5
5392395,4580039.5 5392395,4580009.5 5392425,4579999.5 5392415,4579969.5
5392415,4579959.5 5392425,4579919.5 5392425,4579909.5 5392415,4579889.5
5392415,4579879.5 5392405,4579859.5 5392405,4579849.5 5392395,4579839.5
5392395,4579829.5 5392385,4579829.5 5392375,4579819.5 5392365,4579819.5
5392325,4579809.5 5392325,4579799.5 5392335,4579799.5 5392345,4579809.5
5392355,4579809.5 5392385,4579789.5 5392405,4579769.5 5392405,4579759.5
5392395,4579759.5 5392405,4579749.5 5392415,4579739.5 5392415,4579729.5
5392425,4579699.5 5392425,4579679.5 5392445,4579679.5 5392455,4579649.5
5392485,4579649.5 5392505,4579639.5 5392515,4579639.5 5392525,4579629.5
5392535,4579609.5 5392535,4579609.5 5392565,4579599.5 5392575,4579579.5
5392555,4579579.5 5392545,4579569.5 5392535,4579559.5 5392535,4579559.5
5392545,4579539.5 5392565,4579539.5 5392585,4579549.5 5392595,4579539.5
5392605,4579529.5 5392605,4579529.5 5392615,4579539.5 5392625,4579539.5
5392645,4579559.5 5392625,4579569.5 5392635,4579569.5 5392645,4579549.5
5392665,4579539.5 5392655,4579539.5 5392665,4579529.5 5392675,4579519.5
5392675,4579519.5 5392685,4579509.5 5392695,4579499.5 5392685,4579479.5
5392685,4579469.5 5392675,4579469.5 5392655,4579459.5 5392645,4579469.5
5392635,4579479.5 5392635,4579479.5 5392615,4579459.5 5392615,4579459.5
5392625,4579449.5 5392635,4579439.5 5392635,4579439.5 5392685,4579449.5
5392695,4579449.5 5392705,4579439.5 5392715,4579429.5 5392715,4579399.5
5392745,4579369.5 5392745,4579369.5 5392755,4579349.5 5392775,4579339.5
5392775,4579329.5 5392765,4579329.5 5392745,4579319.5 5392735,4579319.5
5392745,4579309.5 5392755,4579289.5 5392755,4579279.5 5392745,4579269.5
5392745,4579269.5 5392755,4579249.5 5392775,4579239.5 5392775,4579219.5
5392795,4579139.5 5392795,4579068 5392807,4579018 5392807,4579008
5392817,4578988 5392817,4578978 5392827,4578958 5392827,4578948
5392837,4578938 5392837,4578928 5392847,4578918 5392847,4578908
5392857,4578898 5392857,4578888 5392867,4578878 5392867,4578858
5392887,4578848 5392887,4578838 5392897,4578828 5392897,4578808
5392917,4578788 5392917,4578778 5392927,4578768 5392927,4578758
5392937,4578748 5392937,4578738 5392947,4578728 5392947,4578718
5392957,4578708 5392957,4578688 5392977,4578678 5392977,4578668
5392987,4578658 5392987,4578638 5393007,4578628 5393007,4578608
5393027,4578598 5393027,4578548 5393077,4578538 5393077,4578408
5393207,4578408 5393217,4578328 5393297,4578328 5393307,4578238
5393397,4578238 5393407,4578218 5393427,4578218 5393437,4578208
5393447,4578198 5393447,4578188 5393457,4578188 5393467,4578198
5393477,4578198 5393487,4578138 5393547,4578118 5393547,4578088
5393577,4578078 5393577,4578078 5393587,4578048 5393617,4578048
5393627,4578008 5393667,4578008 5393677,4577978 5393707,4577978
5393717,4577948 5393747,4577948 5393757,4577908 5393797,4577908
5393807,4577878 5393837,4577878 5393847,4577848 5393877,4577848
5393887,4577808 5393927,4577808 5393937,4577778 5393967,4577778
5393977,4577748 5394007,4577748 5394027,4577758 5394037,4577758
5394067,4577768 5394077,4577768 5394127,4577778 5394137,4577778
5394157,4577788 5394167,4577788 5394187,4577798 5394197,4577798
5394207,4577808 5394217,4577808 5394247,4577848 5394287,4577858
5394287,4577878 5394307,4577878 5394327,4577888 5394337,4577898
5394337,4577908 5394347,4577918 5394357,4577918 5394367,4577908
5394377,4577908 5394417,4577898 5394427,4577898 5394447,4577888
5394457,4577888 5394477,4577858 5394507,4577848 5394497,4577848
5394477,4577838 5394487,4577838 5394497,4577828 5394507,4577828
5394517,4577808 5394537,4577788 5394537,4577778 5394547,4577778
5394557,4577768 5394567,4577758 5394567,4577748 5394577,4577738
5394577,4577738 5394587,4577718 5394607,4577708 5394607,4577648
5394667,4577648 5394677,4577668 5394677,4577678 5394687,4577668
5394697,4577678 5394697,4577688 5394707,4577688 5394697,4577718
5394667,4577738 5394667,4577748 5394677,4577728 5394697,4577728
5394707,4577718 5394717,4577718 5394737,4577728 5394747,4577738
5394747,4577758 5394727,4577768 5394727,4577788 5394707,4577798
5394707,4577808 5394697,4577818 5394697,4577828 5394707,4577828
5394787,4577838 5394797,4577838 5394807,4577828 5394817,4577828
5394827,4577838 5394837,4577838 5394867,4577828 5394877,4577828
5394917,4577818 5394927,4577818 5394957,4577828 5394957,4577828
5394937,4577858 5394907,4577868 5394917,4577868 5394927,4577878
5394937,4577868 5394947,4577878 5394957,4577882.5 5394969,4577882.5
5395039,4577892.5 5395049,4577892.5 5395069,4577882.5 5395079,4577892.5
5395089,4577892.5 5395099,4577902.5 5395109,4577902.5 5395119,4577912.5
5395129,4577912.5 5395139,4577932.5 5395159,4577932.5 5395169,4577942.5
5395179,4577942.5 5395189,4577932.5 5395199,4577932.5 5395209,4577922.5
5395219,4577912.5 5395229,4577902.5 5395229,4577902.5 5395239,4577892.5
5395249,4577852.5 5395249,4577852.5 5395289,4577832.5 5395309,4577822.5
5395309,4577782.5 5395349,4577772.5 5395349,4577772.5 5395359,4577762.5
5395369,4577762.5 5395379,4577752.5 5395389,4577752.5 5395399,4577742.5
5395409,4577722.5 5395409,4577712.5 5395399,4577702.5 5395399,4577682.5
5395379,4577672.5 5395379,4577662.5 5395369,4577652.5 5395369,4577642.5
5395359,4577642.5 5395299,4577632.5 5395289,4577632.5 5395259,4577612.5
5395239,4577612.5 5395229,4577602.5 5395229,4577592.5 5395219,4577592.5
5395209,4577562.5 5395209,4577552.5 5395199,4577502.5 5395199,4577492.5
5395189,4577482.5 5395189,4577472.5 5395179,4577472.5 5395169,4577442.5
5395139,4577442.5 5395129,4577452.5 5395089,4577452.5 5395079,4577462.5
5395069,4577462.5 5395049,4577472.5 5395039,4577472.5 5395019,4577482.5
5395009,4577482.5 5394999,4577492.5 5394989,4577492.5 5394979,4577512.5
5394959,4577518 5394947,4577518 5394937,4577548 5394907,4577548
5394897,4577568 5394877,4577568 5394867,4577598 5394837,4577598
5394827,4577608 5394817,4577608 5394807,4577618 5394797,4577618
5394787,4577598 5394807,4577588 5394807,4577588 5394837,4577578
5394847,4577568 5394847,4577568 5394857,4577558 5394867,4577548
5394867,4577548 5394877,4577538 5394887,4577528 5394887,4577528
5394897,4577508 5394917,4577498 5394917,4577498 5394937,4577492.5
5394949,4577472.5 5394949,4577472.5 5394959,4577462.5 5394969,4577442.5
5394969,4577442.5 5394989,4577432.5 5394999,4577452.5 5395019,4577452.5
5395059,4577442.5 5395069,4577442.5 5395099,4577439.5
5395110.5,4577435.5 5395115,4577422.5 5395109,4577412.5
5395109,4577402.5 5395099,4577382.5 5395119,4577372.5 5395119,4577382.5
5395129,4577372.5 5395139,4577362.5 5395129,4577362.5 5395169,4577352.5
5395179,4577352.5 5395189,4577332.5 5395209,4577322.5 5395209,4577322.5
5395219,4577312.5 5395229,4577312.5 5395249,4577302.5 5395259,4577302.5
5395289,4577322.5 5395269,4577352.5 5395299,4577352.5 5395359,4577362.5
5395369,4577352.5 5395379,4577362.5 5395379,4577372.5 5395389,4577392.5
5395389,4577422.5 5395419,4577422.5 5395429,4577412.5 5395439,4577412.5
5395449,4577402.5 5395459,4577382.5 5395459,4577372.5 5395469,4577372.5
5395479,4577382.5 5395489,4577392.5 5395479,4577402.5 5395489,4577402.5
5395479,4577442.5 5395439,4577442.5 5395419,4577452.5 5395409,4577462.5
5395409,4577472.5 5395399,4577482.5 5395399,4577492.5 5395409,4577502.5
5395409,4577532.5 5395439,4577532.5 5395449,4577522.5 5395459,4577502.5
5395459,4577502.5 5395469,4577472.5 5395499,4577472.5 5395509,4577462.5
5395519,4577512.5 5395519,4577522.5 5395529,4577562.5 5395529,4577572.5
5395539,4577562.5 5395549,4577532.5 5395549,4577532.5 5395569,4577542.5
5395579,4577552.5 5395579,4577572.5 5395599,4577572.5 5395619,4577582.5
5395629,4577582.5 5395659,4577562.5 5395679,4577562.5 5395689,4577572.5
5395699,4577522.5 5395749,4577522.5 5395779,4577512.5 5395789,4577492.5
5395789,4577482.5 5395799,4577472.5 5395799,4577452.5 5395819,4577432.5
5395819,4577422.5 5395809,4577402.5 5395809,4577392.5 5395819,4577362.5
5395819,4577362.5 5395869,4577382.5 5395869,4577402.5 5395849,4577422.5
5395849,4577432.5 5395859,4577412.5 5395879,4577402.5 5395879,4577372.5
5395909,4577362.5 5395909,4577252.5 5396019,4577252.5 5396029,4577242.5
5396039,4577212.5 5396039,4577212.5 5396059,4577202.5 5396069,4577202.5
5396079,4577142 5396138.5,4577142 5396148.5,4577002 5396288.5,4577002
5396298.5,4576992 5396308.5,4576992 5396318.5,4576932 5396378.5,4576932
5396388.5,4576902 5396418.5,4576902 5396428.5,4576892 5396438.5,4576892
5396448.5,4576872 5396468.5,4576872 5396478.5,4576852 5396498.5,4576852
5396508.5,4576832 5396528.5,4576832 5396538.5,4576822 5396548.5,4576812
5396548.5,4576802 5396558.5,4576792 5396548.5,4576792 5396518.5,4576802
5396508.5,4576802 5396498.5,4576812 5396488.5,4576812 5396478.5,4576822
5396468.5,4576822 5396438.5,4576802 5396458.5,4576802 5396478.5,4576772
5396508.5,4576772 5396518.5,4576762 5396528.5,4576762 5396548.5,4576752
5396558.5,4576752 5396568.5,4576742 5396578.5,4576732 5396578.5,4576722
5396588.5,4576682 5396588.5,4576672 5396598.5,4576642 5396598.5,4576612
5396568.5,4576612 5396558.5,4576582 5396528.5,4576572 5396528.5,4576562
5396538.5,4576562 5396548.5,4576572 5396558.5,4576572 5396568.5,4576562
5396578.5,4576552 5396578.5,4576552 5396588.5,4576532 5396608.5,4576482
5396608.5,4576462 5396588.5,4576442 5396588.5,4576432 5396578.5,4576432
5396558.5,4576422 5396558.5,4576412 5396568.5,4576412 5396578.5,4576402
5396588.5,4576392 5396588.5,4576392 5396598.5,4576382 5396608.5,4576372
5396598.5,4576372 5396578.5,4576382 5396568.5,4576392 5396568.5,4576392
5396538.5,4576492 5396438.5,4576522 5396438.5,4576542 5396418.5,4576542
5396408.5,4576552 5396398.5,4576582 5396398.5,4576572 5396388.5,4576572
5396378.5,4576562 5396368.5,4576552 5396378.5,4576542 5396368.5,4576542
5396358.5,4576512 5396358.5,4576502 5396348.5,4576522 5396328.5,4576532
5396328.5,4576542 5396318.5,4576542 5396308.5,4576552 5396298.5,4576552
5396288.5,4576562 5396278.5,4576562 5396268.5,4576572 5396258.5,4576592
5396258.5,4576612 5396238.5,4576612 5396218.5,4576622 5396208.5,4576632
5396208.5,4576642 5396198.5,4576632 5396198.5,4576622 5396188.5,4576632
5396178.5,4576662 5396178.5,4576722 5396118.5,4576722 5396108.5,4576752
5396078.5,4576762 5396078.5,4576792 5396048.5,4576802 5396048.5,4576812
5396058.5,4576812 5396068.5,4576802 5396078.5,4576802 5396088.5,4576792
5396098.5,4576802 5396108.5,4576802 5396118.5,4576782 5396138.5,4576772
5396138.5,4576752 5396158.5,4576742 5396158.5,4576742 5396168.5,4576722
5396188.5,4576712 5396188.5,4576712 5396228.5,4576702 5396238.5,4576682
5396238.5,4576662 5396258.5,4576652 5396258.5,4576632 5396278.5,4576632
5396288.5,4576622 5396298.5,4576622 5396358.5,4576632 5396368.5,4576682
5396368.5,4576702 5396388.5,4576712 5396388.5,4576722 5396398.5,4576762
5396398.5,4576782 5396378.5,4576772 5396368.5,4576772 5396358.5,4576802
5396328.5,4576812 5396328.5,4576782 5396298.5,4576782 5396248.5,4576772
5396238.5,4576772 5396228.5,4576782 5396218.5,4576802 5396218.5,4576812
5396208.5,4576822 5396208.5,4576852 5396238.5,4576852 5396258.5,4576872
5396278.5,4576872 5396288.5,4576882 5396288.5,4576882 5396268.5,4576892
5396258.5,4576892 5396248.5,4576902 5396238.5,4576912 5396238.5,4576912
5396218.5,4576932 5396198.5,4576932 5396178.5,4576942 5396168.5,4576952
5396178.5,4576962 5396178.5,4576952 5396168.5,4576952 5396158.5,4576962
5396148.5,4576982 5396148.5,4577002 5396128.5,4577002 5396108.5,4576992
5396108.5,4576982 5396098.5,4576982 5396078.5,4576972 5396068.5,4576972
5396058.5,4576962 5396048.5,4576962 5396028.5,4576952 5396018.5,4576952
5395988.5,4576942 5395988.5,4576922 5395968.5,4576922 5395948.5,4576912
5395938.5,4576932 5395918.5,4576932 5395908.5,4576952 5395888.5,4576952
5395838.5,4576942 5395828.5,4576942 5395818.5,4576932 5395808.5,4576932
5395798.5,4576912 5395778.5,4576912 5395768.5,4576882 5395768.5,4576882
5395778.5,4576872 5395788.5,4576872 5395798.5,4576862 5395808.5,4576862
5395818.5,4576842 5395838.5,4576832 5395828.5,4576822 5395828.5,4576812
5395818.5,4576812 5395808.5,4576822 5395798.5,4576822 5395788.5,4576842
5395768.5,4576852 5395768.5,4576872 5395748.5,4576882 5395748.5,4576882
5395738.5,4576892 5395728.5,4576887 5395715.5,4576900.5
5395703.5,4576912.5 5395709,4576912.5 5395719,4576922.5
5395729,4576922.5 5395739,4576932.5 5395749,4576932.5 5395759,4576942.5
5395769,4576942.5 5395779,4576962.5 5395799,4576962.5 5395809,4576972.5
5395819,4576972.5 5395829,4576982.5 5395829,4576992.5 5395819,4576992.5
5395799,4577002.5 5395789,4576992.5 5395779,4577012.5 5395759,4577012.5
5395749,4577082.5 5395679,4577072.5 5395669,4577082.5 5395659,4577082.5
5395649,4577072.5 5395649,4577062.5 5395639,4577052.5 5395639,4577042.5
5395629,4577032.5 5395629,4577022.5 5395619,4577012.5 5395619,4577002.5
5395609,4576992.5 5395609,4576982.5 5395599,4576972.5 5395599,4576962.5
5395589,4576952.5 5395589,4576944 5395581,4576952.5 5395569,4576962.5
5395569,4576992.5 5395539,4577022.5 5395539,4577032.5 5395549,4577042.5
5395549,4577052.5 5395559,4577042.5 5395569,4577032.5 5395569,4577042.5
5395579,4577042.5 5395589,4577072.5 5395559,4577082.5 5395559,4577092.5
5395549,4577132.5 5395549,4577132.5 5395539,4577152.5 5395519,4577152.5
5395509,4577162.5 5395499,4577162.5 5395479,4577172.5 5395469,4577172.5
5395459,4577182.5 5395449,4577182.5 5395439,4577172.5 5395449,4577162.5
5395439,4577162.5 5395429,4577152.5 5395429,4577142.5 5395419,4577122.5
5395419,4577112.5 5395409,4577092.5 5395409,4577082.5 5395399,4577072.5
5395409,4577062.5 5395399,4577052.5 5395399,4577022.5 5395429,4577022.5
5395439,4577002.5 5395459,4577002.5 5395469,4576992.5 5395479,4576982.5
5395479,4576982.5 5395489,4576972.5 5395499,4576962.5 5395499,4576962.5
5395509,4576952.5 5395519,4576952.5 5395539,4576942.5 5395549,4576922.5
5395549,4576912.5 5395559,4576912.5 5395569,4576922.5 5395569,4576933
5395575.5,4576934 5395581.5,4576922.5 5395589,4576902.5
5395589,4576882.5 5395609,4576872.5 5395609,4576862.5 5395619,4576862.5
5395639,4576872.5 5395649,4576872.5 5395659,4576892.5 5395679,4576891
5395704.5,4576882.5 5395709,4576862.5 5395689,4576862.5
5395679,4576852.5 5395669,4576822 5395698.5,4576802 5395698.5,4576802
5395718.5,4576792 5395728.5,4576782 5395738.5,4576752 5395738.5,4576752
5395748.5,4576732 5395768.5,4576732 5395778.5,4576712 5395798.5,4576692
5395798.5,4576662 5395828.5,4576652 5395828.5,4576632 5395848.5,4576642
5395858.5,4576612 5395888.5,4576602 5395888.5,4576572 5395918.5,4576562
5395918.5,4576552 5395928.5,4576542 5395928.5,4576522 5395948.5,4576502
5395948.5,4576482 5395968.5,4576472 5395968.5,4576442 5395998.5,4576432
5395998.5,4576432 5396008.5,4576452 5396028.5,4576442 5396038.5,4576422
5396018.5,4576412 5396028.5,4576392 5396028.5,4576332 5396088.5,4576312
5396088.5,4576302 5396098.5,4576282 5396078.5,4576262 5396078.5,4576242
5396098.5,4576232 5396098.5,4576242 5396108.5,4576262 5396108.5,4576272
5396118.5,4576262 5396128.5,4576252 5396128.5,4576252 5396148.5,4576262
5396148.5,4576272 5396158.5,4576262 5396168.5,4576252 5396168.5,4576242
5396178.5,4576232 5396178.5,4576222 5396188.5,4576192 5396188.5,4576172
5396208.5,4576152 5396208.5,4576142 5396218.5,4576122 5396218.5,4576112
5396228.5,4576092 5396228.5,4576072 5396208.5,4576062 5396208.5,4576052
5396198.5,4576072 5396178.5,4576072 5396168.5,4576082 5396158.5,4576082
5396148.5,4576092 5396138.5,4576092 5396128.5,4576112 5396108.5,4576112
5396098.5,4576122 5396088.5,4576122 5396068.5,4576132 5396058.5,4576132
5396038.5,4576142 5396028.5,4576142 5395988.5,4576152 5395978.5,4576162
5395978.5,4576172 5395968.5,4576172 5395958.5,4576182 5395948.5,4576182
5395928.5,4576192 5395918.5,4576192 5395898.5,4576202 5395888.5,4576202
5395878.5,4576192 5395888.5,4576182 5395888.5,4576152 5395858.5,4576152
5395828.5,4576162 5395818.5,4576162 5395808.5,4576182 5395788.5,4576192
5395798.5,4576212 5395798.5,4576222 5395808.5,4576252 5395778.5,4576252
5395768.5,4576272 5395748.5,4576292 5395748.5,4576312 5395728.5,4576312
5395718.5,4576342 5395688.5,4576342 5395678.5,4576362 5395658.5,4576362
5395648.5,4576382 5395628.5,4576382 5395618.5,4576392 5395608.5,4576392
5395598.5,4576412 5395578.5,4576412 5395568.5,4576422 5395558.5,4576422
5395548.5,4576432 5395538.5,4576432 5395528.5,4576442 5395518.5,4576442
5395508.5,4576452 5395498.5,4576452 5395488.5,4576462 5395478.5,4576462
5395458.5,4576472 5395448.5,4576472 5395438.5,4576482 5395428.5,4576482
5395408.5,4576492 5395398.5,4576492 5395388.5,4576502 5395378.5,4576502
5395348.5,4576512 5395338.5,4576512 5395318.5,4576502 5395318.5,4576492
5395328.5,4576492 5395338.5,4576472 5395358.5,4576452 5395358.5,4576442
5395368.5,4576442 5395388.5,4576432 5395398.5,4576422 5395398.5,4576412
5395388.5,4576412 5395378.5,4576402 5395388.5,4576402 5395408.5,4576392
5395418.5,4576382 5395418.5,4576382 5395428.5,4576362 5395448.5,4576362
5395458.5,4576342 5395478.5,4576332 5395478.5,4576322 5395488.5,4576312
5395488.5,4576122 5395678.5,4576122 5395688.5,4576112 5395698.5,4576102
5395698.5,4576092 5395708.5,4576152 5395768.5,4576142 5395778.5,4576132
5395768.5,4576122 5395768.5,4576092 5395798.5,4576082 5395788.5,4576062
5395788.5,4576052 5395798.5,4576052 5395818.5,4576042 5395828.5,4576042
5395838.5,4576022 5395858.5,4576022 5395868.5,4576032 5395878.5,4576032
5395908.5,4576022 5395918.5,4576022 5395928.5,4576012 5395938.5,4576012
5395958.5,4576002 5395968.5,4576002 5395998.5,4575992 5396008.5,4575992
5396018.5,4575972 5396038.5,4575972 5396048.5,4575952 5396068.5,4575952
5396078.5,4575922 5396108.5,4575922 5396118.5,4575902 5396138.5,4575902
5396148.5,4575872 5396178.5,4575852 5396158.5,4575852 5396148.5,4575842
5396138.5,4575842 5396128.5,4575822 5396108.5,4575822 5396128.5,4575812
5396138.5,4575792 5396138.5,4575792 5396148.5,4575802 5396158.5,4575812
5396158.5,4575832 5396178.5,4575842 5396168.5,4575872 5396198.5,4575872
5396208.5,4575862 5396218.5,4575882 5396238.5,4575902 5396238.5,4575912
5396248.5,4575912 5396258.5,4575882 5396288.5,4575882 5396298.5,4575872
5396308.5,4575862 5396308.5,4575852 5396318.5,4575852 5396328.5,4575832
5396348.5,4575812 5396328.5,4575802 5396328.5,4575782 5396308.5,4575812
5396278.5,4575822 5396278.5,4575802 5396258.5,4575802 5396238.5,4575752
5396238.5,4575742 5396248.5,4575732 5396238.5,4575692 5396238.5,4575682
5396248.5,4575662 5396248.5,4575662 5396258.5,4575642 5396278.5,4575632
5396278.5,4575642 5396288.5,4575642 5396308.5,4575632 5396318.5,4575622
5396318.5,4575622 5396348.5,4575612 5396358.5,4575602 5396358.5,4575592
5396348.5,4575582 5396348.5,4575572 5396338.5,4575592 5396318.5,4575602
5396318.5,4575592 5396308.5,4575592 5396298.5,4575582 5396288.5,4575582
5396298.5,4575572 5396308.5,4575562 5396308.5,4575562 5396318.5,4575552
5396328.5,4575552 5396338.5,4575542 5396348.5,4575532 5396348.5,4575512
5396368.5,4575512 5396378.5,4575522 5396388.5,4575502 5396408.5,4575492
5396408.5,4575482 5396418.5,4575482 5396428.5,4575442 5396468.5,4575452
5396478.5,4575452 5396468.5,4575502 5396418.5,4575512 5396418.5,4575522
5396408.5,4575542 5396408.5,4575552 5396398.5,4575572 5396398.5,4575582
5396408.5,4575662 5396408.5,4575672 5396418.5,4575682 5396418.5,4575692
5396428.5,4575712 5396428.5,4575742 5396458.5,4575742 5396488.5,4575752
5396478.5,4575762 5396488.5,4575762 5396498.5,4575752 5396508.5,4575742
5396498.5,4575742 5396488.5,4575712 5396518.5,4575712 5396528.5,4575702
5396538.5,4575692 5396528.5,4575692 5396548.5,4575672 5396568.5,4575662
5396558.5,4575662 5396548.5,4575672 5396538.5,4575672 5396518.5,4575692
5396498.5,4575692 5396488.5,4575662 5396488.5,4575662 5396518.5,4575652
5396528.5,4575652 5396538.5,4575642 5396548.5,4575632 5396548.5,4575612
5396568.5,4575602 5396568.5,4575602 5396588.5,4575592 5396598.5,4575602
5396608.5,4575602 5396618.5,4575612 5396618.5,4575622 5396628.5,4575632
5396618.5,4575632 5396608.5,4575642 5396598.5,4575662 5396598.5,4575672
5396608.5,4575672 5396598.5,4575682 5396588.5,4575692 5396588.5,4575702
5396598.5,4575742 5396598.5,4575742 5396588.5,4575762 5396568.5,4575762
5396548.5,4575752 5396558.5,4575742 5396558.5,4575722 5396538.5,4575722
5396528.5,4575732 5396518.5,4575742 5396528.5,4575762 5396528.5,4575772
5396538.5,4575782 5396538.5,4575792 5396528.5,4575792 5396498.5,4575782
5396488.5,4575802 5396468.5,4575832 5396468.5,4575842 5396478.5,4575852
5396478.5,4575862 5396488.5,4575872 5396488.5,4575883 5396499,4575882
5396508.5,4575872 5396518.5,4575832 5396518.5,4575822 5396528.5,4575812
5396528.5,4575812 5396548.5,4575802 5396558.5,4575822 5396578.5,4575822
5396588.5,4575832 5396588.5,4575832 5396568.5,4575842 5396558.5,4575852
5396558.5,4575862 5396568.5,4575862 5396548.5,4575872 5396538.5,4575892
5396538.5,4575892 5396518.5,4575902 5396508.5,4575902 5396478.5,4575912
5396468.5,4575922 5396468.5,4575932 5396478.5,4575932 5396498.5,4575952
5396498.5,4575962 5396508.5,4575942 5396528.5,4575952 5396538.5,4575962
5396528.5,4575972 5396538.5,4575962 5396548.5,4575952 5396538.5,4575932
5396558.5,4575922 5396548.5,4575912 5396558.5,4575902 5396558.5,4575892
5396568.5,4575892 5396618.5,4575882 5396628.5,4575872 5396628.5,4575852
5396608.5,4575842 5396608.5,4575842 5396618.5,4575852 5396628.5,4575852
5396638.5,4575862 5396648.5,4575892 5396648.5,4575902 5396658.5,4575902
5396668.5,4575892 5396678.5,4575882 5396668.5,4575872 5396668.5,4575852
5396688.5,4575862 5396698.5,4575862 5396708.5,4575852 5396718.5,4575862
5396728.5,4575872 5396718.5,4575882 5396728.5,4575892 5396718.5,4575902
5396718.5,4575912 5396708.5,4575922 5396718.5,4575902 5396738.5,4575892
5396738.5,4575902 5396748.5,4575892 5396758.5,4575882 5396758.5,4575892
5396768.5,4575882 5396778.5,4575872 5396768.5,4575862 5396768.5,4575872
5396778.5,4575872 5396798.5,4575862 5396808.5,4575852 5396798.5,4575842
5396798.5,4575832 5396808.5,4575842 5396818.5,4575842 5396838.5,4575852
5396838.5,4575862 5396848.5,4575862 5396858.5,4575892 5396888.5,4575892
5396898.5,4575902 5396908.5,4575902 5396948.5,4575892 5396958.5,4575872
5396958.5,4575862 5396948.5,4575862 5396938.5,4575842 5396918.5,4575842
5396928.5,4575852 5396938.5,4575852 5396948.5,4575842 5396958.5,4575832
5396958.5,4575822 5396948.5,4575822 5396938.5,4575812 5396928.5,4575812
5396918.5,4575802 5396928.5,4575792 5396918.5,4575792 5396908.5,4575782
5396898.5,4575792 5396888.5,4575802 5396888.5,4575822 5396868.5,4575832
5396868.5,4575832 5396848.5,4575822 5396838.5,4575802 5396838.5,4575792
5396848.5,4575782 5396848.5,4575792 5396858.5,4575782 5396868.5,4575772
5396858.5,4575762 5396868.5,4575772 5396878.5,4575772 5396888.5,4575762
5396898.5,4575742 5396898.5,4575732 5396888.5,4575722 5396898.5,4575712
5396898.5,4575712 5396908.5,4575722 5396918.5,4575722 5396928.5,4575732
5396918.5,4575742 5396928.5,4575722 5396948.5,4575712 5396948.5,4575692
5396928.5,4575692 5396948.5,4575682 5396958.5,4575672 5396958.5,4575662
5396968.5,4575652 5396968.5,4575642 5396958.5,4575642 5396948.5,4575632
5396938.5,4575622 5396938.5,4575612 5396948.5,4575602 5396938.5,4575592
5396938.5,4575582 5396928.5,4575572 5396928.5,4575562 5396918.5,4575552
5396918.5,4575522 5396888.5,4575512 5396898.5,4575502 5396898.5,4575492
5396888.5,4575492 5396878.5,4575482 5396888.5,4575472 5396888.5,4575462
5396878.5,4575442 5396878.5,4575432 5396868.5,4575432 5396838.5,4575422
5396848.5,4575392 5396848.5,4575392 5396858.5,4575382 5396868.5,4575372
5396858.5,4575362 5396858.5,4575352 5396848.5,4575352 5396818.5,4575362
5396808.5,4575362 5396798.5,4575372 5396788.5,4575372 5396768.5,4575362
5396778.5,4575322 5396778.5,4575312 5396768.5,4575302 5396778.5,4575292
5396778.5,4575292 5396798.5,4575272 5396818.5,4575262 5396818.5,4575252
5396828.5,4575252 5396838.5,4575262 5396848.5,4575252 5396858.5,4575222
5396858.5,4575222 5396868.5,4575212 5396878.5,4575212 5396898.5,4575202
5396908.5,4575202 5396918.5,4575182 5396938.5,4575182 5396948.5,4575162
5396968.5,4575162 5396988.5,4575152 5396998.5,4575152 5397008.5,4575122
5397038.5,4575122 5397058.5,4575112 5397068.5,4575112 5397078.5,4575102
5397088.5,4575102 5397118.5,4575092 5397128.5,4575092 5397148.5,4575072
5397168.5,4575072 5397228.5,4575062 5397238.5,4575062 5397248.5,4575052
5397258.5,4575052 5397268.5,4575042 5397278.5,4575042 5397298.5,4575032
5397308.5,4575032 5397328.5,4575022 5397338.5,4575012 5397338.5,4575002
5397348.5,4575002 5397368.5,4575012 5397368.5,4575022 5397378.5,4575022
5397438.5,4575012 5397448.5,4575012 5397488.5,4575002 5397498.5,4575002
5397558.5,4574992 5397568.5,4574992 5397638.5,4574982 5397648.5,4574982
5397718.5,4574972 5397728.5,4574972 5397838.5,4574962 5397848.5,4574962
5397868.5,4574942 5397888.5,4574942 5397898.5,4574952 5397898.5,4574972
5397918.5,4574972 5397958.5,4574962 5397968.5,4574962 5398048.5,4574952
5398058.5,4574952 5398168.5,4574955.5 5398190.5,4574930.5
5398193,4574916 5398207.5,4574894 5398239,4574889.5 5398259.5,4574892
5398278.5,4574881.5 5398353.5,4574839 5398417.5,4574831
5398439,4574816.5 5398459.5,4574804 5398473,4574792.5 5398479,4574759
5398565.5,4574740 5398601.5,4574723 5398620,4574722 5398633,4574674
5398728,4574658.5 5398729.5,4574638 5398771,4574620.5 5398796,4574608
5398846,4574597.5 5398855,4574595.5 5398866.5,4574574.5
5398872.5,4574523 5398899,4574499.5 5398907.5,4574441
5398909.5,4574406.5 5398922.5,4574321 5398945.5,4574282
5398963.5,4574260 5398967,4574212 5398955,4574209.5 5398953,4574199.5
5398953,4574189.5 5398943,4574179.5 5398943,4574169.5 5398933,4574149.5
5398933,4574149.5 5398943,4574189.5 5398983,4574189.5 5398993,4574179.5
5399003,4574179.5 5399013,4574169.5 5399023,4574159.5 5399023,4574159.5
5399033,4574149.5 5399043,4574139.5 5399043,4574109.5 5399073,4574099.5
5399073,4574069.5 5399103,4574059.5 5399103,4574039.5 5399123,4574029.5
5399123,4573989.5 5399163,4573979.5 5399163,4573959.5 5399183,4573949.5
5399183,4573919.5 5399213,4573909.5 5399213,4573899.5 5399223,4573889.5
5399223,4573879.5 5399233,4573869.5 5399223,4573839.5 5399223,4573839.5
5399233,4573849.5 5399243,4573849.5 5399263,4573819.5 5399293,4573809.5
5399293,4573789.5 5399313,4573779.5 5399313,4573789.5 5399323,4573779.5
5399333,4573769.5 5399333,4573759.5 5399343,4573749.5 5399343,4573739.5
5399333,4573729.5 5399343,4573709.5 5399343,4573699.5 5399353,4573689.5
5399353,4573669.5 5399373,4573609.5 5399373,4573599.5 5399383,4573599.5
5399393,4573589.5 5399403,4573579.5 5399403,4573569.5 5399393,4573549.5
5399393,4573539.5 5399383,4573519.5 5399383,4573519.5 5399393,4573509.5
5399403,4573499.5 5399403,4573479.5 5399383,4573439.5 5399383,4573409.5
5399413,4573229.5 5399413,4573219.5 5399423,4573189.5 5399423,4573179.5
5399433,4573149.5 5399433,4573139.5 5399423,4573009.5 5399423,4572999.5
5399413,4572919.5 5399413,4572914 5399420,4572904 5399420,4572894
5399430,4572814 5399430,4572804 5399440,4572784 5399440,4572754
5399470,4572734 5399470,4572704 5399500,4572694 5399500,4572674
5399520,4572654 5399520,4572664 5399530,4572664 5399560,4572704
5399560,4572714 5399550,4572724 5399550,4572734 5399540,4572744
5399540,4572734 5399530,4572734 5399520,4572744 5399510,4572774
5399510,4572784 5399520,4572774 5399530,4572784 5399530,4572794
5399520,4572874 5399520,4572884 5399510,4572894 5399520,4572904
5399510,4572934 5399510,4572944 5399500,4572954 5399500,4572964
5399510,4572974 5399510,4572984 5399520,4572994 5399520,4572999.5
5399513,4573019.5 5399513,4573029.5 5399503,4573079.5 5399503,4573089.5
5399513,4573099.5 5399513,4573119.5 5399533,4573119.5 5399543,4573109.5
5399553,4573109.5 5399563,4573129.5 5399563,4573129.5 5399553,4573139.5
5399543,4573149.5 5399543,4573159.5 5399533,4573169.5 5399533,4573179.5
5399523,4573219.5 5399523,4573229.5 5399513,4573329.5 5399513,4573339.5
5399503,4573539.5 5399503,4573549.5 5399493,4573559.5 5399493,4573569.5
5399483,4573629.5 5399483,4573639.5 5399473,4573649.5 5399483,4573679.5
5399483,4573689.5 5399493,4573719.5 5399493,4573719.5 5399483,4573729.5
5399473,4573739.5 5399473,4573749.5 5399463,4573769.5 5399463,4573799.5
5399433,4573809.5 5399433,4573809.5 5399423,4573839.5 5399393,4573849.5
5399393,4573859.5 5399383,4573869.5 5399383,4573879.5 5399373,4573889.5
5399373,4573899.5 5399363,4573909.5 5399363,4573909.5 5399353,4573899.5
5399343,4573899.5 5399323,4573909.5 5399313,4573919.5 5399323,4573939.5
5399323,4573979.5 5399283,4573989.5 5399283,4573999.5 5399273,4574019.5
5399273,4574029.5 5399263,4574049.5 5399263,4574059.5 5399253,4574059.5
5399243,4574069.5 5399233,4574089.5 5399233,4574089.5 5399223,4574099.5
5399213,4574099.5 5399203,4574109.5 5399193,4574119.5 5399203,4574159.5
5399163,4574169.5 5399163,4574219.5 5399113,4574219.5 5399103,4574249.5
5399073,4574249.5 5399063,4574259.5 5399053,4574269.5 5399053,4574289.5
5399073,4574309.5 5399053,4574319.5 5399053,4574329.5 5399043,4574349.5
5399043,4574359.5 5399033,4574369.5 5399033,4574379.5 5399023,4574389.5
5399023,4574399.5 5399013,4574409.5 5399013,4574419.5 5399003,4574439.5
5399003,4574449.5 5398993,4574469.5 5398993,4574469.5 5398973,4574499.5
5398943,4574509.5 5398953,4574509.5 5398973,4574599.5 5398973,4574619.5
5398993,4574619.5 5399003,4574609.5 5399013,4574599.5 5399013,4574599.5
5399023,4574549.5 5399073,4574539.5 5399073,4574519.5 5399093,4574509.5
5399093,4574499.5 5399103,4574489.5 5399103,4574469.5 5399123,4574449.5
5399123,4574429.5 5399143,4574379.5 5399143,4574369.5 5399153,4574359.5
5399153,4574349.5 5399163,4574329.5 5399163,4574319.5 5399173,4574309.5
5399173,4574299.5 5399183,4574289.5 5399183,4574279.5 5399193,4574269.5
5399183,4574259.5 5399183,4574239.5 5399203,4574219.5 5399203,4574209.5
5399213,4574199.5 5399213,4574179.5 5399233,4574159.5 5399233,4574149.5
5399243,4574139.5 5399243,4574129.5 5399253,4574119.5 5399253,4574109.5
5399263,4574099.5 5399263,4574089.5 5399273,4574079.5 5399273,4574069.5
5399283,4574069.5 5399293,4574049.5 5399313,4574029.5 5399313,4574009.5
5399333,4573999.5 5399323,4573989.5 5399323,4573969.5 5399343,4573969.5
5399353,4573939.5 5399383,4573919.5 5399383,4573909.5 5399393,4573909.5
5399403,4573869.5 5399443,4573859.5 5399443,4573839.5 5399463,4573839.5
5399473,4573829.5 5399483,4573819.5 5399483,4573809.5 5399493,4573799.5
5399493,4573769.5 5399523,4573769.5 5399533,4573739.5 5399563,4573739.5
5399573,4573729.5 5399583,4573719.5 5399583,4573719.5 5399593,4573709.5
5399603,4573709.5 5399613,4573679.5 5399643,4573679.5 5399663,4573639.5
5399703,4573639.5 5399713,4573619.5 5399733,4573619.5 5399743,4573609.5
5399753,4573609.5 5399763,4573599.5 5399773,4573599.5 5399783,4573569.5
5399813,4573569.5 5399823,4573549.5 5399843,4573549.5 5399853,4573489.5
5399913,4573489.5 5399923,4573479.5 5399933,4573469.5 5399933,4573469.5
5399943,4573439.5 5399973,4573429.5 5399973,4573429.5 5399983,4573424
5399990,4573414 5399990,4573394 5400010,4573394 5400020,4573344
5400070,4573344 5400080,4573334 5400090,4573334 5400100,4573324
5400110,4573324 5400120,4573314 5400130,4573314 5400140,4573294
5400160,4573294 5400180,4573274 5400200,4573274 5400210,4573244
5400240,4573244 5400260,4573234 5400270,4573234 5400290,4573224
5400300,4573224 5400320,4573214 5400330,4573214 5400340,4573194
5400360,4573194 5400370,4573184 5400380,4573184 5400390,4573164
5400410,4573164 5400420,4573144 5400440,4573144 5400450,4573114
5400480,4573114 5400490,4573104 5400500,4573094 5400510,4573084
5400510,4573084 5400520,4573034 5400570,4573034 5400580,4572994
5400620,4572984 5400620,4572974 5400610,4572964 5400610,4572614
5402050,4572614 5402040,4572594 5402030,4572584 5402020,4572574
5402020,4572564 5402000,4572554 5402000,4572544 5401990,4572494
5401970,4572474 5401970,4572444 5401950,4572434 5401940,4572414
5401930,4572404 5401920,4572494 5402050,4572464 5402040,4572404
5402040,4572184 5402160,4572056.727 5402141.818,4572024 5402150,4572009
5402135,4571904 5402120,4571924 5402110,4571924 5402100,4572004
5402130,4572009 5402135,4572056.727 5402141.818,4572064 5402140,4572184
5402160,4571977.829 5401970.432,4571836.698 5401939.281,4571654.393
5401921.131,4571465.504 5401897.582,4571321.206 5401856.119,4571234.363
5401821.73,4571084.45 5401773.725,4571061.53 5401738.561,4571032.985
5401659.457,4571003.147 5401661.364,4570893.923 5401619.481,4570818.294
5401595.143,4570749.534 5401527.801,4570722.508 5401509.883,4570697.721
5401497.639,4570647.849 5401477.855,4570544.038 5401408.347,4570406.7
5401367.444,4570197.288 5401342.574,4570001.999 5401396.699,4569740.381
5401367.062,4569685.358 5401330.405,4569642.728 5401190.272,4569550.6
5401085.975,4569497.071 5401001.208,4569520.638 5400887.166,4569520.737
5400775.771,4569427.787 5400707.832,4569347.271 5400653.122,4569288.49
5400616.553,4569136.794 5400586.214,4568999.998 5400704.59,4568877.829
5400846.262,4568791.626 5400943.527,4568612.778 5401080.586,4568637.533
5401071.504,4568453.91 5401335.186,4568259.317 5401596.861,4567984.077
5401808.381,4567562.685 5402122.866,4567377.783 5402257.228,4566768.225
5402717.633,4566717.68 5402766.388,4566503.816 5402962.319,4566343.568
5403106.542,4566168.873 5403266.902,4566000.267 5403417.793,4565638.536
5403757.03,4565499.184 5403885.594,4565189.166 5404209.171,4565142.847
5404261.446,4565105.561 5404300.551,4564802.106 5404611.024,4564498.467
5404925.443,4564325.676 5405012.26,4564122.668 5405032.448,4563969.594
5405065.187,4563873.139 5405065.265,4563856.65 5405105.038,4563947.396
5405162.601,4564107.556 5405177.838,4564282.615 5405231.676,4564475.959
5405327.501,4564807.115 5405464.975,4565112.876 5405688.116,4565310.96
5405871.979,4565540.935 5406066.493,4565807.245 5406301.836,4565856.79
5406338.996,4565989.945 5406422.604,4566089.037 5406518.6,4566181.936
5406592.918,4566268.641 5406636.271,4566373.926 5406716.783,4566522.564
5406846.841,4566623.602 5406846.05,4566669.784 5406855.757,4566681.137
5406859.356,4566692.675 5406864.802,4566705.229 5406873.386,4566721.17
5406893.727,4566731.111 5406903.669,4566753.099 5406946.496,4566777.189
5407000.985,4566792.484 5407019.912,4566820.206 5407036.546,4566924.023
5407073.064,4566940.848 5407080.902,4566959.393 5407086.255,4566994.19
5407099.065,4567089.211 5407142.466,4567143.7 5407172.1,4567200.101
5407206.132,4567217.698 5407219.119,4567232.222 5407226.589,4567267.592
5407249.914,4567297.8 5407276.299,4567384.027 5407344.745,4567478.092
5407426.574,4567541.185 5407490.814,4567613.073 5407574.364,4567667.18
5407644.532,4567757.039 5407763.261,4567811.5 5407841,4567919
5407982.5,4567978 5407953.5,4568028.5 5407941.5,4568074
5407937,4568134.5 5407938,4568152 5407952,4568149 5407964.5,4568124.5
5407966.5,4568063 5407968.5,4568012.5 5407980,4567963 5408000,4567946
5408014,4568024.5 5408114.5,4568075.5 5408174,4568210.5
5408339.5,4568331 5408473.5,4568805 5408971.5,4568987.5
5409188.5,4569106 5409343.5,4569210 5409494,4569362 5409753,4569491.5
5409991,4569673.188 5410355.366,4569629.077 5410371.908,4569551.5
5410238,4569317 5409774,4569195 5409574,4568930 5409200.5,4568776.5
5409018.5,4568703 5408940,4568322 5408545.5,4568125 5408323,4568096
5408289,4568064.5 5408248.5,4568038 5408269.5,4568003
5408293.5,4567952.5 5408312,4567889.5 5408341,4567852.5
5408370.5,4567813.5 5408419,4567755.5 5408454,4567544.137
5408529.123,4567640.334 5408669.958,4568277 5409280.5,4568662
5409652,4568865.5 5409834.5,4568964.5 5409938.5,4569022 5409994,4569058
5410045,4569135 5410147.5,4569216 5410275.5,4569336.008
5410497.066,4569304.914 5410507.805,4569260.5 5410407,4569250.5
5410397,4569250.5 5410387,4569240.5 5410377,4569240.5 5410367,4569230.5
5410357,4569230.5 5410347,4569220.5 5410337,4569220.5 5410327,4569200.5
5410307,4569200.5 5410297,4569190.5 5410287,4569190.5 5410277,4569180.5
5410267,4569190.5 5410257,4569180.5 5410247,4569180.5 5410237,4569170.5
5410227,4569170.5 5410217,4569160.5 5410207,4569150.5 5410207,4569140.5
5410197,4569140.5 5410187,4569120.5 5410167,4569120.5 5410157,4569100.5
5410137,4569100.5 5410127,4569080.5 5410107,4569080.5 5410097,4569060.5
5410077,4569060.5 5410057,4569040.5 5410037,4569040.5 5410027,4569020.5
5410007,4569020.5 5409997,4569010.5 5410007,4568950.5 5409947,4568950.5
5409957,4568940.5 5409967,4568930.5 5409957,4568920.5 5409957,4568870.5
5409907,4568870.5 5409897,4568860.5 5409897,4568670.5 5409707,4568660.5
5409707,4568650.5 5409697,4568650.5 5409687,4568660.5 5409677,4568670.5
5409677,4568660.5 5409667,4568650.5 5409667,4568620.5 5409637,4568610.5
5409637,4568600.5 5409647,4568420.5 5409467,4568410.5 5409467,4568320.5
5409377,4568330.5 5409367,4568310.5 5409367,4567640.5 5408697,4567630.5
5408707,4567620.5 5408697,4567630.5 5408687,4567563.306
5408619.806,4567543.638 5408607,4567540.5 5408607,4567534.645
5408601.146,4567528.279 5408597,4567520.5 5408597,4567510.5
5408587,4567500.5 5408587,4567490 5408581.5,4567448.664
5408545.164,4567104.739 5408321.239,4567110.5 5408327,4567110.5
5408337,4567120.5 5408347,4567120.5 5408357,4567140.5 5408377,4567140.5
5408387,4567190.5 5408387,4567200.5 5408397,4567220.5 5408397,4567230.5
5408407,4567230.5 5408417,4567220.5 5408427,4567220.5 5408437,4567210.5
5408447,4567200.5 5408447,4567200.5 5408467,4567202 5408478,4567197
5408494,4567184 5408510,4567161 5408526.5,4567115.5 5408553,4567074.5
5408580,4567067 5408591,4567071 5408602.5,4567104.5 5408657,4567111
5408677.5,4567106.5 5408689,4567090.5 5408697,4567080.5
5408697,4567060.5 5408717,4567050.5 5408717,4567040.5 5408727,4567020.5
5408727,4567010.5 5408737,4567000.5 5408737,4566970.5 5408767,4566950.5
5408767,4566950.5 5408777,4566940.5 5408787,4566930.5 5408787,4566920.5
5408797,4566910.5 5408797,4566890.5 5408817,4566880.5 5408817,4566870.5
5408827,4566860.5 5408827,4566850.5 5408837,4566870.5 5408857,4566860.5
5408867,4566870.5 5408877,4566880.5 5408877,4566890.5 5408887,4566880.5
5408897,4566900.5 5408917,4566910.5 5408917,4566950.5 5408957,4566966.5
5408968.5,4566985.5 5408978.5,4566999.5 5408990.5,4567010.5
5409007,4567010.5 5409017,4567000.5 5409027,4566990.5 5409027,4566950.5
5408987,4566930.5 5409007,4566930.5 5409037,4566940.5 5409047,4566940.5
5409057,4566930.5 5409067,4566910.5 5409067,4566900.5 5409077,4566860.5
5409077,4566850.5 5409087,4566840.5 5409087,4566830.5 5409097,4566820.5
5409097,4566820.5 5409117,4566830.5 5409127,4566830.5 5409137,4566840.5
5409147,4566840.5 5409167,4566830.5 5409177,4566830.5 5409197,4566840.5
5409207,4566840.5 5409217,4566860.5 5409237,4566860.5 5409247,4566900.5
5409287,4566900.5 5409337,4566890.5 5409347,4566760.5 5409347,4566750.5
5409357,4566740.5 5409347,4566730.5 5409347,4566720.5 5409337,4566720.5
5409327,4566690.5 5409297,4566670.5 5409317,4566660.5 5409307,4566650.5
5409307,4566640.5 5409297,4566640.5 5409287,4566650.5 5409277,4566660.5
5409277,4566650.5 5409267,4566640.5 5409267,4566630.5 5409257,4566620.5
5409257,4566610.5 5409247,4566600.5 5409247,4566590.5 5409257,4566590.5
5409307,4566580.5 5409317,4566580.5 5409367,4566560.5 5409387,4566560.5
5409427,4566540.5 5409447,4566540.5 5409457,4566550.5 5409447,4566570.5
5409447,4566580.5 5409437,4566600.5 5409437,4566610.5 5409427,4566640.5
5409427,4566650.5 5409437,4566650.5 5409447,4566640.5 5409457,4566640.5
5409477,4566630.5 5409487,4566610.5 5409487,4566590.5 5409507,4566610.5
5409527,4566620.5 5409527,4566630.5 5409517,4566650.5 5409517,4566670.5
5409497,4566730.5 5409497,4566740.5 5409487,4566760.5 5409487,4566770.5
5409477,4566780.5 5409477,4566800.5 5409497,4566820.5 5409497,4566830.5
5409487,4566820.5 5409477,4566820.5 5409467,4566830.5 5409457,4566850.5
5409457,4566860.5 5409447,4566880.5 5409467,4566880.5 5409477,4566900.5
5409457,4566910.5 5409467,4566910.5 5409477,4566930.5 5409497,4566930.5
5409527,4566970.5 5409567,4566980.5 5409567,4566990.5 5409577,4566990.5
5409587,4566980.5 5409597,4566980.5 5409617,4566990.5 5409617,4567010.5
5409637,4567020.5 5409637,4567030.5 5409647,4567050.5 5409647,4567060.5
5409657,4567060.5 5409677,4567080.5 5409697,4567070.5 5409707,4567070.5
5409717,4567050.5 5409737,4567060.5 5409737,4567070.5 5409747,4567170.5
5409747,4567180.5 5409737,4567210.5 5409737,4567220.5 5409747,4567250.5
5409747,4567270.5 5409767,4567280.5 5409757,4567290.5 5409757,4567300.5
5409767,4567320.5 5409767,4567330.5 5409777,4567320.5 5409787,4567270.5
5409787,4567290.5 5409807,4567290.5 5409817,4567320.5 5409817,4567330.5
5409827,4567340.5 5409827,4567340.5 5409807,4567350.5 5409797,4567370.5
5409817,4567370.5 5409837,4567400.5 5409837,4567410.5 5409847,4567430.5
5409847,4567450.5 5409867,4567450.5 5409877,4567460.5 5409887,4567470.5
5409887,4567510.5 5409927,4567520.5 5409927,4567530.5 5409937,4567530.5
5409947,4567520.5 5409957,4567490.5 5409957,4567480.5 5409967,4567480.5
5410027,4567440.5 5410067,4567430.5 5410067,4567420.5 5410077,4567410.5
5410077,4567390.5 5410097,4567380.5 5410097,4567370.5 5410107,4567370.5
5410117,4567310.5 5410177,4567300.5 5410177,4567300.5 5410187,4567290.5
5410197,4567290.5 5410207,4567250.5 5410247,4567230.5 5410247,4567220.5
5410257,4567200.5 5410257,4567190.5 5410267,4567180.5 5410267,4567180.5
5410277,4567140.5 5410317,4567090.5 5410317,4567080.5 5410327,4567060.5
5410327,4567050.5 5410337,4567010.5 5410337,4567000.5 5410347,4566918
5410366,4566888 5410336,4566888 5410316,4566878 5410306,4566878
5410296,4566868 5410286,4566868 5410276,4566848 5410256,4566848
5410236,4566838 5410246,4566828 5410236,4566828 5410226,4566818
5410216,4566818 5410176,4566828 5410166,4566768 5410166,4566718
5410116,4566678 5410116,4566668 5410106,4566648 5410106,4566638
5410116,4566588 5410116,4566578 5410106,4566558 5410106,4566548
5410096,4566488 5410096,4566468 5410076,4566458 5410086,4566448
5410086,4566438 5410076,4566418 5410096,4566408 5410086,4566398
5410096,4566388 5410096,4566378 5410086,4566378 5410076,4566368
5410066,4566359.5 5410062,4566359.5 5410052,4566339.5 5410032,4566349.5
5410022,4566349.5 5410012,4566379.5 5409982,4566379.5 5409972,4566389.5
5409962,4566398 5409956,4566389.5 5409952,4566389.5 5409942,4566399.5
5409932,4566408 5409936,4566428 5409916,4566428 5409906,4566458
5409876,4566458 5409866,4566478 5409846,4566488 5409846,4566498
5409836,4566488 5409826,4566488 5409816,4566478 5409806,4566498
5409786,4566488 5409776,4566488 5409766,4566468 5409746,4566459.5
5409742,4566399.5 5409742,4566389.5 5409732,4566379.5 5409732,4566379.5
5409802,4566359.5 5409822,4566349.5 5409822,4566339.5 5409812,4566339.5
5409832,4566319.5 5409852,4566309.5 5409852,4566299.5 5409862,4566289.5
5409852,4566279.5 5409852,4566269.5 5409862,4566249.5 5409862,4566239.5
5409872,4566209.5 5409872,4566209.5 5409882,4566239.5 5409912,4566259.5
5409912,4566269.5 5409902,4566279.5 5409912,4566289.5 5409912,4566299.5
5409922,4566289.5 5409932,4566249.5 5409932,4566259.5 5409942,4566239.5
5409962,4566239.5 5409972,4566229.5 5409982,4566219.5 5409992,4566209.5
5409992,4566219.5 5410002,4566209.5 5410012,4566209.5 5410022,4566199.5
5410032,4566199.5 5410052,4566179.5 5410072,4566169.5 5410072,4566159.5
5410082,4566139.5 5410082,4566109.5 5410112,4566109.5 5410122,4566069.5
5410162,4566069.5 5410172,4566049.5 5410192,4566019.5 5410192,4566019.5
5410202,4565989.5 5410232,4565959.5 5410232,4565959.5 5410252,4565949.5
5410262,4565929.5 5410262,4565919.5 5410272,4565909.5 5410262,4565909.5
5410282,4565889.5 5410302,4565879.5 5410292,4565859.5 5410292,4565849.5
5410302,4565809.5 5410302,4565799.5 5410312,4565759.5 5410312,4565762.5
5410269.5,4565801 5410239,4565822 5410266.5,4565843 5410260,4565889
5410232,4565866 5410205.5,4565837.5 5410201.5,4565836.5
5410154,4565826.5 5410071,4565808.5 5410045.5,4565818.5
5410021.5,4565795.5 5409978.5,4565443.5 5409906.5,4565443.5
5409793,4565206.5 5409793,4565199 5409831.5,4565089.5 5409838.5,4565071
5410129.5,4565030 5410297.5,4564941.5 5410291.5,4564882.5
5410360.5,4564833.5 5410377,4564759.5 5410374.5,4564707
5410398.5,4564569.5 5410387,4564558 5410387,4564548 5410397,4564519.5
5410397,4564509.5 5410387,4564368 5410387,4564358 5410397,4564218
5410397,4564208 5410407,4564199.5 5410407,4564189.5 5410397,4564128
5410397,4564118 5410407,4564108 5410407,4564098 5410417,4564089.5
5410417,4564079.5 5410407,4564069.5 5410407,4564058.5 5410396.5,4564048
5410407,4564038 5410407,4564028 5410417,4563959.5 5410417,4563949.5
5410407,4563928 5410407,4563918.5 5410416.5,4563899.5 5410397,4563888
5410397,4563878 5410407,4563850.5 5410407,4563848.5 5410409.5,4563835.5
5410412,4563779.5 5410412,4563769.5 5410422,4563699.5 5410422,4563689.5
5410432,4563679.5 5410432,4563659.5 5410412,4563659.5 5410392,4563649.5
5410382,4563639.5 5410382,4563629.5 5410372,4563619.5 5410382,4563599.5
5410382,4563589.5 5410372,4563579.5 5410372,4563569.5 5410362,4563569.5
5410352,4563559.5 5410342,4563559.5 5410312,4563549.5 5410312,4563549.5
5410342,4563539.5 5410352,4563529.5 5410352,4563519.5 5410342,4563519.5
5410332,4563529.5 5410322,4563529.5 5410302,4563539.5 5410292,4563549.5
5410292,4563549.5 5410282,4563569.5 5410262,4563569.5 5410232,4563579.5
5410222,4563579.5 5410192,4563569.5 5410182,4563569.5 5410152,4563549.5
5410132,4563549.5 5410122,4563539.5 5410112,4563539.5 5410102,4563529.5
5410092,4563529.5 5410082,4563509.5 5410062.5,4563486
5410011.5,4563519.5 5409988,4563519 5409984.5,4563478.5 5409967,4563430
5409927.5,4563372.5 5409877.5,4563333 5409834,4563291 5409776,4563248
5409733.5,4563210.5 5409709.5,4563181 5409706.5,4563158.5
5409708.5,4563157 5409712,4563195 5409751.5,4563215.5 5409778.5,4563284
5409881.5,4563322 5409944.5,4563366.5 5410027,4563377 5410070,4563424.5
5410149,4563446.5 5410191,4563448 5410219,4563447 5410245.5,4563434
5410262.5,4563410.5 5410280,4563360 5410272,4563327 5410259,4563202.5
5410201,4563171 5410204,4563089 5410187,4563027.5 5409969.5,4563025.5
5409968,4562970.5 5409969,4562941 5409980,4562911 5410011,4562884.5
5410015,4562883 5410017,4562878 5410125.5,4562880.5 5410126,4562878
5410128,4562878 5410125.5),(4570774 5402849.033,4570777.479
5402838.261,4570805.095 5402752.738,4570806.924 5402747.077,4570806.006
5402749.953,4570805.095 5402752.738,4570781.954 5402824.689,4570777.479
5402838.261,4570776.876 5402840.324,4570774 5402849.033),(4571285.765
5408495.315,4571292 5408436.5,4571292.137 5408438.425,4571285.765
5408495.315),(4570816.582 5402729.434,4570821.176 5402715.648,4570864
5402570.325,4570864 5402570,4570864.155 5402569.845,4570871.334
5402546.928,4570898.253 5402464.253,4570894 5402460,4570895.668
5402459.731,4570898.253 5402464.253,4570864.155 5402569.845,4570864
5402570.325,4570861.871 5402580.726,4570821.176 5402715.648,4570814
5402740,4570816.582 5402729.434),(4566665 5406634,4566678.974
5406622.743,4566684.521 5406614.764,4566719 5406590.5,4566678.974
5406622.743,4566663.5 5406645,4566665 5406634),(4571095.5
5408567.5,4571102.5 5408555.5,4571131 5408546.5,4571095.5
5408567.5),(4569842 5404392.5,4569941 5404483.5,4569925 5404471,4569884
5404433.5,4569842 5404392.5),(4569910 5404512,4569920 5404502,4569950
5404512,4569910 5404512),(4572524 5402090,4572534 5402100,4572564
5402140,4572584 5402160,4572574 5402160,4572564 5402150,4572524
5402090),(4569356.586 5410606.657,4569377.067 5410593.656,4569392.926
5410630.33,4569374.473 5410639.45,4569356.586 5410606.657),(4582632
5392963.5,4582632.5 5392959,4582639 5392953,4582641.5 5392948,4582644.5
5392946,4582654 5392945.5,4582667 5392947.5,4582670 5392949.5,4582672.5
5392953.5,4582671 5392965,4582667.5 5392967.5,4582662.5 5392976,4582660
5392978,4582649 5392979.5,4582642.5 5392977,4582639.5 5392982.5,4582638
5392982.5,4582632 5392963.5),(4571245 5408407,4571291.5
5408377.5,4571313.5 5408358,4571302.079 5408397.124,4571277
5408404.5,4571265.899 5408412.321,4571245 5408407),(4565687.028
5412191.47,4565759.5 5412112,4565816.352 5412111.154,4565728.067
5412202.931,4565687.028 5412191.47),(4581424.5 5392523,4581428
5392520,4581429.5 5392515,4581437 5392512.5,4581440.5 5392507,4581449
5392504.5,4581456 5392494.5,4581466 5392491,4581469 5392483.5,4581480.5
5392481.5,4581487.5 5392486,4581497 5392495,4581500.5 5392502,4581512
5392504.5,4581512.5 5392505.5,4581509.5 5392508,4581505.5
5392508.5,4581505.5 5392511,4581518.5 5392529,4581526 5392533,4581528.5
5392533.5,4581530 5392532.5,4581531 5392535,4581521.5
5392542.5,4581499.5 5392553.5,4581495 5392560,4581488.5
5392563,4581484.5 5392567.5,4581476 5392571.5,4581471.5
5392576.5,4581464.5 5392580,4581460 5392585,4581449.5
5392587.5,4581445.5 5392590.5,4581440.5 5392597,4581427
5392602.5,4581422 5392606,4581412 5392606.5,4581409.5 5392608,4581406.5
5392613,4581406 5392621,4581402.5 5392625,4581391 5392627.5,4581381.5
5392625.5,4581369.5 5392626.5,4581369.5 5392623.5,4581376
5392624,4581377.5 5392621.5,4581373 5392612.5,4581370 5392595,4581366.5
5392584.5,4581370.5 5392575,4581375.5 5392571,4581379 5392563,4581384.5
5392559.5,4581390 5392552.5,4581392 5392546,4581397.5 5392542,4581400.5
5392535.5,4581408 5392534,4581416.5 5392525.5,4581424.5
5392523),(4577954.347 5399138.644,4577989.539 5399107.073,4578109
5399299,4578166.5 5399425.5,4578230.5 5399602.5,4578194
5399607,4578153.5 5399476.5,4578107.5 5399375,4578043.5
5399267,4577954.347 5399138.644),(4581659.5 5392384.5,4581669
5392382,4581674.5 5392377.5,4581679 5392370.5,4581682 5392370,4581691.5
5392372.5,4581714 5392369,4581719.5 5392363.5,4581728 5392347,4581730.5
5392345.5,4581739 5392356.5,4581748.5 5392362.5,4581759.5
5392364.5,4581770 5392364.5,4581771 5392365.5,4581771 5392375,4581777.5
5392385,4581774.5 5392389.5,4581770 5392391,4581757 5392399.5,4581749
5392410,4581747 5392414.5,4581749.5 5392425,4581759.5 5392427.5,4581764
5392434.5,4581764.5 5392446.5,4581760.5 5392480.5,4581741.5
5392496,4581729 5392504.5,4581719.5 5392509,4581702 5392510.5,4581687.5
5392503.5,4581679.5 5392503.5,4581678.5 5392506,4581679.5
5392535,4581671.5 5392557.5,4581670.5 5392566,4581664 5392577,4581654
5392586,4581644.5 5392589.5,4581640 5392588.5,4581637.5
5392586.5,4581634 5392575,4581614 5392549.5,4581610.5 5392542,4581603.5
5392532.5,4581601.5 5392524.5,4581587.5 5392512,4581574.5
5392505,4581574 5392496.5,4581571 5392490,4581569.5 5392489.5,4581566.5
5392495.5,4581566.5 5392504,4581565.5 5392506,4581558 5392511.5,4581557
5392517,4581551.5 5392522.5,4581547 5392521,4581541.5 5392516,4581539.5
5392512.5,4581528.5 5392506,4581519.5 5392497,4581518.5 5392491,4581520
5392477.5,4581530.5 5392464.5,4581536.5 5392462,4581542.5
5392463,4581551 5392468,4581557.5 5392469,4581562 5392471.5,4581566
5392475.5,4581568.5 5392481,4581572.5 5392483.5,4581576.5
5392482,4581578.5 5392474.5,4581578 5392464.5,4581581.5
5392455.5,4581586.5 5392449,4581592 5392436,4581599 5392431.5,4581608.5
5392430,4581616.5 5392424.5,4581623.5 5392416,4581633.5
5392396.5,4581640.5 5392393.5,4581647 5392392.5,4581659.5
5392384.5),(4567896.5 5409901,4567906 5409838,4568032 5409879,4568218
5409947,4568571 5410026.5,4568767 5410036.5,4568767 5410089.5,4568668
5410085,4568479.5 5410051,4568109.5 5409951.5,4567896.5
5409901),(4577187 5397993.5,4577215 5397971,4577270.5
5398072.5,4577369.5 5398223,4577736 5398743,4577892.64
5398981.951,4577868.141 5399001.486,4577685 5398739.5,4577291
5398170,4577239 5398089,4577187 5397993.5),(4582437.5 5392938,4582440.5
5392930.5,4582453.5 5392930,4582461 5392931.5,4582480.5
5392939.5,4582490 5392945.5,4582504.5 5392949,4582506 5392951,4582502
5392960,4582497.5 5392964,4582494 5392965.5,4582485.5
5392965.5,4582475.5 5392977,4582472.5 5392985,4582472.5
5392991,4582478.5 5393003.5,4582481.5 5393004.5,4582488
5393002,4582496.5 5392996.5,4582509.5 5392998,4582520.5
5392997.5,4582525 5392989.5,4582526 5392985,4582536.5 5392979,4582533.5
5392971.5,4582536.5 5392968,4582539 5392959,4582535.5 5392950,4582535
5392944.5,4582531 5392931.5,4582532 5392924.5,4582535 5392922,4582540.5
5392921.5,4582550.5 5392910,4582551.5 5392899,4582549 5392895,4582546.5
5392896,4582540 5392892,4582532.5 5392890,4582519.5 5392878,4582507
5392860,4582508 5392850.5,4582513 5392838,4582517 5392834.5,4582521
5392833,4582523 5392830.5,4582530 5392810.5,4582539 5392803.5,4582550.5
5392792,4582565.5 5392760,4582569 5392754.5,4582580 5392742.5,4582584.5
5392734,4582594 5392726.5,4582600.5 5392718,4582606 5392715.5,4582609.5
5392711,4582631.5 5392704.5,4582647 5392696.5,4582654.5
5392690.5,4582656 5392685.5,4582661 5392684,4582666.5 5392674,4582672.5
5392671.5,4582688.5 5392675,4582696.5 5392675.5,4582698
5392674.5,4582706.5 5392656.5,4582711.5 5392655,4582718.5
5392648,4582721.5 5392649,4582735.5 5392661.5,4582741 5392664,4582748.5
5392659.5,4582759.5 5392648.5,4582780.5 5392636.5,4582789
5392629.5,4582807.5 5392621,4582809 5392618,4582812 5392618,4582818.5
5392613,4582822 5392612,4582832.5 5392613.5,4582833.5 5392611,4582825.5
5392580.5,4582826 5392579,4582831.5 5392575.5,4582834.5
5392570,4582839.5 5392566.5,4582857 5392570,4582862.5 5392572.5,4582874
5392595.5,4582874.5 5392599.5,4582872.5 5392603.5,4582879
5392607.5,4582883 5392613.5,4582883 5392616,4582879.5 5392619,4582878
5392618,4582871 5392607.5,4582867.5 5392605.5,4582859 5392608,4582852.5
5392613,4582851.5 5392615,4582853.5 5392626.5,4582863.5
5392633.5,4582861.5 5392636.5,4582854.5 5392640,4582854
5392644,4582856.5 5392658.5,4582856 5392663.5,4582850.5
5392680,4582830.5 5392720,4582826 5392725.5,4582820.5 5392740.5,4582801
5392742,4582786.5 5392759,4582775 5392764.5,4582771.5 5392770.5,4582763
5392775.5,4582754 5392792,4582730 5392799.5,4582721 5392809,4582712.5
5392811.5,4582708.5 5392821.5,4582702 5392826.5,4582689
5392828.5,4582681 5392832.5,4582661.5 5392830,4582651 5392832.5,4582641
5392832.5,4582623.5 5392826.5,4582618.5 5392826.5,4582602
5392837,4582590 5392839.5,4582584 5392842.5,4582580 5392842,4582576.5
5392843.5,4582555 5392857.5,4582552.5 5392862,4582538.5 5392869,4582538
5392870.5,4582541 5392879,4582551.5 5392889.5,4582570 5392895.5,4582579
5392896,4582582.5 5392898.5,4582583.5 5392904.5,4582591 5392917,4582592
5392921.5,4582588 5392927.5,4582585 5392937,4582573.5
5392949.5,4582561.5 5392959.5,4582560.5 5392963.5,4582555
5392964.5,4582554.5 5392970.5,4582550 5392975.5,4582546 5392977,4582552
5392990,4582559 5393000,4582559.5 5393002.5,4582555.5 5393015,4582540.5
5393020,4582531.5 5393019.5,4582521.5 5393010.5,4582519
5393019.5,4582513.5 5393029.5,4582498 5393045.5,4582492.5
5393062.5,4582483.5 5393083,4582476 5393085.5,4582474.5
5393090.5,4582467 5393096.5,4582464 5393102,4582454.5 5393106,4582459
5393120.5,4582460 5393130.5,4582457.5 5393136.5,4582454
5393141,4582454.5 5393144.5,4582452.5 5393149.5,4582460.5
5393169.5,4582473.5 5393180,4582466.5 5393186.5,4582459
5393190,4582447.5 5393191,4582439.5 5393189,4582435.5 5393194.5,4582433
5393207.5,4582435 5393213,4582440.5 5393219.5,4582452
5393226.5,4582454.5 5393231,4582449.5 5393236.5,4582433.5
5393246,4582427.5 5393264,4582424 5393270,4582426 5393276.5,4582418.5
5393277.5,4582409.5 5393271,4582401 5393268.5,4582396 5393270,4582394.5
5393272,4582391.5 5393272,4582389 5393270.5,4582382.5 5393259.5,4582383
5393231.5,4582386 5393218,4582383 5393207.5,4582383 5393200.5,4582386
5393187,4582385 5393168,4582388.5 5393158.5,4582388.5 5393148.5,4582395
5393136.5,4582395.5 5393133.5,4582394 5393114,4582396.5
5393091.5,4582397 5393074,4582399.5 5393067.5,4582409.5
5393060.5,4582408.5 5393049,4582417.5 5393040,4582418.5
5393032.5,4582417 5393027.5,4582417 5393020.5,4582420.5
5393017.5,4582423.5 5393019,4582425.5 5393021.5,4582426.5
5393029.5,4582440 5393036,4582444.5 5393034,4582449.5
5393029.5,4582453.5 5393020.5,4582451.5 5393014.5,4582446.5
5393009.5,4582438.5 5393005.5,4582435 5393005,4582430.5
5393012.5,4582429 5393011,4582428.5 5393005.5,4582430 5392992,4582432
5392990,4582439 5392988.5,4582441 5392981.5,4582440.5 5392969,4582447.5
5392958.5,4582440 5392946,4582437.5 5392938),(4565277 5412453,4565277
5412463,4565287 5412473,4565287 5412483,4565297 5412493,4565327
5412493,4565367 5412453,4565377 5412453,4565548.764
5412282.188,4565553.756 5412282.188,4565627.247 5412309.567,4565630.05
5412312.721,4565577 5412353,4565577 5412363,4565537 5412403,4565527
5412403,4565457 5412473,4565447 5412473,4565447 5412483,4565437
5412493,4565427 5412493,4565367 5412553,4565367 5412593,4565407
5412633,4565417 5412633,4565447 5412663,4565437 5412673,4565427
5412673,4565417 5412663,4565407 5412663,4565387 5412643,4565377
5412643,4565367 5412633,4565357 5412633,4565347 5412623,4565337
5412623,4565327 5412613,4565287 5412613,4565257 5412643,4565247
5412643,4565217 5412673,4565207 5412673,4565167 5412713,4565157
5412713,4565127 5412743,4565117 5412743,4565097 5412763,4565087
5412763,4565057 5412793,4565047 5412793,4565017 5412823,4565007
5412823,4564977 5412853,4564967 5412853,4564937 5412883,4564927
5412883,4564907 5412903,4564897 5412903,4564867 5412933,4564857
5412933,4564847 5412943,4564827 5412943,4564817 5412953,4564807
5412943,4564877 5412873,4564887 5412873,4564917 5412843,4564927
5412843,4564967 5412803,4564977 5412803,4565017 5412763,4565027
5412763,4565087 5412703,4565097 5412703,4565157 5412643,4565167
5412643,4565237 5412573,4565237 5412553,4565247 5412543,4565247
5412503,4565237 5412493,4565237 5412463,4565247 5412453,4565247
5412433,4565287 5412393,4565297 5412393,4565307 5412383,4565327
5412383,4565337 5412373,4565347 5412373,4565357 5412383,4565337
5412403,4565327 5412403,4565317 5412413,4565307 5412413,4565287
5412433,4565287 5412443,4565277 5412453),(4565915.098
5412017.886,4565866.436 5412003.047,4565958 5411908,4565960.5
5411856.5,4566713.5 5411027,4566738 5411016,4566748 5411026,4566748
5411036,4566758 5411026,4566758 5410996,4566768 5410986,4566778
5410986,4566908 5410856,4566918 5410856,4566998 5410776,4567008
5410776,4567038 5410746,4567048 5410746,4567068 5410726,4567088
5410726,4567094.5 5410733,4566950.5 5410877,4566940.5 5410877,4566770.5
5411047,4566760.5 5411037,4566750.5 5411047,4566760.5 5411057,4566600.5
5411217,4566600.5 5411227,4566590.5 5411237,4566580.5 5411237,4566580.5
5411247,4566490.5 5411337,4566490.5 5411347,4566420.5 5411417,4566420.5
5411427,4566360.5 5411487,4566360.5 5411497,4566300.5 5411557,4566300.5
5411567,4566250.5 5411617,4566250.5 5411627,4566200.5 5411677,4566200.5
5411687,4566150.5 5411737,4566150.5 5411747,4566100.5 5411797,4566100.5
5411807,4566060.5 5411847,4566060.5 5411857,4566010.5
5411907,4565915.098 5412017.886),(4576754.5 5404012.5,4576776.5
5403986,4576829 5404012.5,4576867 5404015,4576922 5403997.5,4576982
5403960,4577216.5 5403802.5,4577247 5403857.5,4576867
5404105.5,4576821.5 5404139,4576797 5404174,4576797 5404231,4576769
5404251.5,4576756 5404223.5,4576719.5 5404206,4576682 5404223.5,4576217
5404541.5,4576102 5404634.5,4575858.5 5404836,4575672 5405012,4575631
5404971.5,4576036.5 5404614.5,4576501 5404269,4576735.5
5404121.5,4576769 5404083.5,4576773.5 5404047,4576754.5
5404012.5),(4582359.5 5393647.5,4582363 5393641.5,4582363
5393639.5,4582370.5 5393628.5,4582380 5393620,4582381.5
5393614.5,4582385 5393609,4582379.5 5393602,4582377.5 5393596.5,4582378
5393582,4582381 5393574.5,4582383 5393572.5,4582387 5393550,4582392.5
5393544,4582396 5393535.5,4582404 5393531.5,4582407.5
5393525.5,4582410.5 5393524.5,4582415.5 5393530,4582417
5393536.5,4582420 5393541,4582429.5 5393544,4582433.5 5393543,4582434
5393541,4582431 5393528,4582422 5393519,4582411.5 5393513.5,4582404
5393515,4582398 5393510,4582400 5393498.5,4582408 5393495.5,4582411.5
5393492.5,4582419 5393489,4582421.5 5393489.5,4582433 5393497.5,4582438
5393497.5,4582439 5393495.5,4582439 5393482.5,4582438 5393480,4582422
5393468,4582419.5 5393463.5,4582419 5393459.5,4582428.5
5393453.5,4582434 5393454.5,4582435 5393453.5,4582435.5
5393438.5,4582436.5 5393436,4582440 5393434,4582441 5393432,4582443
5393411.5,4582447.5 5393400,4582447 5393396,4582450.5
5393383.5,4582450.5 5393376.5,4582447.5 5393368,4582450
5393364.5,4582451 5393359,4582451.5 5393336.5,4582451 5393328.5,4582447
5393320,4582446.5 5393316,4582451 5393314.5,4582453.5
5393310.5,4582451.5 5393304.5,4582449.5 5393302.5,4582439
5393299.5,4582433 5393289.5,4582432.5 5393283,4582434.5
5393283,4582440.5 5393287,4582450 5393289.5,4582466.5 5393280,4582470.5
5393276.5,4582478 5393265,4582480.5 5393263.5,4582486 5393269.5,4582488
5393280,4582486.5 5393287,4582489 5393299,4582486 5393308.5,4582486
5393317,4582480 5393328,4582477.5 5393346.5,4582475 5393350,4582477.5
5393380,4582469.5 5393406.5,4582469.5 5393411.5,4582475.5
5393429.5,4582476.5 5393436,4582474.5 5393462.5,4582475
5393472.5,4582466.5 5393489,4582469.5 5393499,4582465.5
5393502,4582463.5 5393505.5,4582463.5 5393511,4582466.5
5393519.5,4582474.5 5393528,4582475.5 5393530.5,4582473.5
5393533,4582473.5 5393550.5,4582472 5393552.5,4582466 5393553,4582465
5393554.5,4582464.5 5393568,4582473 5393601.5,4582469.5 5393606,4582468
5393610.5,4582477 5393645,4582482 5393657,4582489 5393655.5,4582514.5
5393640.5,4582519 5393637,4582521.5 5393632.5,4582526 5393621.5,4582538
5393579,4582536.5 5393553,4582538 5393547.5,4582546.5 5393546,4582552
5393543,4582561.5 5393542,4582580 5393543.5,4582589 5393546,4582597
5393544,4582602 5393540.5,4582611 5393520.5,4582615 5393515,4582618.5
5393498,4582620.5 5393496.5,4582632 5393495,4582635 5393493,4582637.5
5393484.5,4582637 5393479.5,4582627.5 5393469,4582630 5393468,4582640
5393476.5,4582652.5 5393477,4582659 5393476,4582672 5393485.5,4582688.5
5393484,4582700 5393493.5,4582711.5 5393493.5,4582713.5
5393493,4582714.5 5393484,4582722.5 5393482,4582723 5393480.5,4582720.5
5393464,4582718.5 5393459,4582722.5 5393452,4582731 5393453.5,4582733.5
5393452,4582734.5 5393436,4582739.5 5393430.5,4582760.5
5393429,4582767.5 5393431,4582780.5 5393442.5,4582784 5393449,4582780.5
5393468.5,4582776 5393475,4582775 5393485,4582770 5393492.5,4582768
5393499,4582768 5393505,4582767 5393507,4582760.5 5393511,4582750
5393540.5,4582738.5 5393560,4582742.5 5393569.5,4582741.5
5393579,4582733 5393601.5,4582732 5393621,4582720.5 5393671,4582716
5393677,4582712.5 5393689,4582713.5 5393699.5,4582717.5 5393709,4582715
5393714.5,4582709.5 5393717,4582708 5393719,4582713 5393739.5,4582720.5
5393750,4582724 5393760.5,4582720 5393763.5,4582715 5393764.5,4582711.5
5393771,4582705.5 5393772.5,4582703 5393775,4582701 5393782,4582697.5
5393788,4582691 5393810,4582672.5 5393840.5,4582672 5393859,4582667.5
5393867,4582663 5393882.5,4582661 5393884.5,4582656 5393886,4582651
5393891.5,4582642 5393894,4582638.5 5393899,4582638.5 5393907,4582647.5
5393919.5,4582648 5393922,4582641.5 5393939,4582637 5393946.5,4582627.5
5393968.5,4582620 5393976.5,4582611.5 5393980,4582609.5
5393985,4582607.5 5393980,4582605.5 5393978.5,4582600.5
5393976.5,4582597 5393976.5,4582596 5393983.5,4582587.5
5393987,4582585.5 5393990,4582585 5393994.5,4582571.5
5393993.5,4582560.5 5393989,4582555 5393990,4582551 5393993.5,4582548
5394004.5,4582543.5 5394010.5,4582543 5394014.5,4582544.5
5394019,4582561 5394031.5,4582568.5 5394039.5,4582573
5394050.5,4582567.5 5394057,4582560 5394061.5,4582551.5
5394070.5,4582548 5394078.5,4582555.5 5394097.5,4582557.5
5394117,4582552.5 5394123,4582538.5 5394129.5,4582553.5
5394147.5,4582568.5 5394159.5,4582573.5 5394167.5,4582574
5394170,4582571 5394171,4582566.5 5394176,4582563 5394187.5,4582560.5
5394190.5,4582550 5394191,4582530.5 5394182.5,4582506
5394161.5,4582504.5 5394158,4582507 5394142,4582505 5394138,4582495.5
5394133.5,4582480 5394134,4582477 5394131.5,4582471 5394121,4582468.5
5394121.5,4582462.5 5394132,4582452.5 5394142,4582437
5394147.5,4582421.5 5394149.5,4582411.5 5394155.5,4582400
5394149.5,4582373 5394126,4582357 5394120,4582322.5 5394110,4582320
5394107.5,4582317 5394078.5,4582317.5 5394060.5,4582320
5394048.5,4582365 5394020.5,4582365.5 5394019,4582341 5393976.5,4582340
5393969.5,4582340.5 5393950,4582335 5393940,4582333.5 5393931,4582335
5393911.5,4582329.5 5393868,4582327.5 5393860,4582321.5
5393850.5,4582317 5393836.5,4582315.5 5393827,4582319 5393819.5,4582335
5393807.5,4582341 5393800,4582352 5393774.5,4582362 5393740,4582354.5
5393727,4582352.5 5393720.5,4582363 5393700.5,4582359.5
5393689.5,4582358.5 5393668.5,4582363.5 5393659.5,4582359.5
5393652,4582359.5 5393647.5),(4581936.596 5393037.937,4581932.025
5393065.361,4581928.5 5393072.5,4581839.5 5393408,4581819.5
5393415,4581809.5 5393415,4581799.5 5393425,4581789.5 5393425,4581779.5
5393435,4581759.5 5393435,4581749.5 5393445,4581699.5 5393445,4581689.5
5393435,4581669.5 5393435,4581649.5 5393415,4581639.5 5393415,4581629.5
5393405,4581619.5 5393405,4581599.5 5393385,4581589.5 5393385,4581579.5
5393375,4581569.5 5393375,4581559.5 5393365,4581549.5 5393365,4581529.5
5393345,4581519.5 5393345,4581509.5 5393335,4581499.5 5393335,4581489.5
5393325,4581479.5 5393325,4581469.5 5393335,4581459.5 5393335,4581439.5
5393355,4581429.5 5393355,4581399.5 5393385,4581349.5 5393385,4581289.5
5393325,4581289.5 5393315,4581239.5 5393265,4581239.5 5393255,4581209.5
5393225,4581209.5 5393215,4581199.5 5393205,4581199.5 5393195,4581189.5
5393185,4581189.5 5393135,4581179.5 5393125,4581179.5 5393085,4581169.5
5393075,4581179.5 5393065,4581189.5 5393065,4581199.5 5393055,4581219.5
5393055,4581229.5 5393045,4581249.5 5393045,4581259.5 5393035,4581269.5
5393035,4581279.5 5393025,4581289.5 5393025,4581299.5 5393015,4581309.5
5393015,4581319.5 5393005,4581329.5 5393005,4581349.5 5392985,4581359.5
5392985,4581389.5 5392955,4581399.5 5392955,4581419.5 5392935,4581429.5
5392935,4581459.5 5392905,4581469.5 5392905,4581499.5 5392875,4581509.5
5392875,4581529.5 5392855,4581539.5 5392855,4581569.5 5392825,4581579.5
5392825,4581609.5 5392795,4581619.5 5392795,4581639.5 5392775,4581649.5
5392775,4581679.5 5392745,4581689.5 5392745,4581719.5 5392715,4581729.5
5392715,4581759.5 5392685,4581769.5 5392685,4581789.5 5392665,4581799.5
5392665,4581829.5 5392635,4581839.5 5392635,4581869.5 5392605,4581879.5
5392605,4581909.5 5392575,4581919.5 5392575,4581949.5 5392545,4581959.5
5392545,4581979.5 5392525,4581989.5 5392525,4582009.5 5392505,4582019.5
5392505,4582004 5392622,4581994 5392717,4581955.5 5392963,4581936.596
5393037.937),(4582269.5 5392095,4582279.5 5392085,4582489.5
5392085,4582499.5 5392095,4582579.5 5392095,4582589.5 5392105,4582689.5
5392105,4582699.5 5392115,4582708.412 5392115,4582709.884
5392131.436,4582686.31 5392132.677,4582644.621 5392129.296,4582574.765
5392128.17,4582526.316 5392121.409,4582478.122 5392117.394,4582479.5
5392115,4582469.5 5392115,4582459.5 5392105,4582359.5 5392105,4582369.5
5392115,4582369.5 5392125,4582339.5 5392155,4582329.5 5392155,4582299.5
5392125,4582309.5 5392115,4582239.5 5392115,4582229.5 5392125,4582199.5
5392125,4582189.5 5392135,4582159.5 5392135,4582149.5 5392145,4582129.5
5392145,4582119.5 5392155,4582099.5 5392155,4582089.5 5392165,4582069.5
5392165,4582059.5 5392175,4582049.5 5392175,4582039.5 5392185,4582029.5
5392185,4581989.5 5392225,4581979.5 5392215,4581979.5 5392225,4581969.5
5392235,4581959.5 5392235,4581949.5 5392225,4581939.5 5392225,4581939.5
5392235,4581919.5 5392255,4581909.5 5392245,4581889.5 5392245,4581679
5392351.5,4581032 5392658.5,4580608 5392874,4580468.5 5392935,4580323.5
5392973,4580187.5 5392993.5,4580149 5392995.5,4580140
5392998.5,4580138.5 5393001.5,4580135.5 5393003.5,4580118
5393005,4580113.5 5393008.5,4580095 5393015,4580088 5393021.5,4580080
5393025,4580073.5 5393038.5,4580066 5393048.5,4580054 5393059,4580034
5393068.5,4580019.5 5393072.5,4579999.5 5393081.5,4579989
5393083.5,4579978.5 5393083.5,4579960 5393081,4579922.5
5393071.5,4579909.5 5393067,4579900 5393065.5,4579889
5393066.5,4579870.5 5393064.5,4579830 5393057.5,4579823.5
5393043,4579802 5393026.5,4579786.5 5393024,4579776.5 5393021,4579766.5
5393016,4579767 5393010,4579763 5392992.5,4579755 5392983.5,4579749.5
5392981.5,4579743 5392990,4579722 5392991.5,4579717 5392993.5,4579715
5392998.5,4579720 5393012.5,4579728 5393025,4579728 5393027.5,4579727
5393036.5,4579718.5 5393044,4579715 5393050,4579707.5 5393051,4579701.5
5393056,4579691.5 5393060,4579681.5 5393060.5,4579667.5
5393050.5,4579658.5 5393042,4579649.5 5393040.5,4579641.5
5393035.5,4579639.5 5393033,4579632.5 5393036,4579630 5393045,4579624.5
5393049.5,4579620.5 5393058.5,4579609.5 5393057,4579602.5
5393054.5,4579600 5393051,4579597 5393034,4579588 5393004,4579579.5
5392992.5,4579569 5392988.5,4579565 5392980,4579564.5
5392974.5,4579559.5 5392964.5,4579550.5 5392960,4579547.5
5392962.5,4579548.5 5392984.5,4579551 5392997,4579549.5
5392996.5,4579545 5393000,4579542 5393007.5,4579534.5
5393009.5,4579521.5 5393009,4579498 5393005.5,4579490 5393001,4579479.5
5392993,4579471.5 5392982.5,4579455.5 5392965.5,4579449.5
5392963.5,4579442 5392955,4579441 5392947,4579443.5 5392945.5,4579443.5
5392942,4579440 5392935,4579429.5 5392922.5,4579425 5392913.5,4579425.5
5392900.5,4579430.5 5392875.5,4579423.5 5392863.5,4579420
5392861,4579415.5 5392861,4579407 5392862.5,4579400 5392866,4579393
5392855.5,4579381.5 5392843,4579366 5392839.5,4579360
5392840.5,4579358.5 5392837,4579352.5 5392830,4579347 5392827,4579339.5
5392826.5,4579335.5 5392824.5,4579331.5 5392815.5,4579346.5
5392808.5,4579350 5392805,4579351 5392799.5,4579355.5
5392792.5,4579363.5 5392788.5,4579371.5 5392787.5,4579387.5
5392787.5,4579392.5 5392790,4579398 5392796.5,4579403.5 5392806,4579403
5392807.5,4579395.5 5392810.5,4579395 5392813.5,4579397
5392825.5,4579401.5 5392829.5,4579415.5 5392828,4579423.5
5392825.5,4579430.5 5392825.5,4579433 5392818.5,4579439 5392812,4579459
5392811.5,4579481.5 5392817,4579491 5392815,4579499 5392810,4579502.5
5392806,4579504.5 5392796.5,4579502 5392780,4579502.5 5392768,4579507.5
5392761,4579514 5392757.5,4579517 5392749.5,4579516 5392735.5,4579506
5392727.5,4579504 5392723,4579506 5392718,4579510.5 5392715.5,4579531
5392723,4579536.5 5392731.5,4579542 5392749,4579550 5392763,4579557
5392765.5,4579570 5392766,4579585 5392760,4579589 5392755.5,4579590
5392751.5,4579592.5 5392726,4579596 5392712.5,4579595
5392696.5,4579593.5 5392693,4579587.5 5392686,4579569.5
5392676.5,4579568 5392672.5,4579570 5392666.5,4579577 5392666,4579580
5392667,4579590.5 5392676.5,4579599.5 5392682.5,4579612.5
5392679.5,4579615 5392675,4579616.5 5392663,4579619.5 5392654,4579641
5392646.5,4579643.5 5392641,4579645.5 5392635,4579643.5
5392608.5,4579645 5392605,4579645 5392600.5,4579646.5 5392600,4579660
5392603,4579667 5392615.5,4579670 5392628,4579675 5392637,4579681
5392640,4579688 5392635.5,4579686.5 5392625.5,4579681
5392608.5,4579676.5 5392587.5,4579671 5392576.5,4579671
5392575,4579677.5 5392571.5,4579680.5 5392571.5,4579685.5
5392575.5,4579685 5392585.5,4579688 5392594.5,4579690 5392596,4579697
5392592.5,4579709.5 5392592.5,4579719.5 5392594,4579732
5392585.5,4579737 5392579.5,4579741 5392577,4579769 5392584,4579781.5
5392590.5,4579791 5392588,4579800 5392588,4579808.5 5392596,4579818.5
5392609,4579829.5 5392615.5,4579837.5 5392623,4579856 5392635,4579860.5
5392640,4579887 5392659,4579900 5392663,4579909.5 5392663,4579919
5392665,4579938 5392664,4579986 5392641.5,4580019 5392632.5,4580039
5392625.5,4580071.5 5392618,4580079.5 5392614.5,4580103
5392616,4580120.5 5392612.5,4580140 5392605.5,4580159 5392605.5,4580183
5392597.5,4580230.5 5392593,4580244.5 5392589.5,4580261.5
5392582.5,4580274 5392567.5,4580282.5 5392553,4580287 5392542,4580288
5392534.5,4580293 5392527,4580296 5392517,4580300 5392509.5,4580310.5
5392504,4580319 5392502,4580329.5 5392497,4580356.5 5392476,4580380
5392469,4580418.5 5392471.5,4580448.5 5392471,4580460 5392472,4580467
5392470,4580479 5392461.5,4580480.5 5392462,4580488.5
5392467.5,4580502.5 5392472,4580523.5 5392484,4580541
5392495.5,4580547.5 5392503,4580549 5392508,4580549 5392514.5,4580543.5
5392526,4580530.5 5392546,4580512 5392567,4580487 5392582.5,4580462
5392608.5,4580441 5392620,4580428.5 5392632,4580418.5
5392638.5,4580410.5 5392646.5,4580399.5 5392654,4580387.5
5392669.5,4580359 5392694.5,4580350 5392706.5,4580341
5392721.5,4580332.5 5392727.5,4580324.5 5392736,4580313 5392755,4580304
5392762,4580290 5392769.5,4580280.5 5392778,4580257 5392793.5,4580241.5
5392807.5,4580229.5 5392814.5,4580223.5 5392821.5,4580198.5
5392843.5,4580180.5 5392865.5,4580170 5392875.5,4580166
5392881.5,4580159.5 5392886.5,4580150 5392899,4580140
5392908.5,4580131.5 5392924.5,4580123.5 5392946.5,4580122.5
5392965,4580125 5392974.5,4580147 5392976,4580151.5 5392975.5,4580155
5392970.5,4580160 5392970.5,4580165.5 5392968.5,4580175
5392967.5,4580221.5 5392967.5,4580231 5392965.5,4580233.5
5392961.5,4580236.5 5392959.5,4580242 5392958.5,4580259.5
5392958,4580279 5392955.5,4580291.5 5392956.5,4580297.5
5392951.5,4580300 5392952,4580389.5 5392930.5,4580506.5 5392891,4580684
5392806.5,4581101 5392602,4581864.5 5392231.5,4581899.5
5392215,4581919.5 5392215,4581929.5 5392205,4581939.5 5392205,4581949.5
5392195,4581959.5 5392195,4581969.5 5392185,4581979.5 5392185,4581989.5
5392175,4581999.5 5392175,4581999.5 5392165,4582009.5 5392155,4582019.5
5392165,4582029.5 5392165,4582039.5 5392155,4582049.5 5392155,4582059.5
5392145,4582079.5 5392145,4582089.5 5392135,4582109.5 5392135,4582119.5
5392125,4582139.5 5392125,4582149.5 5392115,4582169.5 5392115,4582179.5
5392105,4582209.5 5392105,4582219.5 5392095,4582269.5
5392095))',31468),31467)), abs(st_area(st_geomfromtext('POLYGON((4562878
5410125.5,4562864.5 5410124,4562855 5410115,4562852.5 5410115,4562813
5410144,4562768.5 5410147,4562728 5410147,4562718 5410157,4562688
5410157,4562678 5410167,4562638 5410167,4562628 5410177,4562608
5410177,4562598 5410187,4562579 5410187,4562569.5 5410192,4562539.5
5410192,4562529.5 5410202,4562499.5 5410202,4562479.5 5410182,4562449.5
5410182,4562429.5 5410202,4562409.5 5410202,4562399.5 5410212,4562369.5
5410212,4562349.5 5410232,4562339.5 5410232,4562329.5 5410242,4562319.5
5410242,4562299.5 5410262,4562289.5 5410252,4562289.5 5410242,4562279.5
5410242,4562269.5 5410232,4562259.5 5410242,4562259.5 5410252,4562249.5
5410262,4562229.5 5410262,4562219.5 5410272,4562219.5 5410292,4562209.5
5410302,4562199.5 5410302,4562199.5 5410312,4562189.5 5410322,4562179.5
5410322,4562169.5 5410332,4562169.5 5410342,4562129.5 5410382,4562109.5
5410382,4562099.5 5410392,4562109.5 5410402,4562099.5 5410412,4562079.5
5410412,4562069.5 5410402,4562059.5 5410402,4562049.5 5410412,4562049.5
5410432,4562039.5 5410442,4562029.5 5410442,4562019.5 5410452,4561939.5
5410452,4561929.5 5410462,4561909.5 5410462,4561899.5 5410472,4561829.5
5410472,4561819.5 5410462,4561809.5 5410462,4561799.5 5410472,4561779.5
5410472,4561739.5 5410432,4561739.5 5410422,4561729.5 5410412,4561729.5
5410372,4561719.5 5410361,4561719.5 5410351,4561709.5 5410341,4561709.5
5410331,4561699.5 5410321,4561699.5 5410311,4561679.5 5410291,4561659.5
5410291,4561639.5 5410271,4561639.5 5410261,4561579.5 5410201,4561569.5
5410201,4561589.5 5410221,4561569.5 5410241,4561619.5 5410291,4561619.5
5410311,4561639.5 5410331,4561639.5 5410361,4561649.5 5410371,4561649.5
5410381,4561629.5 5410401,4561619.5 5410391,4561629.5 5410381,4561609.5
5410381,4561609.5 5410401,4561599.5 5410411,4561589.5 5410411,4561579.5
5410401,4561559.5 5410401,4561549.5 5410411,4561529.5 5410411,4561479.5
5410361,4561479.5 5410351,4561419.5 5410291,4561419.5 5410281,4561409.5
5410281,4561379.5 5410251,4561320.5 5410201,4561378.5
5410101.5,4561378.5 5410088,4561365.5 5410074.5,4561191
5409940.5,4561176.5 5409934,4561101 5409881,4561060.5 5409858,4560971.5
5409821.5,4560965.5 5409812.5,4560965 5409802.5,4560969.5
5409787,4560974 5409774.5,4560988 5409746,4560999 5409715,4561008
5409698.5,4561012.5 5409685.5,4561012 5409679.5,4561007.5
5409671.5,4560999 5409662.5,4560956.5 5409647,4560939 5409643.5,4560929
5409645,4560918 5409650,4560876 5409692,4560886 5409668,4560890.5
5409648,4560888 5409637,4560885.5 5409632.5,4560870.5 5409630,4560854.5
5409624,4560809 5409611.5,4560772.5 5409597,4560760 5409598.5,4560756
5409600.5,4560711.5 5409663,4560734.5 5409603.5,4560738 5409597,4560741
5409578,4560740.5 5409569.5,4560738 5409563.5,4560732.5
5409556.5,4560715.5 5409541,4560709.5 5409537.5,4560710
5409531.5,4560703 5409518,4560698.5 5409504.5,4560702 5409495,4560708
5409489.5,4560717 5409487.5,4560724 5409493.5,4560735.5
5409482.5,4560734 5409473.5,4560725 5409472,4560722 5409469,4560725.5
5409464.5,4560728 5409456.5,4560739.5 5409456,4560740.5
5409443,4560731.5 5409435.5,4560738 5409415,4560746 5409415,4560751.5
5409411,4560742 5409370.5,4560741 5409361.5,4560742 5409343.5,4560740
5409335,4560731.5 5409329,4560713 5409320.5,4560680 5409309.5,4560659.5
5409301,4560646 5409296.5,4560628 5409298,4560614.5 5409305,4560576
5409305.5,4560565 5409302.5,4560534 5409284,4560504 5409276.5,4560469
5409273.5,4560420 5409272,4560397 5409276,4560378.5 5409277,4560361.5
5409275,4560351.5 5409271.5,4560327 5409258.5,4560317 5409254.5,4560302
5409251,4560209.5 5409246.5,4560186 5409243,4560154.5 5409232.5,4560136
5409224.5,4560117.5 5409220,4560100.5 5409224,4560092.5 5409233,4560094
5409239,4560102.5 5409245,4560161 5409268,4560176 5409270.5,4560188
5409270.5,4560200 5409276,4560211 5409275,4560219 5409282.5,4560251
5409290.5,4560336.5 5409301,4560340.5 5409299,4560362.5
5409304,4560371.5 5409304.5,4560388 5409310.5,4560404.5
5409311.5,4560435 5409318,4560470.5 5409323.5,4560478.5 5409317,4560486
5409314.5,4560500.5 5409315,4560508 5409319.5,4560511
5409325.5,4560520.5 5409330,4560532 5409327,4560545.5
5409325.5,4560553.5 5409329,4560553.5 5409334.5,4560570
5409349.5,4560577.5 5409353.5,4560611.5 5409364.5,4560618
5409370,4560618.5 5409376,4560615.5 5409382.5,4560609
5409386.5,4560600.5 5409389,4560593.5 5409394,4560586 5409402.5,4560576
5409408.5,4560570.5 5409415,4560561.5 5409418.5,4560549
5409413.5,4560546.5 5409414.5,4560524 5409405,4560513.5
5409412.5,4560494 5409419.5,4560470 5409434,4560462 5409435,4560448
5409429,4560447 5409425,4560445.5 5409424,4560441.5 5409431.5,4560438.5
5409431,4560420 5409461.5,4560413 5409459.5,4560409 5409450,4560390
5409455.5,4560373.5 5409450,4560368 5409449.5,4560362.5
5409451.5,4560357 5409457,4560336.5 5409493.5,4560314.5 5409540,4560309
5409546.5,4560303.5 5409548.5,4560295.5 5409549,4560290.5
5409548,4560288 5409549.5,4560289 5409564.5,4560282 5409577,4560283
5409581.5,4560249.5 5409553.5,4560195.5 5409517.5,4560189
5409518.5,4560177.5 5409510.5,4560119.5 5409483.5,4560089.5
5409472,4560071.5 5409461.5,4560028.5 5409439.5,4560016.5
5409425.5,4560006 5409415.5,4559990 5409410,4559984.5 5409412,4559981.5
5409415.5,4559974 5409412,4559966 5409415.5,4559961 5409415.5,4559940
5409405.5,4559934.5 5409401,4559924 5409402,4559913 5409399,4559878
5409375.5,4559859.5 5409369.5,4559846 5409368,4559826 5409362.5,4559823
5409355.5,4559747 5409341,4559709 5409330,4559708 5409326,4559705
5409322.5,4559664 5409317.5,4559614.5 5409316,4559594 5409318,4559560
5409314,4559546.5 5409315,4559527 5409313.5,4559495 5409309.5,4559465
5409310.5,4559451 5409312.5,4559440.5 5409300,4559432 5409301.5,4559424
5409310,4559386 5409315,4559358.5 5409314.5,4559354 5409311.5,4559327.5
5409313.5,4559325.5 5409316.5,4559243.5 5409323,4559227.5
5409322.5,4559203.5 5409330.5,4559195.5 5409328,4559188.5
5409331,4559177 5409331.5,4559155.5 5409327,4559133.5
5409333.5,4559114.5 5409348.5,4559092 5409354.5,4559069.5
5409358,4559045 5409356,4558966 5409374.5,4558944 5409378.5,4558917.5
5409381,4558909.5 5409386.5,4558905 5409383,4558904.5 5409384.5,4558909
5409390,4558866 5409414,4558856.5 5409413,4558851 5409416.5,4558846
5409414.5,4558829.5 5409418,4558809.5 5409415.5,4558790.5
5409429,4558781.5 5409433,4558778.5 5409431,4558776.5
5409427.5,4558757.5 5409432.5,4558758 5409442,4558755.5
5409443,4558745.5 5409442,4558731 5409446,4558721.5 5409444,4558694
5409452.5,4558687.5 5409460.5,4558673 5409460.5,4558666
5409455.5,4558640.5 5409442,4558622.5 5409427.5,4558586.5
5409392,4558569.5 5409387,4558563 5409383,4558559 5409387,4558552.5
5409387.5,4558541 5409394,4558543 5409398.5,4558552.5
5409402.5,4558546.5 5409407,4558532 5409403.5,4558528 5409407,4558535
5409429,4558547.5 5409441,4558554 5409458.5,4558560.5 5409495,4558559.5
5409522,4558516 5409540.5,4558496 5409558,4558490.5 5409558.5,4558416
5409606,4558348.5 5409645.5,4558316 5409675.5,4558284.5
5409695.5,4558258.5 5409702.5,4558246.5 5409715,4558226.5
5409739.5,4558188 5409776.5,4558130.5 5409821,4558105.5
5409836,4558086.5 5409831.5,4558074.5 5409835.5,4558061 5409850,4558057
5409874.5,4558046 5409884.5,4558042 5409893.5,4557990 5409938,4557968
5409949.5,4558025 5409896,4558029 5409875.5,4558008 5409858,4558004
5409858.5,4557973.5 5409819.5,4557969.5 5409807.5,4557956.5
5409786.5,4557941.5 5409791.5,4557930.5 5409809,4557889.5
5409865,4557843.5 5409924.5,4557774.5 5409988,4557771 5409994,4557782
5410056.5,4557793.5 5410082.5,4557808 5410085,4557812.5
5410090,4557809.5 5410098.5,4557786.5 5410111.5,4557772
5410077.5,4557759.5 5410075.5,4557746 5410078.5,4557733 5410085,4557735
5410094.5,4557749 5410114,4557758.5 5410122,4557770 5410115,4557775.5
5410122,4557781 5410125,4557778.5 5410129,4557765.5 5410135,4557761
5410130.5,4557733.5 5410146.5,4557728.5 5410152.5,4557737.5
5410176,4557736 5410184,4557708.5 5410216.5,4557710.5
5410222.5,4557704.5 5410230,4557699 5410235,4557682.5 5410237,4557677
5410235,4557651.5 5410218.5,4557634.5 5410222.5,4557618 5410219,4557607
5410211.5,4557595 5410211,4557598.5 5410214,4557598.5 5410225,4557605.5
5410226.5,4557631 5410253.5,4557652.5 5410267.5,4557661.5
5410285,4557657.5 5410310,4557651 5410320.5,4557639.5 5410329.5,4557585
5410395,4557555.5 5410426.5,4557527.5 5410453,4557508.5
5410463,4557476.5 5410487.5,4557446 5410506.5,4557425.5 5410521,4557405
5410532.5,4557370 5410560,4557365 5410558.5,4557343 5410541.5,4557359
5410559.5,4557358.5 5410568,4557350 5410579,4557305.5 5410615,4557285.5
5410634,4557264 5410649,4557230.5 5410667.5,4557218 5410667.5,4557210
5410670.5,4557196.5 5410669,4557187.5 5410661.5,4557171.5
5410644.5,4557149 5410637.5,4557130.5 5410628.5,4557119.5
5410606.5,4557114.5 5410593,4557117 5410561,4557114 5410524,4557107.5
5410500.5,4557099 5410499,4557096.5 5410475,4557098 5410461,4557104.5
5410432.5,4557117 5410420.5,4557120.5 5410410.5,4557010
5410491,4557015.5 5410511.5,4557016 5410529,4557004 5410546.5,4556998.5
5410559,4556995 5410573,4556997 5410591,4557005.5 5410608,4557008.5
5410624.5,4557008.5 5410652,4557004 5410709.5,4556998
5410723.5,4557000.5 5410762,4556995 5410786.5,4556998 5410809,4556995
5410821.5,4556956.5 5410867,4556940.5 5410893,4556875 5410953,4556767.5
5411072,4556784.725 5411085.737,4556774.564 5411092.394,4556703.412
5411170.442,4556683.282 5411189.629,4556665.423 5411208.811,4556605.314
5411288.567,4556599.959 5411294.057,4556647.842 5411359.72,4556995.974
5411003.444,4557197.748 5410801.332,4557392.967 5410603.397,4557541.06
5410501.049,4557764.003 5410347.387,4557947.478 5410250.481,4558154.397
5410140.961,4558220.546 5410106.646,4558376.668 5410037.51,4558680.651
5409903.06,4559121.415 5409819.081,4559165.688 5409816.129,4559373.626
5409802.159,4559621.729 5409784.98,4559630.705 5409786.091,4559978.004
5409829.769,4560200.677 5409855.981,4560227.326 5409864.282,4560391.847
5409915.533,4560587.746 5409975.333,4561020.622 5410199.564,4561387.331
5410407.445,4561403.673 5410420.025,4561683.803 5410635.716,4561755.313
5410760.667,4561874.666 5410974.179,4562013.359 5411265.561,4562217.2
5411541.675,4562414.933 5411709.379,4562221.271 5412402.845,4562223.323
5412402.94,4562331.501 5412408.029,4562494.84 5412415.824,4562444.198
5412636.97,4562260.207 5412859.642,4562229.446 5412873.408,4561964.907
5412988.885,4561974.557 5413037.134,4561975.186 5413039.816,4561977.772
5413053.209,4562012.086 5413230.933,4562039.061 5413363.264,4562377.269
5413606.804,4562053.618 5414016.114,4562052.294 5414017.794,4561918.281
5414049.585,4561789.923 5414080.142,4561711.737 5414352.528,4561706.707
5414370.507,4561701.923 5414385.701,4561649.506 5414562.886,4561629.344
5414631.607,4561611.337 5414691.908,4561585.573 5414778.189,4561616.264
5414821.65,4561624.794 5414833.706,4561632 5414826.5,4561652
5414826.5,4561662 5414816.5,4561672 5414826.5,4561682 5414826.5,4561692
5414816.5,4561702 5414826.5,4561702 5414866.5,4561722 5414886.5,4561722
5414906.5,4561779 5414962.5,4561830 5414895.5,4561847 5414863,4562027
5414683,4562027 5414673,4562087 5414613,4562097 5414613,4562237
5414473,4562247 5414473,4562307 5414413,4562317 5414413,4562367
5414363,4562377 5414363,4562417 5414323,4562427 5414323,4562467
5414283,4562477 5414283,4562507 5414253,4562517 5414253,4562547
5414223,4562557 5414223,4562587 5414193,4562597 5414193,4562627
5414163,4562637 5414163,4562657 5414143,4562667 5414143,4562677
5414133,4562687 5414133,4562697 5414123,4562707 5414123,4562717
5414113,4562727 5414113,4562737 5414123,4562677 5414183,4562667
5414183,4562637 5414213,4562627 5414213,4562597 5414243,4562587
5414243,4562557 5414273,4562547 5414273,4562507 5414313,4562497
5414313,4562447 5414363,4562437 5414363,4562377 5414423,4562367
5414423,4562257 5414533,4562247 5414533,4562047 5414733,4562047
5414743,4561947 5414843,4561947 5414863,4561957 5414863,4561967
5414873,4561957 5414883,4561916 5414884,4561913.5 5414897,4561897
5414913,4561871.5 5414944.5,4561867 5414953,4561860.5 5414956.5,4561857
5414963,4561838 5414983.5,4561827 5414993,4561817 5414993,4561817
5415013,4561827 5415023,4561827 5415089.134,4561837 5415093,4561837
5415003,4561848.5 5414992.5,4561847 5414983,4561883.5
5414946.5,4561889.5 5414942.5,4561899 5414927.5,4561915
5414909.5,4561917 5414903,4561927 5414893,4561937 5414903,4561937
5414923,4561927 5414933,4561937 5414943,4561947 5414943,4561967
5414963,4561977 5414953,4561997 5414973,4561997 5414983,4562027
5414983,4562047 5415003,4562037 5415013,4562047 5415023,4562077
5415023,4562077 5415003,4562087 5414993,4562077 5414983,4562097
5414963,4562107 5414973,4562107 5414903,4562097 5414893,4562097
5414873,4562087 5414863,4562087 5414853,4562077 5414853,4562067
5414843,4562077 5414833,4562087 5414833,4562097 5414823,4562107
5414833,4562107 5414863,4562117 5414873,4562117 5414883,4562127
5414893,4562127 5415013,4562147 5415013,4562157 5415023,4562167
5415023,4562187 5415043,4562187 5415053,4562197 5415063,4562257
5415063,4562267 5415053,4562277 5415053,4562297 5415033,4562327
5415033,4562337 5415023,4562367 5415023,4562377 5415013,4562387
5415023,4562407 5415023,4562417 5415013,4562427 5415013,4562427
5415003,4562447 5414983,4562447 5414973,4562457 5414963,4562477
5414963,4562487 5414953,4562557 5414953,4562567 5414963,4562597
5414963,4562607 5414973,4562617 5414973,4562637 5414993,4562637
5415003,4562657 5415023,4562657 5415043,4562667 5415053,4562667
5415063,4562677 5415073,4562677 5415083,4562687 5415093,4562697
5415093,4562707 5415103,4562717 5415103,4562727 5415113,4562737
5415113,4562757 5415133,4562767 5415123,4562807 5415123,4562817
5415133,4562837 5415113,4562857 5415113,4562867 5415103,4562877
5415103,4562897 5415083,4562907 5415083,4562917 5415073,4562927
5415073,4562977 5415023,4562977 5415013,4563037 5414953,4563037
5414933,4562997 5414893,4563007 5414883,4563047 5414923,4563047
5414913,4563057 5414903,4563087 5414873,4563097 5414873,4563117
5414853,4563117 5414843,4563137 5414823,4563137 5414813,4563157
5414793,4563157 5414783,4563177 5414763,4563177 5414743,4563197
5414723,4563207 5414723,4563207 5414713,4563217 5414703,4563217
5414693,4563237 5414673,4563237 5414663,4563257 5414643,4563257
5414623,4563267 5414613,4563267 5414593,4563257 5414583,4563257
5414553,4563267 5414543,4563267 5414523,4563277 5414513,4563277
5414473,4563257 5414473,4563247 5414483,4563237 5414483,4563227
5414473,4563217 5414473,4563207 5414463,4563197 5414463,4563157
5414423,4563157 5414413,4563147 5414403,4563147 5414383,4563157
5414373,4563157 5414343,4563167 5414333,4563167 5414323,4563177
5414313,4563187 5414313,4563197 5414303,4563217 5414303,4563227
5414293,4563257 5414293,4563267 5414283,4563267 5414263,4563277
5414253,4563297 5414253,4563297 5414243,4563307 5414233,4563317
5414233,4563327 5414223,4563337 5414233,4563347 5414223,4563357
5414223,4563367 5414213,4563407 5414213,4563417 5414203,4563447
5414203,4563457 5414193,4563467 5414203,4563527 5414203,4563537
5414213,4563577 5414213,4563597 5414193,4563677 5414193,4563697
5414213,4563717 5414193,4563837 5414193,4563867 5414223,4563867
5414233,4563857 5414243,4563857 5414273,4563867 5414263,4563887
5414283,4563887 5414293,4563917 5414323,4564007 5414323,4564017
5414333,4564077 5414333,4564087 5414323,4564127 5414323,4564137
5414333,4564147 5414333,4564157 5414323,4564167 5414323,4564177
5414313,4564207 5414313,4564217 5414303,4564237 5414303,4564247
5414313,4564247 5414353,4564257 5414353,4564267 5414363,4564307
5414363,4564317 5414373,4564347 5414373,4564357 5414383,4564387
5414383,4564397 5414393,4564407 5414393,4564417 5414383,4564467
5414383,4564477 5414393,4564497 5414393,4564507 5414403,4564527
5414403,4564537 5414413,4564587 5414413,4564597 5414423,4564607
5414413,4564617 5414423,4564707 5414423,4564717 5414433,4564817
5414433,4564837 5414453,4564837 5414463,4564847 5414453,4564857
5414453,4564867 5414443,4564877 5414443,4564887 5414433,4564907
5414433,4564917 5414423,4564947 5414423,4564957 5414413,4564967
5414413,4564987 5414393,4564997 5414393,4565007 5414383,4565017
5414383,4565027 5414373,4565027 5414333,4565037 5414323,4565037
5414293,4565047 5414283,4565057 5414293,4565057 5414333,4565067
5414343,4565077 5414343,4565087 5414333,4565087 5414323,4565097
5414313,4565097 5414263,4565107 5414253,4565107 5414233,4565117
5414223,4565117 5414213,4565137 5414193,4565197 5414193,4565207
5414198,4565287 5414198,4565297 5414188,4565317 5414208,4565327
5414198,4565337 5414198,4565347 5414188,4565377 5414188,4565407
5414158,4565417 5414158,4565427 5414148,4565437 5414148,4565447
5414138,4565467 5414138,4565477 5414128,4565487 5414128,4565497
5414118,4565507 5414118,4565517 5414108,4565527 5414108,4565537
5414098,4565577 5414098,4565587 5414088,4565607 5414088,4565617
5414078,4565627 5414078,4565637 5414068,4565647 5414068,4565647
5414048,4565657 5414038,4565677 5414038,4565697 5414018,4565717
5414018,4565737 5413998,4565757 5413998,4565767 5413988,4565787
5413988,4565797 5413978,4565807 5413978,4565827 5413958,4565837
5413958,4565837 5413948,4565847 5413938,4565857 5413938,4565857
5413918,4565847 5413928,4565837 5413928,4565827 5413918,4565837
5413908,4565847 5413908,4565857 5413918,4565857 5413908,4565867
5413898,4565857 5413888,4565867 5413878,4565867 5413868,4565877
5413858,4565867 5413848,4565867 5413838,4565857 5413828,4565857
5413618,4565827 5413588,4565827 5413578,4565817 5413568,4565817
5413428,4565827 5413418,4565837 5413418,4565867 5413388,4565877
5413388,4565887 5413378,4565917 5413378,4565927 5413388,4565957
5413388,4565967 5413398,4566017 5413398,4566037 5413378,4566067
5413378,4566077 5413388,4566087 5413388,4566097 5413398,4566167
5413398,4566187 5413418,4566367 5413418,4566387 5413438,4566597
5413438,4566617 5413418,4566677 5413418,4566687 5413408,4566697
5413408,4566707 5413398,4566737 5413398,4566757 5413378,4566767
5413378,4566777 5413368,4566797 5413368,4566807 5413358,4566867
5413358,4566877 5413348,4566887 5413348,4566897 5413338,4566917
5413338,4566927 5413328,4566947 5413328,4566957 5413318,4566977
5413318,4566997 5413298,4567027 5413298,4567047 5413278,4567087
5413278,4567107 5413298,4567107 5413308,4567117 5413318,4567117
5413328,4567127 5413338,4567127 5413358,4567137 5413368,4567147
5413368,4567187 5413408,4567197 5413408,4567217 5413428,4567237
5413428,4567257 5413448,4567257 5413458,4567267 5413468,4567397
5413468,4567407 5413458,4567427 5413458,4567437 5413448,4567447
5413448,4567457 5413438,4567487 5413438,4567507 5413458,4567507
5413468,4567517 5413478,4567517 5413498,4567527 5413508,4567527
5413528,4567517 5413538,4567517 5413548,4567567 5413548,4567577
5413558,4567577 5413568,4567587 5413578,4567587 5413588,4567597
5413578,4567607 5413578,4567617 5413568,4567627 5413578,4567627
5413588,4567637 5413588,4567647 5413598,4567657 5413588,4567657
5413558,4567665.243 5413533.64,4567646.634 5413523.581,4567629.031
5413510.504,4567616.347 5413486.285,4567610.424 5413460.792,4567610.167
5413440.706,4567585.446 5413380.965,4567577.352 5413347.584,4567563.914
5413333.141,4567546.364 5413319.339,4567520.952 5413307.638,4567521.226
5413312.848,4567511.536 5413311.568,4567493.162 5413311.934,4567475.886
5413317.145,4567465.374 5413316.962,4567437.037 5413325.737,4567417.383
5413336.615,4567362.171 5413353.343,4567348.277 5413359.285,4567326.064
5413357.914,4567314.272 5413353.252,4567297.91 5413337.712,4567258.329
5413291.093,4567208.785 5413210.56,4567166.918 5413136.792,4567173.774
5413130.393,4567154.395 5413098.49,4567141.506 5413071.799,4567137.484
5413058.087,4567135.29 5413038.342,4567135.199 5413014.393,4567145.345
5412965.031,4567177.522 5412836.234,4567186.95 5412787.946,4567180.233
5412787.133,4567193.282 5412731.034,4567216.318 5412641.73,4567222.629
5412606.703,4567252.689 5412603.49,4567251.689 5412596.493,4567252.053
5412560.597,4567263.866 5412545.512,4567264.048 5412538.242,4567274.135
5412517.614,4567287.312 5412504.8,4567294.764 5412492.987,4567283.496
5412477.356,4567302.034 5412450.094,4567306.032 5412433.646,4567323.935
5412426.103,4567343.564 5412414.289,4567374.461 5412401.749,4567425.714
5412350.495,4567429.258 5412343.68,4567453.249 5412325.868,4567475.332
5412298.697,4567480.603 5412279.704,4567494.506 5412261.166,4567508.137
5412249.897,4567525.767 5412222.271,4567589.197 5412139.03,4567625.82
5412098.318,4567667.44 5412063.786,4567689.432 5412048.337,4567729.144
5412025.346,4567869.273 5411951.556,4567881.814 5411958.008,4567909.894
5411946.103,4567918.163 5411945.921,4567922.798 5411947.103,4567919.89
5411942.014,4567915.891 5411929.655,4567965.873 5411876.312,4567986.956
5411851.412,4568014.893 5411809.125,4568048.485 5411767.046,4568076.193
5411745.226,4568061.335 5411712.827,4568190.541 5411630.705,4568354.239
5411521.755,4568557.082 5411415.817,4568614.568 5411392.822,4568747.607
5411342.454,4568906.104 5411286.337,4568920.338 5411259.51,4568994.249
5411224.471,4569126.466 5411149.739,4569170.265 5411126.745,4569288.796
5411067.89,4569495.197 5410978.103,4569450.304 5410864.773,4569482.331
5410827.818,4569484.167 5410831.215,4569485.664 5410828.327,4569523.5
5410904,4569590.418 5411025.454,4569612.085 5410933.483,4569647.672
5410857.93,4569733.175 5410784.301,4569742.563 5410774.371,4569749.319
5410770.537,4569782.627 5410742.137,4569813.253 5410734.248,4569822.5
5410729,4569773.628 5410638.736,4569808.558 5410621.11,4569843.219
5410686.432,4569861.397 5410725.73,4569878.29 5410722.235,4570196.251
5410558.456,4570356.391 5410473.87,4570635.941 5410322.337,4570606.837
5410267.575,4570630.508 5410258.537,4570655.5 5410309.5,4570784
5410236,4570775.5 5410216.5,4570779.5 5410204,4570768.658
5410177.979,4570874.375 5410084.249,4570957.523 5410003.378,4570992.832
5409964.652,4571060.035 5409883.782,4571094.205 5409859.862,4571063.452
5409903.145,4571019.03 5409958.957,4570984.859 5409997.683,4570941.577
5410042.105,4570776.419 5410190.177,4570793.504 5410215.235,4570802.617
5410211.818,4570819.702 5410201.567,4570842.482 5410181.065,4570837.926
5410174.231,4570855.012 5410158.284,4570864.123 5410160.563,4570883.487
5410171.953,4570932.464 5410142.338,4570951.267 5410147.76,4570956.132
5410145.083,4571131.529 5409917.548,4571148.327 5409884.502,4571175.154
5409814.972,4571184.69 5409848.585,4571683.5 5409201.5,4571802
5409078.5,4571841 5409022,4571875.5 5408901,4571904.5 5408835.5,4571951
5408756,4571971 5408692.5,4571995.5 5408405,4572004.5 5408250,4572011.5
5408176.5,4572045 5408090,4572107 5408022,4572247 5407949.5,4572326.5
5407923.5,4572436.5 5407865.5,4572529 5407792,4572706.5 5407665,4572870
5407588,4573030.5 5407478.5,4573128.5 5407364,4573208 5407292,4573212.5
5407241,4573274.5 5407200.5,4573352.5 5407180.5,4573436.5
5407118.5,4573582.5 5407039,4573871.5 5406920.5,4573962.5
5406904.5,4574082.5 5406907.5,4574253 5406942,4574347
5406920.5,4574475.5 5406861,4574547.5 5406820.5,4574602.5
5406777,4574743 5406628.5,4574805 5406582,4574894.5 5406527,4575182
5406420,4575241.5 5406385.5,4575335.5 5406297,4575510 5406121,4575579.5
5406025.5,4575623 5405970.5,4575735.5 5405853.5,4575790.5
5405810,4576007 5405779.5,4576019 5405738,4576102.5 5405700,4576175
5405723.5,4576212.5 5405717.5,4576326.5 5405674,4576524.5
5405631,4576627 5405568.5,4576744 5405487.5,4576854 5405428.5,4576933.5
5405409.5,4577111.5 5405385,4577271.5 5405378,4577316.5
5405392.5,4577370 5405405.5,4577411.624 5405410.703,4577424.176
5405412.272,4577438 5405414,4577487.859 5405414.719,4577503.352
5405414.943,4577521.471 5405415.204,4577523.839 5405415.238,4577524.287
5405415.245,4577542 5405415.5,4577557.5 5405412.5,4577557.122
5405408.312,4577555.702 5405392.567,4577551.5 5405346,4577531.545
5405302.961,4577524.293 5405287.319,4577517.407 5405272.468,4577510.274
5405257.084,4577505.36 5405246.486,4577382.5 5404981.5,4577356.5
5404852,4577347.5 5404718,4577414.5 5404594,4577477.5 5404548.5,4577467
5404518,4577488 5404459.5,4577538 5404409.5,4577538 5404399.5,4577558
5404379.5,4577558 5404369.5,4577568 5404359.5,4577568 5404349.5,4577678
5404239.5,4577708 5404239.5,4577718 5404229.5,4577728 5404229.5,4577748
5404249.5,4577758 5404249.5,4577768 5404259.5,4577778 5404259.5,4577788
5404269.5,4577808 5404269.5,4577818 5404279.5,4577818 5404289.5,4577828
5404299.5,4577838 5404299.5,4577848 5404309.5,4577878 5404309.5,4577888
5404319.5,4577898 5404319.5,4577908 5404309.5,4577938 5404309.5,4577988
5404259.5,4577988 5404249.5,4577998 5404239.5,4578008 5404239.5,4578018
5404229.5,4578038 5404229.5,4578048 5404219.5,4578078 5404219.5,4578078
5404209.5,4578108 5404179.5,4578118 5404179.5,4578128 5404169.5,4578208
5404169.5,4578248 5404129.5,4578248 5404119.5,4578258 5404109.5,4578258
5404079.5,4578288 5404049.5,4578298 5404049.5,4578328 5404019.5,4578348
5404019.5,4578358 5404009.5,4578368 5403999.5,4578368 5403989.5,4578378
5403979.5,4578378 5403959.5,4578398 5403939.5,4578408 5403939.5,4578448
5403899.5,4578468 5403899.5,4578558 5403809.5,4578568 5403809.5,4578618
5403759.5,4578618 5403749.5,4578628 5403739.5,4578638 5403739.5,4578678
5403699.5,4578688 5403699.5,4578698 5403689.5,4578708 5403689.5,4578718
5403679.5,4578738 5403679.5,4578758 5403659.5,4578758 5403649.5,4578768
5403639.5,4578768 5403609.5,4578778 5403599.5,4578778 5403589.5,4578788
5403579.5,4578788 5403569.5,4578798 5403559.5,4578808 5403559.5,4578828
5403539.5,4578838 5403539.5,4578868 5403509.5,4578878 5403509.5,4578878
5403489.5,4578868 5403479.5,4578868 5403459.5,4578848 5403459.5,4578838
5403449.5,4578818 5403449.5,4578808 5403439.5,4578788 5403439.5,4578778
5403429.5,4578728 5403429.5,4578718 5403439.5,4578708 5403439.5,4578698
5403449.5,4578648 5403449.5,4578638 5403439.5,4578608 5403439.5,4578578
5403409.5,4578578 5403399.5,4578608 5403369.5,4578638 5403369.5,4578648
5403359.5,4578658 5403359.5,4578658 5403279.5,4578648 5403289.5,4578618
5403289.5,4578608 5403299.5,4578598 5403289.5,4578588 5403289.5,4578568
5403269.5,4578568 5403239.5,4578578 5403229.5,4578578 5403219.5,4578618
5403179.5,4578618 5403169.5,4578628 5403159.5,4578628 5403119.5,4578678
5403069.5,4578678 5403059.5,4578688 5403049.5,4578708 5403049.5,4578708
5403039.5,4578718 5403029.5,4578738 5403029.5,4578738 5403019.5,4578758
5402999.5,4578758 5402989.5,4578738 5402969.5,4578738 5402959.5,4578728
5402949.5,4578738 5402939.5,4578738 5402929.5,4578778 5402889.5,4578778
5402879.5,4578798 5402859.5,4578798 5402849.5,4578808 5402839.5,4578808
5402829.5,4578818 5402819.5,4578818 5402789.5,4578828 5402779.5,4578828
5402769.5,4578838 5402759.5,4578838 5402749.5,4578848 5402739.5,4578848
5402729.5,4578858 5402719.5,4578858 5402699.5,4578868 5402689.5,4578868
5402649.5,4578878 5402639.5,4578878 5402629.5,4578898 5402609.5,4578898
5402599.5,4578918 5402579.5,4578918 5402569.5,4578928 5402559.5,4578928
5402539.5,4578908 5402519.5,4578908 5402509.5,4578888 5402489.5,4578888
5402479.5,4578858 5402449.5,4578858 5402419.5,4578848 5402409.5,4578848
5402389.5,4578838 5402379.5,4578838 5402369.5,4578798 5402329.5,4578798
5402309.5,4578778 5402289.5,4578778 5402279.5,4578768 5402269.5,4578768
5402259.5,4578758 5402249.5,4578758 5402239.5,4578768 5402229.5,4578768
5402159.5,4578818 5402109.5,4578818 5402059.5,4578808 5402049.5,4578808
5402039.5,4578798 5402029.5,4578798 5402019.5,4578788 5402009.5,4578788
5401999.5,4578748 5401959.5,4578748 5401909.5,4578768 5401889.5,4578768
5401869.5,4578778 5401859.5,4578778 5401829.5,4578788 5401819.5,4578788
5401809.5,4578778 5401799.5,4578778 5401789.5,4578768 5401779.5,4578778
5401769.5,4578778 5401759.5,4578768 5401749.5,4578778 5401739.5,4578798
5401739.5,4578798 5401729.5,4578808 5401719.5,4578818 5401719.5,4578828
5401709.5,4578838 5401709.5,4578848 5401699.5,4578858 5401699.5,4578878
5401679.5,4578888 5401679.5,4578918 5401649.5,4578928 5401649.5,4578928
5401639.5,4579008 5401559.5,4579008 5401539.5,4579018 5401529.5,4579018
5401489.5,4579008 5401479.5,4579028 5401459.5,4579028 5401449.5,4579038
5401439.5,4579038 5401409.5,4579048 5401399.5,4579048 5401379.5,4579058
5401369.5,4579058 5401349.5,4579068 5401339.5,4579068 5401269.5,4579058
5401259.5,4579058 5401229.5,4579068 5401219.5,4579058
5401209.5,4579053.5 5401198,4579053.5 5401178,4579073.5
5401158,4579073.5 5401138,4579103.5 5401108,4579093.5 5401098,4579093.5
5401088,4579103.5 5401078,4579093.5 5401068,4579093.5 5401058,4579073.5
5401038,4579083.5 5401028,4579083.5 5400998,4579093.5 5400988,4579093.5
5400978,4579093.5 5400928,4579083.5 5400918,4579083.5 5400908,4579073.5
5400898,4579073.5 5400838,4579083.5 5400828,4579083.5 5400788,4579093.5
5400778,4579093.5 5400768,4579103.5 5400758,4579103.5 5400748,4579093.5
5400738,4579093.5 5400728,4579083.5 5400718,4579083.5 5400688,4579073.5
5400678,4579073.5 5400608,4579083.5 5400598,4579083.5 5400508,4579073.5
5400498,4579073.5 5400428,4579083.5 5400418,4579083.5 5400398,4579093.5
5400388,4579093.5 5400368,4579103.5 5400358,4579103.5 5400348,4579113.5
5400338,4579113.5 5400308,4579133.5 5400288,4579133.5 5400278,4579153.5
5400258,4579153.5 5400228,4579163.5 5400218,4579163.5 5400198,4579183.5
5400178,4579183.5 5400168,4579193.5 5400158,4579193.5 5400118,4579203.5
5400108,4579203.5 5399978,4579183.5 5399958,4579183.5 5399948,4579193.5
5399938,4579173.5 5399938,4579163.5 5399928,4579163.5 5399918,4579153.5
5399908,4579153.5 5399838,4579163.5 5399828,4579163.5 5399818,4579103.5
5399758,4579103.5 5399748,4579073.5 5399718,4579073.5 5399708,4579063.5
5399698,4579053.5 5399698,4579013.5 5399658,4579013.5 5399628,4579003.5
5399618,4579003.5 5399598,4578983.5 5399578,4578973.5 5399578,4578963.5
5399568,4578903.5 5399568,4578893.5 5399558,4578863.5 5399558,4578853.5
5399568,4578843.5 5399568,4578803.5 5399608,4578793.5 5399608,4578783.5
5399598,4578793.5 5399588,4578793.5 5399578,4578783.5 5399578,4578753.5
5399608,4578733.5 5399608,4578723.5 5399618,4578693.5 5399618,4578683.5
5399608,4578673.5 5399608,4578653.5 5399588,4578643.5 5399588,4578633.5
5399578,4578633.5 5399568,4578623.5 5399558,4578623.5 5399548,4578603.5
5399528,4578603.5 5399498,4578593.5 5399498,4578573.5 5399478,4578573.5
5399438,4578583.5 5399428,4578583.5 5399398,4578593.5 5399388,4578593.5
5399368,4578613.5 5399348,4578613.5 5399338,4578633.5 5399318,4578643.5
5399328,4578653.5 5399328,4578663.5 5399338,4578683.5 5399338,4578703.5
5399318,4578733.5 5399318,4578743.5 5399308,4578753.5 5399308,4578763.5
5399298,4578773.5 5399298,4578773.5 5399288,4578793.5 5399268,4578803.5
5399268,4578823.5 5399248,4578833.5 5399248,4578863.5 5399218,4578883.5
5399218,4578893.5 5399208,4578923.5 5399208,4578953.5 5399178,4578953.5
5399168,4578943.5 5399158,4578943.5 5399148,4578933.5 5399138,4578937.5
5399126.5,4578947.5 5399126.5,4578957.5 5399116.5,4578967.5
5399116.5,4578977.5 5399106.5,4578987.5 5399106.5,4579007.5
5399086.5,4579017.5 5399086.5,4579037.5 5399066.5,4579047.5
5399066.5,4579057.5 5399056.5,4579067.5 5399056.5,4579087.5
5399036.5,4579097.5 5399036.5,4579117.5 5399016.5,4579127.5
5399016.5,4579167.5 5398976.5,4579157.5 5398966.5,4579167.5
5398956.5,4579177.5 5398966.5,4579167.5 5398976.5,4579177.5
5398976.5,4579197.5 5398956.5,4579207.5 5398956.5,4579237.5
5398926.5,4579237.5 5398916.5,4579247.5 5398906.5,4579227.5
5398886.5,4579227.5 5398876.5,4579237.5 5398866.5,4579247.5
5398876.5,4579267.5 5398876.5,4579277.5 5398886.5,4579297.5
5398866.5,4579297.5 5398856.5,4579347.5 5398806.5,4579347.5
5398796.5,4579377.5 5398766.5,4579387.5 5398766.5,4579407.5
5398746.5,4579417.5 5398746.5,4579457.5 5398706.5,4579457.5
5398696.5,4579487.5 5398666.5,4579517.5 5398666.5,4579537.5
5398646.5,4579547.5 5398646.5,4579587.5 5398606.5,4579597.5
5398606.5,4579607.5 5398596.5,4579617.5 5398596.5,4579617.5
5398586.5,4579627.5 5398576.5,4579627.5 5398566.5,4579637.5
5398556.5,4579647.5 5398556.5,4579657.5 5398546.5,4579667.5
5398546.5,4579677.5 5398536.5,4579687.5 5398536.5,4579697.5
5398526.5,4579707.5 5398526.5,4579717.5 5398516.5,4579727.5
5398516.5,4579737.5 5398506.5,4579737.5 5398496.5,4579757.5
5398476.5,4579767.5 5398486.5,4579777.5 5398486.5,4579787.5
5398476.5,4579807.5 5398476.5,4579817.5 5398466.5,4579827.5
5398466.5,4579892 5398402,4579995 5398344.5,4580019 5398356,4580023
5398363.5,4580025.5 5398360.5,4580016.5 5398338.5,4580059.5
5398297.5,4580100.5 5398270.5,4580142 5398250,4580170 5398231.5,4580234
5398202,4580237.5 5398208,4580229 5398217.5,4580265.5 5398229,4580290.5
5398208,4580328.5 5398160,4580347 5398133,4580345.5 5398118.5,4580331.5
5398108,4580309 5398107.5,4580283.5 5398120,4580244.5 5398142.5,4580233
5398147.5,4580209 5398123.5,4580209.5 5398116.5,4580249.5
5398061,4580277.5 5398033,4580296.5 5398023.5,4580310
5398027.5,4580318.5 5398039,4580313 5398053,4580313 5398063,4580325
5398074.5,4580343 5398079.5,4580356 5398073,4580367.5 5398060.5,4580370
5398043,4580380 5398032,4580403 5398027.5,4580417.5 5398019.5,4580424.5
5398007,4580426 5397994.5,4580432.5 5397993,4580446.5 5398026.5,4580461
5398041.5,4580506 5398058,4580518 5398052,4580534 5398048,4580580
5398030.5,4580589 5398029.5,4580601 5398035.5,4580605 5398046,4580612
5398056,4580619.5 5398060.5,4580635.5 5398051,4580642 5398014,4580653.5
5398009.5,4580661 5398011,4580674 5398010,4580695.5 5398002,4580734.5
5397980,4580756 5397974,4580797 5397967,4580827.5 5397921,4580842
5397915,4580862.5 5397918.5,4580892.5 5397933.5,4580914 5397941,4580943
5397945.5,4580982.5 5397945,4581012.5 5397927.5,4581048.5
5397900.5,4581074.5 5397892,4581093.5 5397892.5,4581106
5397884.5,4581113.5 5397826,4581109 5397813.5,4581088.5 5397808,4581078
5397801.5,4581076 5397789.5,4581089 5397772.5,4581115.5 5397753,4581127
5397741,4581124 5397712,4581143 5397716,4581163 5397713.5,4581172.5
5397698,4581162.5 5397617.5,4581152 5397561.5,4581143 5397539,4581172
5397561,4581217.5 5397577.5,4581291 5397565,4581319 5397547.5,4581342
5397558,4581358 5397561.5,4581472.5 5397480,4581517 5397360,4581567.5
5397247.5,4581577.5 5397237.5,4581597.5 5397237.5,4581607.5
5397227.5,4581607.5 5397187.5,4581617.5 5397177.5,4581607.5
5397167.5,4581607.5 5397147.5,4581617.5 5397137.5,4581617.5
5397107.5,4581627.5 5397097.5,4581637.5 5397107.5,4581647.5
5397107.5,4581667.5 5397087.5,4581667.5 5397077.5,4581677.5
5397067.5,4581667.5 5397067.5,4581657.5 5397057.5,4581667.5
5397047.5,4581657.5 5397037.5,4581667.5 5397027.5,4581677.5
5397027.5,4581687.5 5397037.5,4581707.5 5397017.5,4581707.5
5397007.5,4581727.5 5396987.5,4581727.5 5396977.5,4581737.5
5396967.5,4581737.5 5396957.5,4581747.5 5396947.5,4581747.5
5396937.5,4581767.5 5396917.5,4581777.5 5396927.5,4581777.5
5396947.5,4581767.5 5396957.5,4581767.5 5396967.5,4581797.5
5396937.5,4581797.5 5396927.5,4581807.5 5396917.5,4581807.5
5396907.5,4581837.5 5396877.5,4581837.5 5396857.5,4581857.5
5396837.5,4581857.5 5396817.5,4581867.5 5396807.5,4581857.5
5396807.5,4581847.5 5396817.5,4581837.5 5396807.5,4581867.5
5396777.5,4581867.5 5396767.5,4581887.5 5396747.5,4581897.5
5396757.5,4581887.5 5396767.5,4581887.5 5396787.5,4581897.5
5396777.5,4581897.5 5396767.5,4581907.5 5396757.5,4581907.5
5396747.5,4581917.5 5396737.5,4581917.5 5396727.5,4581927.5
5396717.5,4581927.5 5396707.5,4581937.5 5396697.5,4581937.5
5396687.5,4581947.5 5396677.5,4581947.5 5396667.5,4581957.5
5396657.5,4581957.5 5396617.5,4581977.5 5396597.5,4581977.5
5396577.5,4582007.5 5396547.5,4582007.5 5396527.5,4582017.5
5396517.5,4582017.5 5396497.5,4582027.5 5396487.5,4582027.5
5396477.5,4582037.5 5396467.5,4582037.5 5396457.5,4582057.5
5396437.5,4582057.5 5396427.5,4582067.5 5396417.5,4582057.5
5396417.5,4582047.5 5396407.5,4582057.5 5396397.5,4582057.5
5396377.5,4582047.5 5396367.5,4582047.5 5396327.5,4582057.5
5396317.5,4582077.5 5396317.5,4582087.5 5396307.5,4582097.5
5396307.5,4582097.5 5396257.5,4582077.5 5396237.5,4582077.5
5396217.5,4582087.5 5396207.5,4582087.5 5396187.5,4582117.5
5396157.5,4582117.5 5396147.5,4582127.5 5396137.5,4582107.5
5396117.5,4582107.5 5396077.5,4582117.5 5396067.5,4582127.5
5396067.5,4582127.5 5396047.5,4582137.5 5396037.5,4582137.5
5395977.5,4582127.5 5395967.5,4582127.5 5395957.5,4582117.5
5395947.5,4582117.5 5395927.5,4582127.5 5395917.5,4582137.5
5395917.5,4582137.5 5395907.5,4582147.5 5395897.5,4582147.5
5395887.5,4582137.5 5395877.5,4582137.5 5395867.5,4582127.5
5395857.5,4582137.5 5395847.5,4582137.5 5395817.5,4582147.5
5395807.5,4582147.5 5395797.5,4582157.5 5395787.5,4582177.5
5395787.5,4582184.5 5395792,4582197.5 5395807.5,4582224.5
5395833.5,4582227.5 5395827.5,4582227.5 5395817.5,4582207.5
5395797.5,4582197 5395789.5,4582183.5 5395781.5,4582177.5
5395767.5,4582157.5 5395747.5,4582157.5 5395737.5,4582137.5
5395737.5,4582127.5 5395727.5,4582137.5 5395717.5,4582178
5395717,4582146 5395459.5,4582135 5395397,4582129 5395345,4582126
5395225,4582098 5395226.5,4582100.5 5395209.5,4582129
5395206.5,4582128.5 5395131,4582132.5 5395028,4582201.5
5395035,4582205.5 5394881,4582343 5394635,4582341.5 5394529.5,4582380
5394409.5,4582465 5394398,4582559.5 5394354.5,4582646
5394328.5,4582663.5 5394312,4582666.5 5394293.5,4582670 5394292,4582685
5394304,4582699.5 5394295,4582706 5394281,4582713 5394276,4582720
5394274.5,4582731 5394276,4582735 5394274.5,4582742.5 5394264,4582752
5394256.5,4582753.5 5394248.5,4582752 5394246,4582738
5394241.5,4582736.5 5394238.5,4582738 5394234.5,4582744.5
5394229,4582754.5 5394239.5,4582762.5 5394232.5,4582764 5394224,4582754
5394209,4582751.5 5394195.5,4582754.5 5394189.5,4582781
5394187.5,4582787.5 5394181.5,4582796 5394167,4582798.5 5394156,4582811
5394132,4582807 5394109,4582802.5 5394103,4582794.5 5394101.5,4582793
5394100,4582794 5394090.5,4582791.5 5394085.5,4582785 5394079,4582778
5394083.5,4582756.5 5394092.5,4582751.5 5394097.5,4582730.5
5394069.5,4582737.5 5394061.5,4582801 5394048.5,4582807.5
5394044,4582812 5394037,4582815.5 5394025.5,4582818 5393999,4582817.5
5393975,4582804 5393932.5,4582800 5393915.5,4582799 5393885.5,4582786
5393878,4582785 5393874.5,4582791.5 5393860,4582794.5 5393857,4582807
5393855.5,4582810.5 5393854,4582811.5 5393850,4582810.5
5393843.5,4582807 5393835.5,4582808 5393829.5,4582812
5393824.5,4582819.5 5393810.5,4582829.5 5393797.5,4582836.5
5393782.5,4582838 5393773,4582827 5393748,4582828.5 5393742,4582838.5
5393730.5,4582826.5 5393726.5,4582825 5393722.5,4582832.5
5393702,4582838.5 5393693.5,4582860.5 5393653,4582878 5393601,4582882.5
5393596.5,4582883 5393587.5,4582889.5 5393569.5,4582897 5393563,4582898
5393557,4582913 5393537.5,4582913.5 5393532,4582933.5 5393480,4582947.5
5393453,4582959 5393441,4582973.5 5393438,4582972 5393434.5,4582958
5393428,4582964 5393400,4582966.5 5393372,4582976 5393344,4582976.5
5393333,4582982.5 5393326,4582988.5 5393321.5,4583022
5393242.5,4583026.5 5393238.5,4583047.5 5393207.5,4583067.5
5393156,4583106.5 5393212.5,4583113.5 5393237,4583129 5393249.5,4583134
5393257.5,4583138 5393268,4583172.5 5393286.5,4583179 5393297.5,4583180
5393312.5,4583177 5393319.5,4583198.5 5393332.5,4583259
5393290,4583241.5 5393269,4583248 5393262.5,4583287.5 5393253,4583329
5393213.5,4583329 5393183.5,4583319 5393173.5,4583319 5393163.5,4583309
5393153.5,4583299 5393153.5,4583289 5393143.5,4583289 5393073.5,4583259
5393043.5,4583259 5392983.5,4583269 5392973.5,4583269 5392953.5,4583279
5392943.5,4583279 5392933.5,4583289 5392923.5,4583289 5392913.5,4583269
5392893.5,4583279 5392883.5,4583299 5392903.5,4583309 5392903.5,4583299
5392893.5,4583329 5392863.5,4583339 5392863.5,4583379 5392823.5,4583379
5392813.5,4583389 5392803.5,4583409 5392803.5,4583419 5392813.5,4583439
5392793.5,4583479 5392793.5,4583489 5392783.5,4583519 5392783.5,4583539
5392763.5,4583539 5392743.5,4583559 5392723.5,4583609 5392723.5,4583609
5392713.5,4583649 5392673.5,4583649 5392663.5,4583659
5392653.5,4583674.5 5392546.5,4583650.5 5392536.5,4583597
5392532.5,4583589.5 5392525,4583617 5392521.5,4583626 5392513.5,4583710
5392515,4583740 5392485,4583764.5 5392485,4583779.5 5392459.5,4583800
5392457.5,4583833 5392444,4583846.5 5392431.5,4583888.5 5392422,4583952
5392417,4584010 5392421.5,4584069 5392412,4584112.5 5392411.5,4584131
5392417.5,4584159 5392435,4584179 5392441.5,4584247 5392416.5,4584274
5392413,4584340.5 5392359,4584350 5392361,4584357.5 5392338,4584384
5392324,4584423.5 5392322,4584495.5 5392310.5,4584512 5392294,4584532
5392294.5,4584547 5392283,4584561.5 5392279.5,4584573.5
5392268.5,4584594.5 5392260.5,4584667 5392215,4584706.5
5392204,4584732.5 5392203.5,4584755.5 5392166,4584849
5392096.5,4584905.5 5392060,4584943.5 5392020.5,4584943
5392000.5,4584972.5 5391963,4585036 5391956,4585048.5
5391953.5,4585169.5 5391835.5,4585194.5 5391805.5,4585245.5
5391756.5,4585313 5391702,4585341.5 5391681,4585387 5391651.5,4585391
5391647.5,4585391 5391642,4585403 5391634,4585404.5 5391619.5,4585413.5
5391605.5,4585427.5 5391593.5,4585442 5391593.5,4585456.5
5391588.5,4585482.5 5391560,4585485 5391550,4585491.5 5391545,4585508.5
5391524.5,4585520 5391514,4585528 5391511,4585564.5 5391479,4585631.5
5391427,4585633 5391422.5,4585666 5391398.5,4585673 5391390.5,4585771.5
5391299.5,4585775.5 5391299,4585787.5 5391276.5,4585835.5
5391230.5,4585849.5 5391230,4585923.5 5391154,4585940.5
5391138,4585955.5 5391120.5,4585953 5391119,4585943 5391122,4585943.5
5391118,4585946.5 5391112.5,4585959 5391109.5,4585968 5391104.5,4586002
5391072.5,4586019.5 5391053.5,4586043.5 5391034,4586062
5391021.5,4586096 5391002,4586115.5 5390997.5,4586128 5390989.5,4586228
5390904,4586257 5390877,4586275 5390859,4586385 5390718.5,4586408
5390691,4586431.5 5390666.5,4586447.5 5390652.5,4586457.5
5390647,4586460 5390643.5,4586452 5390637,4586451 5390634.5,4586467
5390614,4586477 5390606,4586518 5390591.5,4586530 5390579,4586560
5390554,4586586 5390529.5,4586655 5390447.5,4586669.5 5390434,4586674
5390420.5,4586705 5390390.5,4586713.5 5390395.5,4586709
5390387.5,4586716 5390364,4586718 5390345.5,4586736.5 5390330.5,4586749
5390327.5,4586764 5390327.5,4586801.5 5390312.5,4586821
5390280.5,4586850.5 5390256,4586908 5390239,4586930 5390239,4586992
5390204,4587000 5390189.5,4587032 5390177,4587116.5 5390118,4587135.5
5390077,4587153.5 5390053.5,4587090.5 5389990.5,4587089.163
5389989.633,4586393.799 5390252.837,4586274 5390369.5,4586201.5
5390431,4586115.5 5390491,4585950.5 5390583.5,4585880 5390631,4585758
5390722.5,4585592 5390866,4585409.5 5391021.5,4585402 5391044,4585386.5
5391045,4585314 5391099,4585326.5 5391117,4585313.5 5391132,4585303.5
5391135,4585300 5391146,4585274.5 5391135,4585215.5 5391178,4585133
5391261,4585064.5 5391342,4584995.5 5391410,4584896.5 5391496,4584805.5
5391564,4584726 5391614,4584661.5 5391647.5,4584559.5 5391687.5,4584441
5391720,4584323.5 5391731,4584031.5 5391722.5,4583946.5
5391724.5,4583838.5 5391739,4583682 5391790.5,4583583 5391835.5,4583530
5391864,4583533.016 5391863.339,4583490.575 5391889.606,4583444.425
5391914.124,4583323.282 5391974.695,4583256.942 5392002.097,4583215.119
5392022.287,4583160.316 5392045.362,4583099.744 5392068.437,4582987.254
5392098.723,4582912.26 5392108.818,4582850.247 5392114.587,4582770.927
5392116.029,4582719.5 5392112.266,4582719.5 5392085,4582709.5
5392075,4582699.5 5392075,4582679.5 5392055,4582679.5 5392045,4582639.5
5392045,4582629.5 5392035,4582579.5 5392035,4582559.5 5392055,4582539.5
5392055,4582529.5 5392045,4582529.5 5392035,4582509.5 5392035,4582499.5
5392045,4582479.5 5392045,4582469.5 5392035,4582459.5 5392035,4582449.5
5392025,4582419.5 5392025,4582409.5 5392015,4582359.5 5392015,4582349.5
5392005,4582339.5 5392015,4582319.5 5392015,4582309.5 5392025,4582299.5
5392015,4582299.5 5392005,4582279.5 5392005,4582269.5 5392015,4582239.5
5392015,4582229.5 5392005,4582219.5 5392015,4582209.5 5392015,4582209.5
5392025,4582199.5 5392035,4582189.5 5392035,4582189.5 5392045,4582169.5
5392065,4582159.5 5392065,4582149.5 5392055,4582139.5 5392055,4582109.5
5392085,4582099.5 5392085,4582089.5 5392095,4582079.5 5392095,4582059.5
5392115,4582049.5 5392105,4582069.5 5392085,4582079.5 5392075,4582089.5
5392075,4582119.5 5392045,4582129.5 5392045,4582149.5 5392025,4582139.5
5392015,4582139.5 5392005,4582109.5 5392005,4582099.5 5391995,4582089.5
5391995,4582079.5 5391985,4582059.5 5391985,4582039.5 5392005,4582029.5
5391995,4582029.5 5391985,4582009.5 5391985,4582009.5 5392025,4581999.5
5392035,4581989.5 5392025,4581979.5 5392025,4581959.5 5392045,4581949.5
5392035,4581949.5 5392025,4581919.5 5392025,4581919.5 5392045,4581929.5
5392035,4581939.5 5392035,4581949.5 5392045,4581949.5 5392055,4581939.5
5392065,4581929.5 5392065,4581919.5 5392075,4581889.5 5392075,4581879.5
5392065,4581879.5 5392035,4581869.5 5392035,4581859.5 5392025,4581869.5
5392015,4581879.5 5392015,4581869.5 5392005,4581889.5 5391985,4581889.5
5391975,4581899.5 5391965,4581889.5 5391955,4581879.5 5391955,4581869.5
5391965,4581829.5 5391965,4581819.5 5391955,4581799.5 5391955,4581779.5
5391935,4581769.5 5391935,4581759.5 5391925,4581749.5 5391925,4581739.5
5391915,4581729.5 5391915,4581719.5 5391905,4581699.5 5391905,4581689.5
5391895,4581679.5 5391895,4581669.5 5391885,4581649.5 5391885,4581639.5
5391875,4581619.5 5391875,4581609.5 5391885,4581599.5 5391885,4581589.5
5391895,4581569.5 5391895,4581569.5 5391905,4581559.5 5391915,4581569.5
5391925,4581559.5 5391935,4581549.5 5391935,4581539.5 5391925,4581509.5
5391955,4581499.5 5391955,4581469.5 5391985,4581439.5 5391985,4581429.5
5391995,4581419.5 5391995,4581409.5 5392005,4581379.5 5392005,4581369.5
5392015,4581349.5 5392015,4581329.5 5392035,4581319.5 5392035,4581299.5
5392055,4581289.5 5392055,4581279.5 5392065,4581269.5 5392065,4581259.5
5392075,4581249.5 5392075,4581239.5 5392085,4581219.5 5392085,4581209.5
5392095,4581179.5 5392095,4581169.5 5392105,4581129.5 5392105,4581119.5
5392115,4581089.5 5392115,4581079.5 5392105,4581039.5 5392105,4581029.5
5392095,4581029.5 5392085,4581019.5 5392075,4580979.5 5392075,4580969.5
5392065,4580949.5 5392065,4580899.5 5392015,4580899.5 5391955,4580889.5
5391965,4580879.5 5391955,4580879.5 5391945,4580819.5 5391945,4580809.5
5391955,4580749.5 5391955,4580739.5 5391965,4580679.5 5391965,4580679.5
5391975,4580669.5 5391985,4580669.5 5391995,4580679.5 5392005,4580689.5
5392005,4580699.5 5392015,4580689.5 5392025,4580669.5 5392025,4580669.5
5392035,4580699.5 5392035,4580709.5 5392045,4580709.5 5392055,4580719.5
5392055,4580729.5 5392065,4580739.5 5392065,4580749.5 5392075,4580769.5
5392075,4580779.5 5392085,4580799.5 5392085,4580809.5 5392095,4580819.5
5392095,4580829.5 5392105,4580859.5 5392105,4580869.5 5392115,4580879.5
5392115,4580889.5 5392125,4580909.5 5392125,4580919.5 5392135,4580919.5
5392175,4580939.5 5392195,4580939.5 5392205,4580929.5 5392215,4580929.5
5392225,4580889.5 5392265,4580879.5 5392265,4580869.5 5392275,4580859.5
5392275,4580849.5 5392285,4580839.5 5392285,4580829.5 5392295,4580819.5
5392295,4580779.5 5392335,4580759.5 5392335,4580719.5 5392375,4580699.5
5392375,4580689.5 5392385,4580619.5 5392385,4580609.5 5392375,4580569.5
5392375,4580559.5 5392385,4580539.5 5392365,4580529.5 5392365,4580519.5
5392355,4580479.5 5392355,4580469.5 5392345,4580449.5 5392345,4580439.5
5392335,4580229.5 5392335,4580209.5 5392355,4580199.5 5392355,4580179.5
5392375,4580159.5 5392375,4580149.5 5392385,4580129.5 5392385,4580119.5
5392395,4580089.5 5392395,4580079.5 5392385,4580059.5 5392385,4580049.5
5392395,4580039.5 5392395,4580009.5 5392425,4579999.5 5392415,4579969.5
5392415,4579959.5 5392425,4579919.5 5392425,4579909.5 5392415,4579889.5
5392415,4579879.5 5392405,4579859.5 5392405,4579849.5 5392395,4579839.5
5392395,4579829.5 5392385,4579829.5 5392375,4579819.5 5392365,4579819.5
5392325,4579809.5 5392325,4579799.5 5392335,4579799.5 5392345,4579809.5
5392355,4579809.5 5392385,4579789.5 5392405,4579769.5 5392405,4579759.5
5392395,4579759.5 5392405,4579749.5 5392415,4579739.5 5392415,4579729.5
5392425,4579699.5 5392425,4579679.5 5392445,4579679.5 5392455,4579649.5
5392485,4579649.5 5392505,4579639.5 5392515,4579639.5 5392525,4579629.5
5392535,4579609.5 5392535,4579609.5 5392565,4579599.5 5392575,4579579.5
5392555,4579579.5 5392545,4579569.5 5392535,4579559.5 5392535,4579559.5
5392545,4579539.5 5392565,4579539.5 5392585,4579549.5 5392595,4579539.5
5392605,4579529.5 5392605,4579529.5 5392615,4579539.5 5392625,4579539.5
5392645,4579559.5 5392625,4579569.5 5392635,4579569.5 5392645,4579549.5
5392665,4579539.5 5392655,4579539.5 5392665,4579529.5 5392675,4579519.5
5392675,4579519.5 5392685,4579509.5 5392695,4579499.5 5392685,4579479.5
5392685,4579469.5 5392675,4579469.5 5392655,4579459.5 5392645,4579469.5
5392635,4579479.5 5392635,4579479.5 5392615,4579459.5 5392615,4579459.5
5392625,4579449.5 5392635,4579439.5 5392635,4579439.5 5392685,4579449.5
5392695,4579449.5 5392705,4579439.5 5392715,4579429.5 5392715,4579399.5
5392745,4579369.5 5392745,4579369.5 5392755,4579349.5 5392775,4579339.5
5392775,4579329.5 5392765,4579329.5 5392745,4579319.5 5392735,4579319.5
5392745,4579309.5 5392755,4579289.5 5392755,4579279.5 5392745,4579269.5
5392745,4579269.5 5392755,4579249.5 5392775,4579239.5 5392775,4579219.5
5392795,4579139.5 5392795,4579068 5392807,4579018 5392807,4579008
5392817,4578988 5392817,4578978 5392827,4578958 5392827,4578948
5392837,4578938 5392837,4578928 5392847,4578918 5392847,4578908
5392857,4578898 5392857,4578888 5392867,4578878 5392867,4578858
5392887,4578848 5392887,4578838 5392897,4578828 5392897,4578808
5392917,4578788 5392917,4578778 5392927,4578768 5392927,4578758
5392937,4578748 5392937,4578738 5392947,4578728 5392947,4578718
5392957,4578708 5392957,4578688 5392977,4578678 5392977,4578668
5392987,4578658 5392987,4578638 5393007,4578628 5393007,4578608
5393027,4578598 5393027,4578548 5393077,4578538 5393077,4578408
5393207,4578408 5393217,4578328 5393297,4578328 5393307,4578238
5393397,4578238 5393407,4578218 5393427,4578218 5393437,4578208
5393447,4578198 5393447,4578188 5393457,4578188 5393467,4578198
5393477,4578198 5393487,4578138 5393547,4578118 5393547,4578088
5393577,4578078 5393577,4578078 5393587,4578048 5393617,4578048
5393627,4578008 5393667,4578008 5393677,4577978 5393707,4577978
5393717,4577948 5393747,4577948 5393757,4577908 5393797,4577908
5393807,4577878 5393837,4577878 5393847,4577848 5393877,4577848
5393887,4577808 5393927,4577808 5393937,4577778 5393967,4577778
5393977,4577748 5394007,4577748 5394027,4577758 5394037,4577758
5394067,4577768 5394077,4577768 5394127,4577778 5394137,4577778
5394157,4577788 5394167,4577788 5394187,4577798 5394197,4577798
5394207,4577808 5394217,4577808 5394247,4577848 5394287,4577858
5394287,4577878 5394307,4577878 5394327,4577888 5394337,4577898
5394337,4577908 5394347,4577918 5394357,4577918 5394367,4577908
5394377,4577908 5394417,4577898 5394427,4577898 5394447,4577888
5394457,4577888 5394477,4577858 5394507,4577848 5394497,4577848
5394477,4577838 5394487,4577838 5394497,4577828 5394507,4577828
5394517,4577808 5394537,4577788 5394537,4577778 5394547,4577778
5394557,4577768 5394567,4577758 5394567,4577748 5394577,4577738
5394577,4577738 5394587,4577718 5394607,4577708 5394607,4577648
5394667,4577648 5394677,4577668 5394677,4577678 5394687,4577668
5394697,4577678 5394697,4577688 5394707,4577688 5394697,4577718
5394667,4577738 5394667,4577748 5394677,4577728 5394697,4577728
5394707,4577718 5394717,4577718 5394737,4577728 5394747,4577738
5394747,4577758 5394727,4577768 5394727,4577788 5394707,4577798
5394707,4577808 5394697,4577818 5394697,4577828 5394707,4577828
5394787,4577838 5394797,4577838 5394807,4577828 5394817,4577828
5394827,4577838 5394837,4577838 5394867,4577828 5394877,4577828
5394917,4577818 5394927,4577818 5394957,4577828 5394957,4577828
5394937,4577858 5394907,4577868 5394917,4577868 5394927,4577878
5394937,4577868 5394947,4577878 5394957,4577882.5 5394969,4577882.5
5395039,4577892.5 5395049,4577892.5 5395069,4577882.5 5395079,4577892.5
5395089,4577892.5 5395099,4577902.5 5395109,4577902.5 5395119,4577912.5
5395129,4577912.5 5395139,4577932.5 5395159,4577932.5 5395169,4577942.5
5395179,4577942.5 5395189,4577932.5 5395199,4577932.5 5395209,4577922.5
5395219,4577912.5 5395229,4577902.5 5395229,4577902.5 5395239,4577892.5
5395249,4577852.5 5395249,4577852.5 5395289,4577832.5 5395309,4577822.5
5395309,4577782.5 5395349,4577772.5 5395349,4577772.5 5395359,4577762.5
5395369,4577762.5 5395379,4577752.5 5395389,4577752.5 5395399,4577742.5
5395409,4577722.5 5395409,4577712.5 5395399,4577702.5 5395399,4577682.5
5395379,4577672.5 5395379,4577662.5 5395369,4577652.5 5395369,4577642.5
5395359,4577642.5 5395299,4577632.5 5395289,4577632.5 5395259,4577612.5
5395239,4577612.5 5395229,4577602.5 5395229,4577592.5 5395219,4577592.5
5395209,4577562.5 5395209,4577552.5 5395199,4577502.5 5395199,4577492.5
5395189,4577482.5 5395189,4577472.5 5395179,4577472.5 5395169,4577442.5
5395139,4577442.5 5395129,4577452.5 5395089,4577452.5 5395079,4577462.5
5395069,4577462.5 5395049,4577472.5 5395039,4577472.5 5395019,4577482.5
5395009,4577482.5 5394999,4577492.5 5394989,4577492.5 5394979,4577512.5
5394959,4577518 5394947,4577518 5394937,4577548 5394907,4577548
5394897,4577568 5394877,4577568 5394867,4577598 5394837,4577598
5394827,4577608 5394817,4577608 5394807,4577618 5394797,4577618
5394787,4577598 5394807,4577588 5394807,4577588 5394837,4577578
5394847,4577568 5394847,4577568 5394857,4577558 5394867,4577548
5394867,4577548 5394877,4577538 5394887,4577528 5394887,4577528
5394897,4577508 5394917,4577498 5394917,4577498 5394937,4577492.5
5394949,4577472.5 5394949,4577472.5 5394959,4577462.5 5394969,4577442.5
5394969,4577442.5 5394989,4577432.5 5394999,4577452.5 5395019,4577452.5
5395059,4577442.5 5395069,4577442.5 5395099,4577439.5
5395110.5,4577435.5 5395115,4577422.5 5395109,4577412.5
5395109,4577402.5 5395099,4577382.5 5395119,4577372.5 5395119,4577382.5
5395129,4577372.5 5395139,4577362.5 5395129,4577362.5 5395169,4577352.5
5395179,4577352.5 5395189,4577332.5 5395209,4577322.5 5395209,4577322.5
5395219,4577312.5 5395229,4577312.5 5395249,4577302.5 5395259,4577302.5
5395289,4577322.5 5395269,4577352.5 5395299,4577352.5 5395359,4577362.5
5395369,4577352.5 5395379,4577362.5 5395379,4577372.5 5395389,4577392.5
5395389,4577422.5 5395419,4577422.5 5395429,4577412.5 5395439,4577412.5
5395449,4577402.5 5395459,4577382.5 5395459,4577372.5 5395469,4577372.5
5395479,4577382.5 5395489,4577392.5 5395479,4577402.5 5395489,4577402.5
5395479,4577442.5 5395439,4577442.5 5395419,4577452.5 5395409,4577462.5
5395409,4577472.5 5395399,4577482.5 5395399,4577492.5 5395409,4577502.5
5395409,4577532.5 5395439,4577532.5 5395449,4577522.5 5395459,4577502.5
5395459,4577502.5 5395469,4577472.5 5395499,4577472.5 5395509,4577462.5
5395519,4577512.5 5395519,4577522.5 5395529,4577562.5 5395529,4577572.5
5395539,4577562.5 5395549,4577532.5 5395549,4577532.5 5395569,4577542.5
5395579,4577552.5 5395579,4577572.5 5395599,4577572.5 5395619,4577582.5
5395629,4577582.5 5395659,4577562.5 5395679,4577562.5 5395689,4577572.5
5395699,4577522.5 5395749,4577522.5 5395779,4577512.5 5395789,4577492.5
5395789,4577482.5 5395799,4577472.5 5395799,4577452.5 5395819,4577432.5
5395819,4577422.5 5395809,4577402.5 5395809,4577392.5 5395819,4577362.5
5395819,4577362.5 5395869,4577382.5 5395869,4577402.5 5395849,4577422.5
5395849,4577432.5 5395859,4577412.5 5395879,4577402.5 5395879,4577372.5
5395909,4577362.5 5395909,4577252.5 5396019,4577252.5 5396029,4577242.5
5396039,4577212.5 5396039,4577212.5 5396059,4577202.5 5396069,4577202.5
5396079,4577142 5396138.5,4577142 5396148.5,4577002 5396288.5,4577002
5396298.5,4576992 5396308.5,4576992 5396318.5,4576932 5396378.5,4576932
5396388.5,4576902 5396418.5,4576902 5396428.5,4576892 5396438.5,4576892
5396448.5,4576872 5396468.5,4576872 5396478.5,4576852 5396498.5,4576852
5396508.5,4576832 5396528.5,4576832 5396538.5,4576822 5396548.5,4576812
5396548.5,4576802 5396558.5,4576792 5396548.5,4576792 5396518.5,4576802
5396508.5,4576802 5396498.5,4576812 5396488.5,4576812 5396478.5,4576822
5396468.5,4576822 5396438.5,4576802 5396458.5,4576802 5396478.5,4576772
5396508.5,4576772 5396518.5,4576762 5396528.5,4576762 5396548.5,4576752
5396558.5,4576752 5396568.5,4576742 5396578.5,4576732 5396578.5,4576722
5396588.5,4576682 5396588.5,4576672 5396598.5,4576642 5396598.5,4576612
5396568.5,4576612 5396558.5,4576582 5396528.5,4576572 5396528.5,4576562
5396538.5,4576562 5396548.5,4576572 5396558.5,4576572 5396568.5,4576562
5396578.5,4576552 5396578.5,4576552 5396588.5,4576532 5396608.5,4576482
5396608.5,4576462 5396588.5,4576442 5396588.5,4576432 5396578.5,4576432
5396558.5,4576422 5396558.5,4576412 5396568.5,4576412 5396578.5,4576402
5396588.5,4576392 5396588.5,4576392 5396598.5,4576382 5396608.5,4576372
5396598.5,4576372 5396578.5,4576382 5396568.5,4576392 5396568.5,4576392
5396538.5,4576492 5396438.5,4576522 5396438.5,4576542 5396418.5,4576542
5396408.5,4576552 5396398.5,4576582 5396398.5,4576572 5396388.5,4576572
5396378.5,4576562 5396368.5,4576552 5396378.5,4576542 5396368.5,4576542
5396358.5,4576512 5396358.5,4576502 5396348.5,4576522 5396328.5,4576532
5396328.5,4576542 5396318.5,4576542 5396308.5,4576552 5396298.5,4576552
5396288.5,4576562 5396278.5,4576562 5396268.5,4576572 5396258.5,4576592
5396258.5,4576612 5396238.5,4576612 5396218.5,4576622 5396208.5,4576632
5396208.5,4576642 5396198.5,4576632 5396198.5,4576622 5396188.5,4576632
5396178.5,4576662 5396178.5,4576722 5396118.5,4576722 5396108.5,4576752
5396078.5,4576762 5396078.5,4576792 5396048.5,4576802 5396048.5,4576812
5396058.5,4576812 5396068.5,4576802 5396078.5,4576802 5396088.5,4576792
5396098.5,4576802 5396108.5,4576802 5396118.5,4576782 5396138.5,4576772
5396138.5,4576752 5396158.5,4576742 5396158.5,4576742 5396168.5,4576722
5396188.5,4576712 5396188.5,4576712 5396228.5,4576702 5396238.5,4576682
5396238.5,4576662 5396258.5,4576652 5396258.5,4576632 5396278.5,4576632
5396288.5,4576622 5396298.5,4576622 5396358.5,4576632 5396368.5,4576682
5396368.5,4576702 5396388.5,4576712 5396388.5,4576722 5396398.5,4576762
5396398.5,4576782 5396378.5,4576772 5396368.5,4576772 5396358.5,4576802
5396328.5,4576812 5396328.5,4576782 5396298.5,4576782 5396248.5,4576772
5396238.5,4576772 5396228.5,4576782 5396218.5,4576802 5396218.5,4576812
5396208.5,4576822 5396208.5,4576852 5396238.5,4576852 5396258.5,4576872
5396278.5,4576872 5396288.5,4576882 5396288.5,4576882 5396268.5,4576892
5396258.5,4576892 5396248.5,4576902 5396238.5,4576912 5396238.5,4576912
5396218.5,4576932 5396198.5,4576932 5396178.5,4576942 5396168.5,4576952
5396178.5,4576962 5396178.5,4576952 5396168.5,4576952 5396158.5,4576962
5396148.5,4576982 5396148.5,4577002 5396128.5,4577002 5396108.5,4576992
5396108.5,4576982 5396098.5,4576982 5396078.5,4576972 5396068.5,4576972
5396058.5,4576962 5396048.5,4576962 5396028.5,4576952 5396018.5,4576952
5395988.5,4576942 5395988.5,4576922 5395968.5,4576922 5395948.5,4576912
5395938.5,4576932 5395918.5,4576932 5395908.5,4576952 5395888.5,4576952
5395838.5,4576942 5395828.5,4576942 5395818.5,4576932 5395808.5,4576932
5395798.5,4576912 5395778.5,4576912 5395768.5,4576882 5395768.5,4576882
5395778.5,4576872 5395788.5,4576872 5395798.5,4576862 5395808.5,4576862
5395818.5,4576842 5395838.5,4576832 5395828.5,4576822 5395828.5,4576812
5395818.5,4576812 5395808.5,4576822 5395798.5,4576822 5395788.5,4576842
5395768.5,4576852 5395768.5,4576872 5395748.5,4576882 5395748.5,4576882
5395738.5,4576892 5395728.5,4576887 5395715.5,4576900.5
5395703.5,4576912.5 5395709,4576912.5 5395719,4576922.5
5395729,4576922.5 5395739,4576932.5 5395749,4576932.5 5395759,4576942.5
5395769,4576942.5 5395779,4576962.5 5395799,4576962.5 5395809,4576972.5
5395819,4576972.5 5395829,4576982.5 5395829,4576992.5 5395819,4576992.5
5395799,4577002.5 5395789,4576992.5 5395779,4577012.5 5395759,4577012.5
5395749,4577082.5 5395679,4577072.5 5395669,4577082.5 5395659,4577082.5
5395649,4577072.5 5395649,4577062.5 5395639,4577052.5 5395639,4577042.5
5395629,4577032.5 5395629,4577022.5 5395619,4577012.5 5395619,4577002.5
5395609,4576992.5 5395609,4576982.5 5395599,4576972.5 5395599,4576962.5
5395589,4576952.5 5395589,4576944 5395581,4576952.5 5395569,4576962.5
5395569,4576992.5 5395539,4577022.5 5395539,4577032.5 5395549,4577042.5
5395549,4577052.5 5395559,4577042.5 5395569,4577032.5 5395569,4577042.5
5395579,4577042.5 5395589,4577072.5 5395559,4577082.5 5395559,4577092.5
5395549,4577132.5 5395549,4577132.5 5395539,4577152.5 5395519,4577152.5
5395509,4577162.5 5395499,4577162.5 5395479,4577172.5 5395469,4577172.5
5395459,4577182.5 5395449,4577182.5 5395439,4577172.5 5395449,4577162.5
5395439,4577162.5 5395429,4577152.5 5395429,4577142.5 5395419,4577122.5
5395419,4577112.5 5395409,4577092.5 5395409,4577082.5 5395399,4577072.5
5395409,4577062.5 5395399,4577052.5 5395399,4577022.5 5395429,4577022.5
5395439,4577002.5 5395459,4577002.5 5395469,4576992.5 5395479,4576982.5
5395479,4576982.5 5395489,4576972.5 5395499,4576962.5 5395499,4576962.5
5395509,4576952.5 5395519,4576952.5 5395539,4576942.5 5395549,4576922.5
5395549,4576912.5 5395559,4576912.5 5395569,4576922.5 5395569,4576933
5395575.5,4576934 5395581.5,4576922.5 5395589,4576902.5
5395589,4576882.5 5395609,4576872.5 5395609,4576862.5 5395619,4576862.5
5395639,4576872.5 5395649,4576872.5 5395659,4576892.5 5395679,4576891
5395704.5,4576882.5 5395709,4576862.5 5395689,4576862.5
5395679,4576852.5 5395669,4576822 5395698.5,4576802 5395698.5,4576802
5395718.5,4576792 5395728.5,4576782 5395738.5,4576752 5395738.5,4576752
5395748.5,4576732 5395768.5,4576732 5395778.5,4576712 5395798.5,4576692
5395798.5,4576662 5395828.5,4576652 5395828.5,4576632 5395848.5,4576642
5395858.5,4576612 5395888.5,4576602 5395888.5,4576572 5395918.5,4576562
5395918.5,4576552 5395928.5,4576542 5395928.5,4576522 5395948.5,4576502
5395948.5,4576482 5395968.5,4576472 5395968.5,4576442 5395998.5,4576432
5395998.5,4576432 5396008.5,4576452 5396028.5,4576442 5396038.5,4576422
5396018.5,4576412 5396028.5,4576392 5396028.5,4576332 5396088.5,4576312
5396088.5,4576302 5396098.5,4576282 5396078.5,4576262 5396078.5,4576242
5396098.5,4576232 5396098.5,4576242 5396108.5,4576262 5396108.5,4576272
5396118.5,4576262 5396128.5,4576252 5396128.5,4576252 5396148.5,4576262
5396148.5,4576272 5396158.5,4576262 5396168.5,4576252 5396168.5,4576242
5396178.5,4576232 5396178.5,4576222 5396188.5,4576192 5396188.5,4576172
5396208.5,4576152 5396208.5,4576142 5396218.5,4576122 5396218.5,4576112
5396228.5,4576092 5396228.5,4576072 5396208.5,4576062 5396208.5,4576052
5396198.5,4576072 5396178.5,4576072 5396168.5,4576082 5396158.5,4576082
5396148.5,4576092 5396138.5,4576092 5396128.5,4576112 5396108.5,4576112
5396098.5,4576122 5396088.5,4576122 5396068.5,4576132 5396058.5,4576132
5396038.5,4576142 5396028.5,4576142 5395988.5,4576152 5395978.5,4576162
5395978.5,4576172 5395968.5,4576172 5395958.5,4576182 5395948.5,4576182
5395928.5,4576192 5395918.5,4576192 5395898.5,4576202 5395888.5,4576202
5395878.5,4576192 5395888.5,4576182 5395888.5,4576152 5395858.5,4576152
5395828.5,4576162 5395818.5,4576162 5395808.5,4576182 5395788.5,4576192
5395798.5,4576212 5395798.5,4576222 5395808.5,4576252 5395778.5,4576252
5395768.5,4576272 5395748.5,4576292 5395748.5,4576312 5395728.5,4576312
5395718.5,4576342 5395688.5,4576342 5395678.5,4576362 5395658.5,4576362
5395648.5,4576382 5395628.5,4576382 5395618.5,4576392 5395608.5,4576392
5395598.5,4576412 5395578.5,4576412 5395568.5,4576422 5395558.5,4576422
5395548.5,4576432 5395538.5,4576432 5395528.5,4576442 5395518.5,4576442
5395508.5,4576452 5395498.5,4576452 5395488.5,4576462 5395478.5,4576462
5395458.5,4576472 5395448.5,4576472 5395438.5,4576482 5395428.5,4576482
5395408.5,4576492 5395398.5,4576492 5395388.5,4576502 5395378.5,4576502
5395348.5,4576512 5395338.5,4576512 5395318.5,4576502 5395318.5,4576492
5395328.5,4576492 5395338.5,4576472 5395358.5,4576452 5395358.5,4576442
5395368.5,4576442 5395388.5,4576432 5395398.5,4576422 5395398.5,4576412
5395388.5,4576412 5395378.5,4576402 5395388.5,4576402 5395408.5,4576392
5395418.5,4576382 5395418.5,4576382 5395428.5,4576362 5395448.5,4576362
5395458.5,4576342 5395478.5,4576332 5395478.5,4576322 5395488.5,4576312
5395488.5,4576122 5395678.5,4576122 5395688.5,4576112 5395698.5,4576102
5395698.5,4576092 5395708.5,4576152 5395768.5,4576142 5395778.5,4576132
5395768.5,4576122 5395768.5,4576092 5395798.5,4576082 5395788.5,4576062
5395788.5,4576052 5395798.5,4576052 5395818.5,4576042 5395828.5,4576042
5395838.5,4576022 5395858.5,4576022 5395868.5,4576032 5395878.5,4576032
5395908.5,4576022 5395918.5,4576022 5395928.5,4576012 5395938.5,4576012
5395958.5,4576002 5395968.5,4576002 5395998.5,4575992 5396008.5,4575992
5396018.5,4575972 5396038.5,4575972 5396048.5,4575952 5396068.5,4575952
5396078.5,4575922 5396108.5,4575922 5396118.5,4575902 5396138.5,4575902
5396148.5,4575872 5396178.5,4575852 5396158.5,4575852 5396148.5,4575842
5396138.5,4575842 5396128.5,4575822 5396108.5,4575822 5396128.5,4575812
5396138.5,4575792 5396138.5,4575792 5396148.5,4575802 5396158.5,4575812
5396158.5,4575832 5396178.5,4575842 5396168.5,4575872 5396198.5,4575872
5396208.5,4575862 5396218.5,4575882 5396238.5,4575902 5396238.5,4575912
5396248.5,4575912 5396258.5,4575882 5396288.5,4575882 5396298.5,4575872
5396308.5,4575862 5396308.5,4575852 5396318.5,4575852 5396328.5,4575832
5396348.5,4575812 5396328.5,4575802 5396328.5,4575782 5396308.5,4575812
5396278.5,4575822 5396278.5,4575802 5396258.5,4575802 5396238.5,4575752
5396238.5,4575742 5396248.5,4575732 5396238.5,4575692 5396238.5,4575682
5396248.5,4575662 5396248.5,4575662 5396258.5,4575642 5396278.5,4575632
5396278.5,4575642 5396288.5,4575642 5396308.5,4575632 5396318.5,4575622
5396318.5,4575622 5396348.5,4575612 5396358.5,4575602 5396358.5,4575592
5396348.5,4575582 5396348.5,4575572 5396338.5,4575592 5396318.5,4575602
5396318.5,4575592 5396308.5,4575592 5396298.5,4575582 5396288.5,4575582
5396298.5,4575572 5396308.5,4575562 5396308.5,4575562 5396318.5,4575552
5396328.5,4575552 5396338.5,4575542 5396348.5,4575532 5396348.5,4575512
5396368.5,4575512 5396378.5,4575522 5396388.5,4575502 5396408.5,4575492
5396408.5,4575482 5396418.5,4575482 5396428.5,4575442 5396468.5,4575452
5396478.5,4575452 5396468.5,4575502 5396418.5,4575512 5396418.5,4575522
5396408.5,4575542 5396408.5,4575552 5396398.5,4575572 5396398.5,4575582
5396408.5,4575662 5396408.5,4575672 5396418.5,4575682 5396418.5,4575692
5396428.5,4575712 5396428.5,4575742 5396458.5,4575742 5396488.5,4575752
5396478.5,4575762 5396488.5,4575762 5396498.5,4575752 5396508.5,4575742
5396498.5,4575742 5396488.5,4575712 5396518.5,4575712 5396528.5,4575702
5396538.5,4575692 5396528.5,4575692 5396548.5,4575672 5396568.5,4575662
5396558.5,4575662 5396548.5,4575672 5396538.5,4575672 5396518.5,4575692
5396498.5,4575692 5396488.5,4575662 5396488.5,4575662 5396518.5,4575652
5396528.5,4575652 5396538.5,4575642 5396548.5,4575632 5396548.5,4575612
5396568.5,4575602 5396568.5,4575602 5396588.5,4575592 5396598.5,4575602
5396608.5,4575602 5396618.5,4575612 5396618.5,4575622 5396628.5,4575632
5396618.5,4575632 5396608.5,4575642 5396598.5,4575662 5396598.5,4575672
5396608.5,4575672 5396598.5,4575682 5396588.5,4575692 5396588.5,4575702
5396598.5,4575742 5396598.5,4575742 5396588.5,4575762 5396568.5,4575762
5396548.5,4575752 5396558.5,4575742 5396558.5,4575722 5396538.5,4575722
5396528.5,4575732 5396518.5,4575742 5396528.5,4575762 5396528.5,4575772
5396538.5,4575782 5396538.5,4575792 5396528.5,4575792 5396498.5,4575782
5396488.5,4575802 5396468.5,4575832 5396468.5,4575842 5396478.5,4575852
5396478.5,4575862 5396488.5,4575872 5396488.5,4575883 5396499,4575882
5396508.5,4575872 5396518.5,4575832 5396518.5,4575822 5396528.5,4575812
5396528.5,4575812 5396548.5,4575802 5396558.5,4575822 5396578.5,4575822
5396588.5,4575832 5396588.5,4575832 5396568.5,4575842 5396558.5,4575852
5396558.5,4575862 5396568.5,4575862 5396548.5,4575872 5396538.5,4575892
5396538.5,4575892 5396518.5,4575902 5396508.5,4575902 5396478.5,4575912
5396468.5,4575922 5396468.5,4575932 5396478.5,4575932 5396498.5,4575952
5396498.5,4575962 5396508.5,4575942 5396528.5,4575952 5396538.5,4575962
5396528.5,4575972 5396538.5,4575962 5396548.5,4575952 5396538.5,4575932
5396558.5,4575922 5396548.5,4575912 5396558.5,4575902 5396558.5,4575892
5396568.5,4575892 5396618.5,4575882 5396628.5,4575872 5396628.5,4575852
5396608.5,4575842 5396608.5,4575842 5396618.5,4575852 5396628.5,4575852
5396638.5,4575862 5396648.5,4575892 5396648.5,4575902 5396658.5,4575902
5396668.5,4575892 5396678.5,4575882 5396668.5,4575872 5396668.5,4575852
5396688.5,4575862 5396698.5,4575862 5396708.5,4575852 5396718.5,4575862
5396728.5,4575872 5396718.5,4575882 5396728.5,4575892 5396718.5,4575902
5396718.5,4575912 5396708.5,4575922 5396718.5,4575902 5396738.5,4575892
5396738.5,4575902 5396748.5,4575892 5396758.5,4575882 5396758.5,4575892
5396768.5,4575882 5396778.5,4575872 5396768.5,4575862 5396768.5,4575872
5396778.5,4575872 5396798.5,4575862 5396808.5,4575852 5396798.5,4575842
5396798.5,4575832 5396808.5,4575842 5396818.5,4575842 5396838.5,4575852
5396838.5,4575862 5396848.5,4575862 5396858.5,4575892 5396888.5,4575892
5396898.5,4575902 5396908.5,4575902 5396948.5,4575892 5396958.5,4575872
5396958.5,4575862 5396948.5,4575862 5396938.5,4575842 5396918.5,4575842
5396928.5,4575852 5396938.5,4575852 5396948.5,4575842 5396958.5,4575832
5396958.5,4575822 5396948.5,4575822 5396938.5,4575812 5396928.5,4575812
5396918.5,4575802 5396928.5,4575792 5396918.5,4575792 5396908.5,4575782
5396898.5,4575792 5396888.5,4575802 5396888.5,4575822 5396868.5,4575832
5396868.5,4575832 5396848.5,4575822 5396838.5,4575802 5396838.5,4575792
5396848.5,4575782 5396848.5,4575792 5396858.5,4575782 5396868.5,4575772
5396858.5,4575762 5396868.5,4575772 5396878.5,4575772 5396888.5,4575762
5396898.5,4575742 5396898.5,4575732 5396888.5,4575722 5396898.5,4575712
5396898.5,4575712 5396908.5,4575722 5396918.5,4575722 5396928.5,4575732
5396918.5,4575742 5396928.5,4575722 5396948.5,4575712 5396948.5,4575692
5396928.5,4575692 5396948.5,4575682 5396958.5,4575672 5396958.5,4575662
5396968.5,4575652 5396968.5,4575642 5396958.5,4575642 5396948.5,4575632
5396938.5,4575622 5396938.5,4575612 5396948.5,4575602 5396938.5,4575592
5396938.5,4575582 5396928.5,4575572 5396928.5,4575562 5396918.5,4575552
5396918.5,4575522 5396888.5,4575512 5396898.5,4575502 5396898.5,4575492
5396888.5,4575492 5396878.5,4575482 5396888.5,4575472 5396888.5,4575462
5396878.5,4575442 5396878.5,4575432 5396868.5,4575432 5396838.5,4575422
5396848.5,4575392 5396848.5,4575392 5396858.5,4575382 5396868.5,4575372
5396858.5,4575362 5396858.5,4575352 5396848.5,4575352 5396818.5,4575362
5396808.5,4575362 5396798.5,4575372 5396788.5,4575372 5396768.5,4575362
5396778.5,4575322 5396778.5,4575312 5396768.5,4575302 5396778.5,4575292
5396778.5,4575292 5396798.5,4575272 5396818.5,4575262 5396818.5,4575252
5396828.5,4575252 5396838.5,4575262 5396848.5,4575252 5396858.5,4575222
5396858.5,4575222 5396868.5,4575212 5396878.5,4575212 5396898.5,4575202
5396908.5,4575202 5396918.5,4575182 5396938.5,4575182 5396948.5,4575162
5396968.5,4575162 5396988.5,4575152 5396998.5,4575152 5397008.5,4575122
5397038.5,4575122 5397058.5,4575112 5397068.5,4575112 5397078.5,4575102
5397088.5,4575102 5397118.5,4575092 5397128.5,4575092 5397148.5,4575072
5397168.5,4575072 5397228.5,4575062 5397238.5,4575062 5397248.5,4575052
5397258.5,4575052 5397268.5,4575042 5397278.5,4575042 5397298.5,4575032
5397308.5,4575032 5397328.5,4575022 5397338.5,4575012 5397338.5,4575002
5397348.5,4575002 5397368.5,4575012 5397368.5,4575022 5397378.5,4575022
5397438.5,4575012 5397448.5,4575012 5397488.5,4575002 5397498.5,4575002
5397558.5,4574992 5397568.5,4574992 5397638.5,4574982 5397648.5,4574982
5397718.5,4574972 5397728.5,4574972 5397838.5,4574962 5397848.5,4574962
5397868.5,4574942 5397888.5,4574942 5397898.5,4574952 5397898.5,4574972
5397918.5,4574972 5397958.5,4574962 5397968.5,4574962 5398048.5,4574952
5398058.5,4574952 5398168.5,4574955.5 5398190.5,4574930.5
5398193,4574916 5398207.5,4574894 5398239,4574889.5 5398259.5,4574892
5398278.5,4574881.5 5398353.5,4574839 5398417.5,4574831
5398439,4574816.5 5398459.5,4574804 5398473,4574792.5 5398479,4574759
5398565.5,4574740 5398601.5,4574723 5398620,4574722 5398633,4574674
5398728,4574658.5 5398729.5,4574638 5398771,4574620.5 5398796,4574608
5398846,4574597.5 5398855,4574595.5 5398866.5,4574574.5
5398872.5,4574523 5398899,4574499.5 5398907.5,4574441
5398909.5,4574406.5 5398922.5,4574321 5398945.5,4574282
5398963.5,4574260 5398967,4574212 5398955,4574209.5 5398953,4574199.5
5398953,4574189.5 5398943,4574179.5 5398943,4574169.5 5398933,4574149.5
5398933,4574149.5 5398943,4574189.5 5398983,4574189.5 5398993,4574179.5
5399003,4574179.5 5399013,4574169.5 5399023,4574159.5 5399023,4574159.5
5399033,4574149.5 5399043,4574139.5 5399043,4574109.5 5399073,4574099.5
5399073,4574069.5 5399103,4574059.5 5399103,4574039.5 5399123,4574029.5
5399123,4573989.5 5399163,4573979.5 5399163,4573959.5 5399183,4573949.5
5399183,4573919.5 5399213,4573909.5 5399213,4573899.5 5399223,4573889.5
5399223,4573879.5 5399233,4573869.5 5399223,4573839.5 5399223,4573839.5
5399233,4573849.5 5399243,4573849.5 5399263,4573819.5 5399293,4573809.5
5399293,4573789.5 5399313,4573779.5 5399313,4573789.5 5399323,4573779.5
5399333,4573769.5 5399333,4573759.5 5399343,4573749.5 5399343,4573739.5
5399333,4573729.5 5399343,4573709.5 5399343,4573699.5 5399353,4573689.5
5399353,4573669.5 5399373,4573609.5 5399373,4573599.5 5399383,4573599.5
5399393,4573589.5 5399403,4573579.5 5399403,4573569.5 5399393,4573549.5
5399393,4573539.5 5399383,4573519.5 5399383,4573519.5 5399393,4573509.5
5399403,4573499.5 5399403,4573479.5 5399383,4573439.5 5399383,4573409.5
5399413,4573229.5 5399413,4573219.5 5399423,4573189.5 5399423,4573179.5
5399433,4573149.5 5399433,4573139.5 5399423,4573009.5 5399423,4572999.5
5399413,4572919.5 5399413,4572914 5399420,4572904 5399420,4572894
5399430,4572814 5399430,4572804 5399440,4572784 5399440,4572754
5399470,4572734 5399470,4572704 5399500,4572694 5399500,4572674
5399520,4572654 5399520,4572664 5399530,4572664 5399560,4572704
5399560,4572714 5399550,4572724 5399550,4572734 5399540,4572744
5399540,4572734 5399530,4572734 5399520,4572744 5399510,4572774
5399510,4572784 5399520,4572774 5399530,4572784 5399530,4572794
5399520,4572874 5399520,4572884 5399510,4572894 5399520,4572904
5399510,4572934 5399510,4572944 5399500,4572954 5399500,4572964
5399510,4572974 5399510,4572984 5399520,4572994 5399520,4572999.5
5399513,4573019.5 5399513,4573029.5 5399503,4573079.5 5399503,4573089.5
5399513,4573099.5 5399513,4573119.5 5399533,4573119.5 5399543,4573109.5
5399553,4573109.5 5399563,4573129.5 5399563,4573129.5 5399553,4573139.5
5399543,4573149.5 5399543,4573159.5 5399533,4573169.5 5399533,4573179.5
5399523,4573219.5 5399523,4573229.5 5399513,4573329.5 5399513,4573339.5
5399503,4573539.5 5399503,4573549.5 5399493,4573559.5 5399493,4573569.5
5399483,4573629.5 5399483,4573639.5 5399473,4573649.5 5399483,4573679.5
5399483,4573689.5 5399493,4573719.5 5399493,4573719.5 5399483,4573729.5
5399473,4573739.5 5399473,4573749.5 5399463,4573769.5 5399463,4573799.5
5399433,4573809.5 5399433,4573809.5 5399423,4573839.5 5399393,4573849.5
5399393,4573859.5 5399383,4573869.5 5399383,4573879.5 5399373,4573889.5
5399373,4573899.5 5399363,4573909.5 5399363,4573909.5 5399353,4573899.5
5399343,4573899.5 5399323,4573909.5 5399313,4573919.5 5399323,4573939.5
5399323,4573979.5 5399283,4573989.5 5399283,4573999.5 5399273,4574019.5
5399273,4574029.5 5399263,4574049.5 5399263,4574059.5 5399253,4574059.5
5399243,4574069.5 5399233,4574089.5 5399233,4574089.5 5399223,4574099.5
5399213,4574099.5 5399203,4574109.5 5399193,4574119.5 5399203,4574159.5
5399163,4574169.5 5399163,4574219.5 5399113,4574219.5 5399103,4574249.5
5399073,4574249.5 5399063,4574259.5 5399053,4574269.5 5399053,4574289.5
5399073,4574309.5 5399053,4574319.5 5399053,4574329.5 5399043,4574349.5
5399043,4574359.5 5399033,4574369.5 5399033,4574379.5 5399023,4574389.5
5399023,4574399.5 5399013,4574409.5 5399013,4574419.5 5399003,4574439.5
5399003,4574449.5 5398993,4574469.5 5398993,4574469.5 5398973,4574499.5
5398943,4574509.5 5398953,4574509.5 5398973,4574599.5 5398973,4574619.5
5398993,4574619.5 5399003,4574609.5 5399013,4574599.5 5399013,4574599.5
5399023,4574549.5 5399073,4574539.5 5399073,4574519.5 5399093,4574509.5
5399093,4574499.5 5399103,4574489.5 5399103,4574469.5 5399123,4574449.5
5399123,4574429.5 5399143,4574379.5 5399143,4574369.5 5399153,4574359.5
5399153,4574349.5 5399163,4574329.5 5399163,4574319.5 5399173,4574309.5
5399173,4574299.5 5399183,4574289.5 5399183,4574279.5 5399193,4574269.5
5399183,4574259.5 5399183,4574239.5 5399203,4574219.5 5399203,4574209.5
5399213,4574199.5 5399213,4574179.5 5399233,4574159.5 5399233,4574149.5
5399243,4574139.5 5399243,4574129.5 5399253,4574119.5 5399253,4574109.5
5399263,4574099.5 5399263,4574089.5 5399273,4574079.5 5399273,4574069.5
5399283,4574069.5 5399293,4574049.5 5399313,4574029.5 5399313,4574009.5
5399333,4573999.5 5399323,4573989.5 5399323,4573969.5 5399343,4573969.5
5399353,4573939.5 5399383,4573919.5 5399383,4573909.5 5399393,4573909.5
5399403,4573869.5 5399443,4573859.5 5399443,4573839.5 5399463,4573839.5
5399473,4573829.5 5399483,4573819.5 5399483,4573809.5 5399493,4573799.5
5399493,4573769.5 5399523,4573769.5 5399533,4573739.5 5399563,4573739.5
5399573,4573729.5 5399583,4573719.5 5399583,4573719.5 5399593,4573709.5
5399603,4573709.5 5399613,4573679.5 5399643,4573679.5 5399663,4573639.5
5399703,4573639.5 5399713,4573619.5 5399733,4573619.5 5399743,4573609.5
5399753,4573609.5 5399763,4573599.5 5399773,4573599.5 5399783,4573569.5
5399813,4573569.5 5399823,4573549.5 5399843,4573549.5 5399853,4573489.5
5399913,4573489.5 5399923,4573479.5 5399933,4573469.5 5399933,4573469.5
5399943,4573439.5 5399973,4573429.5 5399973,4573429.5 5399983,4573424
5399990,4573414 5399990,4573394 5400010,4573394 5400020,4573344
5400070,4573344 5400080,4573334 5400090,4573334 5400100,4573324
5400110,4573324 5400120,4573314 5400130,4573314 5400140,4573294
5400160,4573294 5400180,4573274 5400200,4573274 5400210,4573244
5400240,4573244 5400260,4573234 5400270,4573234 5400290,4573224
5400300,4573224 5400320,4573214 5400330,4573214 5400340,4573194
5400360,4573194 5400370,4573184 5400380,4573184 5400390,4573164
5400410,4573164 5400420,4573144 5400440,4573144 5400450,4573114
5400480,4573114 5400490,4573104 5400500,4573094 5400510,4573084
5400510,4573084 5400520,4573034 5400570,4573034 5400580,4572994
5400620,4572984 5400620,4572974 5400610,4572964 5400610,4572614
5402050,4572614 5402040,4572594 5402030,4572584 5402020,4572574
5402020,4572564 5402000,4572554 5402000,4572544 5401990,4572494
5401970,4572474 5401970,4572444 5401950,4572434 5401940,4572414
5401930,4572404 5401920,4572494 5402050,4572464 5402040,4572404
5402040,4572184 5402160,4572056.727 5402141.818,4572024 5402150,4572009
5402135,4571904 5402120,4571924 5402110,4571924 5402100,4572004
5402130,4572009 5402135,4572056.727 5402141.818,4572064 5402140,4572184
5402160,4571977.829 5401970.432,4571836.698 5401939.281,4571654.393
5401921.131,4571465.504 5401897.582,4571321.206 5401856.119,4571234.363
5401821.73,4571084.45 5401773.725,4571061.53 5401738.561,4571032.985
5401659.457,4571003.147 5401661.364,4570893.923 5401619.481,4570818.294
5401595.143,4570749.534 5401527.801,4570722.508 5401509.883,4570697.721
5401497.639,4570647.849 5401477.855,4570544.038 5401408.347,4570406.7
5401367.444,4570197.288 5401342.574,4570001.999 5401396.699,4569740.381
5401367.062,4569685.358 5401330.405,4569642.728 5401190.272,4569550.6
5401085.975,4569497.071 5401001.208,4569520.638 5400887.166,4569520.737
5400775.771,4569427.787 5400707.832,4569347.271 5400653.122,4569288.49
5400616.553,4569136.794 5400586.214,4568999.998 5400704.59,4568877.829
5400846.262,4568791.626 5400943.527,4568612.778 5401080.586,4568637.533
5401071.504,4568453.91 5401335.186,4568259.317 5401596.861,4567984.077
5401808.381,4567562.685 5402122.866,4567377.783 5402257.228,4566768.225
5402717.633,4566717.68 5402766.388,4566503.816 5402962.319,4566343.568
5403106.542,4566168.873 5403266.902,4566000.267 5403417.793,4565638.536
5403757.03,4565499.184 5403885.594,4565189.166 5404209.171,4565142.847
5404261.446,4565105.561 5404300.551,4564802.106 5404611.024,4564498.467
5404925.443,4564325.676 5405012.26,4564122.668 5405032.448,4563969.594
5405065.187,4563873.139 5405065.265,4563856.65 5405105.038,4563947.396
5405162.601,4564107.556 5405177.838,4564282.615 5405231.676,4564475.959
5405327.501,4564807.115 5405464.975,4565112.876 5405688.116,4565310.96
5405871.979,4565540.935 5406066.493,4565807.245 5406301.836,4565856.79
5406338.996,4565989.945 5406422.604,4566089.037 5406518.6,4566181.936
5406592.918,4566268.641 5406636.271,4566373.926 5406716.783,4566522.564
5406846.841,4566623.602 5406846.05,4566669.784 5406855.757,4566681.137
5406859.356,4566692.675 5406864.802,4566705.229 5406873.386,4566721.17
5406893.727,4566731.111 5406903.669,4566753.099 5406946.496,4566777.189
5407000.985,4566792.484 5407019.912,4566820.206 5407036.546,4566924.023
5407073.064,4566940.848 5407080.902,4566959.393 5407086.255,4566994.19
5407099.065,4567089.211 5407142.466,4567143.7 5407172.1,4567200.101
5407206.132,4567217.698 5407219.119,4567232.222 5407226.589,4567267.592
5407249.914,4567297.8 5407276.299,4567384.027 5407344.745,4567478.092
5407426.574,4567541.185 5407490.814,4567613.073 5407574.364,4567667.18
5407644.532,4567757.039 5407763.261,4567811.5 5407841,4567919
5407982.5,4567978 5407953.5,4568028.5 5407941.5,4568074
5407937,4568134.5 5407938,4568152 5407952,4568149 5407964.5,4568124.5
5407966.5,4568063 5407968.5,4568012.5 5407980,4567963 5408000,4567946
5408014,4568024.5 5408114.5,4568075.5 5408174,4568210.5
5408339.5,4568331 5408473.5,4568805 5408971.5,4568987.5
5409188.5,4569106 5409343.5,4569210 5409494,4569362 5409753,4569491.5
5409991,4569673.188 5410355.366,4569629.077 5410371.908,4569551.5
5410238,4569317 5409774,4569195 5409574,4568930 5409200.5,4568776.5
5409018.5,4568703 5408940,4568322 5408545.5,4568125 5408323,4568096
5408289,4568064.5 5408248.5,4568038 5408269.5,4568003
5408293.5,4567952.5 5408312,4567889.5 5408341,4567852.5
5408370.5,4567813.5 5408419,4567755.5 5408454,4567544.137
5408529.123,4567640.334 5408669.958,4568277 5409280.5,4568662
5409652,4568865.5 5409834.5,4568964.5 5409938.5,4569022 5409994,4569058
5410045,4569135 5410147.5,4569216 5410275.5,4569336.008
5410497.066,4569304.914 5410507.805,4569260.5 5410407,4569250.5
5410397,4569250.5 5410387,4569240.5 5410377,4569240.5 5410367,4569230.5
5410357,4569230.5 5410347,4569220.5 5410337,4569220.5 5410327,4569200.5
5410307,4569200.5 5410297,4569190.5 5410287,4569190.5 5410277,4569180.5
5410267,4569190.5 5410257,4569180.5 5410247,4569180.5 5410237,4569170.5
5410227,4569170.5 5410217,4569160.5 5410207,4569150.5 5410207,4569140.5
5410197,4569140.5 5410187,4569120.5 5410167,4569120.5 5410157,4569100.5
5410137,4569100.5 5410127,4569080.5 5410107,4569080.5 5410097,4569060.5
5410077,4569060.5 5410057,4569040.5 5410037,4569040.5 5410027,4569020.5
5410007,4569020.5 5409997,4569010.5 5410007,4568950.5 5409947,4568950.5
5409957,4568940.5 5409967,4568930.5 5409957,4568920.5 5409957,4568870.5
5409907,4568870.5 5409897,4568860.5 5409897,4568670.5 5409707,4568660.5
5409707,4568650.5 5409697,4568650.5 5409687,4568660.5 5409677,4568670.5
5409677,4568660.5 5409667,4568650.5 5409667,4568620.5 5409637,4568610.5
5409637,4568600.5 5409647,4568420.5 5409467,4568410.5 5409467,4568320.5
5409377,4568330.5 5409367,4568310.5 5409367,4567640.5 5408697,4567630.5
5408707,4567620.5 5408697,4567630.5 5408687,4567563.306
5408619.806,4567543.638 5408607,4567540.5 5408607,4567534.645
5408601.146,4567528.279 5408597,4567520.5 5408597,4567510.5
5408587,4567500.5 5408587,4567490 5408581.5,4567448.664
5408545.164,4567104.739 5408321.239,4567110.5 5408327,4567110.5
5408337,4567120.5 5408347,4567120.5 5408357,4567140.5 5408377,4567140.5
5408387,4567190.5 5408387,4567200.5 5408397,4567220.5 5408397,4567230.5
5408407,4567230.5 5408417,4567220.5 5408427,4567220.5 5408437,4567210.5
5408447,4567200.5 5408447,4567200.5 5408467,4567202 5408478,4567197
5408494,4567184 5408510,4567161 5408526.5,4567115.5 5408553,4567074.5
5408580,4567067 5408591,4567071 5408602.5,4567104.5 5408657,4567111
5408677.5,4567106.5 5408689,4567090.5 5408697,4567080.5
5408697,4567060.5 5408717,4567050.5 5408717,4567040.5 5408727,4567020.5
5408727,4567010.5 5408737,4567000.5 5408737,4566970.5 5408767,4566950.5
5408767,4566950.5 5408777,4566940.5 5408787,4566930.5 5408787,4566920.5
5408797,4566910.5 5408797,4566890.5 5408817,4566880.5 5408817,4566870.5
5408827,4566860.5 5408827,4566850.5 5408837,4566870.5 5408857,4566860.5
5408867,4566870.5 5408877,4566880.5 5408877,4566890.5 5408887,4566880.5
5408897,4566900.5 5408917,4566910.5 5408917,4566950.5 5408957,4566966.5
5408968.5,4566985.5 5408978.5,4566999.5 5408990.5,4567010.5
5409007,4567010.5 5409017,4567000.5 5409027,4566990.5 5409027,4566950.5
5408987,4566930.5 5409007,4566930.5 5409037,4566940.5 5409047,4566940.5
5409057,4566930.5 5409067,4566910.5 5409067,4566900.5 5409077,4566860.5
5409077,4566850.5 5409087,4566840.5 5409087,4566830.5 5409097,4566820.5
5409097,4566820.5 5409117,4566830.5 5409127,4566830.5 5409137,4566840.5
5409147,4566840.5 5409167,4566830.5 5409177,4566830.5 5409197,4566840.5
5409207,4566840.5 5409217,4566860.5 5409237,4566860.5 5409247,4566900.5
5409287,4566900.5 5409337,4566890.5 5409347,4566760.5 5409347,4566750.5
5409357,4566740.5 5409347,4566730.5 5409347,4566720.5 5409337,4566720.5
5409327,4566690.5 5409297,4566670.5 5409317,4566660.5 5409307,4566650.5
5409307,4566640.5 5409297,4566640.5 5409287,4566650.5 5409277,4566660.5
5409277,4566650.5 5409267,4566640.5 5409267,4566630.5 5409257,4566620.5
5409257,4566610.5 5409247,4566600.5 5409247,4566590.5 5409257,4566590.5
5409307,4566580.5 5409317,4566580.5 5409367,4566560.5 5409387,4566560.5
5409427,4566540.5 5409447,4566540.5 5409457,4566550.5 5409447,4566570.5
5409447,4566580.5 5409437,4566600.5 5409437,4566610.5 5409427,4566640.5
5409427,4566650.5 5409437,4566650.5 5409447,4566640.5 5409457,4566640.5
5409477,4566630.5 5409487,4566610.5 5409487,4566590.5 5409507,4566610.5
5409527,4566620.5 5409527,4566630.5 5409517,4566650.5 5409517,4566670.5
5409497,4566730.5 5409497,4566740.5 5409487,4566760.5 5409487,4566770.5
5409477,4566780.5 5409477,4566800.5 5409497,4566820.5 5409497,4566830.5
5409487,4566820.5 5409477,4566820.5 5409467,4566830.5 5409457,4566850.5
5409457,4566860.5 5409447,4566880.5 5409467,4566880.5 5409477,4566900.5
5409457,4566910.5 5409467,4566910.5 5409477,4566930.5 5409497,4566930.5
5409527,4566970.5 5409567,4566980.5 5409567,4566990.5 5409577,4566990.5
5409587,4566980.5 5409597,4566980.5 5409617,4566990.5 5409617,4567010.5
5409637,4567020.5 5409637,4567030.5 5409647,4567050.5 5409647,4567060.5
5409657,4567060.5 5409677,4567080.5 5409697,4567070.5 5409707,4567070.5
5409717,4567050.5 5409737,4567060.5 5409737,4567070.5 5409747,4567170.5
5409747,4567180.5 5409737,4567210.5 5409737,4567220.5 5409747,4567250.5
5409747,4567270.5 5409767,4567280.5 5409757,4567290.5 5409757,4567300.5
5409767,4567320.5 5409767,4567330.5 5409777,4567320.5 5409787,4567270.5
5409787,4567290.5 5409807,4567290.5 5409817,4567320.5 5409817,4567330.5
5409827,4567340.5 5409827,4567340.5 5409807,4567350.5 5409797,4567370.5
5409817,4567370.5 5409837,4567400.5 5409837,4567410.5 5409847,4567430.5
5409847,4567450.5 5409867,4567450.5 5409877,4567460.5 5409887,4567470.5
5409887,4567510.5 5409927,4567520.5 5409927,4567530.5 5409937,4567530.5
5409947,4567520.5 5409957,4567490.5 5409957,4567480.5 5409967,4567480.5
5410027,4567440.5 5410067,4567430.5 5410067,4567420.5 5410077,4567410.5
5410077,4567390.5 5410097,4567380.5 5410097,4567370.5 5410107,4567370.5
5410117,4567310.5 5410177,4567300.5 5410177,4567300.5 5410187,4567290.5
5410197,4567290.5 5410207,4567250.5 5410247,4567230.5 5410247,4567220.5
5410257,4567200.5 5410257,4567190.5 5410267,4567180.5 5410267,4567180.5
5410277,4567140.5 5410317,4567090.5 5410317,4567080.5 5410327,4567060.5
5410327,4567050.5 5410337,4567010.5 5410337,4567000.5 5410347,4566918
5410366,4566888 5410336,4566888 5410316,4566878 5410306,4566878
5410296,4566868 5410286,4566868 5410276,4566848 5410256,4566848
5410236,4566838 5410246,4566828 5410236,4566828 5410226,4566818
5410216,4566818 5410176,4566828 5410166,4566768 5410166,4566718
5410116,4566678 5410116,4566668 5410106,4566648 5410106,4566638
5410116,4566588 5410116,4566578 5410106,4566558 5410106,4566548
5410096,4566488 5410096,4566468 5410076,4566458 5410086,4566448
5410086,4566438 5410076,4566418 5410096,4566408 5410086,4566398
5410096,4566388 5410096,4566378 5410086,4566378 5410076,4566368
5410066,4566359.5 5410062,4566359.5 5410052,4566339.5 5410032,4566349.5
5410022,4566349.5 5410012,4566379.5 5409982,4566379.5 5409972,4566389.5
5409962,4566398 5409956,4566389.5 5409952,4566389.5 5409942,4566399.5
5409932,4566408 5409936,4566428 5409916,4566428 5409906,4566458
5409876,4566458 5409866,4566478 5409846,4566488 5409846,4566498
5409836,4566488 5409826,4566488 5409816,4566478 5409806,4566498
5409786,4566488 5409776,4566488 5409766,4566468 5409746,4566459.5
5409742,4566399.5 5409742,4566389.5 5409732,4566379.5 5409732,4566379.5
5409802,4566359.5 5409822,4566349.5 5409822,4566339.5 5409812,4566339.5
5409832,4566319.5 5409852,4566309.5 5409852,4566299.5 5409862,4566289.5
5409852,4566279.5 5409852,4566269.5 5409862,4566249.5 5409862,4566239.5
5409872,4566209.5 5409872,4566209.5 5409882,4566239.5 5409912,4566259.5
5409912,4566269.5 5409902,4566279.5 5409912,4566289.5 5409912,4566299.5
5409922,4566289.5 5409932,4566249.5 5409932,4566259.5 5409942,4566239.5
5409962,4566239.5 5409972,4566229.5 5409982,4566219.5 5409992,4566209.5
5409992,4566219.5 5410002,4566209.5 5410012,4566209.5 5410022,4566199.5
5410032,4566199.5 5410052,4566179.5 5410072,4566169.5 5410072,4566159.5
5410082,4566139.5 5410082,4566109.5 5410112,4566109.5 5410122,4566069.5
5410162,4566069.5 5410172,4566049.5 5410192,4566019.5 5410192,4566019.5
5410202,4565989.5 5410232,4565959.5 5410232,4565959.5 5410252,4565949.5
5410262,4565929.5 5410262,4565919.5 5410272,4565909.5 5410262,4565909.5
5410282,4565889.5 5410302,4565879.5 5410292,4565859.5 5410292,4565849.5
5410302,4565809.5 5410302,4565799.5 5410312,4565759.5 5410312,4565762.5
5410269.5,4565801 5410239,4565822 5410266.5,4565843 5410260,4565889
5410232,4565866 5410205.5,4565837.5 5410201.5,4565836.5
5410154,4565826.5 5410071,4565808.5 5410045.5,4565818.5
5410021.5,4565795.5 5409978.5,4565443.5 5409906.5,4565443.5
5409793,4565206.5 5409793,4565199 5409831.5,4565089.5 5409838.5,4565071
5410129.5,4565030 5410297.5,4564941.5 5410291.5,4564882.5
5410360.5,4564833.5 5410377,4564759.5 5410374.5,4564707
5410398.5,4564569.5 5410387,4564558 5410387,4564548 5410397,4564519.5
5410397,4564509.5 5410387,4564368 5410387,4564358 5410397,4564218
5410397,4564208 5410407,4564199.5 5410407,4564189.5 5410397,4564128
5410397,4564118 5410407,4564108 5410407,4564098 5410417,4564089.5
5410417,4564079.5 5410407,4564069.5 5410407,4564058.5 5410396.5,4564048
5410407,4564038 5410407,4564028 5410417,4563959.5 5410417,4563949.5
5410407,4563928 5410407,4563918.5 5410416.5,4563899.5 5410397,4563888
5410397,4563878 5410407,4563850.5 5410407,4563848.5 5410409.5,4563835.5
5410412,4563779.5 5410412,4563769.5 5410422,4563699.5 5410422,4563689.5
5410432,4563679.5 5410432,4563659.5 5410412,4563659.5 5410392,4563649.5
5410382,4563639.5 5410382,4563629.5 5410372,4563619.5 5410382,4563599.5
5410382,4563589.5 5410372,4563579.5 5410372,4563569.5 5410362,4563569.5
5410352,4563559.5 5410342,4563559.5 5410312,4563549.5 5410312,4563549.5
5410342,4563539.5 5410352,4563529.5 5410352,4563519.5 5410342,4563519.5
5410332,4563529.5 5410322,4563529.5 5410302,4563539.5 5410292,4563549.5
5410292,4563549.5 5410282,4563569.5 5410262,4563569.5 5410232,4563579.5
5410222,4563579.5 5410192,4563569.5 5410182,4563569.5 5410152,4563549.5
5410132,4563549.5 5410122,4563539.5 5410112,4563539.5 5410102,4563529.5
5410092,4563529.5 5410082,4563509.5 5410062.5,4563486
5410011.5,4563519.5 5409988,4563519 5409984.5,4563478.5 5409967,4563430
5409927.5,4563372.5 5409877.5,4563333 5409834,4563291 5409776,4563248
5409733.5,4563210.5 5409709.5,4563181 5409706.5,4563158.5
5409708.5,4563157 5409712,4563195 5409751.5,4563215.5 5409778.5,4563284
5409881.5,4563322 5409944.5,4563366.5 5410027,4563377 5410070,4563424.5
5410149,4563446.5 5410191,4563448 5410219,4563447 5410245.5,4563434
5410262.5,4563410.5 5410280,4563360 5410272,4563327 5410259,4563202.5
5410201,4563171 5410204,4563089 5410187,4563027.5 5409969.5,4563025.5
5409968,4562970.5 5409969,4562941 5409980,4562911 5410011,4562884.5
5410015,4562883 5410017,4562878 5410125.5,4562880.5 5410126,4562878
5410128,4562878 5410125.5),(4570774 5402849.033,4570777.479
5402838.261,4570805.095 5402752.738,4570806.924 5402747.077,4570806.006
5402749.953,4570805.095 5402752.738,4570781.954 5402824.689,4570777.479
5402838.261,4570776.876 5402840.324,4570774 5402849.033),(4571285.765
5408495.315,4571292 5408436.5,4571292.137 5408438.425,4571285.765
5408495.315),(4570816.582 5402729.434,4570821.176 5402715.648,4570864
5402570.325,4570864 5402570,4570864.155 5402569.845,4570871.334
5402546.928,4570898.253 5402464.253,4570894 5402460,4570895.668
5402459.731,4570898.253 5402464.253,4570864.155 5402569.845,4570864
5402570.325,4570861.871 5402580.726,4570821.176 5402715.648,4570814
5402740,4570816.582 5402729.434),(4566665 5406634,4566678.974
5406622.743,4566684.521 5406614.764,4566719 5406590.5,4566678.974
5406622.743,4566663.5 5406645,4566665 5406634),(4571095.5
5408567.5,4571102.5 5408555.5,4571131 5408546.5,4571095.5
5408567.5),(4569842 5404392.5,4569941 5404483.5,4569925 5404471,4569884
5404433.5,4569842 5404392.5),(4569910 5404512,4569920 5404502,4569950
5404512,4569910 5404512),(4572524 5402090,4572534 5402100,4572564
5402140,4572584 5402160,4572574 5402160,4572564 5402150,4572524
5402090),(4569356.586 5410606.657,4569377.067 5410593.656,4569392.926
5410630.33,4569374.473 5410639.45,4569356.586 5410606.657),(4582632
5392963.5,4582632.5 5392959,4582639 5392953,4582641.5 5392948,4582644.5
5392946,4582654 5392945.5,4582667 5392947.5,4582670 5392949.5,4582672.5
5392953.5,4582671 5392965,4582667.5 5392967.5,4582662.5 5392976,4582660
5392978,4582649 5392979.5,4582642.5 5392977,4582639.5 5392982.5,4582638
5392982.5,4582632 5392963.5),(4571245 5408407,4571291.5
5408377.5,4571313.5 5408358,4571302.079 5408397.124,4571277
5408404.5,4571265.899 5408412.321,4571245 5408407),(4565687.028
5412191.47,4565759.5 5412112,4565816.352 5412111.154,4565728.067
5412202.931,4565687.028 5412191.47),(4581424.5 5392523,4581428
5392520,4581429.5 5392515,4581437 5392512.5,4581440.5 5392507,4581449
5392504.5,4581456 5392494.5,4581466 5392491,4581469 5392483.5,4581480.5
5392481.5,4581487.5 5392486,4581497 5392495,4581500.5 5392502,4581512
5392504.5,4581512.5 5392505.5,4581509.5 5392508,4581505.5
5392508.5,4581505.5 5392511,4581518.5 5392529,4581526 5392533,4581528.5
5392533.5,4581530 5392532.5,4581531 5392535,4581521.5
5392542.5,4581499.5 5392553.5,4581495 5392560,4581488.5
5392563,4581484.5 5392567.5,4581476 5392571.5,4581471.5
5392576.5,4581464.5 5392580,4581460 5392585,4581449.5
5392587.5,4581445.5 5392590.5,4581440.5 5392597,4581427
5392602.5,4581422 5392606,4581412 5392606.5,4581409.5 5392608,4581406.5
5392613,4581406 5392621,4581402.5 5392625,4581391 5392627.5,4581381.5
5392625.5,4581369.5 5392626.5,4581369.5 5392623.5,4581376
5392624,4581377.5 5392621.5,4581373 5392612.5,4581370 5392595,4581366.5
5392584.5,4581370.5 5392575,4581375.5 5392571,4581379 5392563,4581384.5
5392559.5,4581390 5392552.5,4581392 5392546,4581397.5 5392542,4581400.5
5392535.5,4581408 5392534,4581416.5 5392525.5,4581424.5
5392523),(4577954.347 5399138.644,4577989.539 5399107.073,4578109
5399299,4578166.5 5399425.5,4578230.5 5399602.5,4578194
5399607,4578153.5 5399476.5,4578107.5 5399375,4578043.5
5399267,4577954.347 5399138.644),(4581659.5 5392384.5,4581669
5392382,4581674.5 5392377.5,4581679 5392370.5,4581682 5392370,4581691.5
5392372.5,4581714 5392369,4581719.5 5392363.5,4581728 5392347,4581730.5
5392345.5,4581739 5392356.5,4581748.5 5392362.5,4581759.5
5392364.5,4581770 5392364.5,4581771 5392365.5,4581771 5392375,4581777.5
5392385,4581774.5 5392389.5,4581770 5392391,4581757 5392399.5,4581749
5392410,4581747 5392414.5,4581749.5 5392425,4581759.5 5392427.5,4581764
5392434.5,4581764.5 5392446.5,4581760.5 5392480.5,4581741.5
5392496,4581729 5392504.5,4581719.5 5392509,4581702 5392510.5,4581687.5
5392503.5,4581679.5 5392503.5,4581678.5 5392506,4581679.5
5392535,4581671.5 5392557.5,4581670.5 5392566,4581664 5392577,4581654
5392586,4581644.5 5392589.5,4581640 5392588.5,4581637.5
5392586.5,4581634 5392575,4581614 5392549.5,4581610.5 5392542,4581603.5
5392532.5,4581601.5 5392524.5,4581587.5 5392512,4581574.5
5392505,4581574 5392496.5,4581571 5392490,4581569.5 5392489.5,4581566.5
5392495.5,4581566.5 5392504,4581565.5 5392506,4581558 5392511.5,4581557
5392517,4581551.5 5392522.5,4581547 5392521,4581541.5 5392516,4581539.5
5392512.5,4581528.5 5392506,4581519.5 5392497,4581518.5 5392491,4581520
5392477.5,4581530.5 5392464.5,4581536.5 5392462,4581542.5
5392463,4581551 5392468,4581557.5 5392469,4581562 5392471.5,4581566
5392475.5,4581568.5 5392481,4581572.5 5392483.5,4581576.5
5392482,4581578.5 5392474.5,4581578 5392464.5,4581581.5
5392455.5,4581586.5 5392449,4581592 5392436,4581599 5392431.5,4581608.5
5392430,4581616.5 5392424.5,4581623.5 5392416,4581633.5
5392396.5,4581640.5 5392393.5,4581647 5392392.5,4581659.5
5392384.5),(4567896.5 5409901,4567906 5409838,4568032 5409879,4568218
5409947,4568571 5410026.5,4568767 5410036.5,4568767 5410089.5,4568668
5410085,4568479.5 5410051,4568109.5 5409951.5,4567896.5
5409901),(4577187 5397993.5,4577215 5397971,4577270.5
5398072.5,4577369.5 5398223,4577736 5398743,4577892.64
5398981.951,4577868.141 5399001.486,4577685 5398739.5,4577291
5398170,4577239 5398089,4577187 5397993.5),(4582437.5 5392938,4582440.5
5392930.5,4582453.5 5392930,4582461 5392931.5,4582480.5
5392939.5,4582490 5392945.5,4582504.5 5392949,4582506 5392951,4582502
5392960,4582497.5 5392964,4582494 5392965.5,4582485.5
5392965.5,4582475.5 5392977,4582472.5 5392985,4582472.5
5392991,4582478.5 5393003.5,4582481.5 5393004.5,4582488
5393002,4582496.5 5392996.5,4582509.5 5392998,4582520.5
5392997.5,4582525 5392989.5,4582526 5392985,4582536.5 5392979,4582533.5
5392971.5,4582536.5 5392968,4582539 5392959,4582535.5 5392950,4582535
5392944.5,4582531 5392931.5,4582532 5392924.5,4582535 5392922,4582540.5
5392921.5,4582550.5 5392910,4582551.5 5392899,4582549 5392895,4582546.5
5392896,4582540 5392892,4582532.5 5392890,4582519.5 5392878,4582507
5392860,4582508 5392850.5,4582513 5392838,4582517 5392834.5,4582521
5392833,4582523 5392830.5,4582530 5392810.5,4582539 5392803.5,4582550.5
5392792,4582565.5 5392760,4582569 5392754.5,4582580 5392742.5,4582584.5
5392734,4582594 5392726.5,4582600.5 5392718,4582606 5392715.5,4582609.5
5392711,4582631.5 5392704.5,4582647 5392696.5,4582654.5
5392690.5,4582656 5392685.5,4582661 5392684,4582666.5 5392674,4582672.5
5392671.5,4582688.5 5392675,4582696.5 5392675.5,4582698
5392674.5,4582706.5 5392656.5,4582711.5 5392655,4582718.5
5392648,4582721.5 5392649,4582735.5 5392661.5,4582741 5392664,4582748.5
5392659.5,4582759.5 5392648.5,4582780.5 5392636.5,4582789
5392629.5,4582807.5 5392621,4582809 5392618,4582812 5392618,4582818.5
5392613,4582822 5392612,4582832.5 5392613.5,4582833.5 5392611,4582825.5
5392580.5,4582826 5392579,4582831.5 5392575.5,4582834.5
5392570,4582839.5 5392566.5,4582857 5392570,4582862.5 5392572.5,4582874
5392595.5,4582874.5 5392599.5,4582872.5 5392603.5,4582879
5392607.5,4582883 5392613.5,4582883 5392616,4582879.5 5392619,4582878
5392618,4582871 5392607.5,4582867.5 5392605.5,4582859 5392608,4582852.5
5392613,4582851.5 5392615,4582853.5 5392626.5,4582863.5
5392633.5,4582861.5 5392636.5,4582854.5 5392640,4582854
5392644,4582856.5 5392658.5,4582856 5392663.5,4582850.5
5392680,4582830.5 5392720,4582826 5392725.5,4582820.5 5392740.5,4582801
5392742,4582786.5 5392759,4582775 5392764.5,4582771.5 5392770.5,4582763
5392775.5,4582754 5392792,4582730 5392799.5,4582721 5392809,4582712.5
5392811.5,4582708.5 5392821.5,4582702 5392826.5,4582689
5392828.5,4582681 5392832.5,4582661.5 5392830,4582651 5392832.5,4582641
5392832.5,4582623.5 5392826.5,4582618.5 5392826.5,4582602
5392837,4582590 5392839.5,4582584 5392842.5,4582580 5392842,4582576.5
5392843.5,4582555 5392857.5,4582552.5 5392862,4582538.5 5392869,4582538
5392870.5,4582541 5392879,4582551.5 5392889.5,4582570 5392895.5,4582579
5392896,4582582.5 5392898.5,4582583.5 5392904.5,4582591 5392917,4582592
5392921.5,4582588 5392927.5,4582585 5392937,4582573.5
5392949.5,4582561.5 5392959.5,4582560.5 5392963.5,4582555
5392964.5,4582554.5 5392970.5,4582550 5392975.5,4582546 5392977,4582552
5392990,4582559 5393000,4582559.5 5393002.5,4582555.5 5393015,4582540.5
5393020,4582531.5 5393019.5,4582521.5 5393010.5,4582519
5393019.5,4582513.5 5393029.5,4582498 5393045.5,4582492.5
5393062.5,4582483.5 5393083,4582476 5393085.5,4582474.5
5393090.5,4582467 5393096.5,4582464 5393102,4582454.5 5393106,4582459
5393120.5,4582460 5393130.5,4582457.5 5393136.5,4582454
5393141,4582454.5 5393144.5,4582452.5 5393149.5,4582460.5
5393169.5,4582473.5 5393180,4582466.5 5393186.5,4582459
5393190,4582447.5 5393191,4582439.5 5393189,4582435.5 5393194.5,4582433
5393207.5,4582435 5393213,4582440.5 5393219.5,4582452
5393226.5,4582454.5 5393231,4582449.5 5393236.5,4582433.5
5393246,4582427.5 5393264,4582424 5393270,4582426 5393276.5,4582418.5
5393277.5,4582409.5 5393271,4582401 5393268.5,4582396 5393270,4582394.5
5393272,4582391.5 5393272,4582389 5393270.5,4582382.5 5393259.5,4582383
5393231.5,4582386 5393218,4582383 5393207.5,4582383 5393200.5,4582386
5393187,4582385 5393168,4582388.5 5393158.5,4582388.5 5393148.5,4582395
5393136.5,4582395.5 5393133.5,4582394 5393114,4582396.5
5393091.5,4582397 5393074,4582399.5 5393067.5,4582409.5
5393060.5,4582408.5 5393049,4582417.5 5393040,4582418.5
5393032.5,4582417 5393027.5,4582417 5393020.5,4582420.5
5393017.5,4582423.5 5393019,4582425.5 5393021.5,4582426.5
5393029.5,4582440 5393036,4582444.5 5393034,4582449.5
5393029.5,4582453.5 5393020.5,4582451.5 5393014.5,4582446.5
5393009.5,4582438.5 5393005.5,4582435 5393005,4582430.5
5393012.5,4582429 5393011,4582428.5 5393005.5,4582430 5392992,4582432
5392990,4582439 5392988.5,4582441 5392981.5,4582440.5 5392969,4582447.5
5392958.5,4582440 5392946,4582437.5 5392938),(4565277 5412453,4565277
5412463,4565287 5412473,4565287 5412483,4565297 5412493,4565327
5412493,4565367 5412453,4565377 5412453,4565548.764
5412282.188,4565553.756 5412282.188,4565627.247 5412309.567,4565630.05
5412312.721,4565577 5412353,4565577 5412363,4565537 5412403,4565527
5412403,4565457 5412473,4565447 5412473,4565447 5412483,4565437
5412493,4565427 5412493,4565367 5412553,4565367 5412593,4565407
5412633,4565417 5412633,4565447 5412663,4565437 5412673,4565427
5412673,4565417 5412663,4565407 5412663,4565387 5412643,4565377
5412643,4565367 5412633,4565357 5412633,4565347 5412623,4565337
5412623,4565327 5412613,4565287 5412613,4565257 5412643,4565247
5412643,4565217 5412673,4565207 5412673,4565167 5412713,4565157
5412713,4565127 5412743,4565117 5412743,4565097 5412763,4565087
5412763,4565057 5412793,4565047 5412793,4565017 5412823,4565007
5412823,4564977 5412853,4564967 5412853,4564937 5412883,4564927
5412883,4564907 5412903,4564897 5412903,4564867 5412933,4564857
5412933,4564847 5412943,4564827 5412943,4564817 5412953,4564807
5412943,4564877 5412873,4564887 5412873,4564917 5412843,4564927
5412843,4564967 5412803,4564977 5412803,4565017 5412763,4565027
5412763,4565087 5412703,4565097 5412703,4565157 5412643,4565167
5412643,4565237 5412573,4565237 5412553,4565247 5412543,4565247
5412503,4565237 5412493,4565237 5412463,4565247 5412453,4565247
5412433,4565287 5412393,4565297 5412393,4565307 5412383,4565327
5412383,4565337 5412373,4565347 5412373,4565357 5412383,4565337
5412403,4565327 5412403,4565317 5412413,4565307 5412413,4565287
5412433,4565287 5412443,4565277 5412453),(4565915.098
5412017.886,4565866.436 5412003.047,4565958 5411908,4565960.5
5411856.5,4566713.5 5411027,4566738 5411016,4566748 5411026,4566748
5411036,4566758 5411026,4566758 5410996,4566768 5410986,4566778
5410986,4566908 5410856,4566918 5410856,4566998 5410776,4567008
5410776,4567038 5410746,4567048 5410746,4567068 5410726,4567088
5410726,4567094.5 5410733,4566950.5 5410877,4566940.5 5410877,4566770.5
5411047,4566760.5 5411037,4566750.5 5411047,4566760.5 5411057,4566600.5
5411217,4566600.5 5411227,4566590.5 5411237,4566580.5 5411237,4566580.5
5411247,4566490.5 5411337,4566490.5 5411347,4566420.5 5411417,4566420.5
5411427,4566360.5 5411487,4566360.5 5411497,4566300.5 5411557,4566300.5
5411567,4566250.5 5411617,4566250.5 5411627,4566200.5 5411677,4566200.5
5411687,4566150.5 5411737,4566150.5 5411747,4566100.5 5411797,4566100.5
5411807,4566060.5 5411847,4566060.5 5411857,4566010.5
5411907,4565915.098 5412017.886),(4576754.5 5404012.5,4576776.5
5403986,4576829 5404012.5,4576867 5404015,4576922 5403997.5,4576982
5403960,4577216.5 5403802.5,4577247 5403857.5,4576867
5404105.5,4576821.5 5404139,4576797 5404174,4576797 5404231,4576769
5404251.5,4576756 5404223.5,4576719.5 5404206,4576682 5404223.5,4576217
5404541.5,4576102 5404634.5,4575858.5 5404836,4575672 5405012,4575631
5404971.5,4576036.5 5404614.5,4576501 5404269,4576735.5
5404121.5,4576769 5404083.5,4576773.5 5404047,4576754.5
5404012.5),(4582359.5 5393647.5,4582363 5393641.5,4582363
5393639.5,4582370.5 5393628.5,4582380 5393620,4582381.5
5393614.5,4582385 5393609,4582379.5 5393602,4582377.5 5393596.5,4582378
5393582,4582381 5393574.5,4582383 5393572.5,4582387 5393550,4582392.5
5393544,4582396 5393535.5,4582404 5393531.5,4582407.5
5393525.5,4582410.5 5393524.5,4582415.5 5393530,4582417
5393536.5,4582420 5393541,4582429.5 5393544,4582433.5 5393543,4582434
5393541,4582431 5393528,4582422 5393519,4582411.5 5393513.5,4582404
5393515,4582398 5393510,4582400 5393498.5,4582408 5393495.5,4582411.5
5393492.5,4582419 5393489,4582421.5 5393489.5,4582433 5393497.5,4582438
5393497.5,4582439 5393495.5,4582439 5393482.5,4582438 5393480,4582422
5393468,4582419.5 5393463.5,4582419 5393459.5,4582428.5
5393453.5,4582434 5393454.5,4582435 5393453.5,4582435.5
5393438.5,4582436.5 5393436,4582440 5393434,4582441 5393432,4582443
5393411.5,4582447.5 5393400,4582447 5393396,4582450.5
5393383.5,4582450.5 5393376.5,4582447.5 5393368,4582450
5393364.5,4582451 5393359,4582451.5 5393336.5,4582451 5393328.5,4582447
5393320,4582446.5 5393316,4582451 5393314.5,4582453.5
5393310.5,4582451.5 5393304.5,4582449.5 5393302.5,4582439
5393299.5,4582433 5393289.5,4582432.5 5393283,4582434.5
5393283,4582440.5 5393287,4582450 5393289.5,4582466.5 5393280,4582470.5
5393276.5,4582478 5393265,4582480.5 5393263.5,4582486 5393269.5,4582488
5393280,4582486.5 5393287,4582489 5393299,4582486 5393308.5,4582486
5393317,4582480 5393328,4582477.5 5393346.5,4582475 5393350,4582477.5
5393380,4582469.5 5393406.5,4582469.5 5393411.5,4582475.5
5393429.5,4582476.5 5393436,4582474.5 5393462.5,4582475
5393472.5,4582466.5 5393489,4582469.5 5393499,4582465.5
5393502,4582463.5 5393505.5,4582463.5 5393511,4582466.5
5393519.5,4582474.5 5393528,4582475.5 5393530.5,4582473.5
5393533,4582473.5 5393550.5,4582472 5393552.5,4582466 5393553,4582465
5393554.5,4582464.5 5393568,4582473 5393601.5,4582469.5 5393606,4582468
5393610.5,4582477 5393645,4582482 5393657,4582489 5393655.5,4582514.5
5393640.5,4582519 5393637,4582521.5 5393632.5,4582526 5393621.5,4582538
5393579,4582536.5 5393553,4582538 5393547.5,4582546.5 5393546,4582552
5393543,4582561.5 5393542,4582580 5393543.5,4582589 5393546,4582597
5393544,4582602 5393540.5,4582611 5393520.5,4582615 5393515,4582618.5
5393498,4582620.5 5393496.5,4582632 5393495,4582635 5393493,4582637.5
5393484.5,4582637 5393479.5,4582627.5 5393469,4582630 5393468,4582640
5393476.5,4582652.5 5393477,4582659 5393476,4582672 5393485.5,4582688.5
5393484,4582700 5393493.5,4582711.5 5393493.5,4582713.5
5393493,4582714.5 5393484,4582722.5 5393482,4582723 5393480.5,4582720.5
5393464,4582718.5 5393459,4582722.5 5393452,4582731 5393453.5,4582733.5
5393452,4582734.5 5393436,4582739.5 5393430.5,4582760.5
5393429,4582767.5 5393431,4582780.5 5393442.5,4582784 5393449,4582780.5
5393468.5,4582776 5393475,4582775 5393485,4582770 5393492.5,4582768
5393499,4582768 5393505,4582767 5393507,4582760.5 5393511,4582750
5393540.5,4582738.5 5393560,4582742.5 5393569.5,4582741.5
5393579,4582733 5393601.5,4582732 5393621,4582720.5 5393671,4582716
5393677,4582712.5 5393689,4582713.5 5393699.5,4582717.5 5393709,4582715
5393714.5,4582709.5 5393717,4582708 5393719,4582713 5393739.5,4582720.5
5393750,4582724 5393760.5,4582720 5393763.5,4582715 5393764.5,4582711.5
5393771,4582705.5 5393772.5,4582703 5393775,4582701 5393782,4582697.5
5393788,4582691 5393810,4582672.5 5393840.5,4582672 5393859,4582667.5
5393867,4582663 5393882.5,4582661 5393884.5,4582656 5393886,4582651
5393891.5,4582642 5393894,4582638.5 5393899,4582638.5 5393907,4582647.5
5393919.5,4582648 5393922,4582641.5 5393939,4582637 5393946.5,4582627.5
5393968.5,4582620 5393976.5,4582611.5 5393980,4582609.5
5393985,4582607.5 5393980,4582605.5 5393978.5,4582600.5
5393976.5,4582597 5393976.5,4582596 5393983.5,4582587.5
5393987,4582585.5 5393990,4582585 5393994.5,4582571.5
5393993.5,4582560.5 5393989,4582555 5393990,4582551 5393993.5,4582548
5394004.5,4582543.5 5394010.5,4582543 5394014.5,4582544.5
5394019,4582561 5394031.5,4582568.5 5394039.5,4582573
5394050.5,4582567.5 5394057,4582560 5394061.5,4582551.5
5394070.5,4582548 5394078.5,4582555.5 5394097.5,4582557.5
5394117,4582552.5 5394123,4582538.5 5394129.5,4582553.5
5394147.5,4582568.5 5394159.5,4582573.5 5394167.5,4582574
5394170,4582571 5394171,4582566.5 5394176,4582563 5394187.5,4582560.5
5394190.5,4582550 5394191,4582530.5 5394182.5,4582506
5394161.5,4582504.5 5394158,4582507 5394142,4582505 5394138,4582495.5
5394133.5,4582480 5394134,4582477 5394131.5,4582471 5394121,4582468.5
5394121.5,4582462.5 5394132,4582452.5 5394142,4582437
5394147.5,4582421.5 5394149.5,4582411.5 5394155.5,4582400
5394149.5,4582373 5394126,4582357 5394120,4582322.5 5394110,4582320
5394107.5,4582317 5394078.5,4582317.5 5394060.5,4582320
5394048.5,4582365 5394020.5,4582365.5 5394019,4582341 5393976.5,4582340
5393969.5,4582340.5 5393950,4582335 5393940,4582333.5 5393931,4582335
5393911.5,4582329.5 5393868,4582327.5 5393860,4582321.5
5393850.5,4582317 5393836.5,4582315.5 5393827,4582319 5393819.5,4582335
5393807.5,4582341 5393800,4582352 5393774.5,4582362 5393740,4582354.5
5393727,4582352.5 5393720.5,4582363 5393700.5,4582359.5
5393689.5,4582358.5 5393668.5,4582363.5 5393659.5,4582359.5
5393652,4582359.5 5393647.5),(4581936.596 5393037.937,4581932.025
5393065.361,4581928.5 5393072.5,4581839.5 5393408,4581819.5
5393415,4581809.5 5393415,4581799.5 5393425,4581789.5 5393425,4581779.5
5393435,4581759.5 5393435,4581749.5 5393445,4581699.5 5393445,4581689.5
5393435,4581669.5 5393435,4581649.5 5393415,4581639.5 5393415,4581629.5
5393405,4581619.5 5393405,4581599.5 5393385,4581589.5 5393385,4581579.5
5393375,4581569.5 5393375,4581559.5 5393365,4581549.5 5393365,4581529.5
5393345,4581519.5 5393345,4581509.5 5393335,4581499.5 5393335,4581489.5
5393325,4581479.5 5393325,4581469.5 5393335,4581459.5 5393335,4581439.5
5393355,4581429.5 5393355,4581399.5 5393385,4581349.5 5393385,4581289.5
5393325,4581289.5 5393315,4581239.5 5393265,4581239.5 5393255,4581209.5
5393225,4581209.5 5393215,4581199.5 5393205,4581199.5 5393195,4581189.5
5393185,4581189.5 5393135,4581179.5 5393125,4581179.5 5393085,4581169.5
5393075,4581179.5 5393065,4581189.5 5393065,4581199.5 5393055,4581219.5
5393055,4581229.5 5393045,4581249.5 5393045,4581259.5 5393035,4581269.5
5393035,4581279.5 5393025,4581289.5 5393025,4581299.5 5393015,4581309.5
5393015,4581319.5 5393005,4581329.5 5393005,4581349.5 5392985,4581359.5
5392985,4581389.5 5392955,4581399.5 5392955,4581419.5 5392935,4581429.5
5392935,4581459.5 5392905,4581469.5 5392905,4581499.5 5392875,4581509.5
5392875,4581529.5 5392855,4581539.5 5392855,4581569.5 5392825,4581579.5
5392825,4581609.5 5392795,4581619.5 5392795,4581639.5 5392775,4581649.5
5392775,4581679.5 5392745,4581689.5 5392745,4581719.5 5392715,4581729.5
5392715,4581759.5 5392685,4581769.5 5392685,4581789.5 5392665,4581799.5
5392665,4581829.5 5392635,4581839.5 5392635,4581869.5 5392605,4581879.5
5392605,4581909.5 5392575,4581919.5 5392575,4581949.5 5392545,4581959.5
5392545,4581979.5 5392525,4581989.5 5392525,4582009.5 5392505,4582019.5
5392505,4582004 5392622,4581994 5392717,4581955.5 5392963,4581936.596
5393037.937),(4582269.5 5392095,4582279.5 5392085,4582489.5
5392085,4582499.5 5392095,4582579.5 5392095,4582589.5 5392105,4582689.5
5392105,4582699.5 5392115,4582708.412 5392115,4582709.884
5392131.436,4582686.31 5392132.677,4582644.621 5392129.296,4582574.765
5392128.17,4582526.316 5392121.409,4582478.122 5392117.394,4582479.5
5392115,4582469.5 5392115,4582459.5 5392105,4582359.5 5392105,4582369.5
5392115,4582369.5 5392125,4582339.5 5392155,4582329.5 5392155,4582299.5
5392125,4582309.5 5392115,4582239.5 5392115,4582229.5 5392125,4582199.5
5392125,4582189.5 5392135,4582159.5 5392135,4582149.5 5392145,4582129.5
5392145,4582119.5 5392155,4582099.5 5392155,4582089.5 5392165,4582069.5
5392165,4582059.5 5392175,4582049.5 5392175,4582039.5 5392185,4582029.5
5392185,4581989.5 5392225,4581979.5 5392215,4581979.5 5392225,4581969.5
5392235,4581959.5 5392235,4581949.5 5392225,4581939.5 5392225,4581939.5
5392235,4581919.5 5392255,4581909.5 5392245,4581889.5 5392245,4581679
5392351.5,4581032 5392658.5,4580608 5392874,4580468.5 5392935,4580323.5
5392973,4580187.5 5392993.5,4580149 5392995.5,4580140
5392998.5,4580138.5 5393001.5,4580135.5 5393003.5,4580118
5393005,4580113.5 5393008.5,4580095 5393015,4580088 5393021.5,4580080
5393025,4580073.5 5393038.5,4580066 5393048.5,4580054 5393059,4580034
5393068.5,4580019.5 5393072.5,4579999.5 5393081.5,4579989
5393083.5,4579978.5 5393083.5,4579960 5393081,4579922.5
5393071.5,4579909.5 5393067,4579900 5393065.5,4579889
5393066.5,4579870.5 5393064.5,4579830 5393057.5,4579823.5
5393043,4579802 5393026.5,4579786.5 5393024,4579776.5 5393021,4579766.5
5393016,4579767 5393010,4579763 5392992.5,4579755 5392983.5,4579749.5
5392981.5,4579743 5392990,4579722 5392991.5,4579717 5392993.5,4579715
5392998.5,4579720 5393012.5,4579728 5393025,4579728 5393027.5,4579727
5393036.5,4579718.5 5393044,4579715 5393050,4579707.5 5393051,4579701.5
5393056,4579691.5 5393060,4579681.5 5393060.5,4579667.5
5393050.5,4579658.5 5393042,4579649.5 5393040.5,4579641.5
5393035.5,4579639.5 5393033,4579632.5 5393036,4579630 5393045,4579624.5
5393049.5,4579620.5 5393058.5,4579609.5 5393057,4579602.5
5393054.5,4579600 5393051,4579597 5393034,4579588 5393004,4579579.5
5392992.5,4579569 5392988.5,4579565 5392980,4579564.5
5392974.5,4579559.5 5392964.5,4579550.5 5392960,4579547.5
5392962.5,4579548.5 5392984.5,4579551 5392997,4579549.5
5392996.5,4579545 5393000,4579542 5393007.5,4579534.5
5393009.5,4579521.5 5393009,4579498 5393005.5,4579490 5393001,4579479.5
5392993,4579471.5 5392982.5,4579455.5 5392965.5,4579449.5
5392963.5,4579442 5392955,4579441 5392947,4579443.5 5392945.5,4579443.5
5392942,4579440 5392935,4579429.5 5392922.5,4579425 5392913.5,4579425.5
5392900.5,4579430.5 5392875.5,4579423.5 5392863.5,4579420
5392861,4579415.5 5392861,4579407 5392862.5,4579400 5392866,4579393
5392855.5,4579381.5 5392843,4579366 5392839.5,4579360
5392840.5,4579358.5 5392837,4579352.5 5392830,4579347 5392827,4579339.5
5392826.5,4579335.5 5392824.5,4579331.5 5392815.5,4579346.5
5392808.5,4579350 5392805,4579351 5392799.5,4579355.5
5392792.5,4579363.5 5392788.5,4579371.5 5392787.5,4579387.5
5392787.5,4579392.5 5392790,4579398 5392796.5,4579403.5 5392806,4579403
5392807.5,4579395.5 5392810.5,4579395 5392813.5,4579397
5392825.5,4579401.5 5392829.5,4579415.5 5392828,4579423.5
5392825.5,4579430.5 5392825.5,4579433 5392818.5,4579439 5392812,4579459
5392811.5,4579481.5 5392817,4579491 5392815,4579499 5392810,4579502.5
5392806,4579504.5 5392796.5,4579502 5392780,4579502.5 5392768,4579507.5
5392761,4579514 5392757.5,4579517 5392749.5,4579516 5392735.5,4579506
5392727.5,4579504 5392723,4579506 5392718,4579510.5 5392715.5,4579531
5392723,4579536.5 5392731.5,4579542 5392749,4579550 5392763,4579557
5392765.5,4579570 5392766,4579585 5392760,4579589 5392755.5,4579590
5392751.5,4579592.5 5392726,4579596 5392712.5,4579595
5392696.5,4579593.5 5392693,4579587.5 5392686,4579569.5
5392676.5,4579568 5392672.5,4579570 5392666.5,4579577 5392666,4579580
5392667,4579590.5 5392676.5,4579599.5 5392682.5,4579612.5
5392679.5,4579615 5392675,4579616.5 5392663,4579619.5 5392654,4579641
5392646.5,4579643.5 5392641,4579645.5 5392635,4579643.5
5392608.5,4579645 5392605,4579645 5392600.5,4579646.5 5392600,4579660
5392603,4579667 5392615.5,4579670 5392628,4579675 5392637,4579681
5392640,4579688 5392635.5,4579686.5 5392625.5,4579681
5392608.5,4579676.5 5392587.5,4579671 5392576.5,4579671
5392575,4579677.5 5392571.5,4579680.5 5392571.5,4579685.5
5392575.5,4579685 5392585.5,4579688 5392594.5,4579690 5392596,4579697
5392592.5,4579709.5 5392592.5,4579719.5 5392594,4579732
5392585.5,4579737 5392579.5,4579741 5392577,4579769 5392584,4579781.5
5392590.5,4579791 5392588,4579800 5392588,4579808.5 5392596,4579818.5
5392609,4579829.5 5392615.5,4579837.5 5392623,4579856 5392635,4579860.5
5392640,4579887 5392659,4579900 5392663,4579909.5 5392663,4579919
5392665,4579938 5392664,4579986 5392641.5,4580019 5392632.5,4580039
5392625.5,4580071.5 5392618,4580079.5 5392614.5,4580103
5392616,4580120.5 5392612.5,4580140 5392605.5,4580159 5392605.5,4580183
5392597.5,4580230.5 5392593,4580244.5 5392589.5,4580261.5
5392582.5,4580274 5392567.5,4580282.5 5392553,4580287 5392542,4580288
5392534.5,4580293 5392527,4580296 5392517,4580300 5392509.5,4580310.5
5392504,4580319 5392502,4580329.5 5392497,4580356.5 5392476,4580380
5392469,4580418.5 5392471.5,4580448.5 5392471,4580460 5392472,4580467
5392470,4580479 5392461.5,4580480.5 5392462,4580488.5
5392467.5,4580502.5 5392472,4580523.5 5392484,4580541
5392495.5,4580547.5 5392503,4580549 5392508,4580549 5392514.5,4580543.5
5392526,4580530.5 5392546,4580512 5392567,4580487 5392582.5,4580462
5392608.5,4580441 5392620,4580428.5 5392632,4580418.5
5392638.5,4580410.5 5392646.5,4580399.5 5392654,4580387.5
5392669.5,4580359 5392694.5,4580350 5392706.5,4580341
5392721.5,4580332.5 5392727.5,4580324.5 5392736,4580313 5392755,4580304
5392762,4580290 5392769.5,4580280.5 5392778,4580257 5392793.5,4580241.5
5392807.5,4580229.5 5392814.5,4580223.5 5392821.5,4580198.5
5392843.5,4580180.5 5392865.5,4580170 5392875.5,4580166
5392881.5,4580159.5 5392886.5,4580150 5392899,4580140
5392908.5,4580131.5 5392924.5,4580123.5 5392946.5,4580122.5
5392965,4580125 5392974.5,4580147 5392976,4580151.5 5392975.5,4580155
5392970.5,4580160 5392970.5,4580165.5 5392968.5,4580175
5392967.5,4580221.5 5392967.5,4580231 5392965.5,4580233.5
5392961.5,4580236.5 5392959.5,4580242 5392958.5,4580259.5
5392958,4580279 5392955.5,4580291.5 5392956.5,4580297.5
5392951.5,4580300 5392952,4580389.5 5392930.5,4580506.5 5392891,4580684
5392806.5,4581101 5392602,4581864.5 5392231.5,4581899.5
5392215,4581919.5 5392215,4581929.5 5392205,4581939.5 5392205,4581949.5
5392195,4581959.5 5392195,4581969.5 5392185,4581979.5 5392185,4581989.5
5392175,4581999.5 5392175,4581999.5 5392165,4582009.5 5392155,4582019.5
5392165,4582029.5 5392165,4582039.5 5392155,4582049.5 5392155,4582059.5
5392145,4582079.5 5392145,4582089.5 5392135,4582109.5 5392135,4582119.5
5392125,4582139.5 5392125,4582149.5 5392115,4582169.5 5392115,4582179.5
5392105,4582209.5 5392105,4582219.5 5392095,4582269.5
5392095))',31468))-st_area(st_transform(st_geomfromtext('POLYGON((4562878 5410125.5,4562864.5
5410124,4562855 5410115,4562852.5 5410115,4562813 5410144,4562768.5
5410147,4562728 5410147,4562718 5410157,4562688 5410157,4562678
5410167,4562638 5410167,4562628 5410177,4562608 5410177,4562598
5410187,4562579 5410187,4562569.5 5410192,4562539.5 5410192,4562529.5
5410202,4562499.5 5410202,4562479.5 5410182,4562449.5 5410182,4562429.5
5410202,4562409.5 5410202,4562399.5 5410212,4562369.5 5410212,4562349.5
5410232,4562339.5 5410232,4562329.5 5410242,4562319.5 5410242,4562299.5
5410262,4562289.5 5410252,4562289.5 5410242,4562279.5 5410242,4562269.5
5410232,4562259.5 5410242,4562259.5 5410252,4562249.5 5410262,4562229.5
5410262,4562219.5 5410272,4562219.5 5410292,4562209.5 5410302,4562199.5
5410302,4562199.5 5410312,4562189.5 5410322,4562179.5 5410322,4562169.5
5410332,4562169.5 5410342,4562129.5 5410382,4562109.5 5410382,4562099.5
5410392,4562109.5 5410402,4562099.5 5410412,4562079.5 5410412,4562069.5
5410402,4562059.5 5410402,4562049.5 5410412,4562049.5 5410432,4562039.5
5410442,4562029.5 5410442,4562019.5 5410452,4561939.5 5410452,4561929.5
5410462,4561909.5 5410462,4561899.5 5410472,4561829.5 5410472,4561819.5
5410462,4561809.5 5410462,4561799.5 5410472,4561779.5 5410472,4561739.5
5410432,4561739.5 5410422,4561729.5 5410412,4561729.5 5410372,4561719.5
5410361,4561719.5 5410351,4561709.5 5410341,4561709.5 5410331,4561699.5
5410321,4561699.5 5410311,4561679.5 5410291,4561659.5 5410291,4561639.5
5410271,4561639.5 5410261,4561579.5 5410201,4561569.5 5410201,4561589.5
5410221,4561569.5 5410241,4561619.5 5410291,4561619.5 5410311,4561639.5
5410331,4561639.5 5410361,4561649.5 5410371,4561649.5 5410381,4561629.5
5410401,4561619.5 5410391,4561629.5 5410381,4561609.5 5410381,4561609.5
5410401,4561599.5 5410411,4561589.5 5410411,4561579.5 5410401,4561559.5
5410401,4561549.5 5410411,4561529.5 5410411,4561479.5 5410361,4561479.5
5410351,4561419.5 5410291,4561419.5 5410281,4561409.5 5410281,4561379.5
5410251,4561320.5 5410201,4561378.5 5410101.5,4561378.5
5410088,4561365.5 5410074.5,4561191 5409940.5,4561176.5 5409934,4561101
5409881,4561060.5 5409858,4560971.5 5409821.5,4560965.5
5409812.5,4560965 5409802.5,4560969.5 5409787,4560974 5409774.5,4560988
5409746,4560999 5409715,4561008 5409698.5,4561012.5 5409685.5,4561012
5409679.5,4561007.5 5409671.5,4560999 5409662.5,4560956.5
5409647,4560939 5409643.5,4560929 5409645,4560918 5409650,4560876
5409692,4560886 5409668,4560890.5 5409648,4560888 5409637,4560885.5
5409632.5,4560870.5 5409630,4560854.5 5409624,4560809
5409611.5,4560772.5 5409597,4560760 5409598.5,4560756
5409600.5,4560711.5 5409663,4560734.5 5409603.5,4560738 5409597,4560741
5409578,4560740.5 5409569.5,4560738 5409563.5,4560732.5
5409556.5,4560715.5 5409541,4560709.5 5409537.5,4560710
5409531.5,4560703 5409518,4560698.5 5409504.5,4560702 5409495,4560708
5409489.5,4560717 5409487.5,4560724 5409493.5,4560735.5
5409482.5,4560734 5409473.5,4560725 5409472,4560722 5409469,4560725.5
5409464.5,4560728 5409456.5,4560739.5 5409456,4560740.5
5409443,4560731.5 5409435.5,4560738 5409415,4560746 5409415,4560751.5
5409411,4560742 5409370.5,4560741 5409361.5,4560742 5409343.5,4560740
5409335,4560731.5 5409329,4560713 5409320.5,4560680 5409309.5,4560659.5
5409301,4560646 5409296.5,4560628 5409298,4560614.5 5409305,4560576
5409305.5,4560565 5409302.5,4560534 5409284,4560504 5409276.5,4560469
5409273.5,4560420 5409272,4560397 5409276,4560378.5 5409277,4560361.5
5409275,4560351.5 5409271.5,4560327 5409258.5,4560317 5409254.5,4560302
5409251,4560209.5 5409246.5,4560186 5409243,4560154.5 5409232.5,4560136
5409224.5,4560117.5 5409220,4560100.5 5409224,4560092.5 5409233,4560094
5409239,4560102.5 5409245,4560161 5409268,4560176 5409270.5,4560188
5409270.5,4560200 5409276,4560211 5409275,4560219 5409282.5,4560251
5409290.5,4560336.5 5409301,4560340.5 5409299,4560362.5
5409304,4560371.5 5409304.5,4560388 5409310.5,4560404.5
5409311.5,4560435 5409318,4560470.5 5409323.5,4560478.5 5409317,4560486
5409314.5,4560500.5 5409315,4560508 5409319.5,4560511
5409325.5,4560520.5 5409330,4560532 5409327,4560545.5
5409325.5,4560553.5 5409329,4560553.5 5409334.5,4560570
5409349.5,4560577.5 5409353.5,4560611.5 5409364.5,4560618
5409370,4560618.5 5409376,4560615.5 5409382.5,4560609
5409386.5,4560600.5 5409389,4560593.5 5409394,4560586 5409402.5,4560576
5409408.5,4560570.5 5409415,4560561.5 5409418.5,4560549
5409413.5,4560546.5 5409414.5,4560524 5409405,4560513.5
5409412.5,4560494 5409419.5,4560470 5409434,4560462 5409435,4560448
5409429,4560447 5409425,4560445.5 5409424,4560441.5 5409431.5,4560438.5
5409431,4560420 5409461.5,4560413 5409459.5,4560409 5409450,4560390
5409455.5,4560373.5 5409450,4560368 5409449.5,4560362.5
5409451.5,4560357 5409457,4560336.5 5409493.5,4560314.5 5409540,4560309
5409546.5,4560303.5 5409548.5,4560295.5 5409549,4560290.5
5409548,4560288 5409549.5,4560289 5409564.5,4560282 5409577,4560283
5409581.5,4560249.5 5409553.5,4560195.5 5409517.5,4560189
5409518.5,4560177.5 5409510.5,4560119.5 5409483.5,4560089.5
5409472,4560071.5 5409461.5,4560028.5 5409439.5,4560016.5
5409425.5,4560006 5409415.5,4559990 5409410,4559984.5 5409412,4559981.5
5409415.5,4559974 5409412,4559966 5409415.5,4559961 5409415.5,4559940
5409405.5,4559934.5 5409401,4559924 5409402,4559913 5409399,4559878
5409375.5,4559859.5 5409369.5,4559846 5409368,4559826 5409362.5,4559823
5409355.5,4559747 5409341,4559709 5409330,4559708 5409326,4559705
5409322.5,4559664 5409317.5,4559614.5 5409316,4559594 5409318,4559560
5409314,4559546.5 5409315,4559527 5409313.5,4559495 5409309.5,4559465
5409310.5,4559451 5409312.5,4559440.5 5409300,4559432 5409301.5,4559424
5409310,4559386 5409315,4559358.5 5409314.5,4559354 5409311.5,4559327.5
5409313.5,4559325.5 5409316.5,4559243.5 5409323,4559227.5
5409322.5,4559203.5 5409330.5,4559195.5 5409328,4559188.5
5409331,4559177 5409331.5,4559155.5 5409327,4559133.5
5409333.5,4559114.5 5409348.5,4559092 5409354.5,4559069.5
5409358,4559045 5409356,4558966 5409374.5,4558944 5409378.5,4558917.5
5409381,4558909.5 5409386.5,4558905 5409383,4558904.5 5409384.5,4558909
5409390,4558866 5409414,4558856.5 5409413,4558851 5409416.5,4558846
5409414.5,4558829.5 5409418,4558809.5 5409415.5,4558790.5
5409429,4558781.5 5409433,4558778.5 5409431,4558776.5
5409427.5,4558757.5 5409432.5,4558758 5409442,4558755.5
5409443,4558745.5 5409442,4558731 5409446,4558721.5 5409444,4558694
5409452.5,4558687.5 5409460.5,4558673 5409460.5,4558666
5409455.5,4558640.5 5409442,4558622.5 5409427.5,4558586.5
5409392,4558569.5 5409387,4558563 5409383,4558559 5409387,4558552.5
5409387.5,4558541 5409394,4558543 5409398.5,4558552.5
5409402.5,4558546.5 5409407,4558532 5409403.5,4558528 5409407,4558535
5409429,4558547.5 5409441,4558554 5409458.5,4558560.5 5409495,4558559.5
5409522,4558516 5409540.5,4558496 5409558,4558490.5 5409558.5,4558416
5409606,4558348.5 5409645.5,4558316 5409675.5,4558284.5
5409695.5,4558258.5 5409702.5,4558246.5 5409715,4558226.5
5409739.5,4558188 5409776.5,4558130.5 5409821,4558105.5
5409836,4558086.5 5409831.5,4558074.5 5409835.5,4558061 5409850,4558057
5409874.5,4558046 5409884.5,4558042 5409893.5,4557990 5409938,4557968
5409949.5,4558025 5409896,4558029 5409875.5,4558008 5409858,4558004
5409858.5,4557973.5 5409819.5,4557969.5 5409807.5,4557956.5
5409786.5,4557941.5 5409791.5,4557930.5 5409809,4557889.5
5409865,4557843.5 5409924.5,4557774.5 5409988,4557771 5409994,4557782
5410056.5,4557793.5 5410082.5,4557808 5410085,4557812.5
5410090,4557809.5 5410098.5,4557786.5 5410111.5,4557772
5410077.5,4557759.5 5410075.5,4557746 5410078.5,4557733 5410085,4557735
5410094.5,4557749 5410114,4557758.5 5410122,4557770 5410115,4557775.5
5410122,4557781 5410125,4557778.5 5410129,4557765.5 5410135,4557761
5410130.5,4557733.5 5410146.5,4557728.5 5410152.5,4557737.5
5410176,4557736 5410184,4557708.5 5410216.5,4557710.5
5410222.5,4557704.5 5410230,4557699 5410235,4557682.5 5410237,4557677
5410235,4557651.5 5410218.5,4557634.5 5410222.5,4557618 5410219,4557607
5410211.5,4557595 5410211,4557598.5 5410214,4557598.5 5410225,4557605.5
5410226.5,4557631 5410253.5,4557652.5 5410267.5,4557661.5
5410285,4557657.5 5410310,4557651 5410320.5,4557639.5 5410329.5,4557585
5410395,4557555.5 5410426.5,4557527.5 5410453,4557508.5
5410463,4557476.5 5410487.5,4557446 5410506.5,4557425.5 5410521,4557405
5410532.5,4557370 5410560,4557365 5410558.5,4557343 5410541.5,4557359
5410559.5,4557358.5 5410568,4557350 5410579,4557305.5 5410615,4557285.5
5410634,4557264 5410649,4557230.5 5410667.5,4557218 5410667.5,4557210
5410670.5,4557196.5 5410669,4557187.5 5410661.5,4557171.5
5410644.5,4557149 5410637.5,4557130.5 5410628.5,4557119.5
5410606.5,4557114.5 5410593,4557117 5410561,4557114 5410524,4557107.5
5410500.5,4557099 5410499,4557096.5 5410475,4557098 5410461,4557104.5
5410432.5,4557117 5410420.5,4557120.5 5410410.5,4557010
5410491,4557015.5 5410511.5,4557016 5410529,4557004 5410546.5,4556998.5
5410559,4556995 5410573,4556997 5410591,4557005.5 5410608,4557008.5
5410624.5,4557008.5 5410652,4557004 5410709.5,4556998
5410723.5,4557000.5 5410762,4556995 5410786.5,4556998 5410809,4556995
5410821.5,4556956.5 5410867,4556940.5 5410893,4556875 5410953,4556767.5
5411072,4556784.725 5411085.737,4556774.564 5411092.394,4556703.412
5411170.442,4556683.282 5411189.629,4556665.423 5411208.811,4556605.314
5411288.567,4556599.959 5411294.057,4556647.842 5411359.72,4556995.974
5411003.444,4557197.748 5410801.332,4557392.967 5410603.397,4557541.06
5410501.049,4557764.003 5410347.387,4557947.478 5410250.481,4558154.397
5410140.961,4558220.546 5410106.646,4558376.668 5410037.51,4558680.651
5409903.06,4559121.415 5409819.081,4559165.688 5409816.129,4559373.626
5409802.159,4559621.729 5409784.98,4559630.705 5409786.091,4559978.004
5409829.769,4560200.677 5409855.981,4560227.326 5409864.282,4560391.847
5409915.533,4560587.746 5409975.333,4561020.622 5410199.564,4561387.331
5410407.445,4561403.673 5410420.025,4561683.803 5410635.716,4561755.313
5410760.667,4561874.666 5410974.179,4562013.359 5411265.561,4562217.2
5411541.675,4562414.933 5411709.379,4562221.271 5412402.845,4562223.323
5412402.94,4562331.501 5412408.029,4562494.84 5412415.824,4562444.198
5412636.97,4562260.207 5412859.642,4562229.446 5412873.408,4561964.907
5412988.885,4561974.557 5413037.134,4561975.186 5413039.816,4561977.772
5413053.209,4562012.086 5413230.933,4562039.061 5413363.264,4562377.269
5413606.804,4562053.618 5414016.114,4562052.294 5414017.794,4561918.281
5414049.585,4561789.923 5414080.142,4561711.737 5414352.528,4561706.707
5414370.507,4561701.923 5414385.701,4561649.506 5414562.886,4561629.344
5414631.607,4561611.337 5414691.908,4561585.573 5414778.189,4561616.264
5414821.65,4561624.794 5414833.706,4561632 5414826.5,4561652
5414826.5,4561662 5414816.5,4561672 5414826.5,4561682 5414826.5,4561692
5414816.5,4561702 5414826.5,4561702 5414866.5,4561722 5414886.5,4561722
5414906.5,4561779 5414962.5,4561830 5414895.5,4561847 5414863,4562027
5414683,4562027 5414673,4562087 5414613,4562097 5414613,4562237
5414473,4562247 5414473,4562307 5414413,4562317 5414413,4562367
5414363,4562377 5414363,4562417 5414323,4562427 5414323,4562467
5414283,4562477 5414283,4562507 5414253,4562517 5414253,4562547
5414223,4562557 5414223,4562587 5414193,4562597 5414193,4562627
5414163,4562637 5414163,4562657 5414143,4562667 5414143,4562677
5414133,4562687 5414133,4562697 5414123,4562707 5414123,4562717
5414113,4562727 5414113,4562737 5414123,4562677 5414183,4562667
5414183,4562637 5414213,4562627 5414213,4562597 5414243,4562587
5414243,4562557 5414273,4562547 5414273,4562507 5414313,4562497
5414313,4562447 5414363,4562437 5414363,4562377 5414423,4562367
5414423,4562257 5414533,4562247 5414533,4562047 5414733,4562047
5414743,4561947 5414843,4561947 5414863,4561957 5414863,4561967
5414873,4561957 5414883,4561916 5414884,4561913.5 5414897,4561897
5414913,4561871.5 5414944.5,4561867 5414953,4561860.5 5414956.5,4561857
5414963,4561838 5414983.5,4561827 5414993,4561817 5414993,4561817
5415013,4561827 5415023,4561827 5415089.134,4561837 5415093,4561837
5415003,4561848.5 5414992.5,4561847 5414983,4561883.5
5414946.5,4561889.5 5414942.5,4561899 5414927.5,4561915
5414909.5,4561917 5414903,4561927 5414893,4561937 5414903,4561937
5414923,4561927 5414933,4561937 5414943,4561947 5414943,4561967
5414963,4561977 5414953,4561997 5414973,4561997 5414983,4562027
5414983,4562047 5415003,4562037 5415013,4562047 5415023,4562077
5415023,4562077 5415003,4562087 5414993,4562077 5414983,4562097
5414963,4562107 5414973,4562107 5414903,4562097 5414893,4562097
5414873,4562087 5414863,4562087 5414853,4562077 5414853,4562067
5414843,4562077 5414833,4562087 5414833,4562097 5414823,4562107
5414833,4562107 5414863,4562117 5414873,4562117 5414883,4562127
5414893,4562127 5415013,4562147 5415013,4562157 5415023,4562167
5415023,4562187 5415043,4562187 5415053,4562197 5415063,4562257
5415063,4562267 5415053,4562277 5415053,4562297 5415033,4562327
5415033,4562337 5415023,4562367 5415023,4562377 5415013,4562387
5415023,4562407 5415023,4562417 5415013,4562427 5415013,4562427
5415003,4562447 5414983,4562447 5414973,4562457 5414963,4562477
5414963,4562487 5414953,4562557 5414953,4562567 5414963,4562597
5414963,4562607 5414973,4562617 5414973,4562637 5414993,4562637
5415003,4562657 5415023,4562657 5415043,4562667 5415053,4562667
5415063,4562677 5415073,4562677 5415083,4562687 5415093,4562697
5415093,4562707 5415103,4562717 5415103,4562727 5415113,4562737
5415113,4562757 5415133,4562767 5415123,4562807 5415123,4562817
5415133,4562837 5415113,4562857 5415113,4562867 5415103,4562877
5415103,4562897 5415083,4562907 5415083,4562917 5415073,4562927
5415073,4562977 5415023,4562977 5415013,4563037 5414953,4563037
5414933,4562997 5414893,4563007 5414883,4563047 5414923,4563047
5414913,4563057 5414903,4563087 5414873,4563097 5414873,4563117
5414853,4563117 5414843,4563137 5414823,4563137 5414813,4563157
5414793,4563157 5414783,4563177 5414763,4563177 5414743,4563197
5414723,4563207 5414723,4563207 5414713,4563217 5414703,4563217
5414693,4563237 5414673,4563237 5414663,4563257 5414643,4563257
5414623,4563267 5414613,4563267 5414593,4563257 5414583,4563257
5414553,4563267 5414543,4563267 5414523,4563277 5414513,4563277
5414473,4563257 5414473,4563247 5414483,4563237 5414483,4563227
5414473,4563217 5414473,4563207 5414463,4563197 5414463,4563157
5414423,4563157 5414413,4563147 5414403,4563147 5414383,4563157
5414373,4563157 5414343,4563167 5414333,4563167 5414323,4563177
5414313,4563187 5414313,4563197 5414303,4563217 5414303,4563227
5414293,4563257 5414293,4563267 5414283,4563267 5414263,4563277
5414253,4563297 5414253,4563297 5414243,4563307 5414233,4563317
5414233,4563327 5414223,4563337 5414233,4563347 5414223,4563357
5414223,4563367 5414213,4563407 5414213,4563417 5414203,4563447
5414203,4563457 5414193,4563467 5414203,4563527 5414203,4563537
5414213,4563577 5414213,4563597 5414193,4563677 5414193,4563697
5414213,4563717 5414193,4563837 5414193,4563867 5414223,4563867
5414233,4563857 5414243,4563857 5414273,4563867 5414263,4563887
5414283,4563887 5414293,4563917 5414323,4564007 5414323,4564017
5414333,4564077 5414333,4564087 5414323,4564127 5414323,4564137
5414333,4564147 5414333,4564157 5414323,4564167 5414323,4564177
5414313,4564207 5414313,4564217 5414303,4564237 5414303,4564247
5414313,4564247 5414353,4564257 5414353,4564267 5414363,4564307
5414363,4564317 5414373,4564347 5414373,4564357 5414383,4564387
5414383,4564397 5414393,4564407 5414393,4564417 5414383,4564467
5414383,4564477 5414393,4564497 5414393,4564507 5414403,4564527
5414403,4564537 5414413,4564587 5414413,4564597 5414423,4564607
5414413,4564617 5414423,4564707 5414423,4564717 5414433,4564817
5414433,4564837 5414453,4564837 5414463,4564847 5414453,4564857
5414453,4564867 5414443,4564877 5414443,4564887 5414433,4564907
5414433,4564917 5414423,4564947 5414423,4564957 5414413,4564967
5414413,4564987 5414393,4564997 5414393,4565007 5414383,4565017
5414383,4565027 5414373,4565027 5414333,4565037 5414323,4565037
5414293,4565047 5414283,4565057 5414293,4565057 5414333,4565067
5414343,4565077 5414343,4565087 5414333,4565087 5414323,4565097
5414313,4565097 5414263,4565107 5414253,4565107 5414233,4565117
5414223,4565117 5414213,4565137 5414193,4565197 5414193,4565207
5414198,4565287 5414198,4565297 5414188,4565317 5414208,4565327
5414198,4565337 5414198,4565347 5414188,4565377 5414188,4565407
5414158,4565417 5414158,4565427 5414148,4565437 5414148,4565447
5414138,4565467 5414138,4565477 5414128,4565487 5414128,4565497
5414118,4565507 5414118,4565517 5414108,4565527 5414108,4565537
5414098,4565577 5414098,4565587 5414088,4565607 5414088,4565617
5414078,4565627 5414078,4565637 5414068,4565647 5414068,4565647
5414048,4565657 5414038,4565677 5414038,4565697 5414018,4565717
5414018,4565737 5413998,4565757 5413998,4565767 5413988,4565787
5413988,4565797 5413978,4565807 5413978,4565827 5413958,4565837
5413958,4565837 5413948,4565847 5413938,4565857 5413938,4565857
5413918,4565847 5413928,4565837 5413928,4565827 5413918,4565837
5413908,4565847 5413908,4565857 5413918,4565857 5413908,4565867
5413898,4565857 5413888,4565867 5413878,4565867 5413868,4565877
5413858,4565867 5413848,4565867 5413838,4565857 5413828,4565857
5413618,4565827 5413588,4565827 5413578,4565817 5413568,4565817
5413428,4565827 5413418,4565837 5413418,4565867 5413388,4565877
5413388,4565887 5413378,4565917 5413378,4565927 5413388,4565957
5413388,4565967 5413398,4566017 5413398,4566037 5413378,4566067
5413378,4566077 5413388,4566087 5413388,4566097 5413398,4566167
5413398,4566187 5413418,4566367 5413418,4566387 5413438,4566597
5413438,4566617 5413418,4566677 5413418,4566687 5413408,4566697
5413408,4566707 5413398,4566737 5413398,4566757 5413378,4566767
5413378,4566777 5413368,4566797 5413368,4566807 5413358,4566867
5413358,4566877 5413348,4566887 5413348,4566897 5413338,4566917
5413338,4566927 5413328,4566947 5413328,4566957 5413318,4566977
5413318,4566997 5413298,4567027 5413298,4567047 5413278,4567087
5413278,4567107 5413298,4567107 5413308,4567117 5413318,4567117
5413328,4567127 5413338,4567127 5413358,4567137 5413368,4567147
5413368,4567187 5413408,4567197 5413408,4567217 5413428,4567237
5413428,4567257 5413448,4567257 5413458,4567267 5413468,4567397
5413468,4567407 5413458,4567427 5413458,4567437 5413448,4567447
5413448,4567457 5413438,4567487 5413438,4567507 5413458,4567507
5413468,4567517 5413478,4567517 5413498,4567527 5413508,4567527
5413528,4567517 5413538,4567517 5413548,4567567 5413548,4567577
5413558,4567577 5413568,4567587 5413578,4567587 5413588,4567597
5413578,4567607 5413578,4567617 5413568,4567627 5413578,4567627
5413588,4567637 5413588,4567647 5413598,4567657 5413588,4567657
5413558,4567665.243 5413533.64,4567646.634 5413523.581,4567629.031
5413510.504,4567616.347 5413486.285,4567610.424 5413460.792,4567610.167
5413440.706,4567585.446 5413380.965,4567577.352 5413347.584,4567563.914
5413333.141,4567546.364 5413319.339,4567520.952 5413307.638,4567521.226
5413312.848,4567511.536 5413311.568,4567493.162 5413311.934,4567475.886
5413317.145,4567465.374 5413316.962,4567437.037 5413325.737,4567417.383
5413336.615,4567362.171 5413353.343,4567348.277 5413359.285,4567326.064
5413357.914,4567314.272 5413353.252,4567297.91 5413337.712,4567258.329
5413291.093,4567208.785 5413210.56,4567166.918 5413136.792,4567173.774
5413130.393,4567154.395 5413098.49,4567141.506 5413071.799,4567137.484
5413058.087,4567135.29 5413038.342,4567135.199 5413014.393,4567145.345
5412965.031,4567177.522 5412836.234,4567186.95 5412787.946,4567180.233
5412787.133,4567193.282 5412731.034,4567216.318 5412641.73,4567222.629
5412606.703,4567252.689 5412603.49,4567251.689 5412596.493,4567252.053
5412560.597,4567263.866 5412545.512,4567264.048 5412538.242,4567274.135
5412517.614,4567287.312 5412504.8,4567294.764 5412492.987,4567283.496
5412477.356,4567302.034 5412450.094,4567306.032 5412433.646,4567323.935
5412426.103,4567343.564 5412414.289,4567374.461 5412401.749,4567425.714
5412350.495,4567429.258 5412343.68,4567453.249 5412325.868,4567475.332
5412298.697,4567480.603 5412279.704,4567494.506 5412261.166,4567508.137
5412249.897,4567525.767 5412222.271,4567589.197 5412139.03,4567625.82
5412098.318,4567667.44 5412063.786,4567689.432 5412048.337,4567729.144
5412025.346,4567869.273 5411951.556,4567881.814 5411958.008,4567909.894
5411946.103,4567918.163 5411945.921,4567922.798 5411947.103,4567919.89
5411942.014,4567915.891 5411929.655,4567965.873 5411876.312,4567986.956
5411851.412,4568014.893 5411809.125,4568048.485 5411767.046,4568076.193
5411745.226,4568061.335 5411712.827,4568190.541 5411630.705,4568354.239
5411521.755,4568557.082 5411415.817,4568614.568 5411392.822,4568747.607
5411342.454,4568906.104 5411286.337,4568920.338 5411259.51,4568994.249
5411224.471,4569126.466 5411149.739,4569170.265 5411126.745,4569288.796
5411067.89,4569495.197 5410978.103,4569450.304 5410864.773,4569482.331
5410827.818,4569484.167 5410831.215,4569485.664 5410828.327,4569523.5
5410904,4569590.418 5411025.454,4569612.085 5410933.483,4569647.672
5410857.93,4569733.175 5410784.301,4569742.563 5410774.371,4569749.319
5410770.537,4569782.627 5410742.137,4569813.253 5410734.248,4569822.5
5410729,4569773.628 5410638.736,4569808.558 5410621.11,4569843.219
5410686.432,4569861.397 5410725.73,4569878.29 5410722.235,4570196.251
5410558.456,4570356.391 5410473.87,4570635.941 5410322.337,4570606.837
5410267.575,4570630.508 5410258.537,4570655.5 5410309.5,4570784
5410236,4570775.5 5410216.5,4570779.5 5410204,4570768.658
5410177.979,4570874.375 5410084.249,4570957.523 5410003.378,4570992.832
5409964.652,4571060.035 5409883.782,4571094.205 5409859.862,4571063.452
5409903.145,4571019.03 5409958.957,4570984.859 5409997.683,4570941.577
5410042.105,4570776.419 5410190.177,4570793.504 5410215.235,4570802.617
5410211.818,4570819.702 5410201.567,4570842.482 5410181.065,4570837.926
5410174.231,4570855.012 5410158.284,4570864.123 5410160.563,4570883.487
5410171.953,4570932.464 5410142.338,4570951.267 5410147.76,4570956.132
5410145.083,4571131.529 5409917.548,4571148.327 5409884.502,4571175.154
5409814.972,4571184.69 5409848.585,4571683.5 5409201.5,4571802
5409078.5,4571841 5409022,4571875.5 5408901,4571904.5 5408835.5,4571951
5408756,4571971 5408692.5,4571995.5 5408405,4572004.5 5408250,4572011.5
5408176.5,4572045 5408090,4572107 5408022,4572247 5407949.5,4572326.5
5407923.5,4572436.5 5407865.5,4572529 5407792,4572706.5 5407665,4572870
5407588,4573030.5 5407478.5,4573128.5 5407364,4573208 5407292,4573212.5
5407241,4573274.5 5407200.5,4573352.5 5407180.5,4573436.5
5407118.5,4573582.5 5407039,4573871.5 5406920.5,4573962.5
5406904.5,4574082.5 5406907.5,4574253 5406942,4574347
5406920.5,4574475.5 5406861,4574547.5 5406820.5,4574602.5
5406777,4574743 5406628.5,4574805 5406582,4574894.5 5406527,4575182
5406420,4575241.5 5406385.5,4575335.5 5406297,4575510 5406121,4575579.5
5406025.5,4575623 5405970.5,4575735.5 5405853.5,4575790.5
5405810,4576007 5405779.5,4576019 5405738,4576102.5 5405700,4576175
5405723.5,4576212.5 5405717.5,4576326.5 5405674,4576524.5
5405631,4576627 5405568.5,4576744 5405487.5,4576854 5405428.5,4576933.5
5405409.5,4577111.5 5405385,4577271.5 5405378,4577316.5
5405392.5,4577370 5405405.5,4577411.624 5405410.703,4577424.176
5405412.272,4577438 5405414,4577487.859 5405414.719,4577503.352
5405414.943,4577521.471 5405415.204,4577523.839 5405415.238,4577524.287
5405415.245,4577542 5405415.5,4577557.5 5405412.5,4577557.122
5405408.312,4577555.702 5405392.567,4577551.5 5405346,4577531.545
5405302.961,4577524.293 5405287.319,4577517.407 5405272.468,4577510.274
5405257.084,4577505.36 5405246.486,4577382.5 5404981.5,4577356.5
5404852,4577347.5 5404718,4577414.5 5404594,4577477.5 5404548.5,4577467
5404518,4577488 5404459.5,4577538 5404409.5,4577538 5404399.5,4577558
5404379.5,4577558 5404369.5,4577568 5404359.5,4577568 5404349.5,4577678
5404239.5,4577708 5404239.5,4577718 5404229.5,4577728 5404229.5,4577748
5404249.5,4577758 5404249.5,4577768 5404259.5,4577778 5404259.5,4577788
5404269.5,4577808 5404269.5,4577818 5404279.5,4577818 5404289.5,4577828
5404299.5,4577838 5404299.5,4577848 5404309.5,4577878 5404309.5,4577888
5404319.5,4577898 5404319.5,4577908 5404309.5,4577938 5404309.5,4577988
5404259.5,4577988 5404249.5,4577998 5404239.5,4578008 5404239.5,4578018
5404229.5,4578038 5404229.5,4578048 5404219.5,4578078 5404219.5,4578078
5404209.5,4578108 5404179.5,4578118 5404179.5,4578128 5404169.5,4578208
5404169.5,4578248 5404129.5,4578248 5404119.5,4578258 5404109.5,4578258
5404079.5,4578288 5404049.5,4578298 5404049.5,4578328 5404019.5,4578348
5404019.5,4578358 5404009.5,4578368 5403999.5,4578368 5403989.5,4578378
5403979.5,4578378 5403959.5,4578398 5403939.5,4578408 5403939.5,4578448
5403899.5,4578468 5403899.5,4578558 5403809.5,4578568 5403809.5,4578618
5403759.5,4578618 5403749.5,4578628 5403739.5,4578638 5403739.5,4578678
5403699.5,4578688 5403699.5,4578698 5403689.5,4578708 5403689.5,4578718
5403679.5,4578738 5403679.5,4578758 5403659.5,4578758 5403649.5,4578768
5403639.5,4578768 5403609.5,4578778 5403599.5,4578778 5403589.5,4578788
5403579.5,4578788 5403569.5,4578798 5403559.5,4578808 5403559.5,4578828
5403539.5,4578838 5403539.5,4578868 5403509.5,4578878 5403509.5,4578878
5403489.5,4578868 5403479.5,4578868 5403459.5,4578848 5403459.5,4578838
5403449.5,4578818 5403449.5,4578808 5403439.5,4578788 5403439.5,4578778
5403429.5,4578728 5403429.5,4578718 5403439.5,4578708 5403439.5,4578698
5403449.5,4578648 5403449.5,4578638 5403439.5,4578608 5403439.5,4578578
5403409.5,4578578 5403399.5,4578608 5403369.5,4578638 5403369.5,4578648
5403359.5,4578658 5403359.5,4578658 5403279.5,4578648 5403289.5,4578618
5403289.5,4578608 5403299.5,4578598 5403289.5,4578588 5403289.5,4578568
5403269.5,4578568 5403239.5,4578578 5403229.5,4578578 5403219.5,4578618
5403179.5,4578618 5403169.5,4578628 5403159.5,4578628 5403119.5,4578678
5403069.5,4578678 5403059.5,4578688 5403049.5,4578708 5403049.5,4578708
5403039.5,4578718 5403029.5,4578738 5403029.5,4578738 5403019.5,4578758
5402999.5,4578758 5402989.5,4578738 5402969.5,4578738 5402959.5,4578728
5402949.5,4578738 5402939.5,4578738 5402929.5,4578778 5402889.5,4578778
5402879.5,4578798 5402859.5,4578798 5402849.5,4578808 5402839.5,4578808
5402829.5,4578818 5402819.5,4578818 5402789.5,4578828 5402779.5,4578828
5402769.5,4578838 5402759.5,4578838 5402749.5,4578848 5402739.5,4578848
5402729.5,4578858 5402719.5,4578858 5402699.5,4578868 5402689.5,4578868
5402649.5,4578878 5402639.5,4578878 5402629.5,4578898 5402609.5,4578898
5402599.5,4578918 5402579.5,4578918 5402569.5,4578928 5402559.5,4578928
5402539.5,4578908 5402519.5,4578908 5402509.5,4578888 5402489.5,4578888
5402479.5,4578858 5402449.5,4578858 5402419.5,4578848 5402409.5,4578848
5402389.5,4578838 5402379.5,4578838 5402369.5,4578798 5402329.5,4578798
5402309.5,4578778 5402289.5,4578778 5402279.5,4578768 5402269.5,4578768
5402259.5,4578758 5402249.5,4578758 5402239.5,4578768 5402229.5,4578768
5402159.5,4578818 5402109.5,4578818 5402059.5,4578808 5402049.5,4578808
5402039.5,4578798 5402029.5,4578798 5402019.5,4578788 5402009.5,4578788
5401999.5,4578748 5401959.5,4578748 5401909.5,4578768 5401889.5,4578768
5401869.5,4578778 5401859.5,4578778 5401829.5,4578788 5401819.5,4578788
5401809.5,4578778 5401799.5,4578778 5401789.5,4578768 5401779.5,4578778
5401769.5,4578778 5401759.5,4578768 5401749.5,4578778 5401739.5,4578798
5401739.5,4578798 5401729.5,4578808 5401719.5,4578818 5401719.5,4578828
5401709.5,4578838 5401709.5,4578848 5401699.5,4578858 5401699.5,4578878
5401679.5,4578888 5401679.5,4578918 5401649.5,4578928 5401649.5,4578928
5401639.5,4579008 5401559.5,4579008 5401539.5,4579018 5401529.5,4579018
5401489.5,4579008 5401479.5,4579028 5401459.5,4579028 5401449.5,4579038
5401439.5,4579038 5401409.5,4579048 5401399.5,4579048 5401379.5,4579058
5401369.5,4579058 5401349.5,4579068 5401339.5,4579068 5401269.5,4579058
5401259.5,4579058 5401229.5,4579068 5401219.5,4579058
5401209.5,4579053.5 5401198,4579053.5 5401178,4579073.5
5401158,4579073.5 5401138,4579103.5 5401108,4579093.5 5401098,4579093.5
5401088,4579103.5 5401078,4579093.5 5401068,4579093.5 5401058,4579073.5
5401038,4579083.5 5401028,4579083.5 5400998,4579093.5 5400988,4579093.5
5400978,4579093.5 5400928,4579083.5 5400918,4579083.5 5400908,4579073.5
5400898,4579073.5 5400838,4579083.5 5400828,4579083.5 5400788,4579093.5
5400778,4579093.5 5400768,4579103.5 5400758,4579103.5 5400748,4579093.5
5400738,4579093.5 5400728,4579083.5 5400718,4579083.5 5400688,4579073.5
5400678,4579073.5 5400608,4579083.5 5400598,4579083.5 5400508,4579073.5
5400498,4579073.5 5400428,4579083.5 5400418,4579083.5 5400398,4579093.5
5400388,4579093.5 5400368,4579103.5 5400358,4579103.5 5400348,4579113.5
5400338,4579113.5 5400308,4579133.5 5400288,4579133.5 5400278,4579153.5
5400258,4579153.5 5400228,4579163.5 5400218,4579163.5 5400198,4579183.5
5400178,4579183.5 5400168,4579193.5 5400158,4579193.5 5400118,4579203.5
5400108,4579203.5 5399978,4579183.5 5399958,4579183.5 5399948,4579193.5
5399938,4579173.5 5399938,4579163.5 5399928,4579163.5 5399918,4579153.5
5399908,4579153.5 5399838,4579163.5 5399828,4579163.5 5399818,4579103.5
5399758,4579103.5 5399748,4579073.5 5399718,4579073.5 5399708,4579063.5
5399698,4579053.5 5399698,4579013.5 5399658,4579013.5 5399628,4579003.5
5399618,4579003.5 5399598,4578983.5 5399578,4578973.5 5399578,4578963.5
5399568,4578903.5 5399568,4578893.5 5399558,4578863.5 5399558,4578853.5
5399568,4578843.5 5399568,4578803.5 5399608,4578793.5 5399608,4578783.5
5399598,4578793.5 5399588,4578793.5 5399578,4578783.5 5399578,4578753.5
5399608,4578733.5 5399608,4578723.5 5399618,4578693.5 5399618,4578683.5
5399608,4578673.5 5399608,4578653.5 5399588,4578643.5 5399588,4578633.5
5399578,4578633.5 5399568,4578623.5 5399558,4578623.5 5399548,4578603.5
5399528,4578603.5 5399498,4578593.5 5399498,4578573.5 5399478,4578573.5
5399438,4578583.5 5399428,4578583.5 5399398,4578593.5 5399388,4578593.5
5399368,4578613.5 5399348,4578613.5 5399338,4578633.5 5399318,4578643.5
5399328,4578653.5 5399328,4578663.5 5399338,4578683.5 5399338,4578703.5
5399318,4578733.5 5399318,4578743.5 5399308,4578753.5 5399308,4578763.5
5399298,4578773.5 5399298,4578773.5 5399288,4578793.5 5399268,4578803.5
5399268,4578823.5 5399248,4578833.5 5399248,4578863.5 5399218,4578883.5
5399218,4578893.5 5399208,4578923.5 5399208,4578953.5 5399178,4578953.5
5399168,4578943.5 5399158,4578943.5 5399148,4578933.5 5399138,4578937.5
5399126.5,4578947.5 5399126.5,4578957.5 5399116.5,4578967.5
5399116.5,4578977.5 5399106.5,4578987.5 5399106.5,4579007.5
5399086.5,4579017.5 5399086.5,4579037.5 5399066.5,4579047.5
5399066.5,4579057.5 5399056.5,4579067.5 5399056.5,4579087.5
5399036.5,4579097.5 5399036.5,4579117.5 5399016.5,4579127.5
5399016.5,4579167.5 5398976.5,4579157.5 5398966.5,4579167.5
5398956.5,4579177.5 5398966.5,4579167.5 5398976.5,4579177.5
5398976.5,4579197.5 5398956.5,4579207.5 5398956.5,4579237.5
5398926.5,4579237.5 5398916.5,4579247.5 5398906.5,4579227.5
5398886.5,4579227.5 5398876.5,4579237.5 5398866.5,4579247.5
5398876.5,4579267.5 5398876.5,4579277.5 5398886.5,4579297.5
5398866.5,4579297.5 5398856.5,4579347.5 5398806.5,4579347.5
5398796.5,4579377.5 5398766.5,4579387.5 5398766.5,4579407.5
5398746.5,4579417.5 5398746.5,4579457.5 5398706.5,4579457.5
5398696.5,4579487.5 5398666.5,4579517.5 5398666.5,4579537.5
5398646.5,4579547.5 5398646.5,4579587.5 5398606.5,4579597.5
5398606.5,4579607.5 5398596.5,4579617.5 5398596.5,4579617.5
5398586.5,4579627.5 5398576.5,4579627.5 5398566.5,4579637.5
5398556.5,4579647.5 5398556.5,4579657.5 5398546.5,4579667.5
5398546.5,4579677.5 5398536.5,4579687.5 5398536.5,4579697.5
5398526.5,4579707.5 5398526.5,4579717.5 5398516.5,4579727.5
5398516.5,4579737.5 5398506.5,4579737.5 5398496.5,4579757.5
5398476.5,4579767.5 5398486.5,4579777.5 5398486.5,4579787.5
5398476.5,4579807.5 5398476.5,4579817.5 5398466.5,4579827.5
5398466.5,4579892 5398402,4579995 5398344.5,4580019 5398356,4580023
5398363.5,4580025.5 5398360.5,4580016.5 5398338.5,4580059.5
5398297.5,4580100.5 5398270.5,4580142 5398250,4580170 5398231.5,4580234
5398202,4580237.5 5398208,4580229 5398217.5,4580265.5 5398229,4580290.5
5398208,4580328.5 5398160,4580347 5398133,4580345.5 5398118.5,4580331.5
5398108,4580309 5398107.5,4580283.5 5398120,4580244.5 5398142.5,4580233
5398147.5,4580209 5398123.5,4580209.5 5398116.5,4580249.5
5398061,4580277.5 5398033,4580296.5 5398023.5,4580310
5398027.5,4580318.5 5398039,4580313 5398053,4580313 5398063,4580325
5398074.5,4580343 5398079.5,4580356 5398073,4580367.5 5398060.5,4580370
5398043,4580380 5398032,4580403 5398027.5,4580417.5 5398019.5,4580424.5
5398007,4580426 5397994.5,4580432.5 5397993,4580446.5 5398026.5,4580461
5398041.5,4580506 5398058,4580518 5398052,4580534 5398048,4580580
5398030.5,4580589 5398029.5,4580601 5398035.5,4580605 5398046,4580612
5398056,4580619.5 5398060.5,4580635.5 5398051,4580642 5398014,4580653.5
5398009.5,4580661 5398011,4580674 5398010,4580695.5 5398002,4580734.5
5397980,4580756 5397974,4580797 5397967,4580827.5 5397921,4580842
5397915,4580862.5 5397918.5,4580892.5 5397933.5,4580914 5397941,4580943
5397945.5,4580982.5 5397945,4581012.5 5397927.5,4581048.5
5397900.5,4581074.5 5397892,4581093.5 5397892.5,4581106
5397884.5,4581113.5 5397826,4581109 5397813.5,4581088.5 5397808,4581078
5397801.5,4581076 5397789.5,4581089 5397772.5,4581115.5 5397753,4581127
5397741,4581124 5397712,4581143 5397716,4581163 5397713.5,4581172.5
5397698,4581162.5 5397617.5,4581152 5397561.5,4581143 5397539,4581172
5397561,4581217.5 5397577.5,4581291 5397565,4581319 5397547.5,4581342
5397558,4581358 5397561.5,4581472.5 5397480,4581517 5397360,4581567.5
5397247.5,4581577.5 5397237.5,4581597.5 5397237.5,4581607.5
5397227.5,4581607.5 5397187.5,4581617.5 5397177.5,4581607.5
5397167.5,4581607.5 5397147.5,4581617.5 5397137.5,4581617.5
5397107.5,4581627.5 5397097.5,4581637.5 5397107.5,4581647.5
5397107.5,4581667.5 5397087.5,4581667.5 5397077.5,4581677.5
5397067.5,4581667.5 5397067.5,4581657.5 5397057.5,4581667.5
5397047.5,4581657.5 5397037.5,4581667.5 5397027.5,4581677.5
5397027.5,4581687.5 5397037.5,4581707.5 5397017.5,4581707.5
5397007.5,4581727.5 5396987.5,4581727.5 5396977.5,4581737.5
5396967.5,4581737.5 5396957.5,4581747.5 5396947.5,4581747.5
5396937.5,4581767.5 5396917.5,4581777.5 5396927.5,4581777.5
5396947.5,4581767.5 5396957.5,4581767.5 5396967.5,4581797.5
5396937.5,4581797.5 5396927.5,4581807.5 5396917.5,4581807.5
5396907.5,4581837.5 5396877.5,4581837.5 5396857.5,4581857.5
5396837.5,4581857.5 5396817.5,4581867.5 5396807.5,4581857.5
5396807.5,4581847.5 5396817.5,4581837.5 5396807.5,4581867.5
5396777.5,4581867.5 5396767.5,4581887.5 5396747.5,4581897.5
5396757.5,4581887.5 5396767.5,4581887.5 5396787.5,4581897.5
5396777.5,4581897.5 5396767.5,4581907.5 5396757.5,4581907.5
5396747.5,4581917.5 5396737.5,4581917.5 5396727.5,4581927.5
5396717.5,4581927.5 5396707.5,4581937.5 5396697.5,4581937.5
5396687.5,4581947.5 5396677.5,4581947.5 5396667.5,4581957.5
5396657.5,4581957.5 5396617.5,4581977.5 5396597.5,4581977.5
5396577.5,4582007.5 5396547.5,4582007.5 5396527.5,4582017.5
5396517.5,4582017.5 5396497.5,4582027.5 5396487.5,4582027.5
5396477.5,4582037.5 5396467.5,4582037.5 5396457.5,4582057.5
5396437.5,4582057.5 5396427.5,4582067.5 5396417.5,4582057.5
5396417.5,4582047.5 5396407.5,4582057.5 5396397.5,4582057.5
5396377.5,4582047.5 5396367.5,4582047.5 5396327.5,4582057.5
5396317.5,4582077.5 5396317.5,4582087.5 5396307.5,4582097.5
5396307.5,4582097.5 5396257.5,4582077.5 5396237.5,4582077.5
5396217.5,4582087.5 5396207.5,4582087.5 5396187.5,4582117.5
5396157.5,4582117.5 5396147.5,4582127.5 5396137.5,4582107.5
5396117.5,4582107.5 5396077.5,4582117.5 5396067.5,4582127.5
5396067.5,4582127.5 5396047.5,4582137.5 5396037.5,4582137.5
5395977.5,4582127.5 5395967.5,4582127.5 5395957.5,4582117.5
5395947.5,4582117.5 5395927.5,4582127.5 5395917.5,4582137.5
5395917.5,4582137.5 5395907.5,4582147.5 5395897.5,4582147.5
5395887.5,4582137.5 5395877.5,4582137.5 5395867.5,4582127.5
5395857.5,4582137.5 5395847.5,4582137.5 5395817.5,4582147.5
5395807.5,4582147.5 5395797.5,4582157.5 5395787.5,4582177.5
5395787.5,4582184.5 5395792,4582197.5 5395807.5,4582224.5
5395833.5,4582227.5 5395827.5,4582227.5 5395817.5,4582207.5
5395797.5,4582197 5395789.5,4582183.5 5395781.5,4582177.5
5395767.5,4582157.5 5395747.5,4582157.5 5395737.5,4582137.5
5395737.5,4582127.5 5395727.5,4582137.5 5395717.5,4582178
5395717,4582146 5395459.5,4582135 5395397,4582129 5395345,4582126
5395225,4582098 5395226.5,4582100.5 5395209.5,4582129
5395206.5,4582128.5 5395131,4582132.5 5395028,4582201.5
5395035,4582205.5 5394881,4582343 5394635,4582341.5 5394529.5,4582380
5394409.5,4582465 5394398,4582559.5 5394354.5,4582646
5394328.5,4582663.5 5394312,4582666.5 5394293.5,4582670 5394292,4582685
5394304,4582699.5 5394295,4582706 5394281,4582713 5394276,4582720
5394274.5,4582731 5394276,4582735 5394274.5,4582742.5 5394264,4582752
5394256.5,4582753.5 5394248.5,4582752 5394246,4582738
5394241.5,4582736.5 5394238.5,4582738 5394234.5,4582744.5
5394229,4582754.5 5394239.5,4582762.5 5394232.5,4582764 5394224,4582754
5394209,4582751.5 5394195.5,4582754.5 5394189.5,4582781
5394187.5,4582787.5 5394181.5,4582796 5394167,4582798.5 5394156,4582811
5394132,4582807 5394109,4582802.5 5394103,4582794.5 5394101.5,4582793
5394100,4582794 5394090.5,4582791.5 5394085.5,4582785 5394079,4582778
5394083.5,4582756.5 5394092.5,4582751.5 5394097.5,4582730.5
5394069.5,4582737.5 5394061.5,4582801 5394048.5,4582807.5
5394044,4582812 5394037,4582815.5 5394025.5,4582818 5393999,4582817.5
5393975,4582804 5393932.5,4582800 5393915.5,4582799 5393885.5,4582786
5393878,4582785 5393874.5,4582791.5 5393860,4582794.5 5393857,4582807
5393855.5,4582810.5 5393854,4582811.5 5393850,4582810.5
5393843.5,4582807 5393835.5,4582808 5393829.5,4582812
5393824.5,4582819.5 5393810.5,4582829.5 5393797.5,4582836.5
5393782.5,4582838 5393773,4582827 5393748,4582828.5 5393742,4582838.5
5393730.5,4582826.5 5393726.5,4582825 5393722.5,4582832.5
5393702,4582838.5 5393693.5,4582860.5 5393653,4582878 5393601,4582882.5
5393596.5,4582883 5393587.5,4582889.5 5393569.5,4582897 5393563,4582898
5393557,4582913 5393537.5,4582913.5 5393532,4582933.5 5393480,4582947.5
5393453,4582959 5393441,4582973.5 5393438,4582972 5393434.5,4582958
5393428,4582964 5393400,4582966.5 5393372,4582976 5393344,4582976.5
5393333,4582982.5 5393326,4582988.5 5393321.5,4583022
5393242.5,4583026.5 5393238.5,4583047.5 5393207.5,4583067.5
5393156,4583106.5 5393212.5,4583113.5 5393237,4583129 5393249.5,4583134
5393257.5,4583138 5393268,4583172.5 5393286.5,4583179 5393297.5,4583180
5393312.5,4583177 5393319.5,4583198.5 5393332.5,4583259
5393290,4583241.5 5393269,4583248 5393262.5,4583287.5 5393253,4583329
5393213.5,4583329 5393183.5,4583319 5393173.5,4583319 5393163.5,4583309
5393153.5,4583299 5393153.5,4583289 5393143.5,4583289 5393073.5,4583259
5393043.5,4583259 5392983.5,4583269 5392973.5,4583269 5392953.5,4583279
5392943.5,4583279 5392933.5,4583289 5392923.5,4583289 5392913.5,4583269
5392893.5,4583279 5392883.5,4583299 5392903.5,4583309 5392903.5,4583299
5392893.5,4583329 5392863.5,4583339 5392863.5,4583379 5392823.5,4583379
5392813.5,4583389 5392803.5,4583409 5392803.5,4583419 5392813.5,4583439
5392793.5,4583479 5392793.5,4583489 5392783.5,4583519 5392783.5,4583539
5392763.5,4583539 5392743.5,4583559 5392723.5,4583609 5392723.5,4583609
5392713.5,4583649 5392673.5,4583649 5392663.5,4583659
5392653.5,4583674.5 5392546.5,4583650.5 5392536.5,4583597
5392532.5,4583589.5 5392525,4583617 5392521.5,4583626 5392513.5,4583710
5392515,4583740 5392485,4583764.5 5392485,4583779.5 5392459.5,4583800
5392457.5,4583833 5392444,4583846.5 5392431.5,4583888.5 5392422,4583952
5392417,4584010 5392421.5,4584069 5392412,4584112.5 5392411.5,4584131
5392417.5,4584159 5392435,4584179 5392441.5,4584247 5392416.5,4584274
5392413,4584340.5 5392359,4584350 5392361,4584357.5 5392338,4584384
5392324,4584423.5 5392322,4584495.5 5392310.5,4584512 5392294,4584532
5392294.5,4584547 5392283,4584561.5 5392279.5,4584573.5
5392268.5,4584594.5 5392260.5,4584667 5392215,4584706.5
5392204,4584732.5 5392203.5,4584755.5 5392166,4584849
5392096.5,4584905.5 5392060,4584943.5 5392020.5,4584943
5392000.5,4584972.5 5391963,4585036 5391956,4585048.5
5391953.5,4585169.5 5391835.5,4585194.5 5391805.5,4585245.5
5391756.5,4585313 5391702,4585341.5 5391681,4585387 5391651.5,4585391
5391647.5,4585391 5391642,4585403 5391634,4585404.5 5391619.5,4585413.5
5391605.5,4585427.5 5391593.5,4585442 5391593.5,4585456.5
5391588.5,4585482.5 5391560,4585485 5391550,4585491.5 5391545,4585508.5
5391524.5,4585520 5391514,4585528 5391511,4585564.5 5391479,4585631.5
5391427,4585633 5391422.5,4585666 5391398.5,4585673 5391390.5,4585771.5
5391299.5,4585775.5 5391299,4585787.5 5391276.5,4585835.5
5391230.5,4585849.5 5391230,4585923.5 5391154,4585940.5
5391138,4585955.5 5391120.5,4585953 5391119,4585943 5391122,4585943.5
5391118,4585946.5 5391112.5,4585959 5391109.5,4585968 5391104.5,4586002
5391072.5,4586019.5 5391053.5,4586043.5 5391034,4586062
5391021.5,4586096 5391002,4586115.5 5390997.5,4586128 5390989.5,4586228
5390904,4586257 5390877,4586275 5390859,4586385 5390718.5,4586408
5390691,4586431.5 5390666.5,4586447.5 5390652.5,4586457.5
5390647,4586460 5390643.5,4586452 5390637,4586451 5390634.5,4586467
5390614,4586477 5390606,4586518 5390591.5,4586530 5390579,4586560
5390554,4586586 5390529.5,4586655 5390447.5,4586669.5 5390434,4586674
5390420.5,4586705 5390390.5,4586713.5 5390395.5,4586709
5390387.5,4586716 5390364,4586718 5390345.5,4586736.5 5390330.5,4586749
5390327.5,4586764 5390327.5,4586801.5 5390312.5,4586821
5390280.5,4586850.5 5390256,4586908 5390239,4586930 5390239,4586992
5390204,4587000 5390189.5,4587032 5390177,4587116.5 5390118,4587135.5
5390077,4587153.5 5390053.5,4587090.5 5389990.5,4587089.163
5389989.633,4586393.799 5390252.837,4586274 5390369.5,4586201.5
5390431,4586115.5 5390491,4585950.5 5390583.5,4585880 5390631,4585758
5390722.5,4585592 5390866,4585409.5 5391021.5,4585402 5391044,4585386.5
5391045,4585314 5391099,4585326.5 5391117,4585313.5 5391132,4585303.5
5391135,4585300 5391146,4585274.5 5391135,4585215.5 5391178,4585133
5391261,4585064.5 5391342,4584995.5 5391410,4584896.5 5391496,4584805.5
5391564,4584726 5391614,4584661.5 5391647.5,4584559.5 5391687.5,4584441
5391720,4584323.5 5391731,4584031.5 5391722.5,4583946.5
5391724.5,4583838.5 5391739,4583682 5391790.5,4583583 5391835.5,4583530
5391864,4583533.016 5391863.339,4583490.575 5391889.606,4583444.425
5391914.124,4583323.282 5391974.695,4583256.942 5392002.097,4583215.119
5392022.287,4583160.316 5392045.362,4583099.744 5392068.437,4582987.254
5392098.723,4582912.26 5392108.818,4582850.247 5392114.587,4582770.927
5392116.029,4582719.5 5392112.266,4582719.5 5392085,4582709.5
5392075,4582699.5 5392075,4582679.5 5392055,4582679.5 5392045,4582639.5
5392045,4582629.5 5392035,4582579.5 5392035,4582559.5 5392055,4582539.5
5392055,4582529.5 5392045,4582529.5 5392035,4582509.5 5392035,4582499.5
5392045,4582479.5 5392045,4582469.5 5392035,4582459.5 5392035,4582449.5
5392025,4582419.5 5392025,4582409.5 5392015,4582359.5 5392015,4582349.5
5392005,4582339.5 5392015,4582319.5 5392015,4582309.5 5392025,4582299.5
5392015,4582299.5 5392005,4582279.5 5392005,4582269.5 5392015,4582239.5
5392015,4582229.5 5392005,4582219.5 5392015,4582209.5 5392015,4582209.5
5392025,4582199.5 5392035,4582189.5 5392035,4582189.5 5392045,4582169.5
5392065,4582159.5 5392065,4582149.5 5392055,4582139.5 5392055,4582109.5
5392085,4582099.5 5392085,4582089.5 5392095,4582079.5 5392095,4582059.5
5392115,4582049.5 5392105,4582069.5 5392085,4582079.5 5392075,4582089.5
5392075,4582119.5 5392045,4582129.5 5392045,4582149.5 5392025,4582139.5
5392015,4582139.5 5392005,4582109.5 5392005,4582099.5 5391995,4582089.5
5391995,4582079.5 5391985,4582059.5 5391985,4582039.5 5392005,4582029.5
5391995,4582029.5 5391985,4582009.5 5391985,4582009.5 5392025,4581999.5
5392035,4581989.5 5392025,4581979.5 5392025,4581959.5 5392045,4581949.5
5392035,4581949.5 5392025,4581919.5 5392025,4581919.5 5392045,4581929.5
5392035,4581939.5 5392035,4581949.5 5392045,4581949.5 5392055,4581939.5
5392065,4581929.5 5392065,4581919.5 5392075,4581889.5 5392075,4581879.5
5392065,4581879.5 5392035,4581869.5 5392035,4581859.5 5392025,4581869.5
5392015,4581879.5 5392015,4581869.5 5392005,4581889.5 5391985,4581889.5
5391975,4581899.5 5391965,4581889.5 5391955,4581879.5 5391955,4581869.5
5391965,4581829.5 5391965,4581819.5 5391955,4581799.5 5391955,4581779.5
5391935,4581769.5 5391935,4581759.5 5391925,4581749.5 5391925,4581739.5
5391915,4581729.5 5391915,4581719.5 5391905,4581699.5 5391905,4581689.5
5391895,4581679.5 5391895,4581669.5 5391885,4581649.5 5391885,4581639.5
5391875,4581619.5 5391875,4581609.5 5391885,4581599.5 5391885,4581589.5
5391895,4581569.5 5391895,4581569.5 5391905,4581559.5 5391915,4581569.5
5391925,4581559.5 5391935,4581549.5 5391935,4581539.5 5391925,4581509.5
5391955,4581499.5 5391955,4581469.5 5391985,4581439.5 5391985,4581429.5
5391995,4581419.5 5391995,4581409.5 5392005,4581379.5 5392005,4581369.5
5392015,4581349.5 5392015,4581329.5 5392035,4581319.5 5392035,4581299.5
5392055,4581289.5 5392055,4581279.5 5392065,4581269.5 5392065,4581259.5
5392075,4581249.5 5392075,4581239.5 5392085,4581219.5 5392085,4581209.5
5392095,4581179.5 5392095,4581169.5 5392105,4581129.5 5392105,4581119.5
5392115,4581089.5 5392115,4581079.5 5392105,4581039.5 5392105,4581029.5
5392095,4581029.5 5392085,4581019.5 5392075,4580979.5 5392075,4580969.5
5392065,4580949.5 5392065,4580899.5 5392015,4580899.5 5391955,4580889.5
5391965,4580879.5 5391955,4580879.5 5391945,4580819.5 5391945,4580809.5
5391955,4580749.5 5391955,4580739.5 5391965,4580679.5 5391965,4580679.5
5391975,4580669.5 5391985,4580669.5 5391995,4580679.5 5392005,4580689.5
5392005,4580699.5 5392015,4580689.5 5392025,4580669.5 5392025,4580669.5
5392035,4580699.5 5392035,4580709.5 5392045,4580709.5 5392055,4580719.5
5392055,4580729.5 5392065,4580739.5 5392065,4580749.5 5392075,4580769.5
5392075,4580779.5 5392085,4580799.5 5392085,4580809.5 5392095,4580819.5
5392095,4580829.5 5392105,4580859.5 5392105,4580869.5 5392115,4580879.5
5392115,4580889.5 5392125,4580909.5 5392125,4580919.5 5392135,4580919.5
5392175,4580939.5 5392195,4580939.5 5392205,4580929.5 5392215,4580929.5
5392225,4580889.5 5392265,4580879.5 5392265,4580869.5 5392275,4580859.5
5392275,4580849.5 5392285,4580839.5 5392285,4580829.5 5392295,4580819.5
5392295,4580779.5 5392335,4580759.5 5392335,4580719.5 5392375,4580699.5
5392375,4580689.5 5392385,4580619.5 5392385,4580609.5 5392375,4580569.5
5392375,4580559.5 5392385,4580539.5 5392365,4580529.5 5392365,4580519.5
5392355,4580479.5 5392355,4580469.5 5392345,4580449.5 5392345,4580439.5
5392335,4580229.5 5392335,4580209.5 5392355,4580199.5 5392355,4580179.5
5392375,4580159.5 5392375,4580149.5 5392385,4580129.5 5392385,4580119.5
5392395,4580089.5 5392395,4580079.5 5392385,4580059.5 5392385,4580049.5
5392395,4580039.5 5392395,4580009.5 5392425,4579999.5 5392415,4579969.5
5392415,4579959.5 5392425,4579919.5 5392425,4579909.5 5392415,4579889.5
5392415,4579879.5 5392405,4579859.5 5392405,4579849.5 5392395,4579839.5
5392395,4579829.5 5392385,4579829.5 5392375,4579819.5 5392365,4579819.5
5392325,4579809.5 5392325,4579799.5 5392335,4579799.5 5392345,4579809.5
5392355,4579809.5 5392385,4579789.5 5392405,4579769.5 5392405,4579759.5
5392395,4579759.5 5392405,4579749.5 5392415,4579739.5 5392415,4579729.5
5392425,4579699.5 5392425,4579679.5 5392445,4579679.5 5392455,4579649.5
5392485,4579649.5 5392505,4579639.5 5392515,4579639.5 5392525,4579629.5
5392535,4579609.5 5392535,4579609.5 5392565,4579599.5 5392575,4579579.5
5392555,4579579.5 5392545,4579569.5 5392535,4579559.5 5392535,4579559.5
5392545,4579539.5 5392565,4579539.5 5392585,4579549.5 5392595,4579539.5
5392605,4579529.5 5392605,4579529.5 5392615,4579539.5 5392625,4579539.5
5392645,4579559.5 5392625,4579569.5 5392635,4579569.5 5392645,4579549.5
5392665,4579539.5 5392655,4579539.5 5392665,4579529.5 5392675,4579519.5
5392675,4579519.5 5392685,4579509.5 5392695,4579499.5 5392685,4579479.5
5392685,4579469.5 5392675,4579469.5 5392655,4579459.5 5392645,4579469.5
5392635,4579479.5 5392635,4579479.5 5392615,4579459.5 5392615,4579459.5
5392625,4579449.5 5392635,4579439.5 5392635,4579439.5 5392685,4579449.5
5392695,4579449.5 5392705,4579439.5 5392715,4579429.5 5392715,4579399.5
5392745,4579369.5 5392745,4579369.5 5392755,4579349.5 5392775,4579339.5
5392775,4579329.5 5392765,4579329.5 5392745,4579319.5 5392735,4579319.5
5392745,4579309.5 5392755,4579289.5 5392755,4579279.5 5392745,4579269.5
5392745,4579269.5 5392755,4579249.5 5392775,4579239.5 5392775,4579219.5
5392795,4579139.5 5392795,4579068 5392807,4579018 5392807,4579008
5392817,4578988 5392817,4578978 5392827,4578958 5392827,4578948
5392837,4578938 5392837,4578928 5392847,4578918 5392847,4578908
5392857,4578898 5392857,4578888 5392867,4578878 5392867,4578858
5392887,4578848 5392887,4578838 5392897,4578828 5392897,4578808
5392917,4578788 5392917,4578778 5392927,4578768 5392927,4578758
5392937,4578748 5392937,4578738 5392947,4578728 5392947,4578718
5392957,4578708 5392957,4578688 5392977,4578678 5392977,4578668
5392987,4578658 5392987,4578638 5393007,4578628 5393007,4578608
5393027,4578598 5393027,4578548 5393077,4578538 5393077,4578408
5393207,4578408 5393217,4578328 5393297,4578328 5393307,4578238
5393397,4578238 5393407,4578218 5393427,4578218 5393437,4578208
5393447,4578198 5393447,4578188 5393457,4578188 5393467,4578198
5393477,4578198 5393487,4578138 5393547,4578118 5393547,4578088
5393577,4578078 5393577,4578078 5393587,4578048 5393617,4578048
5393627,4578008 5393667,4578008 5393677,4577978 5393707,4577978
5393717,4577948 5393747,4577948 5393757,4577908 5393797,4577908
5393807,4577878 5393837,4577878 5393847,4577848 5393877,4577848
5393887,4577808 5393927,4577808 5393937,4577778 5393967,4577778
5393977,4577748 5394007,4577748 5394027,4577758 5394037,4577758
5394067,4577768 5394077,4577768 5394127,4577778 5394137,4577778
5394157,4577788 5394167,4577788 5394187,4577798 5394197,4577798
5394207,4577808 5394217,4577808 5394247,4577848 5394287,4577858
5394287,4577878 5394307,4577878 5394327,4577888 5394337,4577898
5394337,4577908 5394347,4577918 5394357,4577918 5394367,4577908
5394377,4577908 5394417,4577898 5394427,4577898 5394447,4577888
5394457,4577888 5394477,4577858 5394507,4577848 5394497,4577848
5394477,4577838 5394487,4577838 5394497,4577828 5394507,4577828
5394517,4577808 5394537,4577788 5394537,4577778 5394547,4577778
5394557,4577768 5394567,4577758 5394567,4577748 5394577,4577738
5394577,4577738 5394587,4577718 5394607,4577708 5394607,4577648
5394667,4577648 5394677,4577668 5394677,4577678 5394687,4577668
5394697,4577678 5394697,4577688 5394707,4577688 5394697,4577718
5394667,4577738 5394667,4577748 5394677,4577728 5394697,4577728
5394707,4577718 5394717,4577718 5394737,4577728 5394747,4577738
5394747,4577758 5394727,4577768 5394727,4577788 5394707,4577798
5394707,4577808 5394697,4577818 5394697,4577828 5394707,4577828
5394787,4577838 5394797,4577838 5394807,4577828 5394817,4577828
5394827,4577838 5394837,4577838 5394867,4577828 5394877,4577828
5394917,4577818 5394927,4577818 5394957,4577828 5394957,4577828
5394937,4577858 5394907,4577868 5394917,4577868 5394927,4577878
5394937,4577868 5394947,4577878 5394957,4577882.5 5394969,4577882.5
5395039,4577892.5 5395049,4577892.5 5395069,4577882.5 5395079,4577892.5
5395089,4577892.5 5395099,4577902.5 5395109,4577902.5 5395119,4577912.5
5395129,4577912.5 5395139,4577932.5 5395159,4577932.5 5395169,4577942.5
5395179,4577942.5 5395189,4577932.5 5395199,4577932.5 5395209,4577922.5
5395219,4577912.5 5395229,4577902.5 5395229,4577902.5 5395239,4577892.5
5395249,4577852.5 5395249,4577852.5 5395289,4577832.5 5395309,4577822.5
5395309,4577782.5 5395349,4577772.5 5395349,4577772.5 5395359,4577762.5
5395369,4577762.5 5395379,4577752.5 5395389,4577752.5 5395399,4577742.5
5395409,4577722.5 5395409,4577712.5 5395399,4577702.5 5395399,4577682.5
5395379,4577672.5 5395379,4577662.5 5395369,4577652.5 5395369,4577642.5
5395359,4577642.5 5395299,4577632.5 5395289,4577632.5 5395259,4577612.5
5395239,4577612.5 5395229,4577602.5 5395229,4577592.5 5395219,4577592.5
5395209,4577562.5 5395209,4577552.5 5395199,4577502.5 5395199,4577492.5
5395189,4577482.5 5395189,4577472.5 5395179,4577472.5 5395169,4577442.5
5395139,4577442.5 5395129,4577452.5 5395089,4577452.5 5395079,4577462.5
5395069,4577462.5 5395049,4577472.5 5395039,4577472.5 5395019,4577482.5
5395009,4577482.5 5394999,4577492.5 5394989,4577492.5 5394979,4577512.5
5394959,4577518 5394947,4577518 5394937,4577548 5394907,4577548
5394897,4577568 5394877,4577568 5394867,4577598 5394837,4577598
5394827,4577608 5394817,4577608 5394807,4577618 5394797,4577618
5394787,4577598 5394807,4577588 5394807,4577588 5394837,4577578
5394847,4577568 5394847,4577568 5394857,4577558 5394867,4577548
5394867,4577548 5394877,4577538 5394887,4577528 5394887,4577528
5394897,4577508 5394917,4577498 5394917,4577498 5394937,4577492.5
5394949,4577472.5 5394949,4577472.5 5394959,4577462.5 5394969,4577442.5
5394969,4577442.5 5394989,4577432.5 5394999,4577452.5 5395019,4577452.5
5395059,4577442.5 5395069,4577442.5 5395099,4577439.5
5395110.5,4577435.5 5395115,4577422.5 5395109,4577412.5
5395109,4577402.5 5395099,4577382.5 5395119,4577372.5 5395119,4577382.5
5395129,4577372.5 5395139,4577362.5 5395129,4577362.5 5395169,4577352.5
5395179,4577352.5 5395189,4577332.5 5395209,4577322.5 5395209,4577322.5
5395219,4577312.5 5395229,4577312.5 5395249,4577302.5 5395259,4577302.5
5395289,4577322.5 5395269,4577352.5 5395299,4577352.5 5395359,4577362.5
5395369,4577352.5 5395379,4577362.5 5395379,4577372.5 5395389,4577392.5
5395389,4577422.5 5395419,4577422.5 5395429,4577412.5 5395439,4577412.5
5395449,4577402.5 5395459,4577382.5 5395459,4577372.5 5395469,4577372.5
5395479,4577382.5 5395489,4577392.5 5395479,4577402.5 5395489,4577402.5
5395479,4577442.5 5395439,4577442.5 5395419,4577452.5 5395409,4577462.5
5395409,4577472.5 5395399,4577482.5 5395399,4577492.5 5395409,4577502.5
5395409,4577532.5 5395439,4577532.5 5395449,4577522.5 5395459,4577502.5
5395459,4577502.5 5395469,4577472.5 5395499,4577472.5 5395509,4577462.5
5395519,4577512.5 5395519,4577522.5 5395529,4577562.5 5395529,4577572.5
5395539,4577562.5 5395549,4577532.5 5395549,4577532.5 5395569,4577542.5
5395579,4577552.5 5395579,4577572.5 5395599,4577572.5 5395619,4577582.5
5395629,4577582.5 5395659,4577562.5 5395679,4577562.5 5395689,4577572.5
5395699,4577522.5 5395749,4577522.5 5395779,4577512.5 5395789,4577492.5
5395789,4577482.5 5395799,4577472.5 5395799,4577452.5 5395819,4577432.5
5395819,4577422.5 5395809,4577402.5 5395809,4577392.5 5395819,4577362.5
5395819,4577362.5 5395869,4577382.5 5395869,4577402.5 5395849,4577422.5
5395849,4577432.5 5395859,4577412.5 5395879,4577402.5 5395879,4577372.5
5395909,4577362.5 5395909,4577252.5 5396019,4577252.5 5396029,4577242.5
5396039,4577212.5 5396039,4577212.5 5396059,4577202.5 5396069,4577202.5
5396079,4577142 5396138.5,4577142 5396148.5,4577002 5396288.5,4577002
5396298.5,4576992 5396308.5,4576992 5396318.5,4576932 5396378.5,4576932
5396388.5,4576902 5396418.5,4576902 5396428.5,4576892 5396438.5,4576892
5396448.5,4576872 5396468.5,4576872 5396478.5,4576852 5396498.5,4576852
5396508.5,4576832 5396528.5,4576832 5396538.5,4576822 5396548.5,4576812
5396548.5,4576802 5396558.5,4576792 5396548.5,4576792 5396518.5,4576802
5396508.5,4576802 5396498.5,4576812 5396488.5,4576812 5396478.5,4576822
5396468.5,4576822 5396438.5,4576802 5396458.5,4576802 5396478.5,4576772
5396508.5,4576772 5396518.5,4576762 5396528.5,4576762 5396548.5,4576752
5396558.5,4576752 5396568.5,4576742 5396578.5,4576732 5396578.5,4576722
5396588.5,4576682 5396588.5,4576672 5396598.5,4576642 5396598.5,4576612
5396568.5,4576612 5396558.5,4576582 5396528.5,4576572 5396528.5,4576562
5396538.5,4576562 5396548.5,4576572 5396558.5,4576572 5396568.5,4576562
5396578.5,4576552 5396578.5,4576552 5396588.5,4576532 5396608.5,4576482
5396608.5,4576462 5396588.5,4576442 5396588.5,4576432 5396578.5,4576432
5396558.5,4576422 5396558.5,4576412 5396568.5,4576412 5396578.5,4576402
5396588.5,4576392 5396588.5,4576392 5396598.5,4576382 5396608.5,4576372
5396598.5,4576372 5396578.5,4576382 5396568.5,4576392 5396568.5,4576392
5396538.5,4576492 5396438.5,4576522 5396438.5,4576542 5396418.5,4576542
5396408.5,4576552 5396398.5,4576582 5396398.5,4576572 5396388.5,4576572
5396378.5,4576562 5396368.5,4576552 5396378.5,4576542 5396368.5,4576542
5396358.5,4576512 5396358.5,4576502 5396348.5,4576522 5396328.5,4576532
5396328.5,4576542 5396318.5,4576542 5396308.5,4576552 5396298.5,4576552
5396288.5,4576562 5396278.5,4576562 5396268.5,4576572 5396258.5,4576592
5396258.5,4576612 5396238.5,4576612 5396218.5,4576622 5396208.5,4576632
5396208.5,4576642 5396198.5,4576632 5396198.5,4576622 5396188.5,4576632
5396178.5,4576662 5396178.5,4576722 5396118.5,4576722 5396108.5,4576752
5396078.5,4576762 5396078.5,4576792 5396048.5,4576802 5396048.5,4576812
5396058.5,4576812 5396068.5,4576802 5396078.5,4576802 5396088.5,4576792
5396098.5,4576802 5396108.5,4576802 5396118.5,4576782 5396138.5,4576772
5396138.5,4576752 5396158.5,4576742 5396158.5,4576742 5396168.5,4576722
5396188.5,4576712 5396188.5,4576712 5396228.5,4576702 5396238.5,4576682
5396238.5,4576662 5396258.5,4576652 5396258.5,4576632 5396278.5,4576632
5396288.5,4576622 5396298.5,4576622 5396358.5,4576632 5396368.5,4576682
5396368.5,4576702 5396388.5,4576712 5396388.5,4576722 5396398.5,4576762
5396398.5,4576782 5396378.5,4576772 5396368.5,4576772 5396358.5,4576802
5396328.5,4576812 5396328.5,4576782 5396298.5,4576782 5396248.5,4576772
5396238.5,4576772 5396228.5,4576782 5396218.5,4576802 5396218.5,4576812
5396208.5,4576822 5396208.5,4576852 5396238.5,4576852 5396258.5,4576872
5396278.5,4576872 5396288.5,4576882 5396288.5,4576882 5396268.5,4576892
5396258.5,4576892 5396248.5,4576902 5396238.5,4576912 5396238.5,4576912
5396218.5,4576932 5396198.5,4576932 5396178.5,4576942 5396168.5,4576952
5396178.5,4576962 5396178.5,4576952 5396168.5,4576952 5396158.5,4576962
5396148.5,4576982 5396148.5,4577002 5396128.5,4577002 5396108.5,4576992
5396108.5,4576982 5396098.5,4576982 5396078.5,4576972 5396068.5,4576972
5396058.5,4576962 5396048.5,4576962 5396028.5,4576952 5396018.5,4576952
5395988.5,4576942 5395988.5,4576922 5395968.5,4576922 5395948.5,4576912
5395938.5,4576932 5395918.5,4576932 5395908.5,4576952 5395888.5,4576952
5395838.5,4576942 5395828.5,4576942 5395818.5,4576932 5395808.5,4576932
5395798.5,4576912 5395778.5,4576912 5395768.5,4576882 5395768.5,4576882
5395778.5,4576872 5395788.5,4576872 5395798.5,4576862 5395808.5,4576862
5395818.5,4576842 5395838.5,4576832 5395828.5,4576822 5395828.5,4576812
5395818.5,4576812 5395808.5,4576822 5395798.5,4576822 5395788.5,4576842
5395768.5,4576852 5395768.5,4576872 5395748.5,4576882 5395748.5,4576882
5395738.5,4576892 5395728.5,4576887 5395715.5,4576900.5
5395703.5,4576912.5 5395709,4576912.5 5395719,4576922.5
5395729,4576922.5 5395739,4576932.5 5395749,4576932.5 5395759,4576942.5
5395769,4576942.5 5395779,4576962.5 5395799,4576962.5 5395809,4576972.5
5395819,4576972.5 5395829,4576982.5 5395829,4576992.5 5395819,4576992.5
5395799,4577002.5 5395789,4576992.5 5395779,4577012.5 5395759,4577012.5
5395749,4577082.5 5395679,4577072.5 5395669,4577082.5 5395659,4577082.5
5395649,4577072.5 5395649,4577062.5 5395639,4577052.5 5395639,4577042.5
5395629,4577032.5 5395629,4577022.5 5395619,4577012.5 5395619,4577002.5
5395609,4576992.5 5395609,4576982.5 5395599,4576972.5 5395599,4576962.5
5395589,4576952.5 5395589,4576944 5395581,4576952.5 5395569,4576962.5
5395569,4576992.5 5395539,4577022.5 5395539,4577032.5 5395549,4577042.5
5395549,4577052.5 5395559,4577042.5 5395569,4577032.5 5395569,4577042.5
5395579,4577042.5 5395589,4577072.5 5395559,4577082.5 5395559,4577092.5
5395549,4577132.5 5395549,4577132.5 5395539,4577152.5 5395519,4577152.5
5395509,4577162.5 5395499,4577162.5 5395479,4577172.5 5395469,4577172.5
5395459,4577182.5 5395449,4577182.5 5395439,4577172.5 5395449,4577162.5
5395439,4577162.5 5395429,4577152.5 5395429,4577142.5 5395419,4577122.5
5395419,4577112.5 5395409,4577092.5 5395409,4577082.5 5395399,4577072.5
5395409,4577062.5 5395399,4577052.5 5395399,4577022.5 5395429,4577022.5
5395439,4577002.5 5395459,4577002.5 5395469,4576992.5 5395479,4576982.5
5395479,4576982.5 5395489,4576972.5 5395499,4576962.5 5395499,4576962.5
5395509,4576952.5 5395519,4576952.5 5395539,4576942.5 5395549,4576922.5
5395549,4576912.5 5395559,4576912.5 5395569,4576922.5 5395569,4576933
5395575.5,4576934 5395581.5,4576922.5 5395589,4576902.5
5395589,4576882.5 5395609,4576872.5 5395609,4576862.5 5395619,4576862.5
5395639,4576872.5 5395649,4576872.5 5395659,4576892.5 5395679,4576891
5395704.5,4576882.5 5395709,4576862.5 5395689,4576862.5
5395679,4576852.5 5395669,4576822 5395698.5,4576802 5395698.5,4576802
5395718.5,4576792 5395728.5,4576782 5395738.5,4576752 5395738.5,4576752
5395748.5,4576732 5395768.5,4576732 5395778.5,4576712 5395798.5,4576692
5395798.5,4576662 5395828.5,4576652 5395828.5,4576632 5395848.5,4576642
5395858.5,4576612 5395888.5,4576602 5395888.5,4576572 5395918.5,4576562
5395918.5,4576552 5395928.5,4576542 5395928.5,4576522 5395948.5,4576502
5395948.5,4576482 5395968.5,4576472 5395968.5,4576442 5395998.5,4576432
5395998.5,4576432 5396008.5,4576452 5396028.5,4576442 5396038.5,4576422
5396018.5,4576412 5396028.5,4576392 5396028.5,4576332 5396088.5,4576312
5396088.5,4576302 5396098.5,4576282 5396078.5,4576262 5396078.5,4576242
5396098.5,4576232 5396098.5,4576242 5396108.5,4576262 5396108.5,4576272
5396118.5,4576262 5396128.5,4576252 5396128.5,4576252 5396148.5,4576262
5396148.5,4576272 5396158.5,4576262 5396168.5,4576252 5396168.5,4576242
5396178.5,4576232 5396178.5,4576222 5396188.5,4576192 5396188.5,4576172
5396208.5,4576152 5396208.5,4576142 5396218.5,4576122 5396218.5,4576112
5396228.5,4576092 5396228.5,4576072 5396208.5,4576062 5396208.5,4576052
5396198.5,4576072 5396178.5,4576072 5396168.5,4576082 5396158.5,4576082
5396148.5,4576092 5396138.5,4576092 5396128.5,4576112 5396108.5,4576112
5396098.5,4576122 5396088.5,4576122 5396068.5,4576132 5396058.5,4576132
5396038.5,4576142 5396028.5,4576142 5395988.5,4576152 5395978.5,4576162
5395978.5,4576172 5395968.5,4576172 5395958.5,4576182 5395948.5,4576182
5395928.5,4576192 5395918.5,4576192 5395898.5,4576202 5395888.5,4576202
5395878.5,4576192 5395888.5,4576182 5395888.5,4576152 5395858.5,4576152
5395828.5,4576162 5395818.5,4576162 5395808.5,4576182 5395788.5,4576192
5395798.5,4576212 5395798.5,4576222 5395808.5,4576252 5395778.5,4576252
5395768.5,4576272 5395748.5,4576292 5395748.5,4576312 5395728.5,4576312
5395718.5,4576342 5395688.5,4576342 5395678.5,4576362 5395658.5,4576362
5395648.5,4576382 5395628.5,4576382 5395618.5,4576392 5395608.5,4576392
5395598.5,4576412 5395578.5,4576412 5395568.5,4576422 5395558.5,4576422
5395548.5,4576432 5395538.5,4576432 5395528.5,4576442 5395518.5,4576442
5395508.5,4576452 5395498.5,4576452 5395488.5,4576462 5395478.5,4576462
5395458.5,4576472 5395448.5,4576472 5395438.5,4576482 5395428.5,4576482
5395408.5,4576492 5395398.5,4576492 5395388.5,4576502 5395378.5,4576502
5395348.5,4576512 5395338.5,4576512 5395318.5,4576502 5395318.5,4576492
5395328.5,4576492 5395338.5,4576472 5395358.5,4576452 5395358.5,4576442
5395368.5,4576442 5395388.5,4576432 5395398.5,4576422 5395398.5,4576412
5395388.5,4576412 5395378.5,4576402 5395388.5,4576402 5395408.5,4576392
5395418.5,4576382 5395418.5,4576382 5395428.5,4576362 5395448.5,4576362
5395458.5,4576342 5395478.5,4576332 5395478.5,4576322 5395488.5,4576312
5395488.5,4576122 5395678.5,4576122 5395688.5,4576112 5395698.5,4576102
5395698.5,4576092 5395708.5,4576152 5395768.5,4576142 5395778.5,4576132
5395768.5,4576122 5395768.5,4576092 5395798.5,4576082 5395788.5,4576062
5395788.5,4576052 5395798.5,4576052 5395818.5,4576042 5395828.5,4576042
5395838.5,4576022 5395858.5,4576022 5395868.5,4576032 5395878.5,4576032
5395908.5,4576022 5395918.5,4576022 5395928.5,4576012 5395938.5,4576012
5395958.5,4576002 5395968.5,4576002 5395998.5,4575992 5396008.5,4575992
5396018.5,4575972 5396038.5,4575972 5396048.5,4575952 5396068.5,4575952
5396078.5,4575922 5396108.5,4575922 5396118.5,4575902 5396138.5,4575902
5396148.5,4575872 5396178.5,4575852 5396158.5,4575852 5396148.5,4575842
5396138.5,4575842 5396128.5,4575822 5396108.5,4575822 5396128.5,4575812
5396138.5,4575792 5396138.5,4575792 5396148.5,4575802 5396158.5,4575812
5396158.5,4575832 5396178.5,4575842 5396168.5,4575872 5396198.5,4575872
5396208.5,4575862 5396218.5,4575882 5396238.5,4575902 5396238.5,4575912
5396248.5,4575912 5396258.5,4575882 5396288.5,4575882 5396298.5,4575872
5396308.5,4575862 5396308.5,4575852 5396318.5,4575852 5396328.5,4575832
5396348.5,4575812 5396328.5,4575802 5396328.5,4575782 5396308.5,4575812
5396278.5,4575822 5396278.5,4575802 5396258.5,4575802 5396238.5,4575752
5396238.5,4575742 5396248.5,4575732 5396238.5,4575692 5396238.5,4575682
5396248.5,4575662 5396248.5,4575662 5396258.5,4575642 5396278.5,4575632
5396278.5,4575642 5396288.5,4575642 5396308.5,4575632 5396318.5,4575622
5396318.5,4575622 5396348.5,4575612 5396358.5,4575602 5396358.5,4575592
5396348.5,4575582 5396348.5,4575572 5396338.5,4575592 5396318.5,4575602
5396318.5,4575592 5396308.5,4575592 5396298.5,4575582 5396288.5,4575582
5396298.5,4575572 5396308.5,4575562 5396308.5,4575562 5396318.5,4575552
5396328.5,4575552 5396338.5,4575542 5396348.5,4575532 5396348.5,4575512
5396368.5,4575512 5396378.5,4575522 5396388.5,4575502 5396408.5,4575492
5396408.5,4575482 5396418.5,4575482 5396428.5,4575442 5396468.5,4575452
5396478.5,4575452 5396468.5,4575502 5396418.5,4575512 5396418.5,4575522
5396408.5,4575542 5396408.5,4575552 5396398.5,4575572 5396398.5,4575582
5396408.5,4575662 5396408.5,4575672 5396418.5,4575682 5396418.5,4575692
5396428.5,4575712 5396428.5,4575742 5396458.5,4575742 5396488.5,4575752
5396478.5,4575762 5396488.5,4575762 5396498.5,4575752 5396508.5,4575742
5396498.5,4575742 5396488.5,4575712 5396518.5,4575712 5396528.5,4575702
5396538.5,4575692 5396528.5,4575692 5396548.5,4575672 5396568.5,4575662
5396558.5,4575662 5396548.5,4575672 5396538.5,4575672 5396518.5,4575692
5396498.5,4575692 5396488.5,4575662 5396488.5,4575662 5396518.5,4575652
5396528.5,4575652 5396538.5,4575642 5396548.5,4575632 5396548.5,4575612
5396568.5,4575602 5396568.5,4575602 5396588.5,4575592 5396598.5,4575602
5396608.5,4575602 5396618.5,4575612 5396618.5,4575622 5396628.5,4575632
5396618.5,4575632 5396608.5,4575642 5396598.5,4575662 5396598.5,4575672
5396608.5,4575672 5396598.5,4575682 5396588.5,4575692 5396588.5,4575702
5396598.5,4575742 5396598.5,4575742 5396588.5,4575762 5396568.5,4575762
5396548.5,4575752 5396558.5,4575742 5396558.5,4575722 5396538.5,4575722
5396528.5,4575732 5396518.5,4575742 5396528.5,4575762 5396528.5,4575772
5396538.5,4575782 5396538.5,4575792 5396528.5,4575792 5396498.5,4575782
5396488.5,4575802 5396468.5,4575832 5396468.5,4575842 5396478.5,4575852
5396478.5,4575862 5396488.5,4575872 5396488.5,4575883 5396499,4575882
5396508.5,4575872 5396518.5,4575832 5396518.5,4575822 5396528.5,4575812
5396528.5,4575812 5396548.5,4575802 5396558.5,4575822 5396578.5,4575822
5396588.5,4575832 5396588.5,4575832 5396568.5,4575842 5396558.5,4575852
5396558.5,4575862 5396568.5,4575862 5396548.5,4575872 5396538.5,4575892
5396538.5,4575892 5396518.5,4575902 5396508.5,4575902 5396478.5,4575912
5396468.5,4575922 5396468.5,4575932 5396478.5,4575932 5396498.5,4575952
5396498.5,4575962 5396508.5,4575942 5396528.5,4575952 5396538.5,4575962
5396528.5,4575972 5396538.5,4575962 5396548.5,4575952 5396538.5,4575932
5396558.5,4575922 5396548.5,4575912 5396558.5,4575902 5396558.5,4575892
5396568.5,4575892 5396618.5,4575882 5396628.5,4575872 5396628.5,4575852
5396608.5,4575842 5396608.5,4575842 5396618.5,4575852 5396628.5,4575852
5396638.5,4575862 5396648.5,4575892 5396648.5,4575902 5396658.5,4575902
5396668.5,4575892 5396678.5,4575882 5396668.5,4575872 5396668.5,4575852
5396688.5,4575862 5396698.5,4575862 5396708.5,4575852 5396718.5,4575862
5396728.5,4575872 5396718.5,4575882 5396728.5,4575892 5396718.5,4575902
5396718.5,4575912 5396708.5,4575922 5396718.5,4575902 5396738.5,4575892
5396738.5,4575902 5396748.5,4575892 5396758.5,4575882 5396758.5,4575892
5396768.5,4575882 5396778.5,4575872 5396768.5,4575862 5396768.5,4575872
5396778.5,4575872 5396798.5,4575862 5396808.5,4575852 5396798.5,4575842
5396798.5,4575832 5396808.5,4575842 5396818.5,4575842 5396838.5,4575852
5396838.5,4575862 5396848.5,4575862 5396858.5,4575892 5396888.5,4575892
5396898.5,4575902 5396908.5,4575902 5396948.5,4575892 5396958.5,4575872
5396958.5,4575862 5396948.5,4575862 5396938.5,4575842 5396918.5,4575842
5396928.5,4575852 5396938.5,4575852 5396948.5,4575842 5396958.5,4575832
5396958.5,4575822 5396948.5,4575822 5396938.5,4575812 5396928.5,4575812
5396918.5,4575802 5396928.5,4575792 5396918.5,4575792 5396908.5,4575782
5396898.5,4575792 5396888.5,4575802 5396888.5,4575822 5396868.5,4575832
5396868.5,4575832 5396848.5,4575822 5396838.5,4575802 5396838.5,4575792
5396848.5,4575782 5396848.5,4575792 5396858.5,4575782 5396868.5,4575772
5396858.5,4575762 5396868.5,4575772 5396878.5,4575772 5396888.5,4575762
5396898.5,4575742 5396898.5,4575732 5396888.5,4575722 5396898.5,4575712
5396898.5,4575712 5396908.5,4575722 5396918.5,4575722 5396928.5,4575732
5396918.5,4575742 5396928.5,4575722 5396948.5,4575712 5396948.5,4575692
5396928.5,4575692 5396948.5,4575682 5396958.5,4575672 5396958.5,4575662
5396968.5,4575652 5396968.5,4575642 5396958.5,4575642 5396948.5,4575632
5396938.5,4575622 5396938.5,4575612 5396948.5,4575602 5396938.5,4575592
5396938.5,4575582 5396928.5,4575572 5396928.5,4575562 5396918.5,4575552
5396918.5,4575522 5396888.5,4575512 5396898.5,4575502 5396898.5,4575492
5396888.5,4575492 5396878.5,4575482 5396888.5,4575472 5396888.5,4575462
5396878.5,4575442 5396878.5,4575432 5396868.5,4575432 5396838.5,4575422
5396848.5,4575392 5396848.5,4575392 5396858.5,4575382 5396868.5,4575372
5396858.5,4575362 5396858.5,4575352 5396848.5,4575352 5396818.5,4575362
5396808.5,4575362 5396798.5,4575372 5396788.5,4575372 5396768.5,4575362
5396778.5,4575322 5396778.5,4575312 5396768.5,4575302 5396778.5,4575292
5396778.5,4575292 5396798.5,4575272 5396818.5,4575262 5396818.5,4575252
5396828.5,4575252 5396838.5,4575262 5396848.5,4575252 5396858.5,4575222
5396858.5,4575222 5396868.5,4575212 5396878.5,4575212 5396898.5,4575202
5396908.5,4575202 5396918.5,4575182 5396938.5,4575182 5396948.5,4575162
5396968.5,4575162 5396988.5,4575152 5396998.5,4575152 5397008.5,4575122
5397038.5,4575122 5397058.5,4575112 5397068.5,4575112 5397078.5,4575102
5397088.5,4575102 5397118.5,4575092 5397128.5,4575092 5397148.5,4575072
5397168.5,4575072 5397228.5,4575062 5397238.5,4575062 5397248.5,4575052
5397258.5,4575052 5397268.5,4575042 5397278.5,4575042 5397298.5,4575032
5397308.5,4575032 5397328.5,4575022 5397338.5,4575012 5397338.5,4575002
5397348.5,4575002 5397368.5,4575012 5397368.5,4575022 5397378.5,4575022
5397438.5,4575012 5397448.5,4575012 5397488.5,4575002 5397498.5,4575002
5397558.5,4574992 5397568.5,4574992 5397638.5,4574982 5397648.5,4574982
5397718.5,4574972 5397728.5,4574972 5397838.5,4574962 5397848.5,4574962
5397868.5,4574942 5397888.5,4574942 5397898.5,4574952 5397898.5,4574972
5397918.5,4574972 5397958.5,4574962 5397968.5,4574962 5398048.5,4574952
5398058.5,4574952 5398168.5,4574955.5 5398190.5,4574930.5
5398193,4574916 5398207.5,4574894 5398239,4574889.5 5398259.5,4574892
5398278.5,4574881.5 5398353.5,4574839 5398417.5,4574831
5398439,4574816.5 5398459.5,4574804 5398473,4574792.5 5398479,4574759
5398565.5,4574740 5398601.5,4574723 5398620,4574722 5398633,4574674
5398728,4574658.5 5398729.5,4574638 5398771,4574620.5 5398796,4574608
5398846,4574597.5 5398855,4574595.5 5398866.5,4574574.5
5398872.5,4574523 5398899,4574499.5 5398907.5,4574441
5398909.5,4574406.5 5398922.5,4574321 5398945.5,4574282
5398963.5,4574260 5398967,4574212 5398955,4574209.5 5398953,4574199.5
5398953,4574189.5 5398943,4574179.5 5398943,4574169.5 5398933,4574149.5
5398933,4574149.5 5398943,4574189.5 5398983,4574189.5 5398993,4574179.5
5399003,4574179.5 5399013,4574169.5 5399023,4574159.5 5399023,4574159.5
5399033,4574149.5 5399043,4574139.5 5399043,4574109.5 5399073,4574099.5
5399073,4574069.5 5399103,4574059.5 5399103,4574039.5 5399123,4574029.5
5399123,4573989.5 5399163,4573979.5 5399163,4573959.5 5399183,4573949.5
5399183,4573919.5 5399213,4573909.5 5399213,4573899.5 5399223,4573889.5
5399223,4573879.5 5399233,4573869.5 5399223,4573839.5 5399223,4573839.5
5399233,4573849.5 5399243,4573849.5 5399263,4573819.5 5399293,4573809.5
5399293,4573789.5 5399313,4573779.5 5399313,4573789.5 5399323,4573779.5
5399333,4573769.5 5399333,4573759.5 5399343,4573749.5 5399343,4573739.5
5399333,4573729.5 5399343,4573709.5 5399343,4573699.5 5399353,4573689.5
5399353,4573669.5 5399373,4573609.5 5399373,4573599.5 5399383,4573599.5
5399393,4573589.5 5399403,4573579.5 5399403,4573569.5 5399393,4573549.5
5399393,4573539.5 5399383,4573519.5 5399383,4573519.5 5399393,4573509.5
5399403,4573499.5 5399403,4573479.5 5399383,4573439.5 5399383,4573409.5
5399413,4573229.5 5399413,4573219.5 5399423,4573189.5 5399423,4573179.5
5399433,4573149.5 5399433,4573139.5 5399423,4573009.5 5399423,4572999.5
5399413,4572919.5 5399413,4572914 5399420,4572904 5399420,4572894
5399430,4572814 5399430,4572804 5399440,4572784 5399440,4572754
5399470,4572734 5399470,4572704 5399500,4572694 5399500,4572674
5399520,4572654 5399520,4572664 5399530,4572664 5399560,4572704
5399560,4572714 5399550,4572724 5399550,4572734 5399540,4572744
5399540,4572734 5399530,4572734 5399520,4572744 5399510,4572774
5399510,4572784 5399520,4572774 5399530,4572784 5399530,4572794
5399520,4572874 5399520,4572884 5399510,4572894 5399520,4572904
5399510,4572934 5399510,4572944 5399500,4572954 5399500,4572964
5399510,4572974 5399510,4572984 5399520,4572994 5399520,4572999.5
5399513,4573019.5 5399513,4573029.5 5399503,4573079.5 5399503,4573089.5
5399513,4573099.5 5399513,4573119.5 5399533,4573119.5 5399543,4573109.5
5399553,4573109.5 5399563,4573129.5 5399563,4573129.5 5399553,4573139.5
5399543,4573149.5 5399543,4573159.5 5399533,4573169.5 5399533,4573179.5
5399523,4573219.5 5399523,4573229.5 5399513,4573329.5 5399513,4573339.5
5399503,4573539.5 5399503,4573549.5 5399493,4573559.5 5399493,4573569.5
5399483,4573629.5 5399483,4573639.5 5399473,4573649.5 5399483,4573679.5
5399483,4573689.5 5399493,4573719.5 5399493,4573719.5 5399483,4573729.5
5399473,4573739.5 5399473,4573749.5 5399463,4573769.5 5399463,4573799.5
5399433,4573809.5 5399433,4573809.5 5399423,4573839.5 5399393,4573849.5
5399393,4573859.5 5399383,4573869.5 5399383,4573879.5 5399373,4573889.5
5399373,4573899.5 5399363,4573909.5 5399363,4573909.5 5399353,4573899.5
5399343,4573899.5 5399323,4573909.5 5399313,4573919.5 5399323,4573939.5
5399323,4573979.5 5399283,4573989.5 5399283,4573999.5 5399273,4574019.5
5399273,4574029.5 5399263,4574049.5 5399263,4574059.5 5399253,4574059.5
5399243,4574069.5 5399233,4574089.5 5399233,4574089.5 5399223,4574099.5
5399213,4574099.5 5399203,4574109.5 5399193,4574119.5 5399203,4574159.5
5399163,4574169.5 5399163,4574219.5 5399113,4574219.5 5399103,4574249.5
5399073,4574249.5 5399063,4574259.5 5399053,4574269.5 5399053,4574289.5
5399073,4574309.5 5399053,4574319.5 5399053,4574329.5 5399043,4574349.5
5399043,4574359.5 5399033,4574369.5 5399033,4574379.5 5399023,4574389.5
5399023,4574399.5 5399013,4574409.5 5399013,4574419.5 5399003,4574439.5
5399003,4574449.5 5398993,4574469.5 5398993,4574469.5 5398973,4574499.5
5398943,4574509.5 5398953,4574509.5 5398973,4574599.5 5398973,4574619.5
5398993,4574619.5 5399003,4574609.5 5399013,4574599.5 5399013,4574599.5
5399023,4574549.5 5399073,4574539.5 5399073,4574519.5 5399093,4574509.5
5399093,4574499.5 5399103,4574489.5 5399103,4574469.5 5399123,4574449.5
5399123,4574429.5 5399143,4574379.5 5399143,4574369.5 5399153,4574359.5
5399153,4574349.5 5399163,4574329.5 5399163,4574319.5 5399173,4574309.5
5399173,4574299.5 5399183,4574289.5 5399183,4574279.5 5399193,4574269.5
5399183,4574259.5 5399183,4574239.5 5399203,4574219.5 5399203,4574209.5
5399213,4574199.5 5399213,4574179.5 5399233,4574159.5 5399233,4574149.5
5399243,4574139.5 5399243,4574129.5 5399253,4574119.5 5399253,4574109.5
5399263,4574099.5 5399263,4574089.5 5399273,4574079.5 5399273,4574069.5
5399283,4574069.5 5399293,4574049.5 5399313,4574029.5 5399313,4574009.5
5399333,4573999.5 5399323,4573989.5 5399323,4573969.5 5399343,4573969.5
5399353,4573939.5 5399383,4573919.5 5399383,4573909.5 5399393,4573909.5
5399403,4573869.5 5399443,4573859.5 5399443,4573839.5 5399463,4573839.5
5399473,4573829.5 5399483,4573819.5 5399483,4573809.5 5399493,4573799.5
5399493,4573769.5 5399523,4573769.5 5399533,4573739.5 5399563,4573739.5
5399573,4573729.5 5399583,4573719.5 5399583,4573719.5 5399593,4573709.5
5399603,4573709.5 5399613,4573679.5 5399643,4573679.5 5399663,4573639.5
5399703,4573639.5 5399713,4573619.5 5399733,4573619.5 5399743,4573609.5
5399753,4573609.5 5399763,4573599.5 5399773,4573599.5 5399783,4573569.5
5399813,4573569.5 5399823,4573549.5 5399843,4573549.5 5399853,4573489.5
5399913,4573489.5 5399923,4573479.5 5399933,4573469.5 5399933,4573469.5
5399943,4573439.5 5399973,4573429.5 5399973,4573429.5 5399983,4573424
5399990,4573414 5399990,4573394 5400010,4573394 5400020,4573344
5400070,4573344 5400080,4573334 5400090,4573334 5400100,4573324
5400110,4573324 5400120,4573314 5400130,4573314 5400140,4573294
5400160,4573294 5400180,4573274 5400200,4573274 5400210,4573244
5400240,4573244 5400260,4573234 5400270,4573234 5400290,4573224
5400300,4573224 5400320,4573214 5400330,4573214 5400340,4573194
5400360,4573194 5400370,4573184 5400380,4573184 5400390,4573164
5400410,4573164 5400420,4573144 5400440,4573144 5400450,4573114
5400480,4573114 5400490,4573104 5400500,4573094 5400510,4573084
5400510,4573084 5400520,4573034 5400570,4573034 5400580,4572994
5400620,4572984 5400620,4572974 5400610,4572964 5400610,4572614
5402050,4572614 5402040,4572594 5402030,4572584 5402020,4572574
5402020,4572564 5402000,4572554 5402000,4572544 5401990,4572494
5401970,4572474 5401970,4572444 5401950,4572434 5401940,4572414
5401930,4572404 5401920,4572494 5402050,4572464 5402040,4572404
5402040,4572184 5402160,4572056.727 5402141.818,4572024 5402150,4572009
5402135,4571904 5402120,4571924 5402110,4571924 5402100,4572004
5402130,4572009 5402135,4572056.727 5402141.818,4572064 5402140,4572184
5402160,4571977.829 5401970.432,4571836.698 5401939.281,4571654.393
5401921.131,4571465.504 5401897.582,4571321.206 5401856.119,4571234.363
5401821.73,4571084.45 5401773.725,4571061.53 5401738.561,4571032.985
5401659.457,4571003.147 5401661.364,4570893.923 5401619.481,4570818.294
5401595.143,4570749.534 5401527.801,4570722.508 5401509.883,4570697.721
5401497.639,4570647.849 5401477.855,4570544.038 5401408.347,4570406.7
5401367.444,4570197.288 5401342.574,4570001.999 5401396.699,4569740.381
5401367.062,4569685.358 5401330.405,4569642.728 5401190.272,4569550.6
5401085.975,4569497.071 5401001.208,4569520.638 5400887.166,4569520.737
5400775.771,4569427.787 5400707.832,4569347.271 5400653.122,4569288.49
5400616.553,4569136.794 5400586.214,4568999.998 5400704.59,4568877.829
5400846.262,4568791.626 5400943.527,4568612.778 5401080.586,4568637.533
5401071.504,4568453.91 5401335.186,4568259.317 5401596.861,4567984.077
5401808.381,4567562.685 5402122.866,4567377.783 5402257.228,4566768.225
5402717.633,4566717.68 5402766.388,4566503.816 5402962.319,4566343.568
5403106.542,4566168.873 5403266.902,4566000.267 5403417.793,4565638.536
5403757.03,4565499.184 5403885.594,4565189.166 5404209.171,4565142.847
5404261.446,4565105.561 5404300.551,4564802.106 5404611.024,4564498.467
5404925.443,4564325.676 5405012.26,4564122.668 5405032.448,4563969.594
5405065.187,4563873.139 5405065.265,4563856.65 5405105.038,4563947.396
5405162.601,4564107.556 5405177.838,4564282.615 5405231.676,4564475.959
5405327.501,4564807.115 5405464.975,4565112.876 5405688.116,4565310.96
5405871.979,4565540.935 5406066.493,4565807.245 5406301.836,4565856.79
5406338.996,4565989.945 5406422.604,4566089.037 5406518.6,4566181.936
5406592.918,4566268.641 5406636.271,4566373.926 5406716.783,4566522.564
5406846.841,4566623.602 5406846.05,4566669.784 5406855.757,4566681.137
5406859.356,4566692.675 5406864.802,4566705.229 5406873.386,4566721.17
5406893.727,4566731.111 5406903.669,4566753.099 5406946.496,4566777.189
5407000.985,4566792.484 5407019.912,4566820.206 5407036.546,4566924.023
5407073.064,4566940.848 5407080.902,4566959.393 5407086.255,4566994.19
5407099.065,4567089.211 5407142.466,4567143.7 5407172.1,4567200.101
5407206.132,4567217.698 5407219.119,4567232.222 5407226.589,4567267.592
5407249.914,4567297.8 5407276.299,4567384.027 5407344.745,4567478.092
5407426.574,4567541.185 5407490.814,4567613.073 5407574.364,4567667.18
5407644.532,4567757.039 5407763.261,4567811.5 5407841,4567919
5407982.5,4567978 5407953.5,4568028.5 5407941.5,4568074
5407937,4568134.5 5407938,4568152 5407952,4568149 5407964.5,4568124.5
5407966.5,4568063 5407968.5,4568012.5 5407980,4567963 5408000,4567946
5408014,4568024.5 5408114.5,4568075.5 5408174,4568210.5
5408339.5,4568331 5408473.5,4568805 5408971.5,4568987.5
5409188.5,4569106 5409343.5,4569210 5409494,4569362 5409753,4569491.5
5409991,4569673.188 5410355.366,4569629.077 5410371.908,4569551.5
5410238,4569317 5409774,4569195 5409574,4568930 5409200.5,4568776.5
5409018.5,4568703 5408940,4568322 5408545.5,4568125 5408323,4568096
5408289,4568064.5 5408248.5,4568038 5408269.5,4568003
5408293.5,4567952.5 5408312,4567889.5 5408341,4567852.5
5408370.5,4567813.5 5408419,4567755.5 5408454,4567544.137
5408529.123,4567640.334 5408669.958,4568277 5409280.5,4568662
5409652,4568865.5 5409834.5,4568964.5 5409938.5,4569022 5409994,4569058
5410045,4569135 5410147.5,4569216 5410275.5,4569336.008
5410497.066,4569304.914 5410507.805,4569260.5 5410407,4569250.5
5410397,4569250.5 5410387,4569240.5 5410377,4569240.5 5410367,4569230.5
5410357,4569230.5 5410347,4569220.5 5410337,4569220.5 5410327,4569200.5
5410307,4569200.5 5410297,4569190.5 5410287,4569190.5 5410277,4569180.5
5410267,4569190.5 5410257,4569180.5 5410247,4569180.5 5410237,4569170.5
5410227,4569170.5 5410217,4569160.5 5410207,4569150.5 5410207,4569140.5
5410197,4569140.5 5410187,4569120.5 5410167,4569120.5 5410157,4569100.5
5410137,4569100.5 5410127,4569080.5 5410107,4569080.5 5410097,4569060.5
5410077,4569060.5 5410057,4569040.5 5410037,4569040.5 5410027,4569020.5
5410007,4569020.5 5409997,4569010.5 5410007,4568950.5 5409947,4568950.5
5409957,4568940.5 5409967,4568930.5 5409957,4568920.5 5409957,4568870.5
5409907,4568870.5 5409897,4568860.5 5409897,4568670.5 5409707,4568660.5
5409707,4568650.5 5409697,4568650.5 5409687,4568660.5 5409677,4568670.5
5409677,4568660.5 5409667,4568650.5 5409667,4568620.5 5409637,4568610.5
5409637,4568600.5 5409647,4568420.5 5409467,4568410.5 5409467,4568320.5
5409377,4568330.5 5409367,4568310.5 5409367,4567640.5 5408697,4567630.5
5408707,4567620.5 5408697,4567630.5 5408687,4567563.306
5408619.806,4567543.638 5408607,4567540.5 5408607,4567534.645
5408601.146,4567528.279 5408597,4567520.5 5408597,4567510.5
5408587,4567500.5 5408587,4567490 5408581.5,4567448.664
5408545.164,4567104.739 5408321.239,4567110.5 5408327,4567110.5
5408337,4567120.5 5408347,4567120.5 5408357,4567140.5 5408377,4567140.5
5408387,4567190.5 5408387,4567200.5 5408397,4567220.5 5408397,4567230.5
5408407,4567230.5 5408417,4567220.5 5408427,4567220.5 5408437,4567210.5
5408447,4567200.5 5408447,4567200.5 5408467,4567202 5408478,4567197
5408494,4567184 5408510,4567161 5408526.5,4567115.5 5408553,4567074.5
5408580,4567067 5408591,4567071 5408602.5,4567104.5 5408657,4567111
5408677.5,4567106.5 5408689,4567090.5 5408697,4567080.5
5408697,4567060.5 5408717,4567050.5 5408717,4567040.5 5408727,4567020.5
5408727,4567010.5 5408737,4567000.5 5408737,4566970.5 5408767,4566950.5
5408767,4566950.5 5408777,4566940.5 5408787,4566930.5 5408787,4566920.5
5408797,4566910.5 5408797,4566890.5 5408817,4566880.5 5408817,4566870.5
5408827,4566860.5 5408827,4566850.5 5408837,4566870.5 5408857,4566860.5
5408867,4566870.5 5408877,4566880.5 5408877,4566890.5 5408887,4566880.5
5408897,4566900.5 5408917,4566910.5 5408917,4566950.5 5408957,4566966.5
5408968.5,4566985.5 5408978.5,4566999.5 5408990.5,4567010.5
5409007,4567010.5 5409017,4567000.5 5409027,4566990.5 5409027,4566950.5
5408987,4566930.5 5409007,4566930.5 5409037,4566940.5 5409047,4566940.5
5409057,4566930.5 5409067,4566910.5 5409067,4566900.5 5409077,4566860.5
5409077,4566850.5 5409087,4566840.5 5409087,4566830.5 5409097,4566820.5
5409097,4566820.5 5409117,4566830.5 5409127,4566830.5 5409137,4566840.5
5409147,4566840.5 5409167,4566830.5 5409177,4566830.5 5409197,4566840.5
5409207,4566840.5 5409217,4566860.5 5409237,4566860.5 5409247,4566900.5
5409287,4566900.5 5409337,4566890.5 5409347,4566760.5 5409347,4566750.5
5409357,4566740.5 5409347,4566730.5 5409347,4566720.5 5409337,4566720.5
5409327,4566690.5 5409297,4566670.5 5409317,4566660.5 5409307,4566650.5
5409307,4566640.5 5409297,4566640.5 5409287,4566650.5 5409277,4566660.5
5409277,4566650.5 5409267,4566640.5 5409267,4566630.5 5409257,4566620.5
5409257,4566610.5 5409247,4566600.5 5409247,4566590.5 5409257,4566590.5
5409307,4566580.5 5409317,4566580.5 5409367,4566560.5 5409387,4566560.5
5409427,4566540.5 5409447,4566540.5 5409457,4566550.5 5409447,4566570.5
5409447,4566580.5 5409437,4566600.5 5409437,4566610.5 5409427,4566640.5
5409427,4566650.5 5409437,4566650.5 5409447,4566640.5 5409457,4566640.5
5409477,4566630.5 5409487,4566610.5 5409487,4566590.5 5409507,4566610.5
5409527,4566620.5 5409527,4566630.5 5409517,4566650.5 5409517,4566670.5
5409497,4566730.5 5409497,4566740.5 5409487,4566760.5 5409487,4566770.5
5409477,4566780.5 5409477,4566800.5 5409497,4566820.5 5409497,4566830.5
5409487,4566820.5 5409477,4566820.5 5409467,4566830.5 5409457,4566850.5
5409457,4566860.5 5409447,4566880.5 5409467,4566880.5 5409477,4566900.5
5409457,4566910.5 5409467,4566910.5 5409477,4566930.5 5409497,4566930.5
5409527,4566970.5 5409567,4566980.5 5409567,4566990.5 5409577,4566990.5
5409587,4566980.5 5409597,4566980.5 5409617,4566990.5 5409617,4567010.5
5409637,4567020.5 5409637,4567030.5 5409647,4567050.5 5409647,4567060.5
5409657,4567060.5 5409677,4567080.5 5409697,4567070.5 5409707,4567070.5
5409717,4567050.5 5409737,4567060.5 5409737,4567070.5 5409747,4567170.5
5409747,4567180.5 5409737,4567210.5 5409737,4567220.5 5409747,4567250.5
5409747,4567270.5 5409767,4567280.5 5409757,4567290.5 5409757,4567300.5
5409767,4567320.5 5409767,4567330.5 5409777,4567320.5 5409787,4567270.5
5409787,4567290.5 5409807,4567290.5 5409817,4567320.5 5409817,4567330.5
5409827,4567340.5 5409827,4567340.5 5409807,4567350.5 5409797,4567370.5
5409817,4567370.5 5409837,4567400.5 5409837,4567410.5 5409847,4567430.5
5409847,4567450.5 5409867,4567450.5 5409877,4567460.5 5409887,4567470.5
5409887,4567510.5 5409927,4567520.5 5409927,4567530.5 5409937,4567530.5
5409947,4567520.5 5409957,4567490.5 5409957,4567480.5 5409967,4567480.5
5410027,4567440.5 5410067,4567430.5 5410067,4567420.5 5410077,4567410.5
5410077,4567390.5 5410097,4567380.5 5410097,4567370.5 5410107,4567370.5
5410117,4567310.5 5410177,4567300.5 5410177,4567300.5 5410187,4567290.5
5410197,4567290.5 5410207,4567250.5 5410247,4567230.5 5410247,4567220.5
5410257,4567200.5 5410257,4567190.5 5410267,4567180.5 5410267,4567180.5
5410277,4567140.5 5410317,4567090.5 5410317,4567080.5 5410327,4567060.5
5410327,4567050.5 5410337,4567010.5 5410337,4567000.5 5410347,4566918
5410366,4566888 5410336,4566888 5410316,4566878 5410306,4566878
5410296,4566868 5410286,4566868 5410276,4566848 5410256,4566848
5410236,4566838 5410246,4566828 5410236,4566828 5410226,4566818
5410216,4566818 5410176,4566828 5410166,4566768 5410166,4566718
5410116,4566678 5410116,4566668 5410106,4566648 5410106,4566638
5410116,4566588 5410116,4566578 5410106,4566558 5410106,4566548
5410096,4566488 5410096,4566468 5410076,4566458 5410086,4566448
5410086,4566438 5410076,4566418 5410096,4566408 5410086,4566398
5410096,4566388 5410096,4566378 5410086,4566378 5410076,4566368
5410066,4566359.5 5410062,4566359.5 5410052,4566339.5 5410032,4566349.5
5410022,4566349.5 5410012,4566379.5 5409982,4566379.5 5409972,4566389.5
5409962,4566398 5409956,4566389.5 5409952,4566389.5 5409942,4566399.5
5409932,4566408 5409936,4566428 5409916,4566428 5409906,4566458
5409876,4566458 5409866,4566478 5409846,4566488 5409846,4566498
5409836,4566488 5409826,4566488 5409816,4566478 5409806,4566498
5409786,4566488 5409776,4566488 5409766,4566468 5409746,4566459.5
5409742,4566399.5 5409742,4566389.5 5409732,4566379.5 5409732,4566379.5
5409802,4566359.5 5409822,4566349.5 5409822,4566339.5 5409812,4566339.5
5409832,4566319.5 5409852,4566309.5 5409852,4566299.5 5409862,4566289.5
5409852,4566279.5 5409852,4566269.5 5409862,4566249.5 5409862,4566239.5
5409872,4566209.5 5409872,4566209.5 5409882,4566239.5 5409912,4566259.5
5409912,4566269.5 5409902,4566279.5 5409912,4566289.5 5409912,4566299.5
5409922,4566289.5 5409932,4566249.5 5409932,4566259.5 5409942,4566239.5
5409962,4566239.5 5409972,4566229.5 5409982,4566219.5 5409992,4566209.5
5409992,4566219.5 5410002,4566209.5 5410012,4566209.5 5410022,4566199.5
5410032,4566199.5 5410052,4566179.5 5410072,4566169.5 5410072,4566159.5
5410082,4566139.5 5410082,4566109.5 5410112,4566109.5 5410122,4566069.5
5410162,4566069.5 5410172,4566049.5 5410192,4566019.5 5410192,4566019.5
5410202,4565989.5 5410232,4565959.5 5410232,4565959.5 5410252,4565949.5
5410262,4565929.5 5410262,4565919.5 5410272,4565909.5 5410262,4565909.5
5410282,4565889.5 5410302,4565879.5 5410292,4565859.5 5410292,4565849.5
5410302,4565809.5 5410302,4565799.5 5410312,4565759.5 5410312,4565762.5
5410269.5,4565801 5410239,4565822 5410266.5,4565843 5410260,4565889
5410232,4565866 5410205.5,4565837.5 5410201.5,4565836.5
5410154,4565826.5 5410071,4565808.5 5410045.5,4565818.5
5410021.5,4565795.5 5409978.5,4565443.5 5409906.5,4565443.5
5409793,4565206.5 5409793,4565199 5409831.5,4565089.5 5409838.5,4565071
5410129.5,4565030 5410297.5,4564941.5 5410291.5,4564882.5
5410360.5,4564833.5 5410377,4564759.5 5410374.5,4564707
5410398.5,4564569.5 5410387,4564558 5410387,4564548 5410397,4564519.5
5410397,4564509.5 5410387,4564368 5410387,4564358 5410397,4564218
5410397,4564208 5410407,4564199.5 5410407,4564189.5 5410397,4564128
5410397,4564118 5410407,4564108 5410407,4564098 5410417,4564089.5
5410417,4564079.5 5410407,4564069.5 5410407,4564058.5 5410396.5,4564048
5410407,4564038 5410407,4564028 5410417,4563959.5 5410417,4563949.5
5410407,4563928 5410407,4563918.5 5410416.5,4563899.5 5410397,4563888
5410397,4563878 5410407,4563850.5 5410407,4563848.5 5410409.5,4563835.5
5410412,4563779.5 5410412,4563769.5 5410422,4563699.5 5410422,4563689.5
5410432,4563679.5 5410432,4563659.5 5410412,4563659.5 5410392,4563649.5
5410382,4563639.5 5410382,4563629.5 5410372,4563619.5 5410382,4563599.5
5410382,4563589.5 5410372,4563579.5 5410372,4563569.5 5410362,4563569.5
5410352,4563559.5 5410342,4563559.5 5410312,4563549.5 5410312,4563549.5
5410342,4563539.5 5410352,4563529.5 5410352,4563519.5 5410342,4563519.5
5410332,4563529.5 5410322,4563529.5 5410302,4563539.5 5410292,4563549.5
5410292,4563549.5 5410282,4563569.5 5410262,4563569.5 5410232,4563579.5
5410222,4563579.5 5410192,4563569.5 5410182,4563569.5 5410152,4563549.5
5410132,4563549.5 5410122,4563539.5 5410112,4563539.5 5410102,4563529.5
5410092,4563529.5 5410082,4563509.5 5410062.5,4563486
5410011.5,4563519.5 5409988,4563519 5409984.5,4563478.5 5409967,4563430
5409927.5,4563372.5 5409877.5,4563333 5409834,4563291 5409776,4563248
5409733.5,4563210.5 5409709.5,4563181 5409706.5,4563158.5
5409708.5,4563157 5409712,4563195 5409751.5,4563215.5 5409778.5,4563284
5409881.5,4563322 5409944.5,4563366.5 5410027,4563377 5410070,4563424.5
5410149,4563446.5 5410191,4563448 5410219,4563447 5410245.5,4563434
5410262.5,4563410.5 5410280,4563360 5410272,4563327 5410259,4563202.5
5410201,4563171 5410204,4563089 5410187,4563027.5 5409969.5,4563025.5
5409968,4562970.5 5409969,4562941 5409980,4562911 5410011,4562884.5
5410015,4562883 5410017,4562878 5410125.5,4562880.5 5410126,4562878
5410128,4562878 5410125.5),(4570774 5402849.033,4570777.479
5402838.261,4570805.095 5402752.738,4570806.924 5402747.077,4570806.006
5402749.953,4570805.095 5402752.738,4570781.954 5402824.689,4570777.479
5402838.261,4570776.876 5402840.324,4570774 5402849.033),(4571285.765
5408495.315,4571292 5408436.5,4571292.137 5408438.425,4571285.765
5408495.315),(4570816.582 5402729.434,4570821.176 5402715.648,4570864
5402570.325,4570864 5402570,4570864.155 5402569.845,4570871.334
5402546.928,4570898.253 5402464.253,4570894 5402460,4570895.668
5402459.731,4570898.253 5402464.253,4570864.155 5402569.845,4570864
5402570.325,4570861.871 5402580.726,4570821.176 5402715.648,4570814
5402740,4570816.582 5402729.434),(4566665 5406634,4566678.974
5406622.743,4566684.521 5406614.764,4566719 5406590.5,4566678.974
5406622.743,4566663.5 5406645,4566665 5406634),(4571095.5
5408567.5,4571102.5 5408555.5,4571131 5408546.5,4571095.5
5408567.5),(4569842 5404392.5,4569941 5404483.5,4569925 5404471,4569884
5404433.5,4569842 5404392.5),(4569910 5404512,4569920 5404502,4569950
5404512,4569910 5404512),(4572524 5402090,4572534 5402100,4572564
5402140,4572584 5402160,4572574 5402160,4572564 5402150,4572524
5402090),(4569356.586 5410606.657,4569377.067 5410593.656,4569392.926
5410630.33,4569374.473 5410639.45,4569356.586 5410606.657),(4582632
5392963.5,4582632.5 5392959,4582639 5392953,4582641.5 5392948,4582644.5
5392946,4582654 5392945.5,4582667 5392947.5,4582670 5392949.5,4582672.5
5392953.5,4582671 5392965,4582667.5 5392967.5,4582662.5 5392976,4582660
5392978,4582649 5392979.5,4582642.5 5392977,4582639.5 5392982.5,4582638
5392982.5,4582632 5392963.5),(4571245 5408407,4571291.5
5408377.5,4571313.5 5408358,4571302.079 5408397.124,4571277
5408404.5,4571265.899 5408412.321,4571245 5408407),(4565687.028
5412191.47,4565759.5 5412112,4565816.352 5412111.154,4565728.067
5412202.931,4565687.028 5412191.47),(4581424.5 5392523,4581428
5392520,4581429.5 5392515,4581437 5392512.5,4581440.5 5392507,4581449
5392504.5,4581456 5392494.5,4581466 5392491,4581469 5392483.5,4581480.5
5392481.5,4581487.5 5392486,4581497 5392495,4581500.5 5392502,4581512
5392504.5,4581512.5 5392505.5,4581509.5 5392508,4581505.5
5392508.5,4581505.5 5392511,4581518.5 5392529,4581526 5392533,4581528.5
5392533.5,4581530 5392532.5,4581531 5392535,4581521.5
5392542.5,4581499.5 5392553.5,4581495 5392560,4581488.5
5392563,4581484.5 5392567.5,4581476 5392571.5,4581471.5
5392576.5,4581464.5 5392580,4581460 5392585,4581449.5
5392587.5,4581445.5 5392590.5,4581440.5 5392597,4581427
5392602.5,4581422 5392606,4581412 5392606.5,4581409.5 5392608,4581406.5
5392613,4581406 5392621,4581402.5 5392625,4581391 5392627.5,4581381.5
5392625.5,4581369.5 5392626.5,4581369.5 5392623.5,4581376
5392624,4581377.5 5392621.5,4581373 5392612.5,4581370 5392595,4581366.5
5392584.5,4581370.5 5392575,4581375.5 5392571,4581379 5392563,4581384.5
5392559.5,4581390 5392552.5,4581392 5392546,4581397.5 5392542,4581400.5
5392535.5,4581408 5392534,4581416.5 5392525.5,4581424.5
5392523),(4577954.347 5399138.644,4577989.539 5399107.073,4578109
5399299,4578166.5 5399425.5,4578230.5 5399602.5,4578194
5399607,4578153.5 5399476.5,4578107.5 5399375,4578043.5
5399267,4577954.347 5399138.644),(4581659.5 5392384.5,4581669
5392382,4581674.5 5392377.5,4581679 5392370.5,4581682 5392370,4581691.5
5392372.5,4581714 5392369,4581719.5 5392363.5,4581728 5392347,4581730.5
5392345.5,4581739 5392356.5,4581748.5 5392362.5,4581759.5
5392364.5,4581770 5392364.5,4581771 5392365.5,4581771 5392375,4581777.5
5392385,4581774.5 5392389.5,4581770 5392391,4581757 5392399.5,4581749
5392410,4581747 5392414.5,4581749.5 5392425,4581759.5 5392427.5,4581764
5392434.5,4581764.5 5392446.5,4581760.5 5392480.5,4581741.5
5392496,4581729 5392504.5,4581719.5 5392509,4581702 5392510.5,4581687.5
5392503.5,4581679.5 5392503.5,4581678.5 5392506,4581679.5
5392535,4581671.5 5392557.5,4581670.5 5392566,4581664 5392577,4581654
5392586,4581644.5 5392589.5,4581640 5392588.5,4581637.5
5392586.5,4581634 5392575,4581614 5392549.5,4581610.5 5392542,4581603.5
5392532.5,4581601.5 5392524.5,4581587.5 5392512,4581574.5
5392505,4581574 5392496.5,4581571 5392490,4581569.5 5392489.5,4581566.5
5392495.5,4581566.5 5392504,4581565.5 5392506,4581558 5392511.5,4581557
5392517,4581551.5 5392522.5,4581547 5392521,4581541.5 5392516,4581539.5
5392512.5,4581528.5 5392506,4581519.5 5392497,4581518.5 5392491,4581520
5392477.5,4581530.5 5392464.5,4581536.5 5392462,4581542.5
5392463,4581551 5392468,4581557.5 5392469,4581562 5392471.5,4581566
5392475.5,4581568.5 5392481,4581572.5 5392483.5,4581576.5
5392482,4581578.5 5392474.5,4581578 5392464.5,4581581.5
5392455.5,4581586.5 5392449,4581592 5392436,4581599 5392431.5,4581608.5
5392430,4581616.5 5392424.5,4581623.5 5392416,4581633.5
5392396.5,4581640.5 5392393.5,4581647 5392392.5,4581659.5
5392384.5),(4567896.5 5409901,4567906 5409838,4568032 5409879,4568218
5409947,4568571 5410026.5,4568767 5410036.5,4568767 5410089.5,4568668
5410085,4568479.5 5410051,4568109.5 5409951.5,4567896.5
5409901),(4577187 5397993.5,4577215 5397971,4577270.5
5398072.5,4577369.5 5398223,4577736 5398743,4577892.64
5398981.951,4577868.141 5399001.486,4577685 5398739.5,4577291
5398170,4577239 5398089,4577187 5397993.5),(4582437.5 5392938,4582440.5
5392930.5,4582453.5 5392930,4582461 5392931.5,4582480.5
5392939.5,4582490 5392945.5,4582504.5 5392949,4582506 5392951,4582502
5392960,4582497.5 5392964,4582494 5392965.5,4582485.5
5392965.5,4582475.5 5392977,4582472.5 5392985,4582472.5
5392991,4582478.5 5393003.5,4582481.5 5393004.5,4582488
5393002,4582496.5 5392996.5,4582509.5 5392998,4582520.5
5392997.5,4582525 5392989.5,4582526 5392985,4582536.5 5392979,4582533.5
5392971.5,4582536.5 5392968,4582539 5392959,4582535.5 5392950,4582535
5392944.5,4582531 5392931.5,4582532 5392924.5,4582535 5392922,4582540.5
5392921.5,4582550.5 5392910,4582551.5 5392899,4582549 5392895,4582546.5
5392896,4582540 5392892,4582532.5 5392890,4582519.5 5392878,4582507
5392860,4582508 5392850.5,4582513 5392838,4582517 5392834.5,4582521
5392833,4582523 5392830.5,4582530 5392810.5,4582539 5392803.5,4582550.5
5392792,4582565.5 5392760,4582569 5392754.5,4582580 5392742.5,4582584.5
5392734,4582594 5392726.5,4582600.5 5392718,4582606 5392715.5,4582609.5
5392711,4582631.5 5392704.5,4582647 5392696.5,4582654.5
5392690.5,4582656 5392685.5,4582661 5392684,4582666.5 5392674,4582672.5
5392671.5,4582688.5 5392675,4582696.5 5392675.5,4582698
5392674.5,4582706.5 5392656.5,4582711.5 5392655,4582718.5
5392648,4582721.5 5392649,4582735.5 5392661.5,4582741 5392664,4582748.5
5392659.5,4582759.5 5392648.5,4582780.5 5392636.5,4582789
5392629.5,4582807.5 5392621,4582809 5392618,4582812 5392618,4582818.5
5392613,4582822 5392612,4582832.5 5392613.5,4582833.5 5392611,4582825.5
5392580.5,4582826 5392579,4582831.5 5392575.5,4582834.5
5392570,4582839.5 5392566.5,4582857 5392570,4582862.5 5392572.5,4582874
5392595.5,4582874.5 5392599.5,4582872.5 5392603.5,4582879
5392607.5,4582883 5392613.5,4582883 5392616,4582879.5 5392619,4582878
5392618,4582871 5392607.5,4582867.5 5392605.5,4582859 5392608,4582852.5
5392613,4582851.5 5392615,4582853.5 5392626.5,4582863.5
5392633.5,4582861.5 5392636.5,4582854.5 5392640,4582854
5392644,4582856.5 5392658.5,4582856 5392663.5,4582850.5
5392680,4582830.5 5392720,4582826 5392725.5,4582820.5 5392740.5,4582801
5392742,4582786.5 5392759,4582775 5392764.5,4582771.5 5392770.5,4582763
5392775.5,4582754 5392792,4582730 5392799.5,4582721 5392809,4582712.5
5392811.5,4582708.5 5392821.5,4582702 5392826.5,4582689
5392828.5,4582681 5392832.5,4582661.5 5392830,4582651 5392832.5,4582641
5392832.5,4582623.5 5392826.5,4582618.5 5392826.5,4582602
5392837,4582590 5392839.5,4582584 5392842.5,4582580 5392842,4582576.5
5392843.5,4582555 5392857.5,4582552.5 5392862,4582538.5 5392869,4582538
5392870.5,4582541 5392879,4582551.5 5392889.5,4582570 5392895.5,4582579
5392896,4582582.5 5392898.5,4582583.5 5392904.5,4582591 5392917,4582592
5392921.5,4582588 5392927.5,4582585 5392937,4582573.5
5392949.5,4582561.5 5392959.5,4582560.5 5392963.5,4582555
5392964.5,4582554.5 5392970.5,4582550 5392975.5,4582546 5392977,4582552
5392990,4582559 5393000,4582559.5 5393002.5,4582555.5 5393015,4582540.5
5393020,4582531.5 5393019.5,4582521.5 5393010.5,4582519
5393019.5,4582513.5 5393029.5,4582498 5393045.5,4582492.5
5393062.5,4582483.5 5393083,4582476 5393085.5,4582474.5
5393090.5,4582467 5393096.5,4582464 5393102,4582454.5 5393106,4582459
5393120.5,4582460 5393130.5,4582457.5 5393136.5,4582454
5393141,4582454.5 5393144.5,4582452.5 5393149.5,4582460.5
5393169.5,4582473.5 5393180,4582466.5 5393186.5,4582459
5393190,4582447.5 5393191,4582439.5 5393189,4582435.5 5393194.5,4582433
5393207.5,4582435 5393213,4582440.5 5393219.5,4582452
5393226.5,4582454.5 5393231,4582449.5 5393236.5,4582433.5
5393246,4582427.5 5393264,4582424 5393270,4582426 5393276.5,4582418.5
5393277.5,4582409.5 5393271,4582401 5393268.5,4582396 5393270,4582394.5
5393272,4582391.5 5393272,4582389 5393270.5,4582382.5 5393259.5,4582383
5393231.5,4582386 5393218,4582383 5393207.5,4582383 5393200.5,4582386
5393187,4582385 5393168,4582388.5 5393158.5,4582388.5 5393148.5,4582395
5393136.5,4582395.5 5393133.5,4582394 5393114,4582396.5
5393091.5,4582397 5393074,4582399.5 5393067.5,4582409.5
5393060.5,4582408.5 5393049,4582417.5 5393040,4582418.5
5393032.5,4582417 5393027.5,4582417 5393020.5,4582420.5
5393017.5,4582423.5 5393019,4582425.5 5393021.5,4582426.5
5393029.5,4582440 5393036,4582444.5 5393034,4582449.5
5393029.5,4582453.5 5393020.5,4582451.5 5393014.5,4582446.5
5393009.5,4582438.5 5393005.5,4582435 5393005,4582430.5
5393012.5,4582429 5393011,4582428.5 5393005.5,4582430 5392992,4582432
5392990,4582439 5392988.5,4582441 5392981.5,4582440.5 5392969,4582447.5
5392958.5,4582440 5392946,4582437.5 5392938),(4565277 5412453,4565277
5412463,4565287 5412473,4565287 5412483,4565297 5412493,4565327
5412493,4565367 5412453,4565377 5412453,4565548.764
5412282.188,4565553.756 5412282.188,4565627.247 5412309.567,4565630.05
5412312.721,4565577 5412353,4565577 5412363,4565537 5412403,4565527
5412403,4565457 5412473,4565447 5412473,4565447 5412483,4565437
5412493,4565427 5412493,4565367 5412553,4565367 5412593,4565407
5412633,4565417 5412633,4565447 5412663,4565437 5412673,4565427
5412673,4565417 5412663,4565407 5412663,4565387 5412643,4565377
5412643,4565367 5412633,4565357 5412633,4565347 5412623,4565337
5412623,4565327 5412613,4565287 5412613,4565257 5412643,4565247
5412643,4565217 5412673,4565207 5412673,4565167 5412713,4565157
5412713,4565127 5412743,4565117 5412743,4565097 5412763,4565087
5412763,4565057 5412793,4565047 5412793,4565017 5412823,4565007
5412823,4564977 5412853,4564967 5412853,4564937 5412883,4564927
5412883,4564907 5412903,4564897 5412903,4564867 5412933,4564857
5412933,4564847 5412943,4564827 5412943,4564817 5412953,4564807
5412943,4564877 5412873,4564887 5412873,4564917 5412843,4564927
5412843,4564967 5412803,4564977 5412803,4565017 5412763,4565027
5412763,4565087 5412703,4565097 5412703,4565157 5412643,4565167
5412643,4565237 5412573,4565237 5412553,4565247 5412543,4565247
5412503,4565237 5412493,4565237 5412463,4565247 5412453,4565247
5412433,4565287 5412393,4565297 5412393,4565307 5412383,4565327
5412383,4565337 5412373,4565347 5412373,4565357 5412383,4565337
5412403,4565327 5412403,4565317 5412413,4565307 5412413,4565287
5412433,4565287 5412443,4565277 5412453),(4565915.098
5412017.886,4565866.436 5412003.047,4565958 5411908,4565960.5
5411856.5,4566713.5 5411027,4566738 5411016,4566748 5411026,4566748
5411036,4566758 5411026,4566758 5410996,4566768 5410986,4566778
5410986,4566908 5410856,4566918 5410856,4566998 5410776,4567008
5410776,4567038 5410746,4567048 5410746,4567068 5410726,4567088
5410726,4567094.5 5410733,4566950.5 5410877,4566940.5 5410877,4566770.5
5411047,4566760.5 5411037,4566750.5 5411047,4566760.5 5411057,4566600.5
5411217,4566600.5 5411227,4566590.5 5411237,4566580.5 5411237,4566580.5
5411247,4566490.5 5411337,4566490.5 5411347,4566420.5 5411417,4566420.5
5411427,4566360.5 5411487,4566360.5 5411497,4566300.5 5411557,4566300.5
5411567,4566250.5 5411617,4566250.5 5411627,4566200.5 5411677,4566200.5
5411687,4566150.5 5411737,4566150.5 5411747,4566100.5 5411797,4566100.5
5411807,4566060.5 5411847,4566060.5 5411857,4566010.5
5411907,4565915.098 5412017.886),(4576754.5 5404012.5,4576776.5
5403986,4576829 5404012.5,4576867 5404015,4576922 5403997.5,4576982
5403960,4577216.5 5403802.5,4577247 5403857.5,4576867
5404105.5,4576821.5 5404139,4576797 5404174,4576797 5404231,4576769
5404251.5,4576756 5404223.5,4576719.5 5404206,4576682 5404223.5,4576217
5404541.5,4576102 5404634.5,4575858.5 5404836,4575672 5405012,4575631
5404971.5,4576036.5 5404614.5,4576501 5404269,4576735.5
5404121.5,4576769 5404083.5,4576773.5 5404047,4576754.5
5404012.5),(4582359.5 5393647.5,4582363 5393641.5,4582363
5393639.5,4582370.5 5393628.5,4582380 5393620,4582381.5
5393614.5,4582385 5393609,4582379.5 5393602,4582377.5 5393596.5,4582378
5393582,4582381 5393574.5,4582383 5393572.5,4582387 5393550,4582392.5
5393544,4582396 5393535.5,4582404 5393531.5,4582407.5
5393525.5,4582410.5 5393524.5,4582415.5 5393530,4582417
5393536.5,4582420 5393541,4582429.5 5393544,4582433.5 5393543,4582434
5393541,4582431 5393528,4582422 5393519,4582411.5 5393513.5,4582404
5393515,4582398 5393510,4582400 5393498.5,4582408 5393495.5,4582411.5
5393492.5,4582419 5393489,4582421.5 5393489.5,4582433 5393497.5,4582438
5393497.5,4582439 5393495.5,4582439 5393482.5,4582438 5393480,4582422
5393468,4582419.5 5393463.5,4582419 5393459.5,4582428.5
5393453.5,4582434 5393454.5,4582435 5393453.5,4582435.5
5393438.5,4582436.5 5393436,4582440 5393434,4582441 5393432,4582443
5393411.5,4582447.5 5393400,4582447 5393396,4582450.5
5393383.5,4582450.5 5393376.5,4582447.5 5393368,4582450
5393364.5,4582451 5393359,4582451.5 5393336.5,4582451 5393328.5,4582447
5393320,4582446.5 5393316,4582451 5393314.5,4582453.5
5393310.5,4582451.5 5393304.5,4582449.5 5393302.5,4582439
5393299.5,4582433 5393289.5,4582432.5 5393283,4582434.5
5393283,4582440.5 5393287,4582450 5393289.5,4582466.5 5393280,4582470.5
5393276.5,4582478 5393265,4582480.5 5393263.5,4582486 5393269.5,4582488
5393280,4582486.5 5393287,4582489 5393299,4582486 5393308.5,4582486
5393317,4582480 5393328,4582477.5 5393346.5,4582475 5393350,4582477.5
5393380,4582469.5 5393406.5,4582469.5 5393411.5,4582475.5
5393429.5,4582476.5 5393436,4582474.5 5393462.5,4582475
5393472.5,4582466.5 5393489,4582469.5 5393499,4582465.5
5393502,4582463.5 5393505.5,4582463.5 5393511,4582466.5
5393519.5,4582474.5 5393528,4582475.5 5393530.5,4582473.5
5393533,4582473.5 5393550.5,4582472 5393552.5,4582466 5393553,4582465
5393554.5,4582464.5 5393568,4582473 5393601.5,4582469.5 5393606,4582468
5393610.5,4582477 5393645,4582482 5393657,4582489 5393655.5,4582514.5
5393640.5,4582519 5393637,4582521.5 5393632.5,4582526 5393621.5,4582538
5393579,4582536.5 5393553,4582538 5393547.5,4582546.5 5393546,4582552
5393543,4582561.5 5393542,4582580 5393543.5,4582589 5393546,4582597
5393544,4582602 5393540.5,4582611 5393520.5,4582615 5393515,4582618.5
5393498,4582620.5 5393496.5,4582632 5393495,4582635 5393493,4582637.5
5393484.5,4582637 5393479.5,4582627.5 5393469,4582630 5393468,4582640
5393476.5,4582652.5 5393477,4582659 5393476,4582672 5393485.5,4582688.5
5393484,4582700 5393493.5,4582711.5 5393493.5,4582713.5
5393493,4582714.5 5393484,4582722.5 5393482,4582723 5393480.5,4582720.5
5393464,4582718.5 5393459,4582722.5 5393452,4582731 5393453.5,4582733.5
5393452,4582734.5 5393436,4582739.5 5393430.5,4582760.5
5393429,4582767.5 5393431,4582780.5 5393442.5,4582784 5393449,4582780.5
5393468.5,4582776 5393475,4582775 5393485,4582770 5393492.5,4582768
5393499,4582768 5393505,4582767 5393507,4582760.5 5393511,4582750
5393540.5,4582738.5 5393560,4582742.5 5393569.5,4582741.5
5393579,4582733 5393601.5,4582732 5393621,4582720.5 5393671,4582716
5393677,4582712.5 5393689,4582713.5 5393699.5,4582717.5 5393709,4582715
5393714.5,4582709.5 5393717,4582708 5393719,4582713 5393739.5,4582720.5
5393750,4582724 5393760.5,4582720 5393763.5,4582715 5393764.5,4582711.5
5393771,4582705.5 5393772.5,4582703 5393775,4582701 5393782,4582697.5
5393788,4582691 5393810,4582672.5 5393840.5,4582672 5393859,4582667.5
5393867,4582663 5393882.5,4582661 5393884.5,4582656 5393886,4582651
5393891.5,4582642 5393894,4582638.5 5393899,4582638.5 5393907,4582647.5
5393919.5,4582648 5393922,4582641.5 5393939,4582637 5393946.5,4582627.5
5393968.5,4582620 5393976.5,4582611.5 5393980,4582609.5
5393985,4582607.5 5393980,4582605.5 5393978.5,4582600.5
5393976.5,4582597 5393976.5,4582596 5393983.5,4582587.5
5393987,4582585.5 5393990,4582585 5393994.5,4582571.5
5393993.5,4582560.5 5393989,4582555 5393990,4582551 5393993.5,4582548
5394004.5,4582543.5 5394010.5,4582543 5394014.5,4582544.5
5394019,4582561 5394031.5,4582568.5 5394039.5,4582573
5394050.5,4582567.5 5394057,4582560 5394061.5,4582551.5
5394070.5,4582548 5394078.5,4582555.5 5394097.5,4582557.5
5394117,4582552.5 5394123,4582538.5 5394129.5,4582553.5
5394147.5,4582568.5 5394159.5,4582573.5 5394167.5,4582574
5394170,4582571 5394171,4582566.5 5394176,4582563 5394187.5,4582560.5
5394190.5,4582550 5394191,4582530.5 5394182.5,4582506
5394161.5,4582504.5 5394158,4582507 5394142,4582505 5394138,4582495.5
5394133.5,4582480 5394134,4582477 5394131.5,4582471 5394121,4582468.5
5394121.5,4582462.5 5394132,4582452.5 5394142,4582437
5394147.5,4582421.5 5394149.5,4582411.5 5394155.5,4582400
5394149.5,4582373 5394126,4582357 5394120,4582322.5 5394110,4582320
5394107.5,4582317 5394078.5,4582317.5 5394060.5,4582320
5394048.5,4582365 5394020.5,4582365.5 5394019,4582341 5393976.5,4582340
5393969.5,4582340.5 5393950,4582335 5393940,4582333.5 5393931,4582335
5393911.5,4582329.5 5393868,4582327.5 5393860,4582321.5
5393850.5,4582317 5393836.5,4582315.5 5393827,4582319 5393819.5,4582335
5393807.5,4582341 5393800,4582352 5393774.5,4582362 5393740,4582354.5
5393727,4582352.5 5393720.5,4582363 5393700.5,4582359.5
5393689.5,4582358.5 5393668.5,4582363.5 5393659.5,4582359.5
5393652,4582359.5 5393647.5),(4581936.596 5393037.937,4581932.025
5393065.361,4581928.5 5393072.5,4581839.5 5393408,4581819.5
5393415,4581809.5 5393415,4581799.5 5393425,4581789.5 5393425,4581779.5
5393435,4581759.5 5393435,4581749.5 5393445,4581699.5 5393445,4581689.5
5393435,4581669.5 5393435,4581649.5 5393415,4581639.5 5393415,4581629.5
5393405,4581619.5 5393405,4581599.5 5393385,4581589.5 5393385,4581579.5
5393375,4581569.5 5393375,4581559.5 5393365,4581549.5 5393365,4581529.5
5393345,4581519.5 5393345,4581509.5 5393335,4581499.5 5393335,4581489.5
5393325,4581479.5 5393325,4581469.5 5393335,4581459.5 5393335,4581439.5
5393355,4581429.5 5393355,4581399.5 5393385,4581349.5 5393385,4581289.5
5393325,4581289.5 5393315,4581239.5 5393265,4581239.5 5393255,4581209.5
5393225,4581209.5 5393215,4581199.5 5393205,4581199.5 5393195,4581189.5
5393185,4581189.5 5393135,4581179.5 5393125,4581179.5 5393085,4581169.5
5393075,4581179.5 5393065,4581189.5 5393065,4581199.5 5393055,4581219.5
5393055,4581229.5 5393045,4581249.5 5393045,4581259.5 5393035,4581269.5
5393035,4581279.5 5393025,4581289.5 5393025,4581299.5 5393015,4581309.5
5393015,4581319.5 5393005,4581329.5 5393005,4581349.5 5392985,4581359.5
5392985,4581389.5 5392955,4581399.5 5392955,4581419.5 5392935,4581429.5
5392935,4581459.5 5392905,4581469.5 5392905,4581499.5 5392875,4581509.5
5392875,4581529.5 5392855,4581539.5 5392855,4581569.5 5392825,4581579.5
5392825,4581609.5 5392795,4581619.5 5392795,4581639.5 5392775,4581649.5
5392775,4581679.5 5392745,4581689.5 5392745,4581719.5 5392715,4581729.5
5392715,4581759.5 5392685,4581769.5 5392685,4581789.5 5392665,4581799.5
5392665,4581829.5 5392635,4581839.5 5392635,4581869.5 5392605,4581879.5
5392605,4581909.5 5392575,4581919.5 5392575,4581949.5 5392545,4581959.5
5392545,4581979.5 5392525,4581989.5 5392525,4582009.5 5392505,4582019.5
5392505,4582004 5392622,4581994 5392717,4581955.5 5392963,4581936.596
5393037.937),(4582269.5 5392095,4582279.5 5392085,4582489.5
5392085,4582499.5 5392095,4582579.5 5392095,4582589.5 5392105,4582689.5
5392105,4582699.5 5392115,4582708.412 5392115,4582709.884
5392131.436,4582686.31 5392132.677,4582644.621 5392129.296,4582574.765
5392128.17,4582526.316 5392121.409,4582478.122 5392117.394,4582479.5
5392115,4582469.5 5392115,4582459.5 5392105,4582359.5 5392105,4582369.5
5392115,4582369.5 5392125,4582339.5 5392155,4582329.5 5392155,4582299.5
5392125,4582309.5 5392115,4582239.5 5392115,4582229.5 5392125,4582199.5
5392125,4582189.5 5392135,4582159.5 5392135,4582149.5 5392145,4582129.5
5392145,4582119.5 5392155,4582099.5 5392155,4582089.5 5392165,4582069.5
5392165,4582059.5 5392175,4582049.5 5392175,4582039.5 5392185,4582029.5
5392185,4581989.5 5392225,4581979.5 5392215,4581979.5 5392225,4581969.5
5392235,4581959.5 5392235,4581949.5 5392225,4581939.5 5392225,4581939.5
5392235,4581919.5 5392255,4581909.5 5392245,4581889.5 5392245,4581679
5392351.5,4581032 5392658.5,4580608 5392874,4580468.5 5392935,4580323.5
5392973,4580187.5 5392993.5,4580149 5392995.5,4580140
5392998.5,4580138.5 5393001.5,4580135.5 5393003.5,4580118
5393005,4580113.5 5393008.5,4580095 5393015,4580088 5393021.5,4580080
5393025,4580073.5 5393038.5,4580066 5393048.5,4580054 5393059,4580034
5393068.5,4580019.5 5393072.5,4579999.5 5393081.5,4579989
5393083.5,4579978.5 5393083.5,4579960 5393081,4579922.5
5393071.5,4579909.5 5393067,4579900 5393065.5,4579889
5393066.5,4579870.5 5393064.5,4579830 5393057.5,4579823.5
5393043,4579802 5393026.5,4579786.5 5393024,4579776.5 5393021,4579766.5
5393016,4579767 5393010,4579763 5392992.5,4579755 5392983.5,4579749.5
5392981.5,4579743 5392990,4579722 5392991.5,4579717 5392993.5,4579715
5392998.5,4579720 5393012.5,4579728 5393025,4579728 5393027.5,4579727
5393036.5,4579718.5 5393044,4579715 5393050,4579707.5 5393051,4579701.5
5393056,4579691.5 5393060,4579681.5 5393060.5,4579667.5
5393050.5,4579658.5 5393042,4579649.5 5393040.5,4579641.5
5393035.5,4579639.5 5393033,4579632.5 5393036,4579630 5393045,4579624.5
5393049.5,4579620.5 5393058.5,4579609.5 5393057,4579602.5
5393054.5,4579600 5393051,4579597 5393034,4579588 5393004,4579579.5
5392992.5,4579569 5392988.5,4579565 5392980,4579564.5
5392974.5,4579559.5 5392964.5,4579550.5 5392960,4579547.5
5392962.5,4579548.5 5392984.5,4579551 5392997,4579549.5
5392996.5,4579545 5393000,4579542 5393007.5,4579534.5
5393009.5,4579521.5 5393009,4579498 5393005.5,4579490 5393001,4579479.5
5392993,4579471.5 5392982.5,4579455.5 5392965.5,4579449.5
5392963.5,4579442 5392955,4579441 5392947,4579443.5 5392945.5,4579443.5
5392942,4579440 5392935,4579429.5 5392922.5,4579425 5392913.5,4579425.5
5392900.5,4579430.5 5392875.5,4579423.5 5392863.5,4579420
5392861,4579415.5 5392861,4579407 5392862.5,4579400 5392866,4579393
5392855.5,4579381.5 5392843,4579366 5392839.5,4579360
5392840.5,4579358.5 5392837,4579352.5 5392830,4579347 5392827,4579339.5
5392826.5,4579335.5 5392824.5,4579331.5 5392815.5,4579346.5
5392808.5,4579350 5392805,4579351 5392799.5,4579355.5
5392792.5,4579363.5 5392788.5,4579371.5 5392787.5,4579387.5
5392787.5,4579392.5 5392790,4579398 5392796.5,4579403.5 5392806,4579403
5392807.5,4579395.5 5392810.5,4579395 5392813.5,4579397
5392825.5,4579401.5 5392829.5,4579415.5 5392828,4579423.5
5392825.5,4579430.5 5392825.5,4579433 5392818.5,4579439 5392812,4579459
5392811.5,4579481.5 5392817,4579491 5392815,4579499 5392810,4579502.5
5392806,4579504.5 5392796.5,4579502 5392780,4579502.5 5392768,4579507.5
5392761,4579514 5392757.5,4579517 5392749.5,4579516 5392735.5,4579506
5392727.5,4579504 5392723,4579506 5392718,4579510.5 5392715.5,4579531
5392723,4579536.5 5392731.5,4579542 5392749,4579550 5392763,4579557
5392765.5,4579570 5392766,4579585 5392760,4579589 5392755.5,4579590
5392751.5,4579592.5 5392726,4579596 5392712.5,4579595
5392696.5,4579593.5 5392693,4579587.5 5392686,4579569.5
5392676.5,4579568 5392672.5,4579570 5392666.5,4579577 5392666,4579580
5392667,4579590.5 5392676.5,4579599.5 5392682.5,4579612.5
5392679.5,4579615 5392675,4579616.5 5392663,4579619.5 5392654,4579641
5392646.5,4579643.5 5392641,4579645.5 5392635,4579643.5
5392608.5,4579645 5392605,4579645 5392600.5,4579646.5 5392600,4579660
5392603,4579667 5392615.5,4579670 5392628,4579675 5392637,4579681
5392640,4579688 5392635.5,4579686.5 5392625.5,4579681
5392608.5,4579676.5 5392587.5,4579671 5392576.5,4579671
5392575,4579677.5 5392571.5,4579680.5 5392571.5,4579685.5
5392575.5,4579685 5392585.5,4579688 5392594.5,4579690 5392596,4579697
5392592.5,4579709.5 5392592.5,4579719.5 5392594,4579732
5392585.5,4579737 5392579.5,4579741 5392577,4579769 5392584,4579781.5
5392590.5,4579791 5392588,4579800 5392588,4579808.5 5392596,4579818.5
5392609,4579829.5 5392615.5,4579837.5 5392623,4579856 5392635,4579860.5
5392640,4579887 5392659,4579900 5392663,4579909.5 5392663,4579919
5392665,4579938 5392664,4579986 5392641.5,4580019 5392632.5,4580039
5392625.5,4580071.5 5392618,4580079.5 5392614.5,4580103
5392616,4580120.5 5392612.5,4580140 5392605.5,4580159 5392605.5,4580183
5392597.5,4580230.5 5392593,4580244.5 5392589.5,4580261.5
5392582.5,4580274 5392567.5,4580282.5 5392553,4580287 5392542,4580288
5392534.5,4580293 5392527,4580296 5392517,4580300 5392509.5,4580310.5
5392504,4580319 5392502,4580329.5 5392497,4580356.5 5392476,4580380
5392469,4580418.5 5392471.5,4580448.5 5392471,4580460 5392472,4580467
5392470,4580479 5392461.5,4580480.5 5392462,4580488.5
5392467.5,4580502.5 5392472,4580523.5 5392484,4580541
5392495.5,4580547.5 5392503,4580549 5392508,4580549 5392514.5,4580543.5
5392526,4580530.5 5392546,4580512 5392567,4580487 5392582.5,4580462
5392608.5,4580441 5392620,4580428.5 5392632,4580418.5
5392638.5,4580410.5 5392646.5,4580399.5 5392654,4580387.5
5392669.5,4580359 5392694.5,4580350 5392706.5,4580341
5392721.5,4580332.5 5392727.5,4580324.5 5392736,4580313 5392755,4580304
5392762,4580290 5392769.5,4580280.5 5392778,4580257 5392793.5,4580241.5
5392807.5,4580229.5 5392814.5,4580223.5 5392821.5,4580198.5
5392843.5,4580180.5 5392865.5,4580170 5392875.5,4580166
5392881.5,4580159.5 5392886.5,4580150 5392899,4580140
5392908.5,4580131.5 5392924.5,4580123.5 5392946.5,4580122.5
5392965,4580125 5392974.5,4580147 5392976,4580151.5 5392975.5,4580155
5392970.5,4580160 5392970.5,4580165.5 5392968.5,4580175
5392967.5,4580221.5 5392967.5,4580231 5392965.5,4580233.5
5392961.5,4580236.5 5392959.5,4580242 5392958.5,4580259.5
5392958,4580279 5392955.5,4580291.5 5392956.5,4580297.5
5392951.5,4580300 5392952,4580389.5 5392930.5,4580506.5 5392891,4580684
5392806.5,4581101 5392602,4581864.5 5392231.5,4581899.5
5392215,4581919.5 5392215,4581929.5 5392205,4581939.5 5392205,4581949.5
5392195,4581959.5 5392195,4581969.5 5392185,4581979.5 5392185,4581989.5
5392175,4581999.5 5392175,4581999.5 5392165,4582009.5 5392155,4582019.5
5392165,4582029.5 5392165,4582039.5 5392155,4582049.5 5392155,4582059.5
5392145,4582079.5 5392145,4582089.5 5392135,4582109.5 5392135,4582119.5
5392125,4582139.5 5392125,4582149.5 5392115,4582169.5 5392115,4582179.5
5392105,4582209.5 5392105,4582219.5 5392095,4582269.5
5392095))',31468),31467)));
