[postgis-users] Cant create a BIGINT column that worked under another login at one point . . .
Bob Basques Bob.Basques at ci.stpaul.mn.us
Thu Mar 15 14:10:49 PDT 2012
Hi S,
Yeah I found all that out while trying to figure things.
It's some sort of permissions error, as in the old user/role has the correct permissioms to make it work, since I went back to the original user and all is well again.  I'll need to figure it out though.
bobb
>>> Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
Bob,
Do this instead:
CREATE TABLE cmdstpinfo
  cmdrecid bigserial NOT NULL,
  updsw smallint,
  rxtime timestamp without time zone DEFAULT now(),
  cmd text,
  CONSTRAINT cmdstpinfo_pkey PRIMARY KEY (cmdrecid)
  WITH ( OIDS=FALSE );
If you use type serial or bigserial, it will create an int or bigint
respectively and create the sequence.
more below ...
On 3/15/2012 3:19 PM, Bob Basques wrote:
> All,
> I have this sequence:
> CREATE SEQUENCE cmdstpinfo_cmdrecid_seq
> INCREMENT 1
> MINVALUE 1
> MAXVALUE 9223372036854775807
> START 132894
> CACHE 1;
> ALTER TABLE cmdstpinfo_cmdrecid_seq
> OWNER TO gismo;
> and I'm trying to create this table:
> cmdrecid bigint NOT NULL DEFAULT
> nextval('cmdstpinfo_cmdrecid_seq'::regclass),
Use double quotes for object names, ie:
nextval("cmdstpinfo_cmdrecid_seq"::regclass),
single quotes are for text strings. This is probably what caused your error.
-Steve
> updsw smallint,
> cmd text,
> WITH (
> OIDS=FALSE
> but get the following error, if I remove the "cmdrecid" column creation
> line, I get the same error but for the smallint on "updsw" on the next
> line down :
> ERROR: syntax error at or near "bigint"
> LINE 3: cmdrecid bigint NOT NULL DEFAULT nextval('cmdstpinfo_cmdre...
> ********** Error **********
> SQL state: 42601
> Character: 38
> What am I doing wrong, Is this a permissions error of some sort?
> Thanks
> bobb
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120315/f226a933/attachment.html>
