[postgis-users] Are there any Ubuntu PPAs that serve PostGIS 2.0 beta releases?
Sandro Santilli strk at keybit.net
Fri Mar 16 01:16:32 PDT 2012
On Thu, Mar 15, 2012 at 11:49:08AM -0700, Charlie Sharpsteen wrote:
> On Thursday, March 15, 2012 10:42:52 AM UTC-7, Stephen V. Mather wrote:
> >  > Pretty slick. I will ponder upgrading GEOS and GDAL and setting up a
> > stable build for the most recent beta releases.
> > Wow.  That would be awesome.
> GDAL should be pretty simple. The problem with GEOS is that it is pretty
> far down at the base of the GIS foodchain---so lots of libraries that are
> used by GDAL also use GEOS and would need to be updated as well. I doubt I
> will have the time to compile my way through everything between GEOS and
> GDAL.
It really depends on whether they are using the C++ or C API.
C-API users work just fine with a newer GEOS.
Check out http://trac.osgeo.org/geos/wiki/Applications
And ask your preferred application to _stop_ using the C++ API :)
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
