[postgis-users] ST_Buffer + grid problem
Ed Linde edolinde at gmail.com
Thu Mar 22 13:43:14 PDT 2012
So far no proper raster, because the following failed, but maybe the
polygon gives us an idea? This polygon is the extent of all the road
geometries in Denmark. Also I remember that when you did the raster at your
end you said it worked. Is 0.000036 degrees = 4m correct if I want to get a
4m by 4m cell sized uniform raster grid?
select ST_AsRaster( ST_GeomFromText('POLYGON((8.07734039737749
54.4984986588244,8.07734039737749 57.7505109647578,15.1919565742587
57.7505109647578,15.1919565742587 54.4984986588244,8.07734039737749
54.4984986588244))'), 0.000036, 0.000036);
On Thu, Mar 22, 2012 at 9:39 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> > Thanks. The raster I need to visualise is a 4m by 4m grid on the entire
> map of
> > Denmark! :) So do you classify that as a large raster? If so is there a
> way to see a
> > portion of it or something?
> > I just want to manually check for a few areas on the map that the
> intersection
> > indeed works as expected and things haven't gone awry thanks to
> projection
> > differences or that I had degrees instead of meters or some such thing.
> Well, I
> > still have to first test if this GDAL upgrade will fix things and if
> make empty raster
> > .. makes a difference.
> That must be big but Danemark is a small country ;-) Only width and height
> tell you if a raster is big.
> In the database, your grid is a set of rectangular geometry (how many?) or
> just a big raster now (width & height)?
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/619cbbad/attachment.html>
