[postgis-users] Why aren't ST_ClosestPoints to polylines ST_Contained in those polylines?
Hilton Long seldomseen at scinternet.net
Sat Mar 24 12:54:37 PDT 2012
I created a table of ST_ClosestPoint()s to polylines.  I assumed that if the
closest points were on the line the queries below would give equal results,
but that's not happening.
"InsideWorking".simplified is a line.
"gaps".closeststartpoint is a point.
SELECT "gaps".closeststartpoint FROM "gaps"
WHERE "gaps".closeststartpoint IS NOT NULL; --Query produces 462 results.
SELECT * FROM "gaps","InsideWorking"
WHERE ST_Covers("InsideWorking".simplified,"gaps".closeststartpoint);
--Query produces 1228 results.
WHERE ST_Contains("InsideWorking".simplified,"gaps".closeststartpoint);
--Query produces 548 results.
SELECT "gaps".closeststartpoint FROM "gaps","InsideWorking"
WHERE ST_Touches("InsideWorking".simplified,"gaps".closeststartpoint);
--Query produces 680 results.
WHERE ST_DWithin("InsideWorking".simplified,"gaps".closeststartpoint,0);
--Query produces 1258 results.
Inspection shows the ST_DWithin() query is getting better results than the
other queries.  So I think I've got something that works, but I'd appreciate
some advice on why the others don't give similar results.
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120324/459bd339/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120324/459bd339/attachment.gif>
