[postgis-users] postgis raster export problem in using gdal_translate
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Mar 28 01:54:46 PDT 2012
Which version of GDAL are you using?
Why do you use mode = 2 if there is only one row in the table?
Now you said the output was not as the original input. how is it different?
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of mahavir trivedi
> Sent: Wednesday, March 28, 2012 12:25 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] postgis raster export problem in using gdal_translate
> On Tue, Mar 27, 2012 at 7:10 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> 	Please send the complete raster2pgsql and gdal_translate command you
> used.
> 	Pierre
> users-
> 	> Sent: Tuesday, March 27, 2012 4:28 AM
> 	> To: postgis-users at postgis.refractions.net
> 	> Subject: [postgis-users] postgis raster export problem in using
> gdal_translate
> 	> dear
> 	> i have 7053x6078 pixel  georeferrance  tiff image.
> 	> it is import using raster2pgsql  ok
> 	> but export it using gdal_translate command output is
> uncleard(Strange) not as
> 	> original input.    my out put format is same Tiff input
> 	_______________________________________________
> 	postgis-users mailing list
> 	http://postgis.refractions.net/mailman/listinfo/postgis-users
