[postgis-users] POSTGIS 2.0 on WIn
Piotr Pachół piotrpachol at gmail.com
Wed Mar 28 12:57:15 PDT 2012
Hello,
I tried all hints from this thread and that:
http://postgis.refractions.net/pipermail/postgis-users/2012-March/033111.html
but it is still impossible to install PostGIS 2.0 on Windows XP.
I also copied libproj-0.dll in bin folder - it didn't help.
Do you have any other suggestion ?
Piotr.
W dniu 2012-03-27 04:26, Paragon Corporation pisze:
> PROJSO  settings shouldn't be necessary anymore because libproj.dll is not
> used.
> I upgraded the install to use proj 4.8.0 so the dll is now libproj-0.dll
> which is what gdal assumes by default.
> It's possible I missed a dll and my tests systems already had them -- make
> sure you have libproj-0.dll in your bin folder.
> I think if postgis is in use it won't be able to copy the dll so you will
> probably need to shut down your service / restart and then run the copy
> script.
> Hope that helps,
> Regina
> http://www.postgis.us
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of Pierre Racine
>> Sent: Monday, March 26, 2012 2:23 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] POSTGIS 2.0 on WIn
>>> Hi at all,
>>> I wished test POSTGIS 2.0 on Win, so after installed on WinXP32   PostgreSQL 9.1.1,  and following instruction for  postgis-pg91-binaries-2.0.
>>> 0beta4w32 .... but I get the following error
>>> "...C:\postgis-pg91-binaries-
>>> 2.0.0beta4w32\postgis-pg91-binaries-
>>> 2.0.0beta4w32>"C:\Programmi\PostgreSQL\9.1\bin\\psql"  -d "testpstg" -c "CREATE EXTENSION postgis;" ERROR:  could not load library
>>> "C:/Programmi/PostgreSQL/9.1/lib/postgis-2.0.dll"
>>> : unknown error 126 ".
>>> Of course 1) postgis-2.0.dll is on the lib dir; 2) I stopped and
>>> restared Postgres service; 3) I've tried also another installation dir for Postgers in order to prevent eventually "space in name" trouble, but...
>>> I get the same problem
>>> Any hints?
>> Try setting the PROJSO to the path of libproj.dll
>> Pierre
