[postgis-users] Installation problem with postgis-pg91-binaries-2.0.0beta4w32
Salvatore Larosa lrssvtml at gmail.com
Thu Mar 29 04:02:32 PDT 2012
Il giorno gio, 29/03/2012 alle 11.25 +0100, feurbano at clix.pt ha scritto:
> Dear list,
> we are trying to install the latest available experimental binaries for windows
> (postgis-pg91-binaries-2.0.0beta4w32).
> We installed postgres 9.1 (32bit) and than run the installer file
> 'makepostgisdb_using_extensions.bat' with the proper (hopefully) set.
> We get this error:
> "C:\Program Files (x86)\PostgreSQL\9.1\bin\psql"  -d "sam" -c "CREATE EXTENSION
> postgis;"
> ERROR:  could not load library "C:/Program Files
> (x86)/PostgreSQL/9.1/lib/postgis-2.0.dll": The specified module could not be found.
Can you check if the file is there (path/postgres/bin)?
DDL files is found in lib directory!
-SL
