[postgis-users] Z coordinate value changes with st_transform
Paul Ramsey pramsey at opengeo.org
Fri Mar 30 10:27:47 PDT 2012
Yeah, bad news, 2.0 is showing this behavour but not 1.5.
http://trac.osgeo.org/postgis/ticket/1742
P.
On Fri, Mar 30, 2012 at 9:59 AM, Stefano Iacovella
<stefano.iacovella at gmail.com> wrote:
> Hi Jose
> Im sure which version of PostGis are you using.
> On my box, Postgis 1.5.3 with Proj 4.8 it seems to work without any
> change to elevation:
> template_postgis=# select
> st_asewkt(st_transform(st_geomfromtext('POINT (700000 4500000 100)',
> 23030), 4326));
> WARNING:  OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
>                        st_asewkt
>  SRID=4326;POINT(-0.635451186670006 40.6259397158234 100)
> (1 row)
> template_postgis=# select postgis_full_version();
>  POSTGIS="1.5.3" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March 2012" LIBXML=
> "2.7.6" USE_STATS
> (1 row)
> Regards
> Stefano
> 2012/3/30 Jose Carlos Martinez <jomarlla at cgf.upv.es>:
>> I didnt get nay answers from now.
>> Someone can tell me why postgis is changing the z coordinate and how i can
>> change this default behavior?
>> Should I keep using  proj4.7 instead of proj4.8?
>> Before:
>> pg20=# select st_astext(st_transform(st_geomfromtext('POINT (700000 4500000
>> 100)', 23030), 4326));
>>                          st_astext
>>  POINT Z (-0.63662073736203 40.6248036513963 100)
>> Now:
>>                          st_astext
>>  POINT Z (-0.63662073736203 40.6248036513963 168.35361468256)
>> On 27/03/2012 21:56, Jose Carlos Martinez Llario wrote:
>>> From proj4.8 changelog:
>>> "Preliminary support has been added for vertical datums using the
>>> +geoidgrids= directive.  The geoidgrids are assumed to provide a
>>> transformation from geoid elevations to ellipsoidal elevations and they are
>>> discussed a bit in the VerticalDatums topic on the web site"
>>> I dont like the st_transform method can change my z coordinates by default
>>> though, dont know if it is because PostGIS is not ready still for proj4.8 or
>>> because it is the proj4.8 default behaviour.
>>> cheers,
>>> Jose
>>> On 27/03/2012 19:02, Jose Carlos Martinez wrote:
>>>> Hi, dont know if this is the expected behavior, maybe its because I built
>>>> postgis with proj 4.8 or because something has changed in spatial_ref_sys.
>>>> Dont know at what time it happened (I missed it).
>>>> Before:
>>>> 4500000 100)', 23030), 4326));
>>>>                          st_astext
>>>> Now:
>>>>                          st_astext
>>>> Using ST_AsKml Its changing the Z coordinate too.
>>>> Someone can confirm when this change happened in PostGIS?
>>>> Regards,
>>>> Jose
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
