[postgis-users] Topology GetRingEdges
Sandro Santilli strk at keybit.net
Wed May 2 13:34:13 PDT 2012
On Mon, Apr 30, 2012 at 08:30:56AM -0700, Bob Pawley wrote:
> Well, it would seem to me that I need to identify the geometry at
> some point as a start (and end) for "walking" the geom, hence, the
> ST_Intersects.
> I've attempted to use the geom column in the edge_data table but so
> far haven't been able to make this work (errors returned) -
> select topology.getringedges(edge_data, 1), entities.wkb_geometry
>    from "TEST".edge_data, entities
>    where "TEST".edge_data.edge_id = 1
The first argument to getRingEdges is a topology _name_.
You're passing "edge_data", which is the name of a table.
You should pass 'TEST' instead.
The second argument is an edge identifier.
You're always passing '1'.
You probably want to pass edge_id instead.
But again, you didn't answer the most important question, being:
what are you looking for, exactly ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
