[postgis-users] Same, similar et al
Bob Pawley rjpawley at shaw.ca
Wed May 9 09:06:15 PDT 2012
Hi Steve
FYI - I'm not involved in the geography side of Postgis, I'm developing an
application to analyze engineering drawings. So, same in shape even if the
shapes are spatially diverse is what I was looking for.
However, since this function doesn't exist I will need to develop something.
Thanks for the info.
Bob
-----Original Message-----
Sent: Wednesday, May 09, 2012 8:54 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Same, similar et al
On 5/9/2012 11:40 AM, Bob Pawley wrote:
> Hi
> I have two geoms that are similar in shape but don’t share the same
> space nor the same size.
> Is there a function or method to compare the two shapes in this
> situation??
> The functions and operators I have found, seem to only look at spatial
> sameness.
> Or is my only option to spatially transfer and size one geometry to the
> other?
> Bob
Bob,
I don't think there is anything in PostGIS that does this. A bigger
question in my mind is how do you want to define "similar"? For example:
1. identical but scaled differently?
2. identical but positioned  or rotated differently?
3. topologically the same, ie: a coffee mug and donut have the same
topology but not the same shape
4. the same visual presentation but made up of different number of segments
5. and the list goes on and on
-Steve W
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
