[postgis-users] Nearest neighbor in 3D
Paul Ramsey pramsey at opengeo.org
Fri May 25 12:37:04 PDT 2012
Using ST_3DDistance will work and give you the right answer, but it
will not be index assisted. The KNN operator <-> is only implemented
against the 2D index currently.
Paul
On Fri, May 25, 2012 at 5:15 PM, Bartosz Bekier
<bartosz.bekier at gmail.com> wrote:
> Hello All!
> This is my first post on the PostGIS mailing list:-).
> I would like to use the <-> to solve the nearest neighbor problem, but in 3D
> space. I tried to do this in 2D and it works perfectly, but apparently it
> doesn't cover the 3D case.
> Basically I have a table of 3D points (x, y, z) and would like to do:
>     ORDER BY point <-> POINT(0 0 0)
> but the distance taken into account should be 3D Euclidean distance. Do I
> have to use ST_3DDistance() for it or is there a faster way?
> Thanks in advance!
> Regards,
> Bartosz Bekier
> postgis-users mailing list
