[postgis-users] raster2pgsql quoted string error
Bborie Park bkpark at ucdavis.edu
Thu Nov 1 09:54:07 PDT 2012
Hey Jean-Daniel,
That error doesn't make sense as nothing in the loader would prematurely
cut the output.  Are you able to show the last several lines of the sql
file (pre-edit).
-bborie
On 11/01/2012 08:05 AM, Jean-Daniel Sylvain wrote:
> Dear PGIS users,
> I'm working with the postgis 2.0 :
> 1. PostgreSQL 9.1.4, compiled by Visual C++ build 1500, 64-bit"
> 2. "POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6
>    March 2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
>    LIBJSON="UNKNOWN" RASTER"
> I'm trying to load a raster.tif (DEM) into  my database with the
> following command.
> raster2pgsql -f elev -F -t 100x100  QC_SRTM.tif QC_SRTM | psql -U
> postgres -d DEM -h localhost -p 5432
> And I catched this error;
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> INSERT 0 1
> psql:elev1.sql:5690: ERREUR:  chaîne entre guillemets non terminée sur
> ou près de « '010000010000000....
> ..... indicating that the string is not quoted near the last line.
> So I ran  the raster2pgsql.exe with this command
> D:\Data\Geodata\Altimetrie\SRTM\DEM90m\PreTraitement>raster2pgsql -f
> elev -F -t 100x100  QC_SRTM.tif QC_SRTM > InsertSRTM.sql
> Processing 1/1: QC_SRTM.sdat
> and looked at the content of the sql file. The last line of the file is
> cut and the command "END;" is not there.
> If I correct the file by ending the line and adding the "End;" command
> the file is load.
> I was wondering what parameter would be responsible for that error in
> raster2pgsql?
> I have many raster to load so this temporary solution is not a TRUE
> solution. Anyone had an idea?
> Thanks.
> Jean-Daniel
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
