[postgis-users] Invalid Geometry problem
Brian Peschel brianp at occinc.com
Mon Nov 5 12:16:29 PST 2012
I am having a problem that I can't explain.
I have a 2 node Slony DB system.
Node 1: Ubuntu 10, Postgres 8.4.13-0ubuntu10.04, PostGIS 1.4.0-2,
libgeos 3.1.0-1
Node 2: Ubuntu 10, Postgres 8.4.3-1, PostGIS 1.4.0-2, libgeos 3.1.0-1
I have a polygon geometric in my database:
    Table "public.table"
     Column     |     Type      | Modifiers
  id            | integer       | not null
  geom          | geometry      |
Indexes:
     "tbl_geom_idx" gist (geom)
Check constraints:
     "enforce_dims_geom" CHECK (ndims(geom) = 2)
     "enforce_srid_geom" CHECK (srid(geom) = 4269)
Which works just fine on Node1:
select st_astext(geom) from table where rid = 1;
  POLYGON((-94.3043033 38.8722515,-94.3047635 38.8672929,-94.303613
38.8674323,-94.3028972 38.868209,-94.3015677 38.8682687,-94.3001871
38.8684878,-94.2983464 38.8695432,-94.2968124 38.869583,-94.2952273
38.8696826,-94.2948182 38.8699813,-94.2946392 38.8704393,-94.2944858
38.8706385,-94.2938722 38.8706783,-94.2933609 38.8706385,-94.2923127
38.8706385,-94.2919548 38.8708774,-94.2917758 38.8711164,-94.2917247
38.8717138,-94.30167 38.8721121,-94.3040732 38.872132,-94.3043033
38.8722515))
But if I try the same thing on Node 2:
ERROR:  geometry contains non-closed rings
And in my postgres log:
2012-11-02 15:23:24 CDT ERROR:  geometry contains non-closed rings
2012-11-02 15:23:24 CDT  STATEMENT:  select st_astext(geom) from table
where rid = 1;
But I can can select the points individually on Node 2:
select 100 + generate_series(1, ST_npoints(geom)-1) as sequence,
ST_Y(pointn(ExteriorRing(geom), generate_series(1,
ST_npoints(geom)-1)))::numeric(10,7) as lat,
ST_X(pointn(ExteriorRing(geom), generate_series(1,
ST_npoints(geom)-1)))::numeric(10,7) as lon from table where id = 1
order by 1;
  sequence |    lat     |     lon
       101 | 38.8722515 | -94.3043033
       102 | 38.8672929 | -94.3047635
       103 | 38.8674323 | -94.3036130
       104 | 38.8682090 | -94.3028972
       105 | 38.8682687 | -94.3015677
       106 | 38.8684878 | -94.3001871
       107 | 38.8695432 | -94.2983464
       108 | 38.8695830 | -94.2968124
       109 | 38.8696826 | -94.2952273
       110 | 38.8699813 | -94.2948182
       111 | 38.8704393 | -94.2946392
       112 | 38.8706385 | -94.2944858
       113 | 38.8706783 | -94.2938722
       114 | 38.8706385 | -94.2933609
       115 | 38.8706385 | -94.2923127
       116 | 38.8708774 | -94.2919548
       117 | 38.8711164 | -94.2917758
       118 | 38.8717138 | -94.2917247
       119 | 38.8721121 | -94.3016700
       120 | 38.8721320 | -94.3040732
(20 rows)
So I am stumped.  I do see this on node 2:
select st_isvalid(geom), st_isvalidreason(geom) from
message_locate_polygon where id = 1;
NOTICE:  IllegalArgumentException: points must form a closed linestring
ERROR:  POSTGIS2GEOS conversion failed
Any thoughts?  I suspect that upgrading postgres on node 2 would solve
it, but I since I don't know the cause of the error, I am still concerned.
Thanks in advance,
- B
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121105/421d97c2/attachment.html>
