[postgis-users] FYI: Solution to Using PostGIS in ArcGIS.
Pietro Rossin pierigis at gmail.com
Wed Nov 7 02:37:17 PST 2012
Hello all
does anybody know if it's possible to load postgis layers in Arcgis 9.2?
I saw zigGIS was discontinued, any other solution?
Thanks
Pietro
2012/11/7 Birgit Laggner <birgit.laggner at vti.bund.de>
> Hi,
> we work with ArcGIS 10.1, now, and since, we don't need ArcSDE for
> communication with PostgreSQL db and PostGIS geometries. If you install
> special db client libraries for PostgreSQL, you are able to create a direct
> database connection to the PostgreSQL database and to directly im- and
> export data between ArcGIS and PostgreSQL. We have not much improved our
> testing because we are waiting for SP1 for ArcGIS 10.1 (which should
> support PostgreSQL 9.1.3 and PostGIS 2.0) and the installation of our new
> PostgreSQL server, so e.g. I can't say which ArcGIS licence level you would
> need...
> For further information see:
> PostgreSQL database requirements for ArcGIS 10.1:
> http://resources.arcgis.com/**en/help/system-requirements/**
> 10.1/index.html#//**015100000075000000<http://resources.arcgis.com/en/help/system-requirements/10.1/index.html#//015100000075000000>
> Setting up a connection to PostgreSQL:
> http://resources.arcgis.com/**en/help/main/10.1/index.html#/**
> /002p0000003q000000<http://resources.arcgis.com/en/help/main/10.1/index.html#//002p0000003q000000>
> Regards,
> Birgit.
> Am 07.11.2012 09:25, schrieb Paolo Corti:
>  On Wed, Nov 7, 2012 at 7:39 AM, Robert Buckley<robertdbuckley at yahoo.**com<robertdbuckley at yahoo.com>>
>>  wrote:
>>> Hi,
>>> just my 2Cents..ArcGIS is now realising that there is a great need for
>>> FOSSGIS interfaces within the ESRI Architecture. If you have ArcSDE and
>>> ArcEditor (only a few 10s of thousands) you can work with PostgreSQL and
>>> PostGIS dbs.
>>> Other than that, there may be some opensource plugins or extentions that
>>> you
>>> may be able to test.
>>> http://gis.stackexchange.com/**questions/147/how-can-i-**
>>> connect-to-a-postgis-database-**from-arcmap-9-3-and-10-0<http://gis.stackexchange.com/questions/147/how-can-i-connect-to-a-postgis-database-from-arcmap-9-3-and-10-0>
>>> http://www.paolocorti.net/**2008/06/06/spatial-database-**
>>> for-postgres-and-arcgis-users-**how-to-choose/<http://www.paolocorti.net/2008/06/06/spatial-database-for-postgres-and-arcgis-users-how-to-choose/>
>>>  Hello Robert
>> please be aware that zigGIS was discontinued (the posted links are
>> very old) [1].
>> In any case, the source code has always been around [2] and I think it
>> should be quiete easy to adapt it to work to latest ArcGIS versions.
>> regards
>> p
>> [1] https://groups.google.com/**forum/?fromgroups=#!topic/**
>> ziggis/FK6KNRVk3p4<https://groups.google.com/forum/?fromgroups=#!topic/ziggis/FK6KNRVk3p4>
>> [2] http://code.google.com/p/**ziggis/ <http://code.google.com/p/ziggis/>
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> ______________________________**_________________
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**users<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121107/7b32e7ad/attachment.html>
