[postgis-users] st_difference throws an error
Francois Hugues hugues.francois at irstea.fr
Mon Nov 12 05:18:32 PST 2012
Honestly, I don't know where it comes from, but st_buffer(geom, 0) often helps to "repair" polygon for some postgis operations.
Hugues.
PS : I have some limitations to configure my professional mail but my first name is Hugues and not François ;)
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Angel Cervera Claudio
Envoyé : lundi 12 novembre 2012 13:58
À : postgis-users at lists.osgeo.org
Objet : Re: [postgis-users] st_difference throws an error
Hi Francois.
This work!
Could be a bug in st_difference?
Thanks, Ángel
On 12/11/12 12:42, Francois Hugues wrote:
	You should try the st_buffer tip :
	select st_astext(
	    st_difference(
	        st_buffer(st_geomfromtext('POLYGON((-5.66666 43.53301,-5.66704 43.53335,-5.66931 43.53374,-5.66975299919511 43.533380063154,-5.66979 43.53335,-5.66971 43.53478,-5.66969091189271 43.5348058613067,-5.67026768864541 43.5374211525033,-5.67084666354158 43.5376334432986,-5.67111 43.53773,-5.67059550578171 43.53754135212,-5.66854 43.53971,-5.66854 43.53971,-5.66854 43.53971,-5.66758 43.53976,-5.6665 43.5402,-5.6665 43.5402,-5.66609712188377 43.539781395014,-5.66401 43.54013,-5.66401 43.54013,-5.66351576708437 43.5392869195307,-5.66281 43.53909,-5.6626 43.53851,-5.66159162498075 43.5369268527413,-5.66131 43.53695,-5.66196 43.53617,-5.66272791899155 43.5356642562857,-5.66378432333548 43.5344801289574,-5.66384 43.53414,-5.66452 43.53344,-5.6656 43.53337,-5.66611 43.5331,-5.66666 43.53301))', 4326),0),
	       st_buffer(st_geomfromtext('POLYGON((-5.66577 43.53447,-5.66612 43.53455,-5.66675167677363 43.5349178897119,-5.66735 43.53529,-5.66811 43.5355,-5.66786 43.53678,-5.66816 43.53697,-5.66801 43.53717,-5.66729498033211 43.5375449497042,-5.6665 43.53782,-5.66634200990626 43.5386936730934,-5.66634 43.53876,-5.66554366174751 43.5384386684555,-5.66521 43.53856,-5.66457 43.53781,-5.6640744056249 43.5375662650614,-5.66341231504476 43.5372589777288,-5.66324 43.53718,-5.66334987968078 43.536344363177,-5.66304550704754 43.5357063513112,-5.66299 43.53559,-5.66358 43.53544,-5.66413 43.53529,-5.66521 43.535,-5.66577 43.53447,-5.66577 43.53447))', 4326),0)
	Hugues.
	Envoyé : lundi 12 novembre 2012 12:23
	Objet : [postgis-users] st_difference throws an error
	Hello.
	I post this problem in http://gis.stackexchange.com/questions/40872/st-difference-throws-an-error buy i'm sure in this mailing list people can help me.
	I'm retrieving "GEOSDifference: TopologyException: found non-noded intersection between" error when executing st_difference sql.
	Followed an example:
	Error:
	ERROR:  GEOSDifference: TopologyException: found non-noded intersection between LINESTRING (-5.67027 43.5374, -5.67085 43.5376) and LINESTRING (-5.67111 43.5377, -5.6706 43.5375) at -5.6708422794605911 43.537631835802237
	SQL:
	select st_astext(
	    st_difference(
	In gis.stackexchange.com i attached images with various shapes with this problem.
	All share a common pattern. Some parts of edge are near to be parallel.
	How to resolve this problem? Is a bug?
	Thanks!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121112/e5942087/attachment.html>
