[postgis-users] Trouble building 2.1 SVN
Bborie Park bkpark at ucdavis.edu
Sun Nov 18 12:11:15 PST 2012
It looks like something is up with your GDAL build/setup.  Check your
output from:
gdal-config --dep-libs
I'm expecting the "external/lib" to be found in the output.
-bborie
On Sun, Nov 18, 2012 at 8:39 AM, Rhys A.D. Stewart
<rhys.stewart at gmail.com> wrote:
> Greetings all,
> Trying to build postgis 2.1 svn but running into some issues. The
> compilation bugs out with:
> _____________________________
> ../../libtool: line 4992: cd: external/lib: No such file or directory
> libtool: link: cannot determine absolute directory name of `external/lib'
> make[2]: *** [raster2pgsql] Error 1
> make[2]: Leaving directory
> `/var/tmp/portage/dev-db/postgis-2.1.0/work/postgis-2.1.0SVN/raster/loader'
> make[1]: *** [rtloader] Error 2
> make[1]: Leaving directory
> `/var/tmp/portage/dev-db/postgis-2.1.0/work/postgis-2.1.0SVN/raster'
> make: *** [all] Error 1
> Not sure what to make of it. I've attached the entire build log and
> environment file. Am running gentoo linux. Building it fails using potage
> (gentoo's package system) with a custom ebuild and fails if i try to build
> it  'by hand'.
> Thanks,
> Rhys
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
