[postgis-users] pgsql2shp on a on-the-fly request
perikut peroc79 at gmail.com
Tue Nov 20 02:37:35 PST 2012
hello, i am trying to make not a usual postgis to shapefile dump, as the
geometry is created on the fly along with other calculations.
this Sql works fine, as you can see i create the geom on the fly
select SUM(counter) as suma, astext(snapped_geom) as centroid,
geomfromText(ST_AsText(ST_Envelope(GEOMETRYFROMTEXT('LINESTRING('||(st_xmax(snapped_geom)-2.5||'
'||(st_ymax(snapped_geom)-2.5)||', '||(st_xmax(snapped_geom)+2.5)||'
'||(st_ymax(snapped_geom)+2.5)||')'),4326)))) as pols from ( SELECT
(regexp_matches(t::text,
E'(Anguilla[\+])([0-9]+)'::text)::text[])[2]::integer as
counter,snapped_geom from (select ST_SnapToGrid( ST_SetSRID(the_geom,
4326), 5) as snapped_geom,array_genus from simple_datapublisher_3 where
array_genus ~ 'Anguilla'::text group by snapped_geom,array_genus) t ) t2
GROUP BY snapped_geom;
but when i directly put on a pgsql2shp operation, i get error like...
Syntax error near to unexpected symbol « ( »
pgsql2shp -f /www/test -p 5432 -h host -u user -P pwd -g polygons select
'||(st_ymax(snapped_geom)+2.5)||')'),4326)))) as polygons from ( SELECT
I am not sure if paremeter -g (set as polygons because the resulting
geometries are named polygons) is correctly set, but even removing it i
allways get the same error.
I know the SQL sentence is a little complicated, just below a very basic
structure to get an idea what is doing.
geom1, Anguilla +30||specieY+10||specieZ+5
geom2, specieX+10|| Anguilla +10
thanks in advance,
Pere Roca
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121120/13bf6fe9/attachment.html>
