[postgis-users] pgsql2shp on a on-the-fly request
perikut peroc79 at gmail.com
Tue Nov 20 05:49:40 PST 2012
  perfect! and yes, i forgot the dbase name.
On Tuesday, 20 November 2012 12:21:23 UTC, Nicolas Ribot wrote:
> Hi,
> Enclose the query string in double quotes:
> pgsql2shp -f file.shp database "select * from ..."
> Didn't you forget to add the database name in your command ?
> Nicolas
> On 20 November 2012 11:37, perikut <per... at gmail.com <javascript:>> wrote:
>> hello, i am trying to make not a usual postgis to shapefile dump, as the
>> geometry is created on the fly along with other calculations.
>> this Sql works fine, as you can see i create the geom on the fly
>> select SUM(counter) as suma, astext(snapped_geom) as centroid,
>> geomfromText(ST_AsText(ST_Envelope(GEOMETRYFROMTEXT('LINESTRING('||(st_xmax(snapped_geom)-2.5||'
>> '||(st_ymax(snapped_geom)-2.5)||', '||(st_xmax(snapped_geom)+2.5)||'
>> '||(st_ymax(snapped_geom)+2.5)||')'),4326)))) as pols from ( SELECT
>> (regexp_matches(t::text,
>> E'(Anguilla[\+])([0-9]+)'::text)::text[])[2]::integer as
>> counter,snapped_geom from (select ST_SnapToGrid( ST_SetSRID(the_geom,
>> 4326), 5) as snapped_geom,array_genus from simple_datapublisher_3 where
>> array_genus ~ 'Anguilla'::text group by snapped_geom,array_genus) t ) t2
>> GROUP BY snapped_geom;
>> but when i directly put on a pgsql2shp operation, i get error like...
>> Syntax error near to unexpected symbol « ( »
>> pgsql2shp -f /www/test -p 5432 -h host -u user -P pwd -g polygons select
>> '||(st_ymax(snapped_geom)+2.5)||')'),4326)))) as polygons from ( SELECT
>> I am not sure if paremeter -g (set as polygons because the resulting
>> geometries are named polygons) is correctly set, but even removing it i
>> allways get the same error.
>> I know the SQL sentence is a little complicated, just below a very basic
>> structure to get an idea what is doing.
>> geom1, Anguilla +30||specieY+10||specieZ+5
>> geom2, specieX+10|| Anguilla +10
>> thanks in advance,
>> Pere Roca
>> postgis-users mailing list
>> postgi... at lists.osgeo.org <javascript:>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121120/3e9fe531/attachment-0001.html>
