[postgis-users] Installing PostGIS 2.0.1 at a different location
Sandeep Thakkar sandeep.thakkar at enterprisedb.com
Mon Nov 26 06:12:46 PST 2012
Please find attached the patch. I should actually send the patch to
postgis-devel, but I guess it's okay for this time. :)
--- postgis/Makefile.in.org     2012-11-26 19:29:47.000000000 +0530
+++ postgis/Makefile.in 2012-11-26 19:30:20.000000000 +0530
@@ -108,7 +108,7 @@
         bindir=/bin
         pkglibdir=/lib
         datadir=/share
-        datamoduledir=contrib/postgis
+        datamoduledir=contrib/postgis- at POSTGIS_MAJOR_VERSION
@. at POSTGIS_MINOR_VERSION@
 endif
 # Make all PostGIS objects depend upon liblwgeom, so that if an underlying
--- doc/Makefile.comments.in.org 2012-11-26 19:41:36.000000000 +0530
+++ doc/Makefile.comments.in 2012-11-26 19:41:59.000000000 +0530
@@ -44,6 +44,6 @@
         bindir=/bin
         pkglibdir=/lib
         datadir=/share
 endif
On Mon, Nov 26, 2012 at 6:40 PM, Sandeep Thakkar <
sandeep.thakkar at enterprisedb.com> wrote:
> Hi,
> I got the sources of PostGIS-2.0.1 and I'm building it against PG9.2.
> Using --with-pgconfig option, I specify the location of the pgconfig. The
> installation was fine and I could see the postgis files.
> But, when I specify PGSQL_SHAREDIR, PGSQL_DOCDIR and DESTDIR during "make
> install", I see that the share folder now consists of two directories,
> postgis and postgis-2.0.
> postgis-2.0 contains only "postgis_restore.pl". All sql files goes into
> 'postgis' folder in share/contrib. Why? How can I fix this?
> Sandeep Thakkar
> Senior Software Engineer
> EnterpriseDB Corporation
> The Enterprise Postgres Company
> Phone: +91.20.30589514
> Website: www.enterprisedb.com
> EnterpriseDB Blog: http://blogs.enterprisedb.com/
> Follow us on Twitter: http://www.twitter.com/enterprisedb
> This e-mail message (and any attachment) is intended for the use of the
> individual or entity to whom it is addressed. This message contains
> information from EnterpriseDB Corporation that may be privileged,
> confidential, or exempt from disclosure under applicable law. If you are
> not the intended recipient or authorized to receive this for the intended
> recipient, any use, dissemination, distribution, retention, archiving, or
> copying of this communication is strictly prohibited. If you have received
> this e-mail in error, please notify the sender immediately by reply e-mail
> and delete this message.
Sandeep Thakkar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121126/ee412587/attachment.html>
