[postgis-users] Adding raster to PostGIS database
Smaran Harihar smaran.harihar at gmail.com
Mon Nov 26 20:40:25 PST 2012
Oh it seems the error was due to ownership being in the name of another
user.
Now I am able to get the gdalinfo,
Driver: GTiff/GeoTIFF
Files: Quercus_acutifolia_raw.tif
Size is 3864, 1583
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["unknown",
        SPHEROID["WGS84",6378137,298.257223563]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433]]
Origin = (-179.960724061474451,86.577964063072983)
Pixel Size = (0.093000000000000,-0.090400000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-179.9607241,  86.5779641) (179d57'38.61"W, 86d34'40.67"N)
Lower Left  (-179.9607241, -56.5252359) (179d57'38.61"W, 56d31'30.85"S)
Upper Right ( 179.3912759,  86.5779641) (179d23'28.59"E, 86d34'40.67"N)
Lower Right ( 179.3912759, -56.5252359) (179d23'28.59"E, 56d31'30.85"S)
Center      (  -0.2847241,  15.0263641) (  0d17' 5.01"W, 15d 1'34.91"N)
Band 1 Block=3864x1 Type=Float32, ColorInterp=Gray
  Min=0.000 Max=0.923
  Minimum=0.000, Maximum=0.923, Mean=0.000, StdDev=0.000
  NoData Value=-3.39999999999999996e+38
  Metadata:
    STATISTICS_MAXIMUM=0.92262234256096
    STATISTICS_MEAN=0
    STATISTICS_MINIMUM=5.6834812171638e-19
    STATISTICS_STDDEV=0
But when I execute,
raster2pgsql -c -s 4326 -I Quercus_acutifolia_raw.tif
public.Quercus_acutifolia_raw | psql -h localhost -d dbname -U usr
I am still not able to create a Table? This is the output,
Processing 1/1: Quercus_acutifolia_raw.tif
Password for user postgres:
BEGIN
NOTICE:  CREATE TABLE will create implicit sequence
"quercus_acutifolia_raw_rid_seq" for serial column
"quercus_acutifolia_raw.rid"
ERROR:  type "raster" does not exist
LINE 1: ...us_acutifolia_raw" ("rid" serial PRIMARY KEY,"rast" raster);
ERROR:  current transaction is aborted, commands ignored until end of
transaction block
transaction block
transaction block
ROLLBACK
Thanks,
Smaran
On Mon, Nov 26, 2012 at 3:07 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> Run the following...
> gdalinfo Quercus_acutifolia_raw.tif
> If that returns an error, something may be wrong with the tif file.
> -bborie
> On 11/26/2012 02:03 PM, Smaran Harihar wrote:
> > But I am executing the command in the directory where it is located
> > I can list that raster using `ls`
> > On Mon, Nov 26, 2012 at 2:46 PM, Bborie Park <bkpark at ucdavis.edu> wrote:
> >> That error would only happen if raster2pgsql can't find the file in your
> >> current working directory. raster2pgsql supports relative paths for
> >> input rasters.
> >> -bborie
> >> On 11/26/2012 01:37 PM, Smaran Harihar wrote:
> >>> Thanks for the reply bborie,
> >>> I ran this command,
> >>> public.Quercus_acutifolia_raw | psql -h localhost -d rasterdb -U
> postgres
> >>> But this is the new error,
> >>> ERROR: Unable to read raster file: Quercus_acutifolia_raw.tif
> >>> Thanks,
> >>> Smaran
> >>> On Mon, Nov 26, 2012 at 2:27 PM, Bborie Park <bkpark at ucdavis.edu>
> wrote:
> >>>> -D is not a valid flag recognized by raster2pgsql.  Remove the flag as
> >>>> raster2pgsql is assuming that -D is a file.
> >>>> -bborie
> >>>> On 11/26/2012 01:23 PM, Smaran Harihar wrote:
> >>>>> Hi Guys,
> >>>>> I am trying to add a raster to PostGIS database using,
> >>>>> raster2pgsql -c -D -s 4326 -I Quercus_acutifolia_raw.tif
> >>>>> public.Quercus_acutifolia_raw | psql -h localhost -d dbnm -U usr
> >>>>> But I am getting this error,
> >>>>> ERROR: Unable to read raster file: -D
> >>>>> Any idea what is wrong? The database already has numerous point and
> >>>> polygon
> >>>>> shapefiles. Is that a problem that I cannot add rasters to the same
> >>>>> database having shapefiles?
> >>>>> _______________________________________________
> >>>>> postgis-users mailing list
> >>>>> postgis-users at lists.osgeo.org
> >>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> >>>> Bborie Park
> >>>> Programmer
> >>>> Center for Vectorborne Diseases
> >>>> UC Davis
> >>>> 530-752-8380
> >> Bborie Park
> >> Programmer
> >> UC Davis
> >> 530-752-8380
> Bborie Park
> Programmer
> UC Davis
> 530-752-8380
Thanks & Regards
Smaran Harihar
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121126/13243058/attachment.html>
