[postgis-users] PostGIS 2 RPM
Jeff Lake jeff at michiganwxsystem.com
Thu Oct 18 08:20:08 PDT 2012
Well that sounded promising
but no joy,
even tried  --without-raster
and got error's galore when I tried to apply postgis.sql to my tables
*Jeff Lake*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 10/18/2012 10:24, Bborie Park wrote:
> It looks like the linker can't find libpq.  You'll want to add the
> following to /etc/ld.so.conf.
> /usr/pgsql-9.1/lib
> -bborie
> On Thu, Oct 18, 2012 at 6:09 AM, Jeff Lake <jeff at michiganwxsystem.com> wrote:
>> Is there any reasoning why EL5 does not have a postGIS2_91 RPM ??
>> this is on CentOS 5.8 64bit
>> I have tried numerous times to install from source and keep getting raster
>> error
>> configure params
>> ./configure --with-raster --with-pgconfig=/usr/pgsql-9.1/bin/pg_config
>> --with-geosconfig=/geos-3.3.5/tools/geos-config
>>    PostGIS is now configured for x86_64-unknown-linux-gnu
>>   -------------- Compiler Info -------------
>>    C compiler:           gcc -g -O2
>>    C++ compiler:         g++ -g -O2
>>    SQL preprocessor:     /usr/bin/cpp -traditional-cpp -P
>>   -------------- Dependencies --------------
>>    GEOS config:          /geos-3.3.5/tools/geos-config
>>    GEOS version:         3.3.5
>>    GDAL config:          /usr/local/bin/gdal-config
>>    GDAL version:         1.9.1
>>    PostgreSQL config:    /usr/pgsql-9.1/bin/pg_config
>>    PostgreSQL version:   PostgreSQL 9.1.6
>>    PROJ4 version:        48
>>    Libxml2 config:       /usr/bin/xml2-config
>>    Libxml2 version:      2.6.26
>>    JSON-C support:       no
>>    PostGIS debug level:  0
>>    Perl:                 /usr/bin/perl
>>   --------------- Extensions ---------------
>>    PostGIS Raster:       enabled
>>    PostGIS Topology:     enabled
>>   -------- Documentation Generation --------
>>    xsltproc:             /usr/bin/xsltproc
>>    xsl style sheets:
>>    dblatex:
>>    convert:              /usr/bin/convert
>>    mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> Entering directory `/postgis-2.0.1/raster/loader'
>> /bin/sh ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom  -I/usr/local/include
>> -I/usr/local/include   raster2pgsql.o ../rt_core/librtcore.a
>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib -lgdal
>> -L/usr/local/lib -lgeos_c  -lc -lm -o raster2pgsql
>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>> -I../rt_core -I../../liblwgeom -I/usr/local/include -I/usr/local/include
>> raster2pgsql.o -o .libs/raster2pgsql  ../rt_core/librtcore.a
>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3 /usr/lib64/libexpat.so
>> -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err
>> -lidn -lz -lmysqlclient -lpthread -lrt -lssl -lcrypto -ldl
>> /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm -Wl,-rpath
>> -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>> /usr/bin/ld: cannot find -lpq
>> collect2: ld returned 1 exit status
>> make[2]: *** [raster2pgsql] Error 1
>> make[2]: Leaving directory `/postgis-2.0.1/raster/loader'
>> make[1]: *** [rtloader] Error 2
>> make[1]: Leaving directory `/postgis-2.0.1/raster'
>> make: *** [all] Error 1
>> Jeff Lake
>> MichiganWxSystem
>> AllisonHouse
>> GRLevelXStuff
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121018/7ca5cfd4/attachment.html>
