[postgis-users] PostGIS 2 RPM
Bborie Park bkpark at ucdavis.edu
Fri Oct 19 09:43:07 PDT 2012
Oh yeah.  Did you trying running make like the following?
LD_LIBRARY_PATH=/usr/pgsql-9.1/lib make
Another approach is to run just "make" in the base directory.  Once it
fails, go into raster/loader and run the above "make".  That way we can
focus on just that step.
-bborie
On 10/19/2012 09:34 AM, Jeff Lake wrote:
> There is something messed up
> I see this in configure
> 'checking for PQserverVersion in -lpq... yes'
> but yet make complains it can't find -lpq
> '/usr/bin/ld: cannot find -lpq
> collect2: ld returned 1 exit status'
> huh ????
> *Jeff Lake*
> MichiganWxSystem <http://www.michiganwxsystem.com>
> AllisonHouse <http://www.allisonhouse.com>
> GRLevelXStuff <http://www.grlevelxstuff.com>
> On 10/19/2012 12:16, Bborie Park wrote:
>> Heh.  ldd looks good.  I suspect the only possibility is to set up a
>> similar environment using CentOS 5.8 and see what happens.
>> -bborie
>> On 10/18/2012 08:19 PM, Jeff Lake wrote:
>>> [root at ldm /]# ldd /usr/pgsql-9.1/lib/libpq.so.5.4
>>>          linux-vdso.so.1 =>  (0x00007fff68bfd000)
>>>          libssl.so.6 => /lib64/libssl.so.6 (0x00002acdf6791000)
>>>          libcrypto.so.6 => /lib64/libcrypto.so.6 (0x00002acdf69de000)
>>>          libgssapi_krb5.so.2 => /usr/lib64/libgssapi_krb5.so.2
>>> (0x00002acdf6d2f000)
>>>          libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00002acdf6f5d000)
>>>          libldap_r-2.3.so.0 => /usr/lib64/libldap_r-2.3.so.0
>>> (0x00002acdf7196000)
>>>          libpthread.so.0 => /lib64/libpthread.so.0 (0x00002acdf73e0000)
>>>          libc.so.6 => /lib64/libc.so.6 (0x00002acdf75fb000)
>>>          libkrb5.so.3 => /usr/lib64/libkrb5.so.3 (0x00002acdf7953000)
>>>          libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00002acdf7be8000)
>>>          libk5crypto.so.3 => /usr/lib64/libk5crypto.so.3
>>> (0x00002acdf7dea000)
>>>          libdl.so.2 => /lib64/libdl.so.2 (0x00002acdf8010000)
>>>          libz.so.1 => /lib64/libz.so.1 (0x00002acdf8214000)
>>>          libkrb5support.so.0 => /usr/lib64/libkrb5support.so.0
>>> (0x00002acdf8428000)
>>>          libkeyutils.so.1 => /lib64/libkeyutils.so.1
>>> (0x00002acdf8631000)
>>>          libresolv.so.2 => /lib64/libresolv.so.2 (0x00002acdf8833000)
>>>          liblber-2.3.so.0 => /usr/lib64/liblber-2.3.so.0
>>> (0x00002acdf8a48000)
>>>          libsasl2.so.2 => /usr/lib64/libsasl2.so.2 (0x00002acdf8c57000)
>>>          /lib64/ld-linux-x86-64.so.2 (0x0000003f2d800000)
>>>          libselinux.so.1 => /lib64/libselinux.so.1 (0x00002acdf8e70000)
>>>          libsepol.so.1 => /lib64/libsepol.so.1 (0x00002acdf9089000)
>>>          linux-vdso.so.1 =>  (0x00007fff319fd000)
>>>          libssl.so.6 => /lib64/libssl.so.6 (0x00002aff20710000)
>>>          libcrypto.so.6 => /lib64/libcrypto.so.6 (0x00002aff2095d000)
>>> (0x00002aff20cae000)
>>>          libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00002aff20edc000)
>>> (0x00002aff21115000)
>>>          libpthread.so.0 => /lib64/libpthread.so.0 (0x00002aff2135f000)
>>>          libc.so.6 => /lib64/libc.so.6 (0x00002aff2157a000)
>>>          libkrb5.so.3 => /usr/lib64/libkrb5.so.3 (0x00002aff218d2000)
>>>          libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00002aff21b67000)
>>> (0x00002aff21d69000)
>>>          libdl.so.2 => /lib64/libdl.so.2 (0x00002aff21f8f000)
>>>          libz.so.1 => /lib64/libz.so.1 (0x00002aff22193000)
>>> (0x00002aff223a7000)
>>> (0x00002aff225b0000)
>>>          libresolv.so.2 => /lib64/libresolv.so.2 (0x00002aff227b2000)
>>> (0x00002aff229c7000)
>>>          libsasl2.so.2 => /usr/lib64/libsasl2.so.2 (0x00002aff22bd6000)
>>>          libselinux.so.1 => /lib64/libselinux.so.1 (0x00002aff22def000)
>>>          libsepol.so.1 => /lib64/libsepol.so.1 (0x00002aff23008000)
>>> CentOS 5.8 64bit
>>> *Jeff Lake*
>>> On 10/18/2012 22:58, Bborie Park wrote:
>>>> Before you give up, can you run "ldd" on libpq?  Also, what OS and
>>>> version?
>>>> -bborie
>>>> On Thu, Oct 18, 2012 at 6:51 PM, Jeff Lake <jeff at michiganwxsystem.com>
>>>> wrote:
>>>>> well I guess I'm stuck at 1.5.5
>>>>> this server is relied on to much to be taken offline for OS upgrade
>>>>> Jeff Lake
>>>>> MichiganWxSystem
>>>>> AllisonHouse
>>>>> GRLevelXStuff
>>>>> On 10/18/2012 19:26, Devrim GÜNDÜZ wrote:
>>>>> Hi,
>>>>> On Thu, 2012-10-18 at 09:09 -0400, Jeff Lake wrote:
>>>>> Entering directory `/postgis-2.0.1/raster/loader'
>>>>> /bin/sh ../../libtool --mode=link gcc -g -O2  -fPIC -DPIC  -Wall
>>>>> -Wmissing-prototypes -I../rt_core -I../../liblwgeom
>>>>> -I/usr/local/include
>>>>> -I/usr/local/include   raster2pgsql.o ../rt_core/librtcore.a
>>>>> ../rt_core/librtcore.a ../../liblwgeom/liblwgeom.la -L/usr/local/lib
>>>>> -lgdal -L/usr/local/lib -lgeos_c  -lc -lm -o raster2pgsql
>>>>> libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
>>>>> -I../rt_core -I../../liblwgeom -I/usr/local/include
>>>>> raster2pgsql.o -o .libs/raster2pgsql ../rt_core/librtcore.a
>>>>> ../../liblwgeom/.libs/liblwgeom.so -L/usr/local/lib
>>>>> /usr/local/lib/libproj.so /usr/local/lib/libgdal.so -L/usr/lib64
>>>>> -L/usr/kerberos/lib64 -L/usr/lib64/mysql -lsqlite3
>>>>> /usr/lib64/libexpat.so -lgif -ljpeg -lpng -lpq -lcurl -lgssapi_krb5
>>>>> -lkrb5 -lk5crypto -lcom_err -lidn -lz -lmysqlclient -lpthread -lrt
>>>>> -lssl
>>>>> -lcrypto -ldl /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so
>>>>> -lc
>>>>> -lm -Wl,-rpath -Wl,/usr/local/lib -Wl,-rpath -Wl,/usr/lib64
>>>>> RPM packager is speaking:
>>>>> IIRC this error does not mean that it is not finding the PostgreSQL
>>>>> libs, but one of the dependencies are not built with PostgreSQL
>>>>> support
>>>>> (which I don't remember now).
>>>>> Please upgrade to RHEL6 -- it will be less painful as compared to
>>>>> trying
>>>>> to build PostGIS 2.0 with raster support.
>>>>> Regards,
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
