[postgis-users] How to make some geometry column visible to Qgis
Francois Hugues hugues.francois at irstea.fr
Mon Oct 22 03:09:17 PDT 2012
Your view is defined by a sql select so you should try to leave this select as is except for the where clause where you could add something like : and c.relname not like 'your_table_name'
I tried it with one of my table and this was ok, the table disappeared from the geometry_columns view
Hugues.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Pietro Rossin
Envoyé : lundi 22 octobre 2012 11:40
À : postgis-users at postgis.refractions.net
Objet : Re: [postgis-users] How to make some geometry column visible to Qgis
Hello Hugues
in my database I have both views and a main table on which these views pick data from.
All of them have their own geometry column registered into the geometry column set by postgis
My problem is that the main table (a huge one with mixed geometry data type) has its own geometry column.
When qgis starts the connection to this db automatically looks into the geometry column set and find the geom.column relative to the main table, so it searches that table for the geometry type and take a lot of time to do it...
How can I hide this geometry column?
Thnx
Pietro
2012/10/22 Francois Hugues [via PostGIS] <[hidden email]>
	Hello
	"This because I cannot remove the entities geometry column unless I remove the entity table first.
	And if I don't remove (or make invisible to qgis if possible) the entities geometry column it slow down the qgis connection."
	Did you try to edit the view, using the where clause to exclude the tables you don't want to be seen by postgis ?
	Hugues.
	De : [hidden email] <http://user/SendEmail.jtp?type=node&node=5000686&i=0>  [mailto:[hidden email] <http://user/SendEmail.jtp?type=node&node=5000686&i=1> ] De la part de Pietro Rossin
	Envoyé : lundi 22 octobre 2012 09:25
	À : [hidden email] <http://user/SendEmail.jtp?type=node&node=5000686&i=2>
	DELETE FROM geometry_columns WHERE f_table_name = 'puntigronda';
	Query returned successfully: 0 rows affected, 0 ms execution time.
	INSERT INTO geometry_columns (f_table_catalog,f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid,type)Â
	Â  VALUES ('','', 'puntigronda', 'the_geom', 3, 3004,'POINTS');
	Query returned successfully: 0 rows affected, 16 ms execution time.
	select relkind from pg_class where relname = 'geometry_columns';
	returns:
	"v"
	What is this?
	By the way
	If my technique works, is it still better to explode the "entities" table in one of this cases:
	a) single layers
	b) same kind of geometries
	in both cases table permanent.
	Thanks for your help
	Pietro
	2012/10/22 Sandro Santilli [via PostGIS] <[hidden email] <http://user/SendEmail.jtp?type=node&node=5000685&i=0> >
		> Is there something wrong?
		What's wrong is that the "geometry_columns" table should be a view,
		in PostGIS-2.0. If it is a view, your DELETE and INSERT and UPDATE
		to it should have no effect.
		Can you verify this first ?
		The DELETE/INSERT/UPDATE commands all return the number of affected
		rows. If PostGIS is correctly installed you should alwyas get 0,
		no matter what you try to insert/delete/update.
		Also check:
		--strk;
		 http://www.cartodb.com - Map, analyze and build applications with your data
		                                       ~~ http://strk.keybit.net
		postgis-users mailing list
		[hidden email] <http://user/SendEmail.jtp?type=node&node=5000684&i=0>
		http://postgis.refractions.net/mailman/listinfo/postgis-users
		If you reply to this email, your message will be added to the discussion below:
		http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000684.html
		To unsubscribe from How to make some geometry column visible to Qgis, click here.
		NAML <http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
	View this message in context: Re: How to make some geometry column visible to Qgis <http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000685.html>
	Sent from the PostGIS - User mailing list archive <http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html>  at Nabble.com.
	[hidden email] <http://user/SendEmail.jtp?type=node&node=5000686&i=3>
	http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000686.html
View this message in context: Re: How to make some geometry column visible to Qgis <http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000687.html>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121022/2729c11b/attachment.html>
