[postgis-users] identify rows in a shapefile that have illegal characters for UTF-8 encoding
Francois Hugues hugues.francois at irstea.fr
Mon Oct 22 23:57:03 PDT 2012
Hello,
I often play with postgis data in arcgis, using original shapefiles encoded using LATIN1 and I have no characters problem.
My major problem comes from null values which prevent arcgis to display data attributes but, usually, all my geometries are here and I can even play with symbology without the possibility to display the data I'm working on.
Did you check null values or did you try to import them in arcgis as a request layer using the where clause to exclude null data ?
Hugues.
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Mark Volz
Envoyé : lundi 22 octobre 2012 22:01
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] identify rows in a shapefile that have illegal characters for UTF-8 encoding
Hello,
I am trying to load my parcels into PostGIS, which will eventually be consumed by MapServer, and ArcGIS.  Initially when loaded my data I received a warning that I should change my encoding from UTF-8 to LATIN1.  Doing so allowed me to load data into PostGIS however, I could not consume the data in ArcGIS.  So from what I observed, I need to stick with UTF-8 encoding.  I have determined that the field for the legal description in my parcels is stopping me from loading the shapefile into PostGIS using UTF-8.
How can I find out which rows in my shapefile have illegal characters for UTF-8 encoding?
Thank You
Mark Volz
GIS Specialist
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
