[postgis-users] Problem with 3D polygon intersection test
Ed Linde edolinde at gmail.com
Tue Oct 30 03:05:49 PDT 2012
Ok thanks!
On Tue, Oct 30, 2012 at 11:04 AM, Nicolas Ribot <nicolas.ribot at gmail.com>wrote:
> st_dumpRings will return the rings (closed linestrings) composing the
> polygon (exterior first, then interiors)
> and st_dumpPoints will return all the points forming the rings, in the
> right order.
> Nicolas
> On 30 October 2012 10:56, Ed Linde <edolinde at gmail.com> wrote:
>> Ok, for a polygon, is there a good postgis function that can return the
>> edges to me in the
>> right sequence? Or at least the points that constitute the polygon in the
>> right order, so I can
>> generate the edges in a script?
>> Thanks,
>> Ed
>> On Tue, Oct 30, 2012 at 10:46 AM, Ed Linde <edolinde at gmail.com> wrote:
>>> Ah drat! Ok then I have to basically do edge intersection tests by
>>> myself.
>>> Ah well. bad news! :(
>>> On Tue, Oct 30, 2012 at 10:44 AM, Nicolas Ribot <nicolas.ribot at gmail.com
>>> > wrote:
>>>> Hi,
>>>> st_intersection is only suitable for 2D operations. Third dimension is
>>>> not taken into account.
>>>> Nicolas
>>>> On 30 October 2012 09:44, Ed Linde <edolinde at gmail.com> wrote:
>>>>> Hi All,
>>>>> Is there a simpler test I can do? I am quite sure that I am probably
>>>>> not using the right
>>>>> function in my SQL, or not doing the intersection test correctly. Is
>>>>> there any simpler
>>>>> way to test this 3D intersection? Am waiting on the postgis gurus to
>>>>> come along and
>>>>> give me some ideas, coz I am at my wits ends on this one! :) The
>>>>> polygons look good
>>>>> to me when I visualize them, but don't get how all triangles are found
>>>>> as intersecting?
>>>>> Anyway will wait.
>>>>> Cheers,
>>>>> Ed
>>>>> On Tue, Oct 30, 2012 at 9:00 AM, Ed Linde <edolinde at gmail.com> wrote:
>>>>>> Hi All,
>>>>>> I am having some troubles getting the *ST_Intersect* function to
>>>>>> work with 3D polygons.
>>>>>> I have a table to hold triangles as polygons in *"small_tris"*
>>>>>> Another table for holding the polygonal faces of a 3D voronoi diagram
>>>>>> in *"vfaces"*
>>>>>> So now I am trying to do an intersection between the triangles and
>>>>>> the voronoi faces
>>>>>> to get the triangles that intersect with the faces. And it seems that
>>>>>> *ALL* triangles
>>>>>> are intersecting. I have attached a PDF where I have plotted the
>>>>>> triangles and the
>>>>>> voronoi cells. so the box around in red and blue with a major face
>>>>>> going through is
>>>>>> the voronoi diagram. The Voronoi partition in 3D is shown at the
>>>>>> bottom too for clarity
>>>>>> Can someone please help and let me know what am I doing wrong here?
>>>>>> Is the select assuming something? So the polygons are flat and the
>>>>>> intersections
>>>>>> should just be lines or points. I am under some pressure to get this
>>>>>> to work, so if
>>>>>> anyone needs more information to help, the please let me know! :)
>>>>>> Cheers,
>>>>>> Ed
>>>>>> *-- TABLE SCHEMAS*
>>>>>> bounds=# \d vfaces;
>>>>>>       Table "public.vfaces"
>>>>>>   Column  |   Type   | Modifiers
>>>>>>  gen_id   | integer  |
>>>>>>  geomtext | geometry |
>>>>>> bounds=# \d small_tris;
>>>>>>     Table "public.small_tris"
>>>>>>  id       | integer  | not null
>>>>>>  v0       | integer  |
>>>>>>  v1       | integer  |
>>>>>>  v2       | integer  |
>>>>>> Indexes:
>>>>>>     "small_tris_pkey" PRIMARY KEY, btree (id)
>>>>>>     "small_idx" gist (geomtext)
>>>>>> -- TABLE CONTENT*
>>>>>> bounds=# select id, st_astext( geomtext ) from small_tris;
>>>>>>  id |                       st_astext
>>>>>>   0 | POLYGON Z ((10 10 805,20 10 809,10 20 814,10 10 805))
>>>>>>   1 | POLYGON Z ((10 20 814,20 10 809,20 20 819,10 20 814))
>>>>>>   2 | POLYGON Z ((20 20 819,30 10 809,30 20 812,20 20 819))
>>>>>>   3 | POLYGON Z ((30 10 809,20 20 819,20 10 809,30 10 809))
>>>>>>   4 | POLYGON Z ((30 20 812,30 10 809,40 10 826,30 20 812))
>>>>>>   5 | POLYGON Z ((20 20 819,30 20 812,20 30 827,20 20 819))
>>>>>>   6 | POLYGON Z ((10 20 814,20 20 819,20 30 827,10 20 814))
>>>>>>   7 | POLYGON Z ((10 40 805,10 30 814,20 30 827,10 40 805))
>>>>>>   8 | POLYGON Z ((10 50 804,10 40 805,20 40 807,10 50 804))
>>>>>>   9 | POLYGON Z ((20 30 827,20 40 807,10 40 805,20 30 827))
>>>>>>  10 | POLYGON Z ((30 30 817,20 40 807,20 30 827,30 30 817))
>>>>>>  11 | POLYGON Z ((30 40 816,20 50 809,20 40 807,30 40 816))
>>>>>>  12 | POLYGON Z ((20 40 807,20 50 809,10 50 804,20 40 807))
>>>>>>  13 | POLYGON Z ((10 30 814,10 20 814,20 30 827,10 30 814))
>>>>>>  14 | POLYGON Z ((30 30 817,20 30 827,30 20 812,30 30 817))
>>>>>>  15 | POLYGON Z ((30 20 812,40 20 823,30 30 817,30 20 812))
>>>>>>  16 | POLYGON Z ((40 20 823,30 20 812,40 10 826,40 20 823))
>>>>>>  17 | POLYGON Z ((40 20 823,40 10 826,50 10 803,40 20 823))
>>>>>>  18 | POLYGON Z ((30 30 817,40 20 823,40 30 814,30 30 817))
>>>>>>  19 | POLYGON Z ((40 20 823,50 20 808,40 30 814,40 20 823))
>>>>>>  20 | POLYGON Z ((50 20 808,40 20 823,50 10 803,50 20 808))
>>>>>>  21 | POLYGON Z ((40 30 814,50 20 808,50 30 816,40 30 814))
>>>>>>  22 | POLYGON Z ((30 30 817,40 30 814,40 40 800,30 30 817))
>>>>>>  23 | POLYGON Z ((30 40 816,40 40 800,30 50 813,30 40 816))
>>>>>>  24 | POLYGON Z ((30 40 816,30 30 817,40 40 800,30 40 816))
>>>>>>  25 | POLYGON Z ((30 50 813,40 40 800,40 50 817,30 50 813))
>>>>>>  26 | POLYGON Z ((30 40 816,30 50 813,20 50 809,30 40 816))
>>>>>>  27 | POLYGON Z ((50 40 821,40 50 817,40 40 800,50 40 821))
>>>>>>  28 | POLYGON Z ((50 50 809,40 50 817,50 40 821,50 50 809))
>>>>>>  29 | POLYGON Z ((50 40 821,40 40 800,50 30 816,50 40 821))
>>>>>>  30 | POLYGON Z ((40 30 814,50 30 816,40 40 800,40 30 814))
>>>>>>  31 | POLYGON Z ((30 30 817,30 40 816,20 40 807,30 30 817))
>>>>>> (32 rows)
>>>>>>  select st_astext(geomtext) from vfaces;
>>>>>> st_astext
>>>>>>  POLYGON Z ((51 17.8 799,9 38.8 799,9 51 819.33333333333,19.4 51
>>>>>> 828,51 35.2 828,51 17.8 799))
>>>>>>  POLYGON Z ((51 17.8 799,9 38.8 799,9 51 799,51 51 799,51 17.8 799))
>>>>>>  POLYGON Z ((51 35.2 828,19.4 51 828,51 51 828,51 35.2 828))
>>>>>>  POLYGON Z ((9 9 799,9 38.8 799,51 17.8 799,51 9 799,9 9 799))
>>>>>>  POLYGON Z ((9 9 828,9 51 828,19.4 51 828,51 35.2 828,51 9 828,9 9
>>>>>> 828))
>>>>>> (6 rows)
>>>>>> *select distinct a.id
>>>>>> from small_tris a, vfaces b
>>>>>> where st_intersects (a.geomtext, b.geomtext)
>>>>>> order by a.id;*
>>>>>>  id
>>>>>>   0
>>>>>>   1
>>>>>>   2
>>>>>>   3
>>>>>>   4
>>>>>>   5
>>>>>>   6
>>>>>>   7
>>>>>>   8
>>>>>>   9
>>>>>>  10
>>>>>>  11
>>>>>>  12
>>>>>>  13
>>>>>>  14
>>>>>>  15
>>>>>>  16
>>>>>>  17
>>>>>>  18
>>>>>>  19
>>>>>>  20
>>>>>>  21
>>>>>>  22
>>>>>>  23
>>>>>>  24
>>>>>>  25
>>>>>>  26
>>>>>>  27
>>>>>>  28
>>>>>>  29
>>>>>>  30
>>>>>>  31
>>>>>> (32 rows)
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121030/432b53c5/attachment.html>
