[postgis-users] Retrieving linestring data between endpoints
Max Pyziur pyz at brama.com
Thu Sep 6 13:11:53 PDT 2012
On Thu, 6 Sep 2012, Nicolas Ribot wrote:
> Hi,
> Maybe this thread about closing contour polylines can give some hints:
> http://postgis.refractions.net/pipermail/postgis-users/2012-May/034149.html
Much thanks. This script is worth exploring.
> Do you have sample data we could play with ?
The data that I sourced is here:
National Transportation atlas Database
http://www.bts.gov/publications/national_transportation_atlas_database/
Oak Ridge National Laboratory - CTA Network
http://cta.ornl.gov/transnet/RailRoads.html
I don't have readily available city point data; but that shouldn't be a
challenge in finding.
My thinking now is to try and create a polygon with two endpoint, say
Edmonton and Vancouver, and play with the diameter (20, 40 miles, etc.),
trying to see which rail lines fall within the polygon. Possibly from
that, I can construct a single linestring based some form of ownership
(the BTS data is only for the US; the ORNL data is for North America).
> Nicolas
Much thanks again,
Max
> On 5 September 2012 19:15, Max Pyziur <pyz at brama.com> wrote:
>> Greetings,
>> I'm trying to figure out a way of constructing linestrings between
>> endpoints.
>> Shapefile data for pipelines and railroads does not present continuous
>> lines; instead they are in the form of small line segments. The applications
>> are using data for roads, pipelines, or railroads.
>> Interstate 70 is not one complete linestring between Washington DC and the
>> middle of Utah; instead it is a series of segments. The same with pipeline
>> and railroad data.
>> The problem becomes more cumbersome (at least to me) when there is no
>> knowledge of the data between two points (say Edmonton and Vancouver) and
>> you want to see if there is a way to string a set of segments between two
>> points (to answer a question like is there a railline between Edmonton and
>> Vancouver)?
>> I would appreciate any advice on how to proceed.
>> Much thanks,
>> Max Pyziur
>> pyz at brama.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
